Kiwirob wrote:At a guess the taxes from Sweden is probably also part of the reason for this move??
SASViking wrote:Kiwirob wrote:At a guess the taxes from Sweden is probably also part of the reason for this move??
Yes and also the "Flygskam" (shame of flying). CPH also offers better connections than ARN, especially from Poland and northern Germany
mercure1 wrote:Shame how environmental taxes drive flight away, simply across the border which obviously hurts economic activity in Sweden for benefit of Denmark with zero benefit environmentally.
Actually might be worse as I believe Sweden-LA market is larger than Denmark-LA so the Swedes must now take an additional flight to connect which is likely worse environmentally.
LAXintl wrote:
The new time schedule for the route starting January 13th:
Flight SK931 departs from CPH 09:35 and arrives in Los Angeles 12:15 the same day.
Flight SK932 departs from Los Angeles 14:00 and arrives in CPH 10:10 the day after.
B747forever wrote:Ha, so much for Stockholm being the capital of Scandinavia. With SAS first moving HKG and now LAX + Norwegian cutting their ARN-US network, ARN is back to square one again with only EWR/ORD. Maybe time to shelve the preclearance plans and with dropping pax numbers stop grandiose expansion plans at ARN.
I believe that ARN-LAX O&D is substantially higher than CPH-LAX O&D, but with a weak Swedish krona, flygskam and the aviation tax it makes more sense to move it to CPH where SAS also has a better feeder network. Still a shame ARN is losing the route, but I guess they had it coming.
1h and 45min looks a bit tight for turning around the airplane. Any slight delay on arrival will automatically mean a late departure. The current schedule has a 2hrs turn around which leaves a bit more of wiggle room.
Also interesting that they will change the flight number with the move.
B747forever wrote:1h and 45min looks a bit tight for turning around the airplane. Any slight delay on arrival will automatically mean a late departure. The current schedule has a 2hrs turn around which leaves a bit more of wiggle room.
kanye wrote:It’s interesting how ARN is failing despite being located in the biggest city in the Nordics both population wise and economical. Stockholm has more headquarters of global companies than Helsinki and Copenhagen combined.
MAH4546 wrote:B747forever wrote:Ha, so much for Stockholm being the capital of Scandinavia. With SAS first moving HKG and now LAX + Norwegian cutting their ARN-US network, ARN is back to square one again with only EWR/ORD. Maybe time to shelve the preclearance plans and with dropping pax numbers stop grandiose expansion plans at ARN.
SAS also has MIA-ARN in the winter.
Norwegian still flies FLL-ARN year round and OAK/LAX/JFK-ARN seasonally.
SK931/932 is the same flightnumber as when SAS first opened CPH-LAX back in 1954. So it makes perfect sense for them to reuse it
Someone83 wrote:B747forever wrote:1h and 45min looks a bit tight for turning around the airplane. Any slight delay on arrival will automatically mean a late departure. The current schedule has a 2hrs turn around which leaves a bit more of wiggle room.
However, I do believe there is some slack in the scheduled flight timekanye wrote:It’s interesting how ARN is failing despite being located in the biggest city in the Nordics both population wise and economical. Stockholm has more headquarters of global companies than Helsinki and Copenhagen combined.
But quite a few large international companies have their Nordic HQ in Copenhagen
Cointrin330 wrote:Seems like a lot of long haul from ARN doesn't work or is seasonal at best.
ss278 wrote:And thus history completes the circle. SAS's original polar route in the 1960's was CPH-SEA-LAX operated with a DC-8-50 series aircraft. After the acquisition of the DC-8-62, it was flown CPH-LAX nonstop for several years then LAX was dropped and it was CPH-SEA for a bit until the route was eventually dropped altogether.
Using the same flight numbers as in the old days as well, SK931/932.
Northpole wrote:People living in the Stockholm-area ( the capital of Sweden) fail to understand that there are som 1.5 million Swedes living in southern Sweden, who can take the train or go by car to Copenhagen Airport in 20 Minutes up to 1 hour depending on where You live. So Copenhagen is a large airport not only for Danish people . Furthermore I am of the opinion thet SAS needs to have one strong hub instead of three weak ones... good decision.
kanye wrote:Someone83 wrote:B747forever wrote:1h and 45min looks a bit tight for turning around the airplane. Any slight delay on arrival will automatically mean a late departure. The current schedule has a 2hrs turn around which leaves a bit more of wiggle room.
Quite a few yes, in 2015 it was 41, and 125 in Stockholm which is more than all other Nordic countries combined.
workhorse wrote:These last years, there are so much things that Denmark got right and Sweden got wrong. It's a great country full of great people, but they definitely have to do something about the image they project to the world. Who would want to have a hub in the land of Greta Thunberg?
cedarjet wrote:workhorse wrote:Greta Thunberg is a great example to all of us and all Swedes should be (and are) super proud of her.
NiMar wrote:Greater CPH (including parts of Sweden) is according to wikipedia somewhere north of 3 million. Metro Stockholm is 2.5 million. 100 miles difference on great circle mapper.
ARN wrote:Could the Swedish government give away bilateral trafic rights to Norwegian instead? I know U.S. is open skies but some Asian countries are not.
aemoreira1981 wrote:I understand that SK carries a lot of belly cargo between EWR and all 3 Scandinavian hubs, but what about ORD (to maintain ARN from there)? Is it possible that ARN could lose ORD as well, leaving just EWR?
For whatever reason (flygskam, high taxes, a shrinking/leisure oriented market/a weaker economy+weaker crown) SAS will be inevitably concentrate most if not all of long-haul flying in CPH. There's no way around this. The Scandinavian market is basically composed by three small/medium, highly fragmented markets with fluctuating demand directed in variable numbers to a fairly small number of selected destinations - there's no way that 3 hubs for one airline are going to prove sustainable, save for the large domestic markets served respectively by OSL and ARN. CPH is the de-facto air capital, the one with better geographical location (closer to Europe, and less on the northern fringes), the better infrastructure (already in place), the bigger catchment, the bigger market, the better weather, the better connections.
Jetty wrote:Kiwirob wrote:At a guess the taxes from Sweden is probably also part of the reason for this move??
Sweden is a mess nowadays, with much crime at night and many immigration problems. Makes sense to move this flight elsewhere.
Jetty wrote:Sweden is a mess nowadays, with much crime at night and many immigration problems. Makes sense to move this flight elsewhere.
ei146 wrote:Interesting how much people can read into this. A flight moved to an other airport is a sign that whole nations fall and others prosper?
ARNPEK wrote:Congratulations AY! For every LH flight that moves away from ARN AY gains pax on theirs since HEL is often a lesser back track than CPH if there are no direct connections (planes, trains etc).
SK is caught in the dilemma that they can not have three LH hubs since there isn't enough passengers for it and instead the company has to focus on one airport. CPH is a detour for LH flights for all Scandinavians that do not live in the Öresund region but due infrastructure (ARN is not a good connecting airport) and historical/political reasons CPH is the compromise. However when there are no direct flights from the airport that provides the fastest route to a destination then pax will look at competing 1-stops and price will decide...
ARN and OSL will likely be healthy airports without SK LH routes, since other airlines can and will create direct O/D routes or 1-stop solutions that are more convenient than going via CPH.
