IFlyVeryLittle
Hurricane hunters
Thu Sep 05, 2019 6:21 pm
When a NOAA aircraft flies into (or over) a hurricane for the purposes of data collection, is it still under the control of an enroute center? Presumably, there wouldn't be a lot of traffic around, and I'm not sure how precisely each flight is planned. So I guess I'm asking if turns and changes in altitude require permission. Thanks.
strfyr51
Re: Hurricane hunters
Thu Sep 05, 2019 7:25 pm
No it's not under control of an en route controller as there is no way TO control entering a Hurricane except by experience and best practices. Having flown Into a few hurricanes. they're using the right plane for it in a P3. That's what I flew into and out of ne in and the ride is Hairy! It's all a matter of technique. though I did prefer a Hurricane in the Atlantic to s typhoon in the Pacific and Daylight as opposed to Darkness. It doesn't make a difference to the airplane But Darkness was a damn sight scarier. VW-4 did it in C-130's. which I would think would be a rough ride..
blockski
Thu Sep 05, 2019 7:41 pm
Here's a clip from an old IMAX documentary from 1995, where the pilots are talking with Miami Center a lot as they fly though the storm:
https://www.youtube.com/watch?v=a-SnxC-BkPo
benjjk
Fri Sep 06, 2019 1:29 am
Being in controlled airspace they still need a clearance of some kind, it's just that clearance would be along the lines of "do whatever you want within this block", so not every single turn needs approval. Test flights are often performed in the same way.
QueenoftheSkies
Fri Sep 06, 2019 1:58 am
Enlighten us as to what aircraft are going to be in the airspace of a hurricane? Lol
benjjk
Fri Sep 06, 2019 2:11 am
Not one that I'll be on! I'll leave it to the NOAA guys.
My point is though that they do still need a clearance to conduct their work, even if nobody else is around.
packmedic
Fri Sep 06, 2019 2:14 am
Nobody said aircraft are going to be in the airspace of a hurricane. However on an IFR flight you do still need to be in contact with ATC. They'll give you a block of airspace to do whatever you want in, but you're still in controlled airspace. Just because there's nobody nearby doesn't mean the rules don't apply
A319 A320 A321 A332 A333 A359 A388 AT72 B717 B733 B734 B734C B735 B73G B738 B739 B744 B752 B764 B772 B789 B78X CRJ2 CRJ7 CRJ9 DH8D E135 E140 E145 E170 E175 E190 MD80 MD90
jetmechanicdave
Fri Sep 06, 2019 2:18 am
viewtopic.php?f=10&t=1430345
Here’s another thread on the same topic.
Aircraft Mechanic and Airliners.net Forum Moderator
atcsundevil
Fri Sep 06, 2019 2:35 am
I've never worked a TEAL flight, but they are definitely radar identified, and they operate to and from their mission on an IFR clearance. If they expect to operate above FL180, operate in a warning area, and/or operate in oceanic airspace, they most certainly will be on an IFR clearance.
Aircraft can operate on IFR clearances without necessarily being "under our control" — they can file to a fix, waypoint, fix radial distance, lat/long, etc. and carry out their mission. Whether that be an orbit, circuit, or whatever. ATC gets paperwork on special mission flights, so we don't have a need to control their maneuvers if it's precoordinated. They're simply "delayed" at the fix/waypoint/FRD for the anticipated duration of their mission, then they'll typically return to that point to return to base. To and from that point, they'll obviously be expected to operate on their route at their assigned altitude, but there's significant flexibility while they're performing their mission. This isn't atypical for controllers, because the military regularly perform missions like this, as do photo missions, NASA, air sampling, etc.
It's either worked by a center or possibly other controlling authority. By that, I mean military controllers when operating in warning areas (FACSFAC VACAPES or "Giant Killer" in Virginia Beach, for example). If you read what I wrote above, I describe how these sorts of missions typically work. I haven't worked a TEAL flight, so I don't know the specifics, but these missions typically work in a similar fashion. Essentially, they operate to/from their mission area under ATC clearance, and then perform a precoordinated mission. That can include outlining specific maneuvers, altitude changes, and so forth. They have a wide degree of latitude when performing their mission when it's coordinated ahead of time.
