CarbonFibre
Smoky A350!
Sun Sep 01, 2019 8:58 am
BA's A350 is spending the weekend in Shannon for some final crew training before DXB starts tomorrow.
Some of the go-arounds have been pretty smoky! https://www.flickr.com/photos/[email protected] ... /contacts/
WIederling
Re: Smoky A350!
Sun Sep 01, 2019 9:43 am
go arounds? ( i.e. drastic thrust increase without having yet reached a stable thrust state )
Murphy is an optimist
Faro
Re: Smoky A350!
Sun Sep 01, 2019 9:57 am
Understood...but even then, that is a turbojet-707-ish level of smoke...I find it quite surprising...
Faro
The chalice not my son
DL747400
Re: Smoky A350!
Sun Sep 01, 2019 10:03 am
That’s just terrible. The EU should outlaw this immediately and BA should be fined. (Sarcasm)
From First to Worst: The history of Airliners.net.
All posts reflect my opinions, not those of my employer or any other company.
Re: Smoky A350!
Sun Sep 01, 2019 10:41 am
Must be a problem with the air data system on that particular aircraft, the ACTDS (automatic chem trail delivery system) is not supposed to activate until they are in cruise.
KFTG
Re: Smoky A350!
The edit of the photo could be "revealing" more exhaust than would otherwise be noticeable by the naked eye.
RvA
Re: Smoky A350!
Sun Sep 01, 2019 10:46 am
I think that could be the key to the answer. All jet engines emit plenty of “crap” but it isn’t as bad nor pronounced as it was on say a 707 back in the day but it’s still considerable but usually not as clearly visible. You can find pictures out there of for example a Ferrari at full throttle that also looks like it’s running a 707 engine. Very interesting picture nonetheless!
KFTG
Re: Smoky A350!
Sun Sep 01, 2019 10:51 am
Specifically, substantial adjustments to contrast are the "norm" for aviation photography - especially here, but the practice is widespread.
The idea being to make the "blacks black" and the "whites white", despite that likely not being the "true" conditions witnessed in person.
PaxPicti
Re: Smoky A350!
Sun Sep 01, 2019 10:53 am
Not a normal go-around since the #1 engine appears to have been shut down. They must be doing engine-out simulation.
VV
Re: Smoky A350!
Sun Sep 01, 2019 11:00 am
I think you are mistaken.
kwidenka
Re: Smoky A350!
Sun Sep 01, 2019 11:08 am
[quote="KFTG" despite that likely not being the "true" conditions witnessed in person.[/quote]
the true purpose of phothography
time to ride the sky
TurboJet707
Re: Smoky A350!
Sun Sep 01, 2019 11:20 am
And suddenly this sophisticated and efficient big twin is starting to look really charismatic :D
Love it.
JesseCasserly
Re: Smoky A350!
Sun Sep 01, 2019 11:32 am
It's surprisingly normal enough. You only really see this when a turbofan is increasing thrust, not when it's at a stable thrust level (unless it's a PW4000!). Basically, when the throttle is firewalled and the engine is accelerating, which takes a couple of seconds, there's is more jet fuel being pumped into the engine than the current engine speed is capable of cleanly burning in order to speed up! Once the engine has reached it's selected thrust, it can perfectly manage the flow of fuel and the combustion is far cleaner!
sandbender
Re: Smoky A350!
Sun Sep 01, 2019 11:52 am
He most certainly is. Everyone knows that the ACTDS chem-trail delivery system has be phased out in favor of the SARCASM system. :D
Re: Smoky A350!
Sun Sep 01, 2019 11:55 am
:bigthumbsup:
VV
Re: Smoky A350!
Sun Sep 01, 2019 12:15 pm
Does it mean there's a real issue or what?
BrianWilkes
Re: Smoky A350!
Sun Sep 01, 2019 12:36 pm
Almost every aircraft will do this one a go around some are worse then others!
DL717
Re: Smoky A350!
Sun Sep 01, 2019 12:57 pm
Looks like someone had a little water in the go juice.
Welcome to Nothingburgers. May I take your order?
reltney
Re: Smoky A350!
Sun Sep 01, 2019 1:00 pm
Everyone knows the ACTDS system was phased out but they are still have problems with the SARCASM system due to the additives in fuels in some countries. There is an AD for the SARCASM system on later model planes not able to swallow the fuels from all countries. Attached inline with the SARCASM system fuel must pass thru the YGBSM filter to further take the impurities out of the system. Compliance is not required until 2021. The handwriting in the sky indicates the SARCASM system is not the end all be all system to correct the ACTDS shortfalls which is why the YGBSM was developed by Boeing. Production delays no doubt have occurred due to the BS department being backed up by other issues. More to come...
Knives don't kill people. People with knives kill people.
OUTLAW KNIVES.
I am a pilot, therefore I envy no one...
Luftymatt
Re: Smoky A350!
Sun Sep 01, 2019 1:36 pm
No they're not. Engine failure practice is reserved for the simulator, not for base training.
chase the sun
Some1Somewhere
Re: Smoky A350!
Sun Sep 01, 2019 1:40 pm
CriticalPoint
Re: Smoky A350!
Sun Sep 01, 2019 2:33 pm
Sometimes when you go TOGA thrust the Bleeds will over pressure and the chemtrail outflow valve will open to relive the pressure. It’s temporary, typically the chemtrails are not released until above FL300.....like Zeke said
CarbonFibre
Re: Smoky A350!
Sun Sep 01, 2019 2:50 pm
It's certainly done a lot of circuits these last two days. https://www.flightradar24.com/data/aircraft/g-xwba
PaxPicti
Re: Smoky A350!
Sun Sep 01, 2019 3:10 pm
So why is the #1 engine fan stationary? You can see the blades clearly.
CriticalPoint
Re: Smoky A350!
Sun Sep 01, 2019 3:15 pm
If the engine was shut down it wouldn’t have an exhaust trail.
OldAeroGuy
Re: Smoky A350!
Sun Sep 01, 2019 3:23 pm
With a hard BREXIT emerging, maybe the English are taking more direct action against the Irish. :D
diverted
Re: Smoky A350!
Sun Sep 01, 2019 3:24 pm
It's not stationary. Expand the photo and look at the other engine, same thing
That's what you're seeing
VV
Re: Smoky A350!
Sun Sep 01, 2019 3:50 pm
When is SARCASM system relaxed?
PolarRoute
Re: Smoky A350!
Sun Sep 01, 2019 11:05 pm
Holy smokes these posts! :lol: :lol: :lol:
Re: Smoky A350!
Sun Sep 01, 2019 11:06 pm
Depends on who makes the engines and aircraft, as there are more and more aircraft flying these days, we don’t need to add as much by each aircraft like we did with the older generations. Friday afternoons see it ramping up slightly more of it as the traffic reduces over the weekend. It is sometimes referred to as the British Atmospheric Normalisation of Tropopause Environmental Readings system or The B.A.N.T.E.R. System, or B.S. in the industry vernacular.
strfyr51
Re: Smoky A350!
Sun Sep 01, 2019 11:31 pm
that could be "Jam acceleration" smoke with rthe sudden spool up of RPM and fuel flow. It doesn't appear to be excessive.
VV
Re: Smoky A350!
Mon Sep 02, 2019 6:07 am
I have the feeling people try to avoid discussing this picture seriously.
Is there anything that motivates this attitude?
BlatantEcho
Re: Smoky A350!
Mon Sep 02, 2019 7:48 am
You were close on the SARCASM system. You should dig deeper into that.
It works really well here, mostly.
JannEejit
Re: Smoky A350!
Mon Sep 02, 2019 9:44 am
I witnessed the same scene at GLA a couple of weeks ago when Virgin Atlantic's G-VLUX was based for a week's crew training. I also thought the 'smokiness' trailing behind both engines was reminiscent of 50 years prior turbojet on approach.
gloom
Re: Smoky A350!
Mon Sep 02, 2019 10:25 am
Well, to relax S.A.R.C.A.S.M. a bit...
It's a bit like any diesel engine in your car. They're using heavy fuel (large particles, sticky). When you need to go from low-power mode (less fuel, less air) and accelerate, you just get more fuel into engine. But - you don't get more air until it spools up. So basically, for a few seconds you're going to have this fuel leaving the exhaust as it is. It will not be burnt at all. That's what you see.
Of course, one can argue whether (and to what degree) it can be controlled by electronic units adjusting etc. The sad thing is - when you need power, you need it. Not delayed by half a second, or two seconds. That's why they still tend to be visible. After all, the JetA1 has not changed that much, and what you see is exactly JetA1. Not a smoke, not any product of burning. Actually, quite opposite.
Adam
RWA380
Re: Smoky A350!
Mon Sep 02, 2019 10:31 am
Faro
Not even close to the same amount of smoke, I can remember watching DC-8's & 707's disappearing in the thick black smoke of burning kerosene in the late 60's & early 70's on take-off. I agree to see any smoke coming from such a modern aircraft is unusual & I've never seen it before on an A-350, but if one is pushing large amounts of fuel through the system (aka goosing or flooring) it, no matter the environmental features of the technology can only mitigate so much.
707 717 720 727-1/2 737-1/2/3/4/5/6/7/8/9 747-1/2/3/4 757-2/3 767-2/3/4 777-2/3 DC8 DC9 MD80/2/7/8 D10-1/3/4 M11 L10-1/2/5 A300/310/320
AA AC AQ AS BA BD BN CO CS DL EA EZ HA HG HP KL KN MP MW NK NW OZ PA PS QX RC RH RW SA TG TW UA US VS WA WC WN WP YS 8M
scbriml
Re: Smoky A350!
Mon Sep 02, 2019 10:43 am
It’s clearly a major issue that Airbus is trying to hide. Thankfully, someone is trying to shine a torch on this. Keep up the good work!
lazyme
Re: Smoky A350!
Mon Sep 02, 2019 11:02 am
They just prepare for the 2022 festivities of The Great Smog 70 years ago.
tropical
Re: Smoky A350!
Mon Sep 02, 2019 11:19 am
A worldwide grounding of the A350 is surely just a question of time now :wink2:
uta999
Re: Smoky A350!
Mon Sep 02, 2019 11:29 am
Maybe Rolls-Royce are trying out that nifty fan coating that worked so well for them on the 787
Your computer just got better
keesje
Re: Smoky A350!
Mon Sep 02, 2019 1:47 pm
I feel more attention should be paid to engine fuel efficiency and exhaust during go arounds and engine failure continued take-off's.. :angel:
https://youtu.be/IS91IQN_qYI
VV
Re: Smoky A350!
Mon Sep 02, 2019 3:36 pm
There's no indication whatsoever about any concern. So why do we have all this dramatisation?
People were so motivated and firm about the fuel volume of the A350-1000 compared to A350-900 when we know it's not a big deal and yet people are elusive and evasive on the subject in this thread.
What's going on?
PW100
Re: Smoky A350!
Mon Sep 02, 2019 3:57 pm
What's going on?
I think it all started to get out of hand right here, when you missed the sarcasm . . .
SRQKEF
Re: Smoky A350!
Mon Sep 02, 2019 4:02 pm
What's going on?
Whoooosh.
DylanHarvey
Re: Smoky A350!
Mon Sep 02, 2019 4:06 pm
Simply more proof the A350 is inferior to the 787. Relax, relax, relax it’s just a joke.
SQ22
Re: Smoky A350!
Mon Sep 02, 2019 4:20 pm
I hope you all enjoyed having some fun, thread will be locked.
