enilria
OAG Changes 8/18/2019:AS Adds GEG-PAE;DL Adds LGW/MAN;HA Adds LAS-OGG;SY Cuts STL-MSP;UA Cuts EWR-PSP;WN
Sun Aug 18, 2019 12:11 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
4B ABQ-CVN SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0]
4O DFW-MEX JAN 1.5>2[1.8] FEB 1.4>2[1.4]
4O IAH-MEX NOV 1.6>2[1.6] JAN 1.6>2[1.7] FEB 1.6>2[1.4] MAR 1.5>2[1.5]
4O LAS-MTY NOV 0.6>1.0[0.7] DEC 0.6>1.0[0.6] JAN 0.6>1.0[0.6] FEB 0.6>1.0[0.6] MAR 0.6>1.0[0.6] APR 0.6>1.0[0.6] MAY 0.6>1.0[0.6]
4O MEX-ORD JAN 1.5>2[1.7] FEB 1.5>2[1.4]
7H ANC-CDB SEP 0.6>0.4[0] OCT 0.9>0.4[0] NOV 0.8>0.4[0] DEC 0.8>0.4[0] JAN 0.8>0.4[0] FEB 0.9>0.4[0] MAR 0.8>0.4[0] APR 0.9>0.4[0] MAY 0.8>0.4[0.1]
7H ANC-SDP SEP 0.6>0.4[0] OCT 0.9>0.4[0] NOV 0.8>0.4[0] DEC 0.8>0.4[0] JAN 0.8>0.4[0] FEB 0.9>0.4[0] MAR 0.8>0.4[0] APR 0.9>0.4[0] MAY 0.8>0.4[0.2]
7H CDB-SDP SEP 0.2>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0]
7Q PWM-VRB DEC 0>0.2[0]
9K ACK-EWB NOV 1.6>2[0.9] DEC 1.5>2[0.9]
9K ACK-HYA OCT 7>9[4] NOV 4>7[4] DEC 4>7[4]
9K BOS-HYA NOV 1.5>1.0[1.5] DEC 1.5>1.1[1.5]
AA DFW-EYW DEC 1.0>1.5[0.3]
AA DFW-FLL JAN 6>7[6] FEB 6>7[6] MAR 6>7[6] APR 6>7[5]
AA DFW-GSP DEC 2>3[2]
AA DFW-MRY DEC 0.1>1.0[0] JAN 0>0.2[0]
AA IND-LAX DEC 1.1>1.5[1.7] JAN 1.0>1.2[0.9]
AA JFK-SFO DEC 5>3[4]
Kinda weird, but I guess they are trying some unusual holiday routes?
*AA LAX-MEM DEC 0>0.4[0] JAN 0>0.2[0]
AA LAX-MFR DEC 1.0>1.4[1.4] JAN 1.0>1.2[1.2]
AA LAX-OKC DEC 2>3[3]
AA LAX-RDM DEC 1.0>1.5[1.4]
AA LAX-RDU DEC 1.1>1.5[1.3] JAN 1.0>1.2[0.8]
AA MYR-PHL DEC 1.9>2[1.0] JAN 0.8>1.0[1.0]
AA ONT-ORD DEC 0.1>0.5[0] JAN 0>0.2[0]
AA ORD-PBI DEC 2>3[2]
AA ORD-SAT DEC 2>3[2]
AA ORD-SPI DEC 0.2>0.6[0] JAN 0>0.2[0]
AA PHL-SLC DEC 0>0.5[0.4] JAN 0>0.2[1.0]
AC SEA-YUL MAY 0>0.9[0]
AC SJC-YYZ MAY 0>0.9[0]
What is this?
*AG AUA-MIA SEP 0.3>0[1.0] OCT 0.3>0[1.0] NOV 0.3>0[1.0] DEC 0.3>0[0.9] JAN 0.3>0[1.0] FEB 0.3>0[0.9] MAR 0.3>0[0.9] APR 0.3>0[0.7] MAY 0.3>0[0.5]
Moved to DL
*AM ATL-GDL NOV 0.3>0[1.0] DEC 0.3>0[1.0]
AN HHR-PHX NOV 0.0>0.4[0] DEC 0>0.4[0]
*AS GEG-PAE NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0]
B6 BOS-PUJ OCT 0.4>0.1[0.4]
B6 FLL-PUJ OCT 1.0>0.4[1.0]
CZ CAN-JFK NOV 1.0>0.7[1.3]
DL ATL-BRU DEC 0.5>0.3[0.6]
DL ATL-LOS DEC 0.5>0.7[0.6]
DL ATL-PUJ NOV 1.4>1.1[2] DEC 2>1.8[3]
DL BOM-JFK APR 0.7>1.0[0]
DL BOS-DUB DEC 0>0.3[0]
*DL BOS-LGW MAY 0>0.4[0]
*DL BOS-MAN MAY 0>0.4[0]
DL CDG-MSP DEC 0.8>0.6[1.0]
DL DTW-FRA DEC 0.9>0.6[1.0]
DL DTW-SJC NOV 1.1>0.7[0.4]
DL JFK-LHR APR 2>3[2] MAY 2>3[2]
DL has a lot of planes filling in for AM
*DL JFK-MEX OCT 1.0>2[1.0] NOV 0.9>1.9[0.9]
DL JFK-TLV DEC 1.0>1.4[1.0]
*DL LAX-MEX OCT 1.0>4[1.0] NOV 0.9>4[0.9] DEC 0.9>1.1[0.9]
DL MSP-MSY OCT 1.0>1.3[1.0] NOV 1.0>1.3[1.0] DEC 1.0>1.3[1.0]
DL MSP-SAT JAN 3>1.9[1.8] FEB 3>1.8[1.8]
F9 BNA-MCO OCT 0.6>0.8[0.9]
Surprising route to be non-daily
*F9 LAS-LAX NOV 1.0>0.6[0]
F9 LAS-MIA NOV 1.0>0.6[0]
F9 MCO-ORF OCT 0.3>0.5[0.3]
G4 AVL-PBI DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 AZA-BLV OCT 0.3>0[0.3] NOV 0.3>0[0.3]
G4 AZA-FNL DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 AZA-TVC NOV 0>0.2[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 AZA-XNA NOV 0>0.2[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 BLV-SRQ DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 CHS-PGD NOV 0>0.2[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 CVG-PBI DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 CVG-SRQ DEC 0.4>0.6[0.3] JAN 0.3>0.6[0.3] FEB 0.4>0.7[0.3] MAR 0.6>0.9[0.3] APR 0.4>0.7[0.4]
G4 DSM-SRQ DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 ELM-PGD NOV 0>0.2[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 FLL-SYR NOV 0.3>0.5[0.3]
G4 FNL-LAS NOV 0>0.2[0] DEC 0>0.6[0] JAN 0>0.4[0] FEB 0>0.3[0] MAR 0>0.6[0] APR 0>0.6[0] MAY 0>0.2[0]
G4 FNT-SRQ DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 FSD-PGD DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 FWA-SRQ DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 IND-PBI DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 IND-TUS NOV 0>0.2[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 MEM-PGD DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 ORF-PGD NOV 0>0.2[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 PBI-PIT NOV 0>0.2[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 PBI-TYS DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 PBI-USA DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G4 RFD-SRQ DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 SBN-SRQ DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 SDF-SRQ DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
G4 SRQ-TYS DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
G7 CVG-STL SEP 0.9>0[0.8] OCT 0.9>0[0.9] NOV 0.8>0[0.9] DEC 0.9>0[0.8] JAN 0.9>0[0.9] FEB 0.8>0[0.9] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.9]
GV BET-KWK OCT 0.9>1.4[1.0] NOV 0.5>1.4[1.0] DEC 0.5>1.4[1.0] JAN 0.5>1.4[1.0] FEB 0.5>1.4[1.0] MAR 0.5>1.4[1.0] APR 0.5>1.4[0.1] MAY 0.5>1.4[1.4]
GV BET-SCM OCT 1.4>1.9[2] NOV 1.4>1.9[2] DEC 1.4>1.9[2] JAN 1.4>1.9[2] FEB 1.4>1.9[2] MAR 1.4>1.9[2] APR 1.4>1.9[1.8] MAY 1.4>1.9[1.9]
GV BET-VAK OCT 1.4>1.9[2] NOV 1.4>1.9[2] DEC 1.4>1.9[2] JAN 1.4>1.9[2] FEB 1.4>1.9[2] MAR 1.4>1.9[2] APR 1.4>1.9[1.8] MAY 1.4>1.9[1.9]
GV BET-WTL OCT 0.9>1.4[1.0] NOV 0.5>1.4[1.0] DEC 0.5>1.4[1.0] JAN 0.5>1.4[1.0] FEB 0.5>1.4[1.0] MAR 0.5>1.4[1.0] APR 0.5>1.4[0.1] MAY 0.5>1.4[1.4]
GV HPB-SCM OCT 1.4>1.9[2] NOV 1.4>1.9[2] DEC 1.4>1.9[2] JAN 1.4>1.9[2] FEB 1.4>1.9[2] MAR 1.4>1.9[2] APR 1.4>1.9[1.8] MAY 1.4>1.9[1.9]
GV HPB-VAK OCT 1.4>1.9[2] NOV 1.4>1.9[2] DEC 1.4>1.9[2] JAN 1.4>1.9[2] FEB 1.4>1.9[2] MAR 1.4>1.9[2] APR 1.4>1.9[1.8] MAY 1.4>1.9[1.9]
GV KKH-KWK OCT 0.9>1.4[1.0] NOV 0.5>1.4[1.0] DEC 0.5>1.4[1.0] JAN 0.5>1.4[1.0] FEB 0.5>1.4[1.0] MAR 0.5>1.4[1.0] APR 0.5>1.4[0.1] MAY 0.5>1.4[1.4]
GV KKH-WTL OCT 0.9>1.4[1.0] NOV 0.5>1.4[1.0] DEC 0.5>1.4[1.0] JAN 0.5>1.4[1.0] FEB 0.5>1.4[1.0] MAR 0.5>1.4[1.0] APR 0.5>1.4[0.1] MAY 0.5>1.4[1.4]
HA HNL-SEA JAN 1.2>1.5[1.2] FEB 1.0>1.4[1.0] MAR 1.0>1.4[1.0] APR 1.0>1.4[1.0] MAY 1.0>1.4[1.0]
*HA LAS-OGG DEC 0>0.3[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.6[0] APR 0>0.6[0] MAY 0>0.6[0]
HA LAX-OGG DEC 1.0>1.2[1.0]
K3 HYL-KLW SEP 0.8>0.1[0.4] OCT 0.9>0[0] NOV 0.9>0[0] DEC 0.8>0[0] JAN 0.9>0[0] FEB 0.9>0[0] MAR 0.8>0[0] APR 0.9>0[0] MAY 0.8>0[0.7]
K3 HYL-KTN SEP 0.4>0.1[0.4] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0] JAN 0.4>0[0] FEB 0.4>0[0] MAR 0.4>0[0] APR 0.4>0[0] MAY 0.4>0[0.4]
K3 KLW-KTN SEP 0.4>0.8[0.4] OCT 0.4>0.8[0.8] NOV 0.4>0.8[0.8] DEC 0.4>0.7[0.8] JAN 0.4>0.7[0.8] FEB 0.4>0.8[0.8] MAR 0.4>0.8[0.8] APR 0.4>0.8[0.4] MAY 0.4>0.7[0.5]
LF BWI-MCN NOV 0.9>1.7[1.7] DEC 0>1.7[1.6] FEB 0>1.0[1.7]
LF STL-TBN DEC 0.8>1.6[0] JAN 0>1.8[0] FEB 0>1.0[1.1]
I'm assuming this is Winter only?
**SY MSP-STL JAN 0.5>0.1[0] FEB 0.6>0[0] MAR 0.6>0[0] APR 0.3>0[0]
UA ABQ-ORD JAN 2>1.2[2] FEB 2>1.6[1.5]
UA ACV-SFO JAN 4>3[3]
UA AEX-IAH JAN 3>1.8[1.9]
UA ALB-ORD JAN 4>3[3]
UA AMA-IAH JAN 3>1.9[2]
UA ATL-IAD JAN 4>3[3]
UA ATL-IAH JAN 7>6[6]
UA ATL-ORD JAN 7>5[6] FEB 7>6[7]
UA AUS-DEN JAN 3>4[3]
UA AVL-ORD JAN 3>2[2]
UA BDL-ORD JAN 4>3[3]
UA BNA-DEN JAN 3>4[3]
UA BOI-DEN JAN 4>5[4]
UA BOS-EWR JAN 11>9[8] FEB 11>10[9]
UA BRO-IAH JAN 5>4[3]
UA BTV-EWR JAN 4>3[5]
UA BTV-ORD JAN 3>2[2]
UA BUF-EWR JAN 5>4[5]
UA BUF-IAD JAN 3>1.7[3] FEB 3>2[3]
UA BWI-DEN JAN 2>1.1[1.1] FEB 2>1.6[1.5]
UA BWI-ORD JAN 4>3[3]
UA CAK-ORD JAN 5>4[4]
UA CHO-IAD JAN 3>1.8[1.9]
UA CHS-EWR JAN 5>4[4]
UA CID-ORD JAN 5>6[5]
UA CLE-IAH JAN 5>4[4]
UA CLL-IAH JAN 3>1.9[2]
UA CLT-IAH JAN 5>4[4]
UA CMH-IAH JAN 4>3[4]
UA CMH-ORD JAN 8>7[6]
UA COS-IAH JAN 3>2[3]
UA COS-LAX JAN 3>2[1.9]
UA COU-ORD JAN 3>2[1.9]
UA CRW-ORD JAN 4>1.9[0.9] FEB 4>3[0.9]
UA CVG-EWR JAN 6>5[4]
UA CVG-IAH JAN 4>3[4]
*UA DAY-EWR JAN 1.0>0.2[1.1] FEB 1.0>0[1.0] MAR 1.0>0.1[1.0]
UA DAY-ORD JAN 7>6[6]
UA DCA-ORD JAN 13>10[13] FEB 14>12[14]
UA DEN-DTW JAN 1.9>1.1[1.9] FEB 1.8>1.4[1.9]
UA DEN-GTF JAN 2>1.3[2] FEB 2>1.6[2]
UA DEN-IND NOV 3>2[3]
UA DEN-ISN JAN 4>3[4]
UA DEN-MEM JAN 3>2[2]
UA DEN-MFR JAN 3>2[2]
UA DEN-MKE JAN 2>3[2]
UA DEN-MSY JAN 2>3[1.9]
UA DEN-PIT NOV 3>2.0[2.0] JAN 3>2[2]
UA DEN-RSW JAN 2>1.3[1.2] FEB 2>1.6[1.1]
UA DEN-SAN JAN 4>5[4]
UA DEN-SBA JAN 4>3[3]
UA DEN-SJC JAN 5>4[4]
UA DEN-TPA JAN 2>3[2]
UA DEN-TUL JAN 4>3[4]
UA DEN-YWG JAN 1.8>1.0[1.0] FEB 2>1.6[1.0]
UA DFW-EWR JAN 5>6[5]
UA DLH-ORD JAN 3>2[2]
UA DTW-IAD JAN 3>2[3]
UA EWR-EYW JAN 2>3[2]
UA EWR-GRR JAN 3>2[1.7]
UA EWR-GSP JAN 4>3[3]
**UA EWR-HND APR 0>1.0[0] MAY 0>1.0[0]
UA EWR-IAD JAN 6>7[6]
UA EWR-LAX JAN 10>9[9] FEB 11>10[9]
UA EWR-MCO JAN 9>10[8]
UA EWR-MIA JAN 5>6[5]
*UA EWR-OKC JAN 1.0>0.2[0.2] FEB 1.0>0[0] MAR 1.0>0.1[0.0]
UA EWR-OMA JAN 3>2.0[2]
UA EWR-ORF JAN 6>5[5]
UA EWR-PBI JAN 6>7[6]
UA EWR-PHX JAN 4>3[2]
UA EWR-PIT JAN 10>9[7]
**UA EWR-PSP JAN 1.0>0.2[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[0.7] MAY 1.0>0[0]
UA EWR-ROC JAN 5>4[4]
UA EWR-SLC JAN 1.2>2[1.1] FEB 1.0>1.4[1.5]
UA EWR-SRQ JAN 2>3[2]
UA EWR-TPA JAN 5>6[5]
UA EYW-ORD NOV 2>1.1[0.4] JAN 2>1.2[0.4] FEB 2>1.6[0.7]
UA FAR-ORD JAN 4>3[3]
UA FNT-ORD JAN 4>3[3]
UA FSD-ORD JAN 5>4[4]
UA GRR-IAH JAN 1.7>1.3[1.0]
UA GRR-ORD JAN 8>7[6]
UA GSO-ORD JAN 4>3[3]
UA GSP-ORD JAN 4>3[4]
*UA HND-IAD APR 0>1.0[0] MAY 0>1.0[0]
*UA HND-LAX APR 0>1.0[0] MAY 0>1.0[0]
*UA HND-ORD APR 0>1.0[0] MAY 0>1.0[0]
UA HSV-IAD JAN 1.8>1.0[1.6] FEB 2>1.6[1.8]
UA HSV-IAH JAN 4>3[3]
UA IAD-ITH JAN 3>1.9[1.8]
UA IAD-LAX JAN 5>6[5]
UA IAD-MHT JAN 3>2[0]
UA IAD-MIA JAN 1.2>2[1.2] FEB 1.0>1.4[1.0]
UA IAD-MSP JAN 2>1.2[1.2] FEB 2>1.6[1.0]
*UA IAD-NRT APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA IAD-PDX JAN 1.0>0.2[0.2] FEB 1.0>0.6[0]
UA IAD-PUJ JAN 1.8>1.0[1.0] FEB 2>1.0[1.5]
UA IAD-PWM JAN 3>2[2]
UA IAD-ROC JAN 4>3[3]
UA IAD-SAV JAN 3>2[3]
UA IAD-SDF JAN 2>0.7[2.0] FEB 2>1.4[2.0]
UA IAD-SYR JAN 3>2[3]
UA IAD-TYS JAN 3>2[3]
UA IAD-YOW JAN 3>2[3]
UA IAD-YUL JAN 3>2[2]
UA IAD-YYZ JAN 4>3[3]
UA IAH-JAX JAN 4>3[3]
UA IAH-LAS JAN 6>7[6]
UA IAH-LIT JAN 6>5[5]
UA IAH-MKE NOV 3>2[1.9]
UA IAH-OMA NOV 4>3[4]
UA IAH-ORD JAN 10>8[8]
UA IAH-PHX JAN 4>5[4]
UA IAH-PNS JAN 5>4[4]
UA IAH-SAN JAN 4>5[4]
UA IAH-SEA JAN 4>3[4]
UA IAH-SFO JAN 9>8[9]
UA IAH-STL JAN 5>6[5]
UA IAH-TPA JAN 5>4[5]
UA IAH-TYS JAN 4>3[3]
UA JAX-ORD JAN 3>2[3]
*UA LAX-LIH JAN 1.2>0.4[1.2] FEB 1.1>0.8[1.0]
UA LAX-ORD JAN 9>7[9]
UA LAX-PHX JAN 4>3[3]
UA LAX-SBP JAN 4>3[3]
UA LAX-SMF JAN 3>2[3]
UA LEX-ORD JAN 4>3[4]
UA LGA-ORD JAN 15>13[14] FEB 15>14[15]
UA MCO-ORD JAN 5>7[6] FEB 7>8[7]
UA MDT-ORD JAN 4>3[3]
UA MLI-ORD JAN 4>5[4]
*UA NRT-ORD APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA OMA-SFO OCT 1.6>1.1[1.0]
UA ORD-PIT JAN 6>4[6] FEB 6>5[6]
UA ORD-PVD JAN 3>1.0[1.2] FEB 3>2[1.5]
UA ORD-PWM JAN 3>2[2]
UA ORD-RAP DEC 1.4>1.0[1.0] JAN 1.2>0.2[0.2] FEB 1.0>0.6[0]
UA ORD-RDU JAN 6>5[4]
UA ORD-ROA JAN 3>0.9[2] FEB 3>1.7[2]
UA ORD-SAT JAN 4>3[3]
UA ORD-SBN JAN 5>6[5]
UA ORD-SCE JAN 4>3[3]
UA ORD-SEA JAN 3>4[3]
UA ORD-SFO JAN 11>8[9] FEB 11>10[8]
UA ORD-SGF JAN 4>3[3]
UA ORD-SLC JAN 3>4[3]
UA ORD-SPI JAN 3>2[2]
UA ORD-TUS OCT 1.7>1.0[1.1]
UA ORD-TVC JAN 3>2[3]
UA ORD-TYS JAN 5>3[4]
UA ORD-YUL JAN 3>1.9[3]
UA ORD-YVR JAN 2>1.2[1.2] FEB 2>1.6[1.0]
UA ORD-YWG JAN 2>1.1[1.9] FEB 2>1.6[2]
UA PAE-SFO JAN 4>3[0]
UA PHX-SFO JAN 4>5[4]
UA RNO-SFO JAN 4>5[5]
UA SFO-STL OCT 1.6>1.0[1.8]
VS JFK-LGW MAY 0>0.3[0]
VS JFK-LHR APR 6>5[6] MAY 6>5[6]
VS LHR-SEA APR 1.0>1.6[1.0] MAY 1.0>1.6[1.0]
MAR is a partial month so ignore. Use final JAN and FEB vs the prior year.
I had missed that WN loaded an extension. Any big changes besides EWR?
WN ABQ-AUS JAN 0.2>1.3[0.5] FEB 0>1.3[0.5] MAR 0>0.3[0.5]
WN ABQ-BWI JAN 0.2>1.0[0.9] FEB 0>1.0[0.9] MAR 0>0.2[1.1]
WN ABQ-DAL JAN 0.7>5[5] MAR 0>0.9[5]
WN ABQ-DEN JAN 0.5>3[3] MAR 0>0.5[3]
WN ABQ-HOU JAN 0.5>3[3] MAR 0>0.5[3]
WN ABQ-LAS JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.8[4]
WN ABQ-LAX JAN 0.3>1.8[2] FEB 0>1.7[1.9] MAR 0>0.4[2]
WN ABQ-MCI JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[0.8]
WN ABQ-MDW JAN 0.3>1.1[1.1] FEB 0>1.0[0.9] MAR 0>0.2[1.2]
WN ABQ-OAK JAN 0.4>1.7[1.8] FEB 0>1.5[1.6] MAR 0>0.4[1.8]
WN ABQ-PHX JAN 0.9>6[5] FEB 0>6[5] MAR 0>1.1[5]
WN ABQ-SAN JAN 0.3>1.8[1.8] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN ABQ-SJC JAN 0.1>0.8[0.2] FEB 0>0.7[0.1]
WN ALB-BWI JAN 0.7>4[5] FEB 0>4[5] MAR 0>0.8[5]
WN ALB-FLL JAN 0.0>1.0[0.9] FEB 0>1.1[1.2] MAR 0>0.2[1.0]
WN ALB-MCO JAN 0.3>2[2] MAR 0>0.4[2]
WN ALB-MDW JAN 0.4>1.9[1.8] MAR 0>0.4[1.9]
WN ALB-TPA JAN 0.2>1.2[1.1] FEB 0>1.3[1.1] MAR 0>0.2[1.3]
WN AMA-DAL JAN 0.6>4[4] MAR 0>0.7[4]
WN AMA-LAS JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN ATL-AUS JAN 0.5>3[3] MAR 0>0.5[3]
WN ATL-BNA JAN 0.7>4[4] MAR 0>0.9[4]
WN ATL-BWI JAN 0.9>5[5] MAR 0>1.0[6]
WN ATL-CLE JAN 0.3>1.9[1.8] MAR 0>0.4[1.8]
WN ATL-CMH JAN 0.4>3[3] MAR 0>0.5[3]
WN ATL-DAL JAN 0.8>6[5] FEB 0>6[5] MAR 0>1.2[5]
WN ATL-DCA JAN 0.6>4[4] MAR 0>0.7[4]
WN ATL-DEN JAN 0.6>4[4] MAR 0>0.8[4]
WN ATL-FLL JAN 0.8>5[5] MAR 0>1.0[5]
WN ATL-GSP JAN 0.5>3[3] MAR 0>0.5[3]
WN ATL-HOU JAN 0.9>6[6] MAR 0>1.2[6]
WN ATL-IAD JAN 0.4>3[1.7] FEB 0>3[1.7] MAR 0>0.5[1.8]
WN ATL-IND JAN 0.5>3[3] MAR 0>0.6[3]
WN ATL-JAX JAN 0.4>3[3] MAR 0>0.5[3]
WN ATL-LAS JAN 0.5>2[3] FEB 0>1.8[3] MAR 0>0.4[4]
WN ATL-LAX JAN 0.4>2[3] FEB 0>2[3] MAR 0>0.4[3]
WN ATL-LGA JAN 0.8>5[5] MAR 0>0.9[5]
WN ATL-MCI JAN 0.5>3[3] MAR 0>0.5[3]
WN ATL-MCO JAN 0.9>6[6] MAR 0>1.2[6]
WN ATL-MDW JAN 0.9>6[5] FEB 0>6[5] MAR 0>1.2[6]
WN ATL-MKE JAN 0.3>1.9[1.9] MAR 0>0.4[1.8]
WN ATL-MSY JAN 0.6>4[4] MAR 0>0.8[4]
WN ATL-OAK JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN ATL-PBI JAN 0.2>1.6[1.6] MAR 0>0.4[1.9]
WN ATL-PHL JAN 0.3>1.9[1.9] MAR 0>0.4[2.0]
WN ATL-PHX JAN 0.5>3[2] FEB 0>3[2.0] MAR 0>0.6[2]
I'm kinda surprised this is working given some of the other routes that have fallen out in ATL.
*WN ATL-PIT JAN 0.4>3[1.9] FEB 0>3[1.9] MAR 0>0.5[2.0]
WN ATL-RDU JAN 0.4>3[3] MAR 0>0.5[3]
WN ATL-RIC JAN 0.5>3[3] MAR 0>0.5[3]
WN ATL-RSW JAN 0.3>2.0[1.9] FEB 0>2[1.9] MAR 0>0.4[3]
WN ATL-SAN JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN ATL-SAT JAN 0.3>1.8[1.8] MAR 0>0.4[1.8]
WN ATL-STL JAN 0.6>4[4] MAR 0>0.8[4]
WN ATL-TPA JAN 0.8>5[6] FEB 0>5[6] MAR 0>1.0[6]
WN AUA-BWI JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.3]
WN AUA-FLL JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN AUS-BNA JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.6[2]
WN AUS-BWI JAN 0.5>3[1.9] FEB 0>3[1.8] MAR 0>0.5[2.0]
WN AUS-DAL JAN 1.5>10[9] FEB 0>10[9] MAR 0>2[9]
WN AUS-DCA JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN AUS-DEN JAN 0.8>6[5] FEB 0>6[5] MAR 0>1.2[5]
WN AUS-ELP JAN 0.4>2[2] FEB 0>2.0[1.9] MAR 0>0.4[2.0]
WN AUS-FLL JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.7]
WN AUS-HOU JAN 0.8>5[5] FEB 0>5[6] MAR 0>1.0[5]
WN AUS-HRL JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[0.8]
WN AUS-LAS JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.8[3]
WN AUS-LAX JAN 0.4>3[2] MAR 0>0.5[3]
WN AUS-LBB JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN AUS-MCI JAN 0.2>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN AUS-MCO JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.6[2]
WN AUS-MDW JAN 0.6>3[2] MAR 0>0.6[3]
WN AUS-MSY JAN 0.5>3[1.9] MAR 0>0.6[2]
WN AUS-OAK JAN 0.1>1.0[1.0] MAR 0>0.2[1.1]
WN AUS-PHX JAN 0.7>4[4] MAR 0>0.8[4]
WN AUS-SAN JAN 0.4>3[3] MAR 0>0.5[3]
WN AUS-SJC JAN 0.4>3[2] MAR 0>0.5[2.0]
WN AUS-SMF JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[0.8]
WN AUS-STL JAN 0.3>1.9[1.9] MAR 0>0.4[1.8]
WN AUS-TPA JAN 0.3>1.9[1.0] FEB 0>1.8[1.0] MAR 0>0.4[1.7]
WN BDL-BWI JAN 0.8>5[5] MAR 0>1.0[6]
WN BDL-FLL JAN 0.2>1.2[1.1] FEB 0>1.3[1.1] MAR 0>0.2[1.2]
WN BDL-MCO JAN 0.5>3[3] MAR 0>0.6[3]
WN BDL-MDW JAN 0.4>1.9[2] FEB 0>1.7[1.8] MAR 0>0.4[1.7]
WN BDL-RSW JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.0]
WN BDL-STL JAN 0.1>1.0[1.0] MAR 0>0.2[1.0]
WN BDL-TPA JAN 0.2>2.0[2] MAR 0>0.4[2]
WN BHM-BWI JAN 0.2>1.0[1.1] MAR 0>0.2[1.0]
WN BHM-DAL JAN 0.3>2[2] MAR 0>0.4[2]
WN BHM-HOU JAN 0.3>1.8[1.7] FEB 0>1.7[1.6] MAR 0>0.4[1.8]
WN BHM-LAS JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN BHM-MCO JAN 0.4>2[2] MAR 0>0.4[2]
WN BHM-MDW JAN 0.3>1.6[1.7] FEB 0>1.5[1.6] MAR 0>0.4[1.9]
WN BHM-TPA JAN 0.3>1.3[1.9] FEB 0>1.3[1.8] MAR 0>0.3[1.8]
WN BNA-BOS JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.7[2]
WN BNA-BWI JAN 0.9>6[6] MAR 0>1.2[6]
WN BNA-CHS JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.1]
WN BNA-CLE JAN 0.4>2[2] MAR 0>0.4[2]
WN BNA-CLT JAN 0.3>1.9[1.9] MAR 0>0.4[1.8]
WN BNA-CMH JAN 0.3>1.9[1.8] FEB 0>1.8[1.7] MAR 0>0.4[1.9]
WN BNA-DAL JAN 0.8>6[5] FEB 0>6[5] MAR 0>1.2[5]
WN BNA-DCA JAN 0.6>4[4] MAR 0>0.8[4]
WN BNA-DEN JAN 0.7>5[4] FEB 0>5[4] MAR 0>1.0[5]
WN BNA-DTW JAN 0.4>3[1.8] FEB 0>3[1.9] MAR 0>0.5[1.8]
WN BNA-ECP JAN 0.3>2[2] FEB 0>2[2.0] MAR 0>0.4[2]
WN BNA-FLL JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.8[5]
WN BNA-HOU JAN 0.6>4[4] MAR 0>0.8[4]
WN BNA-JAX JAN 0.5>2[2] FEB 0>2.0[1.8] MAR 0>0.4[3]
WN BNA-LAS JAN 0.6>3[3] MAR 0>0.6[3]
WN BNA-LAX JAN 0.5>3[3] MAR 0>0.6[3]
WN BNA-LGA JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.8[3]
WN BNA-MCI JAN 0.5>3[3] MAR 0>0.6[3]
WN BNA-MCO JAN 0.8>5[5] FEB 0>6[5] MAR 0>1.0[6]
WN BNA-MDW JAN 1.0>6[6] FEB 0>5[6] MAR 0>1.2[6]
WN BNA-MKE JAN 0.3>1.9[1.8] MAR 0>0.4[2.0]
WN BNA-MSP JAN 0.3>1.7[1.0] FEB 0>1.7[1.0] MAR 0>0.4[1.0]
WN BNA-MSY JAN 0.6>4[4] MAR 0>0.8[4]
WN BNA-OAK JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN BNA-PHL JAN 0.5>3[3] MAR 0>0.5[3]
WN BNA-PHX JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.8[3]
WN BNA-PIT JAN 0.3>1.9[1.9] MAR 0>0.4[1.8]
WN BNA-PNS JAN 0.3>2[2] MAR 0>0.4[2]
WN BNA-RDU JAN 0.5>3[3] MAR 0>0.6[3]
WN BNA-RSW JAN 0>0.2[0.1] FEB 0>0.3[0.1]
WN BNA-SAN JAN 0.3>1.9[1.2] FEB 0>1.8[1.0] MAR 0>0.4[1.8]
WN BNA-SAT JAN 0.3>1.9[1.8] FEB 0>1.8[1.7] MAR 0>0.4[1.9]
WN BNA-SJC JAN 0.2>1.0[0] FEB 0>1.0[0] MAR 0>0.2[0]
WN BNA-STL JAN 0.5>3[2] FEB 0>3[2.0] MAR 0>0.6[3]
WN BNA-TPA JAN 0.5>4[4] MAR 0>0.8[5]
WN BOI-DEN JAN 0.3>1.8[2] FEB 0>1.7[2.0] MAR 0>0.4[2]
WN BOI-GEG JAN 0.3>1.7[1.7] MAR 0>0.4[1.8]
WN BOI-LAS JAN 0.3>2[2] MAR 0>0.4[2]
WN BOI-OAK JAN 0.3>2[2] FEB 0>2[2.0] MAR 0>0.4[2]
WN BOI-PHX JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.0]
WN BOI-SAN JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN BOI-SJC JAN 0.3>1.7[1.0] FEB 0>1.7[1.0] MAR 0>0.4[1.0]
WN BOI-SMF JAN 0.2>1.0[1.1] MAR 0>0.2[1.0]
WN BOS-BWI JAN 1.3>8[7] FEB 0>8[7] MAR 0>1.7[8]
WN BOS-CMH JAN 0.1>0.8[1.0] FEB 0>0.7[0.9]
WN BOS-DEN JAN 0.3>1.9[1.3] FEB 0>1.9[1.1] MAR 0>0.4[1.7]
WN BOS-MDW JAN 0.7>4[2] FEB 0>4[2] MAR 0>0.8[3]
WN BOS-STL JAN 0.5>3[3] MAR 0>0.5[3]
WN BUF-BWI JAN 0.7>5[4] MAR 0>0.9[4]
WN BUF-FLL JAN 0.2>2[2] MAR 0>0.4[2.0]
WN BUF-LAS JAN 0.2>1.0[1.0] MAR 0>0.2[1.7]
WN BUF-MCO JAN 0.5>3[3] MAR 0>0.4[4]
WN BUF-MDW JAN 0.3>1.9[2] FEB 0>1.8[2.0] MAR 0>0.4[1.9]
WN BUF-PHX JAN 0.2>0.4[1.0] FEB 0>0.3[1.0]
WN BUF-RSW FEB 0>0.5[0.4]
WN BUF-TPA JAN 0.2>2.0[2] MAR 0>0.4[2]
WN BUR-DAL JAN 0.2>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN BUR-DEN JAN 0.4>3[1.9] FEB 0>3[1.8] MAR 0>0.5[1.8]
WN BUR-HOU JAN 0.2>1.0[0.9] FEB 0>1.0[0.9] MAR 0>0.2[0.8]
WN BUR-LAS JAN 1.5>10[9] FEB 0>10[9] MAR 0>1.9[9]
WN BUR-OAK JAN 2>13[11] FEB 0>13[11] MAR 0>3[11]
WN BUR-PDX JAN 0.2>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[0.8]
WN BUR-PHX JAN 1.0>6[6] MAR 0>1.3[6]
WN BUR-SFO JAN 0.8>5[4] FEB 0>5[4] MAR 0>1.1[4]
WN BUR-SJC JAN 1.7>11[10] FEB 0>11[10] MAR 0>2[10]
WN BUR-SLC JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN BUR-SMF JAN 1.6>11[9] FEB 0>10[9] MAR 0>2[8]
WN BWI-CHS JAN 0.6>3[3] MAR 0>0.6[3]
WN BWI-CLE JAN 0.5>3[3] MAR 0>0.6[3]
WN BWI-CLT JAN 0.5>3[3] MAR 0>0.6[3]
WN BWI-CMH JAN 0.6>3[3] MAR 0>0.5[4]
WN BWI-CUN JAN 0.4>2[2] MAR 0>0.4[2]
WN BWI-CVG JAN 0.4>3[3] MAR 0>0.5[3]
WN BWI-DAL JAN 0.6>5[4] FEB 0>5[4] MAR 0>1.0[4]
WN BWI-DEN JAN 0.7>5[5] MAR 0>0.9[5]
WN BWI-DTW JAN 0.5>3[3] MAR 0>0.6[2]
WN BWI-FLL JAN 1.5>9[9] MAR 0>1.8[9]
WN BWI-GRR JAN 0.1>1.0[1.0] MAR 0>0.2[1.0]
WN BWI-GSP JAN 0.2>1.0[0] FEB 0>1.0[0] MAR 0>0.2[0]
WN BWI-HOU JAN 0.6>3[3] MAR 0>0.6[3]
WN BWI-IND JAN 0.5>3[2] FEB 0>3[1.9] MAR 0>0.6[3]
WN BWI-ISP JAN 0.7>4[4] MAR 0>0.7[4]
WN BWI-JAX JAN 0.5>3[3] MAR 0>0.6[4]
WN BWI-LAS JAN 0.7>4[3] MAR 0>0.8[4]
WN BWI-LAX JAN 0.6>3[3] MAR 0>0.6[3]
WN BWI-LIR JAN 0.0>0.2[0.1] FEB 0>0.3[0.1]
WN BWI-MBJ JAN 0.3>2[2] MAR 0>0.4[2]
WN BWI-MCI JAN 0.3>1.9[1.9] MAR 0>0.4[2.0]
WN BWI-MCO JAN 1.6>10[9] FEB 0>10[9] MAR 0>2.0[10]
WN BWI-MDW JAN 1.1>6[6] MAR 0>1.2[6]
WN BWI-MEM JAN 0.2>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN BWI-MHT JAN 0.8>5[5] MAR 0>0.9[5]
WN BWI-MKE JAN 0.4>2[1.9] FEB 0>1.8[1.7] MAR 0>0.4[2]
WN BWI-MSP JAN 0.3>1.8[1.6] MAR 0>0.4[1.8]
WN BWI-MSY JAN 0.6>3[2] FEB 0>3[2] MAR 0>0.6[3]
WN BWI-NAS JAN 0.1>0.3[0.2] FEB 0>0.3[0.1]
WN BWI-OAK JAN 0.2>1.0[0.9] FEB 0>1.0[0.9] MAR 0>0.2[1.0]
WN BWI-OKC JAN 0.2>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN BWI-ORF JAN 0.6>4[4] MAR 0>0.9[4]
WN BWI-PBI JAN 0.5>4[4] FEB 0>5[4] MAR 0>0.9[5]
WN BWI-PHX JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.6[3]
WN BWI-PIT JAN 0.4>3[3] MAR 0>0.5[2]
WN BWI-PUJ JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.3]
WN BWI-PVD JAN 0.9>5[5] FEB 0>5[4] MAR 0>0.9[5]
WN BWI-PWM JAN 0.5>3[3] MAR 0>0.5[3]
WN BWI-RDU JAN 0.9>5[5] MAR 0>1.0[5]
WN BWI-ROC JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.5[3]
WN BWI-RSW JAN 0.7>6[5] FEB 0>6[5] MAR 0>1.2[5]
WN BWI-SAN JAN 0.5>2[2] MAR 0>0.4[3]
WN BWI-SAT JAN 0.3>1.8[1.8] MAR 0>0.4[3]
WN BWI-SDF JAN 0.5>3[3] FEB 0>3[2] MAR 0>0.6[3]
WN BWI-SJO JAN 0.0>0.2[0.1] FEB 0>0.3[0.1]
WN BWI-SJU JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.2]
WN BWI-SLC JAN 0.1>1.0[0.3] FEB 0>1.0[0.1] MAR 0>0.2[0.8]
WN BWI-STL JAN 0.6>3[3] MAR 0>0.6[4]
WN BWI-TPA JAN 1.1>8[6] FEB 0>8[6] MAR 0>1.5[8]
WN BZE-FLL JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN BZE-HOU JAN 0.2>1.0[1.1] MAR 0>0.2[1.0]
WN CHS-HOU JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN CHS-MDW JAN 0.3>1.1[1.3] FEB 0>1.0[1.6] MAR 0>0.2[1.8]
WN CLE-DEN JAN 0.3>1.1[1.0] MAR 0>0.2[1.0]
WN CLE-LAS JAN 0.1>0.3[1.0] FEB 0>0.3[1.0]
WN CLE-MCO JAN 0.1>0.4[0.1] FEB 0>0.5[0.1]
WN CLE-MDW JAN 0.7>4[4] MAR 0>0.8[4]
WN CLE-MKE JAN 0.2>1.6[1.6] FEB 0>1.5[1.6] MAR 0>0.4[1.5]
WN CLE-PHX JAN 0.2>0.4[1.0] FEB 0>0.3[1.0]
WN CLE-STL JAN 0.4>3[1.9] FEB 0>3[1.8] MAR 0>0.5[1.8]
WN CLE-TPA JAN 0.1>0.3[0] FEB 0>0.3[0]
WN CLT-DAL JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN CLT-HOU JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN CLT-MDW JAN 0.4>2.0[2] MAR 0>0.4[2.0]
WN CMH-DAL JAN 0.2>1.1[1.1] MAR 0>0.2[1.2]
WN CMH-DCA JAN 0.3>1.8[1.9] FEB 0>1.7[1.9] MAR 0>0.4[1.8]
WN CMH-DEN JAN 0.2>1.1[1.1] FEB 0>1.1[1.0] MAR 0>0.2[1.7]
WN CMH-FLL JAN 0.2>1.4[1.4] FEB 0>1.5[1.2] MAR 0>0.2[1.3]
WN CMH-HOU JAN 0.2>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN CMH-LAS JAN 0.2>1.8[1.8] MAR 0>0.4[2]
WN CMH-MCO JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.8[4]
WN CMH-MDW JAN 0.7>5[5] FEB 0>5[4] MAR 0>0.9[5]
WN CMH-PHX JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.3]
WN CMH-RSW JAN 0.2>2[2] MAR 0>0.4[3]
WN CMH-STL JAN 0.3>1.9[1.9] MAR 0>0.4[1.8]
WN CMH-TPA JAN 0.3>2[2] MAR 0>0.4[3]
WN CRP-HOU JAN 0.6>4[4] MAR 0>0.7[4]
WN CUN-DEN JAN 0.2>1.2[1.3] FEB 0>1.2[1.1] MAR 0>0.2[1.2]
WN CUN-FLL JAN 0.3>2[2] MAR 0>0.4[2]
WN CUN-HOU JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.6[2]
WN CUN-MDW JAN 0.3>0.5[1.4] FEB 0>0.3[1.3]
WN CUN-STL JAN 0.2>0.4[1.0] FEB 0>0.3[1.0]
WN CVG-DEN JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN CVG-MCO JAN 0.1>0.3[0] FEB 0>0.3[0]
WN CVG-MDW JAN 0.6>4[5] FEB 0>4[5] MAR 0>0.9[5]
WN DAL-DCA JAN 0.8>5[5] MAR 0>0.9[5]
WN DAL-DEN JAN 1.1>8[7] FEB 0>8[7] MAR 0>1.6[7]
WN DAL-ELP JAN 0.6>4[4] MAR 0>0.8[4]
WN DAL-FLL JAN 0.5>4[3] FEB 0>4[3] MAR 0>0.8[3]
WN DAL-HOU JAN 3>19[19] MAR 0>4[19]
WN DAL-IND JAN 0.2>1.0[1.2] FEB 0>1.0[1.1] MAR 0>0.2[1.2]
WN DAL-LAS JAN 0.7>6[5] FEB 0>6[5] MAR 0>1.3[5]
WN DAL-LAX JAN 0.7>5[5] FEB 0>6[5] MAR 0>1.1[5]
WN DAL-LBB JAN 0.7>5[5] MAR 0>0.9[5]
WN DAL-LGA JAN 0.7>5[5] MAR 0>0.9[5]
WN DAL-LIT JAN 0.5>2[3] FEB 0>2[3] MAR 0>0.4[3]
WN DAL-MAF JAN 0.7>5[4] FEB 0>5[4] MAR 0>0.9[4]
WN DAL-MCI JAN 0.9>7[6] FEB 0>7[6] MAR 0>1.4[6]
WN DAL-MCO JAN 0.8>6[5] FEB 0>6[5] MAR 0>1.1[5]
WN DAL-MDW JAN 1.1>8[7] MAR 0>1.5[7]
WN DAL-MEM JAN 0.4>1.9[2] FEB 0>1.8[3] MAR 0>0.4[3]
WN DAL-MKE JAN 0.2>1.0[0.8] MAR 0>0.2[1.0]
WN DAL-MSP JAN 0.2>1.0[0.8] MAR 0>0.2[1.0]
WN DAL-MSY JAN 1.1>8[7] FEB 0>8[7] MAR 0>1.6[7]
WN DAL-OAK JAN 0.2>1.7[1.9] FEB 0>1.7[1.8] MAR 0>0.4[1.8]
WN DAL-OMA JAN 0.2>1.0[1.0] MAR 0>0.2[1.3]
WN DAL-ONT JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN DAL-PHX JAN 1.0>7[6] FEB 0>7[6] MAR 0>1.4[6]
WN DAL-PIT JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN DAL-RDU JAN 0.2>1.1[1.1] MAR 0>0.2[1.0]
WN DAL-RSW JAN 0.2>1.0[0.8] MAR 0>0.2[1.0]
WN DAL-SAN JAN 0.6>4[4] MAR 0>0.8[4]
WN DAL-SAT JAN 1.5>10[9] FEB 0>10[9] MAR 0>2[10]
WN DAL-SDF JAN 0.2>1.0[0.8] MAR 0>0.2[1.0]
WN DAL-SJC JAN 0.4>3[1.8] FEB 0>2[1.7] MAR 0>0.5[1.7]
WN DAL-SLC JAN 0.2>1.2[1.2] MAR 0>0.2[1.1]
WN DAL-SMF JAN 0.2>1.0[1.0] MAR 0>0.2[1.1]
WN DAL-STL JAN 0.9>6[6] MAR 0>1.4[6]
WN DAL-TPA JAN 0.5>3[3] MAR 0>0.6[3]
WN DAL-TUL JAN 0.5>4[4] FEB 0>3[4] MAR 0>0.7[4]
WN DCA-FLL JAN 0.4>2[2] MAR 0>0.4[2]
WN DCA-HOU JAN 0.5>3[3] MAR 0>0.6[3]
WN DCA-MCI JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN DCA-MCO JAN 0.4>2[2] MAR 0>0.4[2]
WN DCA-MDW JAN 1.0>6[6] MAR 0>1.1[6]
WN DCA-MKE JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN DCA-MSY JAN 0.3>2[2] MAR 0>0.4[2]
WN DCA-OKC JAN 0.1>1.0[1.0] MAR 0>0.2[1.0]
WN DCA-OMA JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN DCA-PVD JAN 0.4>1.9[2] FEB 0>1.8[2] MAR 0>0.4[2]
WN DCA-STL JAN 0.6>4[4] MAR 0>0.8[4]
WN DCA-TPA JAN 0.4>2[2] MAR 0>0.4[2]
WN DEN-DTW JAN 0.3>1.1[1.1] MAR 0>0.2[1.5]
WN DEN-ELP JAN 0.2>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN DEN-FLL JAN 0.3>3[2] FEB 0>3[2] MAR 0>0.6[3]
WN DEN-GEG JAN 0.3>2[2] MAR 0>0.4[2]
WN DEN-HOU JAN 1.0>7[6] FEB 0>7[6] MAR 0>1.4[6]
WN DEN-IAD JAN 0.4>2.0[2.0] FEB 0>1.8[1.9] MAR 0>0.4[3]
WN DEN-IND JAN 0.6>3[3] MAR 0>0.6[3]
WN DEN-JAX JAN 0.2>1.0[1.0] MAR 0>0.2[1.1]
WN DEN-LAS JAN 1.5>9[9] MAR 0>1.8[9]
WN DEN-LAX JAN 1.1>7[7] MAR 0>1.3[7]
WN DEN-LBB JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN DEN-LGA JAN 0.5>4[3] MAR 0>0.7[3]
WN DEN-MCI JAN 1.0>6[6] FEB 0>5[6] MAR 0>1.2[6]
WN DEN-MCO JAN 0.5>4[3] FEB 0>4[3] MAR 0>0.7[4]
WN DEN-MDW JAN 1.3>8[8] FEB 0>7[8] MAR 0>1.5[8]
WN DEN-MEM JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN DEN-MKE JAN 0.5>3[3] MAR 0>0.6[3]
WN DEN-MSP JAN 0.5>4[4] MAR 0>0.9[4]
WN DEN-MSY JAN 0.4>3[2] MAR 0>0.6[2]
WN DEN-OAK JAN 0.7>5[5] MAR 0>1.0[5]
WN DEN-OKC JAN 0.5>3[3] MAR 0>0.5[3]
WN DEN-OMA JAN 0.5>3[3] MAR 0>0.6[3]
WN DEN-ONT JAN 0.4>2[1.8] FEB 0>2.0[1.7] MAR 0>0.4[1.9]
WN DEN-PDX JAN 0.7>4[4] MAR 0>0.7[4]
WN DEN-PHL JAN 0.4>2.0[2] FEB 0>1.8[2] MAR 0>0.4[2]
WN DEN-PHX JAN 1.8>12[11] MAR 0>2[11]
WN DEN-PIT JAN 0.3>1.9[1.0] FEB 0>1.8[1.0] MAR 0>0.4[1.4]
WN DEN-PVR JAN 0.1>1.0[1.0] MAR 0>0.2[1.3]
WN DEN-RDU JAN 0.3>1.1[1.2] MAR 0>0.2[1.8]
WN DEN-RNO JAN 0.3>1.1[1.2] MAR 0>0.2[1.8]
WN DEN-SAN JAN 0.9>6[5] MAR 0>1.2[6]
WN DEN-SAT JAN 0.4>3[2] FEB 0>3[2] MAR 0>0.5[3]
WN DEN-SDF JAN 0.1>1.0[1.0] MAR 0>0.2[1.0]
WN DEN-SEA JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.7[2]
WN DEN-SFO JAN 0.8>4[3] FEB 0>4[3] MAR 0>0.7[3]
WN DEN-SJC JAN 0.6>4[3] FEB 0>4[3] MAR 0>0.8[4]
WN DEN-SJD JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.4]
WN DEN-SLC JAN 0.9>6[6] MAR 0>1.1[6]
WN DEN-SMF JAN 0.8>4[4] MAR 0>0.8[4]
WN DEN-SNA JAN 0.6>4[4] MAR 0>0.8[5]
WN DEN-STL JAN 0.8>6[5] FEB 0>6[5] MAR 0>1.2[5]
WN DEN-TPA JAN 0.4>3[3] MAR 0>0.6[3]
WN DEN-TUL JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN DEN-TUS JAN 0.3>2[2] MAR 0>0.4[3]
WN DSM-LAS JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN DSM-STL JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN DTW-LAS JAN 0.0>0.3[1.0] FEB 0>0.4[1.0]
WN DTW-MDW JAN 0.6>4[4] MAR 0>0.7[3]
WN DTW-STL JAN 0.4>3[1.8] FEB 0>3[1.7] MAR 0>0.5[1.8]
WN ECP-HOU JAN 0.2>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN ELP-HOU JAN 0.5>3[3] MAR 0>0.5[3]
WN ELP-LAS JAN 0.4>2[2] FEB 0>2[2.0] MAR 0>0.4[2]
WN ELP-LAX JAN 0.3>1.8[1.2] FEB 0>1.7[1.0] MAR 0>0.4[1.1]
WN ELP-PHX JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.5[2]
WN ELP-SAN JAN 0.2>1.0[0.9] FEB 0>1.0[1.1] MAR 0>0.2[1.2]
WN ELP-SAT JAN 0.3>2[1.9] FEB 0>2.0[1.9] MAR 0>0.4[1.8]
WN FLL-GCM JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN FLL-HAV JAN 0.5>3[3] MAR 0>0.6[3]
WN FLL-HOU JAN 0.5>3[3] MAR 0>0.6[3]
WN FLL-IND JAN 0.4>2[1.9] FEB 0>2[2.0] MAR 0>0.4[2]
WN FLL-ISP JAN 0.2>1.1[1.9] FEB 0>1.2[2] MAR 0>0.2[1.9]
WN FLL-LAS JAN 0.2>0.4[0.9] FEB 0>0.3[1.0]
WN FLL-MBJ JAN 0.3>2[2] MAR 0>0.4[2]
WN FLL-MCI JAN 0.2>2.0[1.9] FEB 0>2[2.0] MAR 0>0.4[2]
WN FLL-MCO JAN 0.6>4[5] FEB 0>4[5] MAR 0>0.8[5]
WN FLL-MDW JAN 0.6>5[4] FEB 0>5[3] MAR 0>1.0[5]
WN FLL-MKE JAN 0.2>1.1[1.1] FEB 0>1.2[1.1]
WN FLL-MSY JAN 0.4>3[2] FEB 0>3[2] MAR 0>0.6[2]
WN FLL-NAS JAN 0.3>2[2] MAR 0>0.4[2]
WN FLL-PHL JAN 0.2>1.1[2.0] FEB 0>1.2[2] MAR 0>0.2[1.2]
WN FLL-PHX JAN 0.2>0.4[1.0] FEB 0>0.3[1.0]
WN FLL-PIT JAN 0.3>2[1.2] FEB 0>2[1.1] MAR 0>0.4[1.8]
WN FLL-PLS JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN FLL-PUJ JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN FLL-PVD JAN 0.2>2[2.0] MAR 0>0.4[2]
WN FLL-RDU JAN 0.3>1.3[1.1] FEB 0>1.2[1.0] MAR 0>0.2[1.1]
WN FLL-SAT JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN FLL-SJO JAN 0.2>1.0[1.2] MAR 0>0.2[1.1]
WN FLL-SJU JAN 0.2>1.5[1.2] FEB 0>1.5[1.1] MAR 0>0.3[1.2]
WN FLL-STL JAN 0.3>2[2] MAR 0>0.4[3]
WN FLL-TPA JAN 0.7>5[5] MAR 0>0.9[5]
WN GEG-LAS JAN 0.3>2[2] MAR 0>0.4[2]
WN GEG-OAK JAN 0.3>2[2] MAR 0>0.4[2]
WN GEG-PHX JAN 0.2>1.0[1.0] MAR 0>0.2[1.1]
WN GEG-SAN JAN 0.2>1.0[0] FEB 0>1.0[0] MAR 0>0.2[0]
WN GEG-SJC JAN 0.2>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN GEG-SMF JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN GRR-MCO JAN 0.0>1.1[1.0] FEB 0>1.3[1.1] MAR 0>0.2[1.2]
WN GRR-MDW JAN 0.5>3[3] MAR 0>0.6[3]
WN GRR-RSW JAN 0.0>0.2[0.7] FEB 0>0.3[0.9]
WN HAV-TPA JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.2]
WN HNL-ITO JAN 0>1.7[0] FEB 0>4[0] MAR 0>0.8[0]
WN HNL-KOA JAN 0.6>4[0] FEB 0>4[0] MAR 0>0.8[0]
WN HNL-LIH JAN 0>1.7[0] FEB 0>4[0] MAR 0>0.8[0]
WN HNL-OAK JAN 0.3>2[0] FEB 0>2[0] MAR 0>0.4[0]
WN HNL-OGG JAN 0.6>4[0] FEB 0>4[0] MAR 0>0.8[0]
WN HNL-SJC JAN 0.2>1.0[0] FEB 0>1.0[0] MAR 0>0.2[0]
WN HNL-SMF JAN 0>0.4[0] FEB 0>1.0[0] MAR 0>0.2[0]
WN HOU-HRL JAN 0.7>5[4] MAR 0>0.9[4]
WN HOU-IND JAN 0.2>1.0[1.1] MAR 0>0.2[1.9]
WN HOU-JAX JAN 0.2>0.9[1.1] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN HOU-LAS JAN 0.8>5[5] MAR 0>1.0[5]
WN HOU-LAX JAN 0.7>5[5] FEB 0>4[5] MAR 0>0.9[5]
WN HOU-LGA JAN 0.5>3[3] MAR 0>0.5[3]
WN HOU-LIR JAN 0.2>1.0[1.0] MAR 0>0.2[1.1]
WN HOU-LIT JAN 0>0.7[0] FEB 0>0.9[0]
WN HOU-MAF JAN 0.5>3[3] MAR 0>0.7[3]
WN HOU-MCI JAN 0.4>3[3] MAR 0>0.5[3]
WN HOU-MCO JAN 0.8>4[4] MAR 0>0.8[4]
WN HOU-MDW JAN 1.0>6[6] MAR 0>1.2[7]
WN HOU-MEM JAN 0.3>1.9[1.7] FEB 0>1.8[1.7] MAR 0>0.4[1.8]
WN HOU-MKE JAN 0.2>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN HOU-MSY JAN 1.5>10[9] FEB 0>9[10] MAR 0>1.9[9]
WN HOU-OAK JAN 0.3>2[2] MAR 0>0.4[2]
WN HOU-OKC JAN 0.5>4[4] FEB 0>5[4] MAR 0>0.9[4]
WN HOU-OMA JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN HOU-PHX JAN 0.8>5[5] MAR 0>1.0[5]
WN HOU-PIT JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN HOU-PNS JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN HOU-PVR JAN 0.2>1.0[1.0] MAR 0>0.2[1.1]
WN HOU-RDU JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN HOU-SAN JAN 0.5>3[2] FEB 0>3[2] MAR 0>0.5[2]
WN HOU-SAT JAN 1.0>5[5] MAR 0>1.0[5]
WN HOU-SDF JAN 0.2>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN HOU-SJC JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN HOU-SJD JAN 0.3>2[1.0] FEB 0>2[1.0] MAR 0>0.4[1.3]
WN HOU-SJO JAN 0.2>1.0[1.0] MAR 0>0.2[1.1]
WN HOU-SLC JAN 0.2>0.4[0.3] FEB 0>0.3[0.5]
WN HOU-STL JAN 0.6>4[4] MAR 0>0.8[4]
WN HOU-TPA JAN 0.5>3[3] MAR 0>0.6[3]
WN HOU-TUL JAN 0.4>3[3] MAR 0>0.6[3]
WN ICT-LAS JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN ICT-PHX JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN ICT-STL JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN IND-LAS JAN 0.3>1.9[2.0] MAR 0>0.4[3]
WN IND-MCI JAN 0.3>1.7[1.6] FEB 0>1.7[1.6] MAR 0>0.4[1.5]
WN IND-MCO JAN 0.5>4[4] MAR 0>0.8[5]
WN IND-MDW JAN 0.2>1.0[1.7] FEB 0>1.0[1.7] MAR 0>0.2[1.7]
WN IND-PHX JAN 0.3>1.9[1.7] FEB 0>2[1.9] MAR 0>0.4[3]
WN IND-RSW JAN 0.2>3[2] MAR 0>0.6[4]
WN IND-TPA JAN 0.3>2[2] MAR 0>0.4[3]
WN ISP-MCO JAN 0.5>2[2] MAR 0>0.4[3]
WN ISP-PBI JAN 0.3>2[2] MAR 0>0.4[2]
WN ISP-TPA JAN 0.2>1.0[1.0] MAR 0>0.2[1.5]
WN JAX-MDW JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN KOA-OAK JAN 0>0.3[0] FEB 0>0.6[0]
WN KOA-OGG JAN 0>0.4[0] FEB 0>1.0[0] MAR 0>0.2[0]
WN KOA-SJC FEB 0>0.4[0]
WN LAS-LAX JAN 1.4>10[9] MAR 0>2[10]
WN LAS-LBB JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN LAS-LIT JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN LAS-MAF JAN 0.2>1.1[1.2] MAR 0>0.2[1.2]
WN LAS-MCI JAN 0.6>3[3] FEB 0>3[4] MAR 0>0.6[4]
WN LAS-MCO JAN 0.3>1.3[2.0] FEB 0>1.2[2] MAR 0>0.2[2]
WN LAS-MDW JAN 1.2>7[7] MAR 0>1.3[9]
WN LAS-MKE JAN 0.4>3[3] MAR 0>0.6[3]
WN LAS-MSY JAN 0.4>1.5[1.3] FEB 0>1.4[1.1] MAR 0>0.3[1.7]
WN LAS-OAK JAN 1.4>9[8] MAR 0>1.7[9]
WN LAS-OKC JAN 0.3>2[1.9] FEB 0>2[1.8] MAR 0>0.4[2]
WN LAS-OMA JAN 0.2>1.9[2] FEB 0>2[2.0] MAR 0>0.4[3]
WN LAS-ONT JAN 0.6>4[4] MAR 0>0.8[4]
WN LAS-PDX JAN 0.6>3[3] MAR 0>0.6[4]
WN LAS-PHX JAN 1.6>11[10] FEB 0>11[10] MAR 0>2[11]
WN LAS-PIT JAN 0.2>1.0[1.1] MAR 0>0.2[1.7]
WN LAS-RNO JAN 1.4>9[9] FEB 0>9[8] MAR 0>1.9[9]
WN LAS-SAN JAN 1.6>10[10] MAR 0>2[10]
WN LAS-SAT JAN 0.6>4[4] MAR 0>0.8[4]
WN LAS-SDF JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN LAS-SEA JAN 0.4>2[3] FEB 0>2[3] MAR 0>0.4[3]
WN LAS-SFO JAN 1.0>6[6] MAR 0>1.2[5]
WN LAS-SJC JAN 1.6>10[9] FEB 0>10[9] MAR 0>2[9]
WN LAS-SLC JAN 0.6>5[5] MAR 0>1.0[5]
WN LAS-SMF JAN 1.3>9[8] FEB 0>9[8] MAR 0>1.8[8]
WN LAS-SNA JAN 0.8>5[6] FEB 0>5[6] MAR 0>1.0[6]
WN LAS-STL JAN 0.5>3[3] MAR 0>0.6[4]
WN LAS-TPA JAN 0.2>0.4[1.7] FEB 0>0.3[1.9]
WN LAS-TUL JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.0]
WN LAS-TUS JAN 0.6>3[3] MAR 0>0.6[3]
WN LAX-MCI JAN 0.4>1.8[3] FEB 0>1.5[3] MAR 0>0.4[3]
WN LAX-MDW JAN 0.9>5[5] MAR 0>1.0[5]
WN LAX-MSY JAN 0.3>1.9[3] FEB 0>1.8[3] MAR 0>0.4[3]
WN LAX-OAK JAN 1.9>13[12] MAR 0>3[12]
WN LAX-PDX JAN 0.3>1.0[1.8] FEB 0>0.8[1.6] MAR 0>0.2[2]
WN LAX-PHX JAN 1.3>8[9] FEB 0>8[9] MAR 0>1.7[8]
WN LAX-RNO JAN 0.4>3[3] MAR 0>0.6[3]
WN LAX-SAT JAN 0.3>1.7[1.7] FEB 0>1.5[1.6] MAR 0>0.4[1.8]
WN LAX-SFO JAN 1.3>8[8] MAR 0>1.6[8]
WN LAX-SJC JAN 1.6>11[10] FEB 0>10[11] MAR 0>2[10]
WN LAX-SLC JAN 0.4>3[3] MAR 0>0.6[3]
WN LAX-SMF JAN 1.2>8[8] MAR 0>1.7[8]
WN LAX-STL JAN 0.5>3[3] MAR 0>0.5[3]
WN LAX-TUS JAN 0.4>3[3] MAR 0>0.6[3]
WN LGA-MCI JAN 0.3>1.7[1.7] FEB 0>1.5[1.7] MAR 0>0.4[1.8]
WN LGA-MDW JAN 1.0>6[6] FEB 0>5[6] MAR 0>1.1[6]
WN LGA-MKE JAN 0.3>1.8[1.9] FEB 0>1.7[1.9] MAR 0>0.4[1.7]
WN LGA-MSY JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN LGA-STL JAN 0.5>3[3] MAR 0>0.6[3]
WN LGA-TPA JAN 0.3>1.9[1.9] MAR 0>0.4[1.7]
WN LGB-OAK JAN 0.6>4[4] MAR 0>0.8[4]
WN LGB-SJC JAN 0.6>4[0] FEB 0>4[0] MAR 0>0.7[0]
WN LGB-SMF JAN 0.6>4[4] MAR 0>0.7[4]
WN LIH-OAK FEB 0>0.4[0]
WN LIH-SJC JAN 0>0.3[0] FEB 0>0.6[0]
WN LIT-STL JAN 0.3>1.9[1.9] MAR 0>0.4[1.8]
WN MBJ-MCO JAN 0.1>0.3[0.7] FEB 0>0.3[0.7]
WN MBJ-MDW JAN 0.1>0.3[0.9] FEB 0>0.3[1.0]
WN MCI-MCO JAN 0.4>3[2] FEB 0>3[2] MAR 0>0.5[3]
WN MCI-MDW JAN 1.2>7[7] FEB 0>6[7] MAR 0>1.3[7]
WN MCI-MKE JAN 0.3>1.7[1.6] FEB 0>1.7[1.6] MAR 0>0.4[1.6]
WN MCI-MSP JAN 0.2>1.6[1.6] FEB 0>1.5[1.6] MAR 0>0.4[1.5]
WN MCI-MSY JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.0]
WN MCI-OAK JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[0.7]
WN MCI-PHX JAN 0.5>4[3] FEB 0>4[3] MAR 0>0.8[5]
WN MCI-RDU JAN 0.1>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN MCI-RSW JAN 0>0.7[0.8] FEB 0>0.9[1.0]
WN MCI-SAN JAN 0.3>1.8[1.8] MAR 0>0.4[2.0]
WN MCI-SAT JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[1.0]
WN MCI-STL JAN 0.6>4[4] MAR 0>0.7[4]
WN MCI-TPA JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[3]
WN MCO-MDW JAN 1.3>7[7] MAR 0>1.4[9]
WN MCO-MEM JAN 0.2>1.2[1.2] FEB 0>1.1[1.0] MAR 0>0.2[2]
WN MCO-MHT JAN 0.4>2[2] FEB 0>2[3] MAR 0>0.4[2]
WN MCO-MKE JAN 0.5>3[3] MAR 0>0.6[4]
WN MCO-MSY JAN 0.6>4[4] MAR 0>0.8[4]
WN MCO-ORF JAN 0.2>1.3[1.2] FEB 0>1.3[1.1] MAR 0>0.2[1.0]
WN MCO-PHL JAN 0.7>3[3] MAR 0>0.4[3]
WN MCO-PHX JAN 0.2>1.2[1.3] MAR 0>0.2[1.5]
WN MCO-PIT JAN 0.7>4[4] MAR 0>0.8[5]
WN MCO-PVD JAN 0.5>3[3] MAR 0>0.6[4]
WN MCO-RDU JAN 0.5>3[3] MAR 0>0.6[3]
WN MCO-RIC JAN 0.0>0.2[0] FEB 0>0.3[0]
WN MCO-ROC JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.1]
WN MCO-SAT JAN 0.2>1.2[1.1] MAR 0>0.2[1.8]
WN MCO-SDF JAN 0.2>1.3[1.2] FEB 0>1.3[1.1] MAR 0>0.2[1.2]
WN MCO-SJU JAN 0.3>2[2] MAR 0>0.4[2]
WN MCO-STL JAN 0.7>5[4] FEB 0>5[4] MAR 0>1.0[5]
WN MDW-MEM JAN 0.3>1.8[1.9] FEB 0>1.7[1.9] MAR 0>0.4[2.0]
WN MDW-MHT JAN 0.2>1.0[1.9] FEB 0>1.0[1.8] MAR 0>0.2[1.0]
WN MDW-MSP JAN 1.0>6[6] MAR 0>1.3[6]
WN MDW-MSY JAN 0.6>3[2] MAR 0>0.6[3]
WN MDW-OAK JAN 0.4>2[2] FEB 0>2.0[2] MAR 0>0.4[2]
WN MDW-OKC JAN 0.2>0.4[0.2] FEB 0>0.3[0]
WN MDW-OMA JAN 0.6>4[4] MAR 0>0.8[4]
WN MDW-ONT JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN MDW-ORF JAN 0.2>1.0[1.2] FEB 0>1.0[1.1] MAR 0>0.2[1.2]
WN MDW-PDX JAN 0.3>1.2[1.2] MAR 0>0.2[1.5]
WN MDW-PHL JAN 0.8>5[5] FEB 0>4[5] MAR 0>1.0[5]
WN MDW-PHX JAN 1.0>6[6] MAR 0>1.2[9]
WN MDW-PIT JAN 0.6>4[4] MAR 0>0.9[4]
WN MDW-PUJ JAN 0.1>0.3[1.0] FEB 0>0.3[1.0]
WN MDW-PVD JAN 0.2>1.1[1.5] FEB 0>1.1[1.7] MAR 0>0.2[1.8]
WN MDW-RDU JAN 0.6>3[3] MAR 0>0.5[3]
WN MDW-RSW JAN 0.6>4[4] FEB 0>4[3] MAR 0>0.6[6]
WN MDW-SAN JAN 0.6>3[3] MAR 0>0.6[4]
WN MDW-SAT JAN 0.4>1.8[1.9] FEB 0>1.7[1.9] MAR 0>0.4[2]
WN MDW-SDF JAN 0.5>3[2] FEB 0>3[2.0] MAR 0>0.6[3]
WN MDW-SEA JAN 0.3>1.7[1.8] MAR 0>0.4[1.8]
WN MDW-SFO JAN 0.3>1.7[1.9] FEB 0>1.7[1.9] MAR 0>0.4[2.0]
WN MDW-SJC JAN 0.3>1.1[1.1] MAR 0>0.2[1.0]
WN MDW-SLC JAN 0.2>1.9[2] MAR 0>0.4[2]
WN MDW-SMF JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN MDW-STL JAN 1.0>6[6] MAR 0>1.3[6]
WN MDW-TPA JAN 0.8>4[4] MAR 0>0.8[6]
WN MDW-TUS JAN 0.2>1.0[1.0] MAR 0>0.2[1.1]
WN MEM-TPA JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.1]
WN MHT-TPA JAN 0.2>1.1[1.1] FEB 0>1.2[1.1] MAR 0>0.2[1.3]
WN MKE-PHX JAN 0.4>3[2] FEB 0>3[2] MAR 0>0.5[4]
WN MKE-RSW JAN 0.2>1.7[1.9] FEB 0>1.9[2] MAR 0>0.3[3]
WN MKE-STL JAN 0.3>1.9[1.8] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN MKE-TPA JAN 0.2>1.2[1.1] FEB 0>1.3[1.1] MAR 0>0.2[3]
WN MSP-OAK JAN 0>0.8[0.9] FEB 0>1.0[0.9] MAR 0>0.2[0.8]
WN MSP-PHX JAN 0.3>1.4[2] FEB 0>1.3[2] MAR 0>0.2[3]
WN MSP-STL JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[2.0]
WN MSY-OAK JAN 0.1>1.0[1.0] MAR 0>0.2[1.0]
WN MSY-PHX JAN 0.3>1.9[1.1] FEB 0>1.8[1.0] MAR 0>0.4[1.7]
WN MSY-SAN JAN 0.1>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN MSY-SAT JAN 0.3>1.9[1.0] FEB 0>1.8[1.0] MAR 0>0.4[1.1]
WN MSY-STL JAN 0.4>2[2] MAR 0>0.4[2]
WN MSY-TPA JAN 0.5>3[3] MAR 0>0.6[3]
WN OAK-OGG JAN 0.3>2[0] FEB 0>2[0] MAR 0>0.4[0]
WN OAK-ONT JAN 1.0>7[7] FEB 0>6[7] MAR 0>1.4[6]
WN OAK-PDX JAN 0.9>5[5] MAR 0>1.1[6]
WN OAK-PHX JAN 0.9>6[6] MAR 0>1.2[7]
WN OAK-RNO JAN 0.3>1.9[2.0] FEB 0>1.8[1.9] MAR 0>0.4[3]
WN OAK-SAN JAN 1.8>11[10] FEB 0>11[10] MAR 0>2[11]
WN OAK-SEA JAN 0.9>6[6] MAR 0>1.3[6]
WN OAK-SLC JAN 0.4>3[3] MAR 0>0.6[3]
WN OAK-SNA JAN 1.0>7[7] FEB 0>6[7] MAR 0>1.4[7]
WN OAK-STL JAN 0.1>0.9[0.2] FEB 0>0.8[0] MAR 0>0.2[0.8]
WN OGG-SJC JAN 0.2>1.0[0] FEB 0>1.0[0] MAR 0>0.2[0]
WN OKC-PHX JAN 0.4>3[2.0] FEB 0>3[1.9] MAR 0>0.5[2]
WN OKC-STL JAN 0.3>1.9[1.8] FEB 0>1.8[1.7] MAR 0>0.4[1.8]
WN OMA-PHX JAN 0.4>3[3] MAR 0>0.6[4]
WN OMA-SAN JAN 0.1>0.9[0] FEB 0>0.8[0] MAR 0>0.2[0]
WN OMA-STL JAN 0.5>2[2] MAR 0>0.4[3]
WN ONT-PDX JAN 0.1>0.9[0.8] FEB 0>0.8[0.7] MAR 0>0.2[0.9]
WN ONT-PHX JAN 1.0>6[6] MAR 0>1.3[6]
WN ONT-SFO JAN 0.5>4[0] FEB 0>4[0] MAR 0>0.7[0]
WN ONT-SJC JAN 0.7>5[4] FEB 0>5[4] MAR 0>0.9[4]
WN ONT-SMF JAN 1.1>7[6] FEB 0>7[6] MAR 0>1.5[6]
WN PDX-PHX JAN 0.5>3[3] MAR 0>0.6[3]
WN PDX-SAN JAN 0.4>1.2[3] FEB 0>1.0[3] MAR 0>0.2[3]
WN PDX-SJC JAN 0.8>6[6] MAR 0>1.3[6]
WN PDX-SMF JAN 0.7>5[5] FEB 0>4[5] MAR 0>1.0[5]
WN PDX-STL JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN PHL-STL JAN 0.4>3[3] MAR 0>0.5[3]
WN PHL-TPA JAN 0.2>1.7[1.9] MAR 0>0.4[2]
WN PHX-PIT JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN PHX-RDU JAN 0.2>0.4[1.0] FEB 0>0.3[1.0]
WN PHX-RNO JAN 0.3>2[2] MAR 0>0.4[2]
WN PHX-SAN JAN 1.7>11[10] MAR 0>2[10]
WN PHX-SAT JAN 0.5>3[3] MAR 0>0.6[3]
WN PHX-SDF JAN 0.2>0.4[0.3] FEB 0>0.3[0.1]
WN PHX-SEA JAN 0.5>3[3] MAR 0>0.6[4]
WN PHX-SFO JAN 0.7>4[5] FEB 0>4[5] MAR 0>0.8[5]
WN PHX-SJC JAN 1.0>6[6] FEB 0>6[5] MAR 0>1.2[6]
WN PHX-SLC JAN 0.8>6[6] MAR 0>1.2[6]
WN PHX-SMF JAN 0.9>5[5] MAR 0>1.0[6]
WN PHX-SNA JAN 1.0>7[6] MAR 0>1.4[6]
WN PHX-STL JAN 0.5>4[3] FEB 0>4[3] MAR 0>0.8[4]
WN PHX-TPA JAN 0.2>1.2[1.1] FEB 0>1.1[1.0] MAR 0>0.2[1.1]
WN PHX-TUL JAN 0.2>1.1[1.8] FEB 0>1.1[1.9] MAR 0>0.2[2.0]
WN PIT-RSW JAN 0.2>1.2[1.1] FEB 0>1.3[1.1] MAR 0>0.2[1.8]
WN PIT-STL JAN 0.2>1.0[1.1] MAR 0>0.2[1.0]
WN PIT-TPA JAN 0.3>2[2] MAR 0>0.4[3]
WN PVD-TPA JAN 0.2>1.2[1.2] FEB 0>1.3[1.1] MAR 0>0.2[2.0]
WN RDU-STL JAN 0.3>1.2[1.2] MAR 0>0.2[1.1]
WN RDU-TPA JAN 0.3>2.0[3] FEB 0>2.0[3] MAR 0>0.4[2]
WN RIC-TPA JAN 0.1>0.3[0] FEB 0>0.3[0]
WN RNO-SAN JAN 0.4>3[3] MAR 0>0.6[2]
WN RNO-SJC JAN 0.4>2[1.8] FEB 0>2[1.7] MAR 0>0.5[1.7]
WN ROC-TPA JAN 0.0>0.2[1.0] FEB 0>0.3[1.0]
WN RSW-STL JAN 0.3>2[3] MAR 0>0.4[3]
WN SAN-SAT JAN 0.3>1.7[1.8] MAR 0>0.4[1.8]
WN SAN-SEA JAN 0.2>1.0[1.0] MAR 0>0.2[1.8]
WN SAN-SFO JAN 1.2>7[7] MAR 0>1.5[7]
WN SAN-SJC JAN 2>15[14] FEB 0>15[14] MAR 0>3[13]
WN SAN-SJD JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN SAN-SLC JAN 0.3>1.8[1.0] FEB 0>1.8[1.0] MAR 0>0.4[1.0]
WN SAN-SMF JAN 2>14[13] FEB 0>14[13] MAR 0>3[13]
WN SAN-STL JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[2.0]
WN SAN-TUS JAN 0.3>2[1.9] FEB 0>2.0[1.9] MAR 0>0.4[2]
WN SAT-STL JAN 0.3>1.9[1.9] FEB 0>1.8[1.9] MAR 0>0.4[2.0]
WN SAT-TPA JAN 0.2>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.1]
WN SDF-TPA JAN 0.2>1.1[1.0] FEB 0>1.1[1.0] MAR 0>0.2[1.3]
WN SEA-SJC JAN 0.7>4[4] MAR 0>0.9[4]
WN SEA-SMF JAN 0.7>4[4] MAR 0>0.9[4]
WN SEA-STL JAN 0.1>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN SFO-STL JAN 0.2>1.0[1.0] MAR 0>0.2[1.0]
WN SJC-SLC JAN 0.3>1.8[1.7] FEB 0>1.8[1.9] MAR 0>0.4[1.8]
WN SJC-SNA JAN 1.5>11[11] MAR 0>2[11]
WN SJC-STL JAN 0.1>0.9[1.0] FEB 0>0.8[1.0] MAR 0>0.2[1.0]
WN SJC-TUS JAN 0.1>0.9[0.9] FEB 0>0.8[0.9] MAR 0>0.2[0.8]
WN SJU-TPA JAN 0.2>0.6[1.0] FEB 0>0.6[0.7]
WN SLC-SMF JAN 0.1>1.0[1.0] MAR 0>0.2[1.0]
WN SLC-STL JAN 0.1>0.9[0] FEB 0>0.8[0] MAR 0>0.2[0]
WN SMF-SNA JAN 0.9>6[6] MAR 0>1.2[6]
WN SMF-STL JAN 0.1>1.0[1.0] MAR 0>0.2[1.0]
WN STL-TPA JAN 0.4>2[2] MAR 0>0.5[3]
WN STL-TUL JAN 0.3>1.9[1.9] MAR 0>0.4[1.8]
VS4ever
Re: OAG Changes 8/18/2019:AS Adds GEG-PAE;DL Adds LGW/MAN;HA Adds LAS-OGG;SY Cuts STL-MSP;UA Cuts EWR-PSP;WN
Sun Aug 18, 2019 12:26 pm
Thank you as always for producing this :). One question. I see that DL posted BOS-DUB 0.3 for December, I always thought this route was seasonal and ended in October Anyone know if it’s actually gone year round just a couple of times a week rather than the summer daily, or if this may just be a filing error. I haven’t seen anything to support a year round anywhere.
That feeling when you sit at the end of a runway, brakes are released and the raw power takes over. Now that is a thing of beauty and it never gets old.
kavok
Sun Aug 18, 2019 12:41 pm
Thank you as always for this weekly update.
Interesting UA has the new awarded HND flights available. Does that mean they have slot time approvals from the Japanese Authorities (and I missed it), or did UA view getting those more as a formality and just decided to post them anyway?
Ishrion
Sun Aug 18, 2019 12:44 pm
Yes, the DOT officially allocated the slots last week and UA proposed the timings on Friday.
https://hub.united.com/united-adds-serv ... 55994.html
Polot
Sun Aug 18, 2019 12:46 pm
Operating a few flights around the holidays.
Ishrion
Sun Aug 18, 2019 12:48 pm
Thanks as always!
That's pretty amazing. From Dec 18 to Jan 6, not only will AA have a daily A319 flight to Key West, they'll now have a second daily E-175 flight.
From this thread, AA will have 2 daily A321Ts on MIA-LAX: viewtopic.php?f=3&t=1429515&p=21595617#p21595617
I guess this is where the aircraft is coming from?
tphuang
Sun Aug 18, 2019 12:50 pm
Thanks enilria. Great way to start a sunday.
enilria wrote:
F
AA keeps cutting these back.
DR continues to be weak.
is A321NEO allowing for the aded flights on HNL-SEA?
this didn't last long. All that added capacity by B6 here caused a pretty bloody market.
Ishrion
Sun Aug 18, 2019 12:51 pm
What is this?
Looks like Surinam Airways? https://flightaware.com/live/flight/SLM ... /TNCA/KMIA
cledaybuck
Sun Aug 18, 2019 1:17 pm
Added HNL-ITO/LIH/SMF
KOA-OAK/SJC/OGG
LIH-SJC/OAK
HOU-LIT
Plus some seasonal weekend only stuff to Florida.
Lots of cuts too:
ATL/MCI/MKE-BOS
OAK-CMH
PIT/PVR/OMA/CUN-LAX
DAL/FLL-JAX
OKC/SFO-DAL
LGA-MCO
AUS-SFO
As we celebrate mediocrity, all the boys upstairs want to see, how much you'll pay for what you used to get for free.
Ishrion
Sun Aug 18, 2019 1:20 pm
Has AA ever operated ORD-SPI before this? Never saw any news about it and it looks like it'll operate for 3 weeks on an E-145 and then it's gone.
Runway28L
Never seen UA this low here. Plus, UA.com is still showing 6x daily for January. Perhaps this is a filing error?
Both DL and now WN upping capacity here for this upcoming winter.
enilria
Sun Aug 18, 2019 1:32 pm
KOA-OAK/SJC/OGG
LIH-SJC/OAK
HOU-LIT
Lots of cuts too:
ATL/MCI/MKE-BOS
OAK-CMH
PIT/PVR/OMA/CUN-LAX
DAL/FLL-JAX
OKC/SFO-DAL
LGA-MCO
AUS-SFO
Those are MAX cuts or the MAX is still loaded? Those are frequency cuts or route drops?
cledaybuck
Sun Aug 18, 2019 1:37 pm
KOA-OAK/SJC/OGG
LIH-SJC/OAK
HOU-LIT
Lots of cuts too:
ATL/MCI/MKE-BOS
OAK-CMH
PIT/PVR/OMA/CUN-LAX
DAL/FLL-JAX
OKC/SFO-DAL
LGA-MCO
AUS-SFO
Route drops.
N292UX
Sun Aug 18, 2019 1:42 pm
LAX-MEM on AA was overdue IMO. Hopefully that route ends up working out for them.
DDR
Sun Aug 18, 2019 1:48 pm
Is this an increase or a decrease in flights?
VS4ever
Sun Aug 18, 2019 1:51 pm
Jan is flat, feb slightly down, March is a partial file so ignore it.
The original Jan was probably a partial load, they’ve loaded Feb in full this time around hence the 0 to 1.8
Ishrion
Sun Aug 18, 2019 1:57 pm
Has AA served ORD-ONT before? I'm not seeing anything about it...
DDR
Sun Aug 18, 2019 2:00 pm
THANKS VS4ever!! I miss the days when people actually helped people on this site rather than looking for ways to attack them.
I just have problems trying to understand this thread sometimes. But it is an awesome thread that I look forward to each week.
pmanni1
Sun Aug 18, 2019 2:12 pm
These flights were announced to only run JUN-DEC
VS4ever
Sun Aug 18, 2019 2:20 pm
Happy to help, if you have more questions, send me a DM and I can help you straighten them out. It’s fairly easy to follow once you understand the logic.
chepos
Sun Aug 18, 2019 2:21 pm
Yes, it operated a few summers back as redeye out of ONT on the 738. I guess it is coming back for a brief period during the holidays this year
Fly the Flag!!!!
enilria
Sun Aug 18, 2019 2:29 pm
They have not been a formality in the past. OTOH, given the JV it is a lot more likely AA and UA can get good slots. DL OTOH.
I read that the airlines still need to get HND slots through the IATA slot process.
Ishrion wrote:
Thanks as always!
tphuang wrote:
enilria wrote:
F
I'm assuming that's a deep Holiday cut, but agree.
Good point. I assume that has mostly blown over going forward.
Is HA not having problems with NEO engines like everybody else?
Ishrion wrote:
What is this?
Hmm...AUA is kind of a waste of pre-clearance. I guess it is just too far to make much use of it. If that island were closer it would be a lot more popular.
With CLE-ATL gone, I would expect this would also be on deathwatch, but they are adding freq.
cledaybuck wrote:
enilria wrote:
KOA-OAK/SJC/OGG
LIH-SJC/OAK
HOU-LIT
Lots of cuts too:
ATL/MCI/MKE-BOS
OAK-CMH
PIT/PVR/OMA/CUN-LAX
DAL/FLL-JAX
OKC/SFO-DAL
LGA-MCO
AUS-SFO
Route drops.
They are no longer flying DAL-OKC? :o Are you sure of that?
I guess they had hopes of Winter.
jplatts
Sun Aug 18, 2019 2:51 pm
WN had stated that it was going to be permanently discontinuing DAL-OKC in its January 2020 Base Schedule summary.
The PDEW on DAL-OKC was only 45 passengers per day in 2018, and over 86% of the passengers on the DAL-OKC nonstops in 2018 were connecting through DAL to other destinations.
The other destinations that had daily nonstop service to DAL on WN in 2018 had higher PDEW's (and more O&D passengers) than DAL-OKC.
CIDFlyer
AA has done SPI before. When STL was a hub they ran flights there but eventually cut them and shifted to ORD. At the time they started DFW they shifted ORD to DFW. Probably been over 10 years. Must be a holiday season capacity addition. I think they have up OrD to UA when they shifted to DFW
CIDFlyer
Sun Aug 18, 2019 2:52 pm
AA has done SPI - ORD before. When STL was a hub they ran flights there but eventually cut them (this was even after the main STL cutback in 2003) and shifted to ORD. At the time they started DFW they shifted ORD to DFW. Probably been over 10 years. Must be a holiday season capacity addition. I think they have up OrD to UA when they shifted to DFW
DDR
Sun Aug 18, 2019 3:03 pm
WOW that is shocking and a little sad. This was one of the first routes flown outside TX. Hopefully TUL can keep their DAL flights.
I was afraid we would start seeing these kinds cuts at DAL once they were able to fly to larger cities from Love Field.
jb1087xna
Sun Aug 18, 2019 3:24 pm
*Double post*
jb1087xna
Sun Aug 18, 2019 3:26 pm
Thanks as always! Best part of my Sunday morning.
Looks like WN is basically trading a LIT-DAL flight for a LIT-HOU flight, so just a slight negative change for LIT. Rare to see LIT come up in any WN schedule adjustments, whether additions or subtractions.
stl07
Sun Aug 18, 2019 4:02 pm
It’s also sad to read the pdew considering the history of the route. Oh well, is what it is.
Instead of typing in "mods", consider using the report function.
Love how every "travel blogger" says they will never fly AA/Ethihad again and then says it again and again on subsequent flights.
sprxUSA
Sun Aug 18, 2019 4:46 pm
Well the drive is easy and now maybe AMTRAK between OKC-FTW-DAL will gain a couple more folks.....
Gem State Airlines..."we have a gem of an airline"
Cubsrule
Sun Aug 18, 2019 5:09 pm
Ehh. The history of the route includes a time of significantly lower speed limits. Isn’t it 75 most of the way now?
cledaybuck
Sun Aug 18, 2019 5:17 pm
The history of the route also includes the Wright Amendment which artificially inflated passenger numbers.
Cubsrule
Sun Aug 18, 2019 5:20 pm
Maybe a bit, but OKC never had that much out-of-perimeter service, so I doubt it had the effect it did in places like BHM and ABQ.
hiflyeras
Sun Aug 18, 2019 5:27 pm
UA dropping a PAE-SFO yet not adding anything in its place...are they giving up one of their slots?
AirFiero
Sun Aug 18, 2019 5:49 pm
Whoa! A surprise...
...and if I’m reading all of this right WN adding a bunch of frequencies including a few routes going from 1x/week to almost daily (like ABQ)? The SJC build up continues!
There were a couple what appears to be seasonal trims, some stayed the same, but on balance it looks like 8 more flights at SJC.
khinstorff
Sun Aug 18, 2019 6:12 pm
I wonder if this is what allowed AS to add GEG out of PAE?
AirFiero
Sun Aug 18, 2019 6:15 pm
Previously mentioned in another thread, they are reducing an LAX frequency.
alasizon
Sun Aug 18, 2019 6:23 pm
I thought the LAX reduction was how they funded the PSP addition.
AirFiero
Sun Aug 18, 2019 6:25 pm
I could have it wrong. I’m sure someone will confirm or correct it.
Brickell305
Sun Aug 18, 2019 6:42 pm
The route was only added for the holiday season.
jplatts
Sun Aug 18, 2019 7:09 pm
The PDEW's on DAL-OKC had been decreasing since the 9/11 attacks almost 18 years ago, even before the changes to the Wright Amendment that allowed nonstop service to Missouri from DAL or the sale of connecting flights from DAL to destinations in states that could not be served nonstop from DAL under the Wright Amendment.
In addition to post-Wright Amendment expansion at DAL, tightened airport security following the 9/11 attacks, and higher Interstate highway speed limits, WN is also now charging higher fares on nonstop routes out of DAL to destinations in Texas and neighboring states than was the case in the past.
USAavdork
Sun Aug 18, 2019 7:18 pm
LAX-PAE is currently at 4x.... 1x is being dropped to fund PAE-PSP and another is being dropped to fund
d PAE-GEG. I’m guessing 4x LAX-PAE was too much capacity since they didn’t fund it from another city (SAN, SFO both have 2x).
enilria
Sun Aug 18, 2019 7:28 pm
To me that's extremely shocking. That market used to be MUCH larger. Maybe NK should be considering it.
Interesting, in T100 the Bay Area looks much weaker.
Rdh3e
Sun Aug 18, 2019 7:29 pm
UA.com shows a third Denver flight that was not picked up here apparently.
SANFan
Sun Aug 18, 2019 7:47 pm
If I'm not mistaken, PAE-SFO is the only competitive route from Everett served by both cx. Plus of course AS also connects PAE with SJC.
Doesn't seem too surprising that there is a bit of over-capacity on PAE-SFO.
bb
DDR
Sun Aug 18, 2019 8:13 pm
Hey Cubs, yea the speed limit is a lot higher than it used to be. I'm just bummed for sentimental reasons.
AirFiero
Sun Aug 18, 2019 8:59 pm
Are you talking published load factors?
delta747tlv
Sun Aug 18, 2019 11:33 pm
2nd frequency ends Oct 24th 2019
Operates 2x Jan 19-Dec 6
returns for S20 on May 21
cledaybuck
Mon Aug 19, 2019 1:16 am
NK would get their ass handed to them on DFW-OKC.
Cubsrule
Mon Aug 19, 2019 1:55 am
The way you stimulate a ~200 mile city pair profitably is by convincing the business travelers on 0-1 day trips to fly it. That's not exactly a market NK targets or one with which NK succeeds.
