flee
PW1524 on LX A220-300 suffered a mechanical failure
Wed Aug 21, 2019 10:17 am
It had to come, I guess - after so many issues with the PW engines on various aircraft, it was only a matter of time that an uncontained engine failure happened...
See report:
https://www.airlive.net/alert-french-au ... wiss-a220/
Reason: Title updated
Momo1435
Re: Pratt & Whitney PW1524 suffered a mechanical failure
Wed Aug 21, 2019 10:21 am
Not everyone will know that this is the engine that powers the A220.
Hopefully for all companies involved it is an isolated event without too much trouble for the program which is currently ramping up the production.
SQ22
Wed Aug 21, 2019 10:25 am
Title has been updated accordingly.
Revelation
Re: PW1524 on LX A220-300 suffered a mechanical failure
Wed Aug 21, 2019 1:28 pm
See report:
Are we sure this is "uncontained" i.e. parts escaped the case rather than ejected out the back?
https://www.flightglobal.com/news/artic ... ne-460377/ is report on the same failure.
There have been uncontained failures in the past, ref: https://avherald.com/h?article=4c2283b8&opt=0 regarding "Korean Airlines Bombardier C-Series CS-300, registration HL8314 performing flight KE-753" reporting "several holes in the low pressure turbine case".
Also https://avherald.com/h?search_term=bcs& ... search.y=0 gives a run down of various other problems with the type.
ltbewr
Wed Aug 21, 2019 1:51 pm
Pieces could be as large as 30 CM (about 12 inches for our non-metrics) a size that could kill some one, damage a house or car. Hopefully no serious damage to the plane in other ways, and so far no known injuries,
I wonder if with some newer engines the limits of technology and materials are being pushed and adjustments may have to be made in design or maintenance to reduce such risks.
SPREE34
Wed Aug 21, 2019 5:34 pm
flee wrote:
It had to come, I guess - after so many issues with the PW engines on various aircraft, it was only a matter of time .........
Dramatic, much? Fact based? "It had to come..." Right. As it has on PWs, RRs, GEs, MTU, IAE, CFM, Kilmov, Ivchenko, Williams, Allison,..................
I don't understand everything I don't know about this.
OmerMaz
Wed Aug 21, 2019 6:11 pm
Wasn't there an issue related to a fast waring of the engine at one point? I'm glad it ended safely.
AA737-823
Wed Aug 21, 2019 10:24 pm
Well, I mean.. he makes a point. Dramatic a little, maybe.
But it's not like this engine hasn't had an eyebrow-raising number of in-service issues, across multiple airframe types.
maximairways
Wed Aug 21, 2019 10:34 pm
Every GTF is a different engine. They are not simple % scales of each other. The E2 has not had any major issues...
WayexTDI
Wed Aug 21, 2019 10:40 pm
At the same time, the E2 has only had 7 E190-E2 delivered and in service in the past 18 months... Small population.
JayinKitsap
Thu Aug 22, 2019 1:38 am
This could rain on the PW1524 ETOPS rating. Mean time between failures needs to be very, very low.
N212R
Thu Aug 22, 2019 1:56 am
If the shoe fits...a healthy dose of counterpoint to the one-way A220 hoopla you read about here.
Only 10 responses, the less said the better, eh?
jimatkins
Thu Aug 22, 2019 2:02 am
Shouldn't the MTBF be very high? Common sense.
JayinKitsap
Thu Aug 22, 2019 3:34 am
You are right, ETOPS rules require the following:
Engines must have an In-flight shutdown (IFSD) rate better than 1 per 20,000 hours for ETOPS 120, 1 per 50,000 hours for ETOPS 180 and 1 per 100,000 hours for beyond 180.
I was thinking the occurrence of failures kills the ETOPs approval.
wrongwayup
Thu Aug 22, 2019 3:43 am
That actually strikes me as kind of low. 20,000 hours at 2500hr/yr x 2 engines is 1 IFSD/yr in a fleet of 4 aircraft for ETOPS 120, which gets you everything you could probably want to do with an A220 save for Hawaii.
Armadillo1
Thu Aug 22, 2019 11:51 am
Hawaii need ETOPS 120 only, not 180+?
i think it need 180
https://aerosavvy.com/etops/
SteelChair
Thu Aug 22, 2019 11:55 am
Hawaii needs 180
