DUSdude
Edelweiss A340 YVR-SAN
Fri Aug 30, 2019 9:34 pm
Hi!
Flightradar24 currently shows an Edelweiss A340-313, HB-JMF enroute YVR-SAN as EDW5019. That's a rather unusual route for this aircraft, to say the least. It appears its last previous flight was ZRH-YVR on 8/2. The return to ZRH was then canceled. Does anyone know what happened? Serious mx issue at YVR causing a near one month grounding? Thanks in advance.
EDIT: cruising now at FL410, which for an A340-313 suggests an empty aircraft on a repositioning flight.
thepinkmachine
Re: Edelweiss A340 YVR-SAN
Fri Aug 30, 2019 9:38 pm
You kind of answered your own question :)
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
DUSdude
Fri Aug 30, 2019 10:48 pm
I speculated. ;-) Would appreciate substantiated info and back story from someone in the know. Thx
Spacepope
Fri Aug 30, 2019 10:49 pm
Collided with an AC 787. Has been parked at YVR for a while with the APU region taped up awaiting repairs.
HJM
Fri Aug 30, 2019 11:01 pm
Saw it recently in AC hangar YVR.
DUSdude
Fri Aug 30, 2019 11:06 pm
Thanks for the info, Spacepope.
inAjet
Sat Aug 31, 2019 12:50 am
dcajet
Sat Aug 31, 2019 12:54 am
Leaving as WK19 SAN-ZRH in a bit over an hour (7:15 PM PDT).
Mon Sep 02, 2019 12:24 pm
Edelweiss cancelled ZRH-SAN, and uses the now repaired -JMF to operate the return SAN-ZRH. Smart way to reschedule the frame into service and reduce flight cancellations and positioning flights at the same time.
The other option was cancelling ZRH-SAN + SAN-ZRH & reposition empty YVR-ZRH. Makes perfect sense to me.
flown: F50,F70,CR1,CR2,CR9,CS3,E75,E90,143,AR8,AR1,733,735,736,73G,738,
