moa999
Re: Qantas plans 3 Project Sunrise research flights in Q4 2019 using 787-9's, final decision on PS by end of 2019
Thu Nov 14, 2019 11:53 am
Aircraft had to get from Everett to Australia somehow. Just took a slight detour.
Qantas have flights that are 3 hours shorter. Yes they can extrapolate based on that data, but you still need to validate it.
Maybe you also thing Boeing and Airbus shouldn't bother with test aircraft or test flight programs and just rely on the computer models.
RyanairGuru
Thu Nov 14, 2019 11:55 am
77H wrote:
RyanairGuru wrote:
Would I be correct is assuming that Qantas does not have any Russian over-flight rights? They used to operate HKG-MEL so there is a chance they do.
The reason I ask is that I wouldn't be surprised if in certain conditions it was more efficient to fly over Russia and down over Japan. Chinese airspace is chronically inefficient, as can be seen in the above image with the dogs-leg through China.
Why would QF or any airline for that matter need Russian overflight rights to operate HKG-MEL? HKG is quite a ways south of Russia.
77H
Apologies, I meant HKG-LHR.
Worked Hard, Flew Right
dtw2hyd
Thu Nov 14, 2019 1:25 pm
sevenair wrote:
Ultra long haul flying is nothing new. QF, CASA et all have untold amounts of data at hand from other competent authorities, airlines, crews, passengers, suppliers.
Whilst greater sydney burns, QF are producing tonnes and tonnes of emissions to provide data that already exists.
If ULH is nothing new, what is the issue here?
There is no blanket approval for ULH routes even within the same CAA/Airline combination. The airline has to prove each flight.
CASA is not going to approve SYD-LHR by watching Sam Chui's SIN-EWR vlog.
All posts are just opinions.
ikolkyo
Thu Nov 14, 2019 4:11 pm
Seems like the flight is making great time, it was estimated at about 19:15 and according to FR24 it might make it in 18:00.
rheinwaldner
Thu Nov 14, 2019 5:03 pm
flipdewaf wrote:
I ran some numbers through my model/simulation using almost equal legs from SYD-LHR (picked an airport somewhere in china) and the A350-1000 in total used about $5k less fuel for the two 1/2 legs vs the single long leg.
You should not model both cases with the same aircraft. Compare a single A359 ULR leg vs two 781 legs.
Many things are difficult, all things are possible!
dtw2hyd
Thu Nov 14, 2019 5:33 pm
flipdewaf wrote:
I ran some numbers through my model/simulation using almost equal legs from SYD-LHR (picked an airport somewhere in china) and the A350-1000 in total used about $5k less fuel for the two 1/2 legs vs the single long leg. The reality of the 2 "half" legs is that:
Fred
That doesn't sound right. Fuel savings have to be much higher with a stop.
Crew cost gets cheaper with 2MH compared 1ULH, because of heavy rest requirements mandated for ULH routes. You can roster a ULH crew set twice a month.
Catering and waste disposal is another advantage of 2MH.
If you pick an expensive and congested hub as the stop, all advantages are lost.
flipdewaf
Thu Nov 14, 2019 6:09 pm
I think the ‘burn fuel to carry fuel’ mantra gets very over played and in a relatively low fuel price environment it’s not as big of a deal.
Run some numbers, the more the match of technology moves on and the more the efficiencies improve the shallower the slope (fuel cost per unit distance effectively) of the payload range charts. We aren’t designing 8500nm jets. We are designing 5500nm MZFW jets but the cargo you swap for fuel gets you further theses days.
Fred
seabosdca
Thu Nov 14, 2019 7:59 pm
thepinkmachine wrote:
- Takeoff fuel is 99 Tonnes. That’s ~2T below the max capacity
It's interesting to think about how the folks who planned the record-breaking 747-400 flight in 1989 would have reacted had they been told that a widebody 2/3 the size and weight would make the same flight with 40 passengers and a 99 t fuel load thirty years later. :faint:
dtw2hyd
Thu Nov 14, 2019 8:33 pm
Fred
Interesting. Is there a thread/blog/article on this topic?
benjjk
Fri Nov 15, 2019 1:15 am
Fred
Yes it is overplayed, especially when comparing to a stopover having 2 somewhat heavy takeoffs instead of 1 really big one.
Another overlooked factor is that when you have salaried crews like Qantas, SYD-SIN-LHR takes a lot more bodies to operate than SYD-LHR.
rnav2dlrey
Fri Nov 15, 2019 1:19 am
“moderate turbulence” reported on approach by the A332 ahead of 7879. i’m seeing 11kt wind at the field, no gust reported.
mdavies06
I am sorry if this has been asked / discussed before, but as part of this project has QF ever considered running East Coast-LHR westbound with a technical fuel stop whilst doing non-stop eastbound? I am thinking if will be economically viable as regular scheduled services and make it less onerous for Airbus and Boeing. Going back to history quite a few airlines (not specifically QF routes) did this if range is an issue. To me it seems East Coast-LHR is much more challenging than JFK-SYD which I'll consider as the second longest sector targetted under this project.
benjjk
Fri Nov 15, 2019 1:21 am
This used to be the case but isn't anymore. SQ ULR crews now only need three nights at home before they can go again: https://www.caas.gov.sg/docs/default-so ... 11-2(rev-0)-fatigue-risk-management-for-ulr-operations.pdf
qf789
Fri Nov 15, 2019 1:51 am
Forum Moderator
dtw2hyd
Fri Nov 15, 2019 2:07 am
I have different take on these, but I think this is not the right thread to discuss ULH economics in detail.
qf789
Fri Nov 15, 2019 3:06 am
ZNJ landed in SYD with around 6300 kg of fuel, roughly 1 hr and 45 minutes flying time
https://www.qantasnewsroom.com.au/media ... ght-lands/
Forum Moderator
EK413
Fri Nov 15, 2019 6:48 am
qf789 wrote:
1st commercial service will be QF127 SYDHKG Saturday 16/11
Good evening, ladies and gentlemen. We are tonight’s entertainment!
Bruce
Fri Nov 15, 2019 8:34 am
Do they have any more 787-9 on order? Which plane will operate the 3rd Project Sunrise flight?
vhqpa
Fri Nov 15, 2019 9:01 am
There are 4 outstanding 787-9s for Qantas. I can't tell you which one will do the next PS delivery flight.
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
moa999
Fri Nov 15, 2019 10:16 am
Pretty sure ZNK will be the 3rd test. It was only a few aircraft (or about a fortnight) behind ZNJ on the production schedule. Should be visible at Everett any day.
Don't believe ZNL/M/N are due until the 2nd half of 2020
RyanairGuru
Fri Nov 15, 2019 12:16 pm
I assume the 06:00 departure time was driven more by LHR slots than a marketing opportunity, but I did get a smile out of Alan Joyce's declaration that "we saw a double sunrise" given the history behind the name Project Sunrise.
At the other end of the spectrum, I hate to be "that person" but I am not shocked in the slightest that the flight was late into Sydney. People may recall that a month or so ago me and other posters said that it appeared that they messed up the arrival time in Sydney. Either they managed to stuff up the time difference or they underestimated the length of the flight (I still lean towards the former) but 18h45m chocks-off to chocks-on was always wishful thinking.
readytotaxi
Fri Nov 15, 2019 2:14 pm
Video report from inside the aircraft.
https://www.bbc.co.uk/news/av/world-aus ... -to-sydney
Growing older, but not up.
EK413
Sat Nov 16, 2019 12:14 am
VHZNJ entered revenue service operating today’s QF127 from Sydney to Hong Kong
https://fr24.com/QFA127/22dbed8d
PW100
Sat Nov 16, 2019 5:32 pm
Fred
The more intersting study would be, how much payload (pax and/or cargo) one could carry for the same fuel consumption (ie. $, CO2 and NOx emissions per unit of paylaod) on the non-stop vs one-stop mission (and for good measures, might want to throw in the two-stop mission as well).
flipdewaf
Sat Nov 16, 2019 9:58 pm
Fred
I put some basic numbers for payload availability and fuel loads in the A350-1000ulr thread. It doesn’t have the exact numbers you are after but if you can do some basic maths then you should be able to derive the figures you need through the breguet equation.
Fred
dtw2hyd
Sun Nov 17, 2019 1:47 am
Sam Chui was on the LHR-SYD flight. Posted very detailed report.
QF served only Coconut water and kombucha. No caffeinated soft drinks or alcohol were served. Interesting.
https://www.youtube.com/watch?v=eJP93u7n5Ok
qf789
Sun Nov 17, 2019 2:34 am
ZNL will be delivered early April , M and N will be delivered by June 2020
Forum Moderator
aviationaware
Sun Nov 17, 2019 3:32 am
Any airline that doesn't offer diet coke is off my menu.
ltbewr
Sun Nov 17, 2019 3:40 am
I want to note on the LHR-SYD test flight, the Captain, especially for the take off and landing, was a woman. Perhaps this was intentional for public relations, but it also may be as to studying the affects of ULH flights on a woman as a lead pilot.
One question I have is do aircraft doing ULH is if there are special maintenance procedures, especially with the engines ?
qf789
Sun Nov 17, 2019 3:53 am
You do know that the chief 787 pilot is also a woman and has piloted many long haul flights already, including the delivery of the first 789 plus the inaugural PER-LHR and was also on the first JFK-SYD as well
Forum Moderator
VV
Sun Nov 17, 2019 6:25 am
Is there any chance they would decide anything before year end?
Is the whole thing just a way to make publicity?
qf789
Sun Nov 17, 2019 6:32 am
Qantas CEO Alan Joyce said the following regarding Project Sunrise a couple of days ago
the intention is to make a decision this year and an order could follow into early next year.
https://www.airlineratings.com/news/tes ... e-sunrise/
Forum Moderator
VV
Sun Nov 17, 2019 6:39 am
It sounds like he will order some A350 and "postpone" the very long flights to a later date.
RyanairGuru
Sun Nov 17, 2019 7:36 am
How did you get that from the linked article?!?
If they are going ahead with ULR then all bets are off for an A350/77X order, but if they don't pursue ULR then I can't see an A350 order for the foreseeable future.
If the network remains largely as is then I don't think there will be an A350/77X order for another decade until the A380s are retired. 12 A380s and 12 787s isn't necessarily the most optimal fleet, but adding another <10 of a different types achieves nothing except added cost for limited returns. More 787s, possibly including 787-10 for SIN/HKG/HND, would be a more efficient.
VV
Sun Nov 17, 2019 10:13 am
I think they regretted to not having ordered 777-300ER back then. So, it would be normal to order some A350-1000 today even if it is not used for some the very long routes mentioned in the Project Sunrise.
RyanairGuru
Sun Nov 17, 2019 10:52 am
They might "regret" it in as much, in hindsight, the 77W would probably have been a better option than the A380, but Qantas have a pretty tiny long hual fleet in the scheme of things and spreading that across three types with no commonality is not cost effective. Leaving aside the A330, on the current trajectory the fleet is migrating from A380+747 to A380+787, with two relatively small fleets of both.
If Sunrise happens then they will of course add another fleet but otherwise I really can't see them purchasing a different type, potential A330 replacement notwithstanding.
If Qantas can tap into the sort of high yield traffic they expect with Sunrise then the new fleet should pay for itself, but on the current network I really don't see how they recoup the added capex and operating costs.
moa999
Sun Nov 17, 2019 12:06 pm
Back when?. 777-300ERs might have been better than the 747ERs although the first 300ER wasnt delivered until 2004, 2 years after the 744ERs, but then until they got ETOPS330 they were pretty useless for many of QFs routes, as VA found out on its JNB route.
I think for QFs routes between busy airports with curfew the A380 has mostly worked, and certainly helped it's reputation. But they probably got a few too many.
Possibly a 10 A380 / 10 777 order would have been better than 12 A380 / 6 747s, but that's CEO Harry Hindsight
If Sunrise doesn't happen now, I'd suspect more 787 deliveries to replace the older 332s and 333s in 5 years or so, and then another CEO can try Sunrise2 when the 350neo is launched and look at 380 replacements.
Max Q
Sun Nov 17, 2019 12:58 pm
I haven’t read through all the posts on this topic so perhaps I’ve missed this, is there a plan to operate one of these ‘experimental’ flights from SYD- LHR ?
That is, after all the most challenging sector of all
GGg
flipdewaf
Sun Nov 17, 2019 1:02 pm
I don’t think any of QF current fleet is capable. A380 might be able to with nearly 0 payload but the 787-9 lacks fuel capacity. If the wanted to fit the 787-9 with some aux tanks it might make it, TOW on the previous sunrise test flights have been about 233t if memory serves correctly.
Fred
vhtje
Sun Nov 17, 2019 1:05 pm
Is this a joke?
Wake up, buddy, it’s 2019, not 1959.
I only turn left when boarding aircraft. Well, mostly. All right, sometimes. OH OKAY - rarely.
dtw2hyd
Sun Nov 17, 2019 3:42 pm
This may be the longest ULH, but not the only ULH flight. AI's all-women crew did the DEL-SFO-DEL round-the-world(Pacific/Atlantic) route. I am sure other airlines had an all-women/women crew on ULH in the past.
RyanairGuru
Sun Nov 17, 2019 8:43 pm
No, these "tests" are just delivery flights of new build 787s.
RyanairGuru
Sun Nov 17, 2019 8:44 pm
You've quoted the wrong person.
cpd
Mon Nov 18, 2019 11:26 am
At the risk of us going off topic and away from the original subject, that would be Georgina Sutton. I have a huge amount of respect for her. Grateful also for some of her experiences she shared which have benefited me a lot.
She’d probably roll her eye at LTBEWR’s comment. She actually wanted to be a Police helicopter pilot, but the old fashioned Police bureaucracy of the day put paid to that, so she went and flew 747-400s and 767s instead. The rest of that story is classic.
DeltaB717
Mon Nov 18, 2019 10:08 pm
The Chief Pilot for the 787, and the project lead for the 787 introduction, is actually Lisa Norman.
claudiofalcao
Mon Nov 18, 2019 11:20 pm
Imagine that Boeing will be choosed, but the 777-8 is not available. Could the 777-200LR be used as interim option in Project Sunrise flights?
Flew, as a passenger, on B727-200, 737-200/300/400/800, 747-300, 757-200, 767-300, 777-200, A310, A319, A320 Ceo/Neo, A321, DC-10, MD-87, MD-11, E-190, E-195.
ShamrockBoi330
Tue Nov 19, 2019 12:33 am
Read articles yesterday indicating (rumour mill!) this was the compelling offer that was made to QF and it was too good to refuse... take the 777-200LRs with 270 capacity until the 777-8 is ready and then BA take them back and convert to freighters for FedEx.
EDIT: including link
https://www.airlineratings.com/news/wil ... -aircraft/
Stitch
Tue Nov 19, 2019 12:52 am
I wonder how "compelling" that offer really is. As noted, Qantas looked at the 777-200LR and A340-500 in the mid-2000s and didn't find other attractive enough to go forward. And converting them to freighters implies Boeing (finally) has a P2F program ready to go for the 777 family.
claudiofalcao
Tue Nov 19, 2019 1:13 am
Wow!
Has the 777-200LR enough ability to reach London, from Sydney, with 270 souls?
ShamrockBoi330
Tue Nov 19, 2019 1:49 am
Wow!
if it did, you'd wonder what all the fuss is about, and why isn't it already operating tbh!
