enilria
OAG Changes 9/8/2019:DL Adds PDX-LAS,SEA-BZN, Shifts NRT to HND;SY Exits PVD;UA Ends CHA-IAD,EWR-DAY/YOW,EGE-IAD
Sun Sep 08, 2019 12:10 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
4B ALS-DEN NOV 3>4[3] DEC 3>4[3]
4O CUN-LAX NOV 0>0.7[1.0] DEC 0>0.5[1.2] JAN 0>0.2[1.0]
7H GAM-OME OCT 1.4>0.9[0.9] NOV 1.4>0.9[0.9] DEC 1.4>0.9[0.9] JAN 1.4>0.9[1.4] FEB 1.4>0.9[1.4] MAR 1.4>0.9[1.4] APR 1.4>0.9[1.4] MAY 1.4>0.9[1.4] JUN 1.4>0.9[1.4]
7H GAM-SVA OCT 1.4>0.9[0.9] NOV 1.4>0.9[0.9] DEC 1.4>0.9[0.9] JAN 1.4>0.9[1.4] FEB 1.4>0.9[1.4] MAR 1.4>0.9[1.4] APR 1.4>0.9[1.4] MAY 1.4>0.9[1.4] JUN 1.4>0.9[1.4]
7H OME-SVA OCT 1.4>0.9[0.9] NOV 1.4>0.9[0.9] DEC 1.4>0.9[0.9] JAN 1.4>0.9[1.4] FEB 1.4>0.9[1.4] MAR 1.4>0.9[1.4] APR 1.4>0.9[1.4] MAY 1.4>0.9[1.4] JUN 1.4>0.9[1.4]
AA CLT-DAB JAN 4>5[4] FEB 4>5[5] MAR 4>5[5] APR 4>5[5] MAY 4>5[4] JUN 4>5[4]
AA CLT-ELH FEB 0.2>0.4[0.1] MAR 0.1>0.6[0.2] APR 0.1>0.6[0.1] MAY 0.2>0.6[0.1] JUN 0.1>0.6[0.2]
AA CLT-PUJ FEB 1.8>1.2[1.8] MAR 2>1.0[2] APR 2>1.0[2] MAY 3>2[3] JUN 3>2[3]
AA DFW-LIR DEC 0.8>0.5[0.5]
AA LGA-MCO JAN 1.1>1.9[1.0] FEB 1.0>2[1.0] MAR 1.0>2[1.0] APR 1.0>2[1.0] MAY 1.0>2[1.0] JUN 1.0>2[1.0]
AA LGA-ORD JAN 13>12[12] FEB 13>12[14] MAR 14>12[13] APR 14>13[14] MAY 13>12[12] JUN 14>13[12]
AA MGA-MIA JAN 3>1.8[3] FEB 3>2[3] MAR 3>2[3]
AA MIA-SNU JAN 1.8>1.0[1.1] FEB 2>1.0[1.0] MAR 1.9>1.0[1.0] JUN 1.9>1.0[1.8]
AA ORD-SMF DEC 1.1>1.5[1.0]
AA PHX-PVR JAN 2>1.5[2]
AA PHX-SJO JAN 0.5>1.0[0.5] FEB 0.8>1.0[0.8]
AM GDL-SFO FEB 0.9>0.4[0.9] MAR 0.8>0.4[0.9] APR 0.9>0.4[0.8] MAY 0.9>0.4[0.9]
AS ANC-DUT JAN 2>4[3]
AS ANC-RDB NOV 0.1>0.5[0.3] DEC 0.0>0.4[0.3]
*AS PDX-SBP JUN 0>0.4[0]
*AS SAN-SBP JAN 0>0.8[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
AS SFO-SNA NOV 6>7[5] DEC 6>7[5]
B0 EWR-NCE JUN 0>0.5[0.7]
DL ATL-CID FEB 1.7>2[2]
*DL ATL-HND APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
*DL ATL-NRT APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
DL ATL-PVR JAN 1.1>0.9[1.0] FEB 1.2>0.9[1.1]
Now not just weekends in peak
**DL BZN-SEA JAN 0.4>1.9[0.1] FEB 0.3>2[0] MAR 0.3>2[0.2] APR 0>1.9[0] MAY 0>1.8[0] JUN 0.0>1.9[0.0]
DL CMH-DTW MAR 6>7[6] APR 6>7[6]
DL CMH-RDU FEB 0.8>0.6[0.8]
DL DTW-FLL MAR 6>7[6] APR 5>6[4]
*DL DTW-HND APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
DL DTW-MBJ APR 1.1>0.8[0.1]
*DL DTW-NRT APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
DL FLL-RDU DEC 1.3>1.6[1.3]
DL GTF-MSP DEC 1.3>1.0[1.3]
*DL HND-HNL APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
*DL HND-PDX APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
*DL HND-SEA APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
*DL HNL-NRT APR 1.0>0[1.1] MAY 1.0>0[1.1] JUN 1.0>0[1.0]
*DL ISN-MSP OCT 2>0.6[2] NOV 1.9>0[1.9] DEC 1.9>0[1.9] JAN 1.9>0[1.9] FEB 1.9>0[1.9] MAR 2>0[2] APR 2>0[2] MAY 3>0[2] JUN 3>0[3]
Shortening the season
*DL JFK-KEF MAR 0.6>0[0.6]
**DL LAS-PDX APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
DL MSN-MSP FEB 4>5[5] MAR 5>6[5]
*DL MSP-XWA OCT 0>1.4[0] NOV 0>1.9[0] DEC 0>1.9[0] JAN 0>1.9[0] FEB 0>1.9[0] MAR 0>2[0] APR 0>2[0] MAY 0>3[0] JUN 0>3[0]
*DL NRT-PDX APR 1.0>0[0.7] MAY 1.0>0[0.8] JUN 1.0>0[1.0]
*DL NRT-SEA APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
DL PHL-SLC MAR 1.4>1.0[1.0]
DL SEA-SJC JAN 4>5[4] FEB 4>5[4] MAR 5>6[4] APR 5>6[4] MAY 5>6[5]
OB MIA-VVI DEC 0.6>1.0[0.8] JAN 0.6>1.0[0.8] FEB 0.6>1.0[0.9] MAR 0.6>1.0[0.6] APR 0.6>1.0[0.6] MAY 0.6>1.0[0.6] JUN 0.6>1.0[0.6]
OZ ICN-SEA NOV 1.0>0.7[0.7] DEC 1.0>0.7[0.7] JAN 1.0>0.7[0.7] FEB 1.0>0.7[0.7] MAR 1.0>0.7[0.7]
SK ARN-LAX JAN 0.9>0.4[0.8] FEB 0.9>0[0.9] MAR 0.8>0[0.9] APR 0.9>0[0.8] MAY 0.9>0[0.9] JUN 0.8>0[0.9]
SK CPH-LAX JAN 0>0.5[0] FEB 0>0.9[0] MAR 0>0.9[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
PVD focus city didn't pan out. No flights are left it appears.
*SY BNA-PVD NOV 0.7>0[0] DEC 0.5>0[0] JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0]
SY DEN-MSP DEC 0.6>1.0[0]
*SY EWR-MSP JAN 0.1>0.6[0] FEB 0>0.6[0] MAR 0>0.5[0]
*SY LAS-PVD NOV 0.3>0[0] DEC 0.2>0[0] JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0]
SY MSP-PUJ JAN 0.9>0.5[0.9] FEB 1.5>0.8[1.5] APR 0.8>0.1[0.7]
*SY MSP-PVD NOV 0.7>0[0] DEC 0.6>0[0]
SY MSP-SJD JAN 0.1>0.3[0.3]
SY MSP-SMF DEC 0.5>0.6[0]
*SY MSY-PVD NOV 0.3>0[0] DEC 0.3>0[0] JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0]
TOM BHX-SFB MAY 0>0.3[0.2] JUN 0>0.2[0.1]
TOM GLA-SFB JUN 0>0.2[0.1]
*UA CAE-IAH OCT 0.7>0[1.0] NOV 1.0>0[1.0] DEC 0.9>0[1.0] JAN 0.9>0[1.0] FEB 0.8>0[1.0]
*UA CHA-IAD DEC 1.6>0.2[1.6] JAN 1.8>0[1.7] FEB 2>0[1.9] MAR 2>0[2] APR 2>0[2] MAY 2>0[2] JUN 2>0[2]
UA CHA-ORD DEC 3>4[3] JAN 3>4[3] FEB 2>3[3] MAR 3>4[3] APR 3>4[3] MAY 3>4[1.9] JUN 3>4[1.9]
*UA DAY-EWR APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
UA DAY-IAD APR 2>3[2.0] MAY 2>3[2] JUN 2>3[1.9]
*UA EGE-IAD DEC 0.4>0[0.4] JAN 0.3>0[0.3] MAR 0.8>0[0.8]
*UA EWR-YOW MAR 2>0.2[1.9] APR 2>0[2] MAY 2>0[2.0] JUN 2>0[3]
UA FAI-ORD MAY 1.0>0.8[1.0]
UA ILM-ORD JAN 1.0>0.1[1.2] FEB 0.4>0[1.0]
MAX Cuts rolled forward
WN ATL-BNA DEC 4>3[4]
WN ATL-BOS DEC 1.1>0.6[2.0]
WN ATL-RSW DEC 1.7>1.3[1.6]
WN AUS-EWR DEC 1.7>1.1[1.6]
WN AUS-RDU DEC 0.9>0.5[0]
WN AUS-SFO DEC 0.8>0.4[0.9]
WN BHM-BWI DEC 1.6>1.9[1.5]
WN BHM-LAS DEC 1.0>0.5[1.0]
WN BNA-BUR DEC 1.0>0.5[0]
WN BNA-CHS DEC 1.4>1.8[1.2]
WN BNA-EWR DEC 3>1.3[0]
WN BNA-MKE DEC 1.6>1.3[1.7]
WN BOI-GEG DEC 1.6>1.3[1.7]
WN BOI-PHX DEC 1.4>1.8[1.3]
WN BOI-SMF DEC 1.4>1.8[1.4]
WN BOS-CMH DEC 1.0>1.4[1.3]
WN BOS-DAL DEC 1.2>1.5[1.0]
WN BOS-MCI DEC 0.9>0.5[1.0]
WN BOS-MKE DEC 0.6>0.9[1.2]
WN BUF-TPA DEC 1.5>1.8[1.4]
WN BUR-DAL DEC 1.3>1.7[1.0]
WN BUR-SLC DEC 0.9>0.5[1.0]
WN BUR-SMF DEC 10>8[8]
WN BWI-EWR DEC 1.8>0.9[0]
WN BWI-MEM DEC 1.6>1.9[1.3]
WN BWI-OAK DEC 1.3>1.7[1.3]
WN BWI-SEA DEC 0.6>0.9[0.9]
WN BWI-SJC DEC 0.6>0.9[0.9]
WN CHS-DEN DEC 0.5>0.8[0.4]
WN CLE-PHX DEC 1.0>0.6[1.1]
WN CMH-DAL DEC 1.5>1.8[1.3]
WN CMH-DEN DEC 1.4>1.7[1.3]
WN CMH-FLL DEC 1.5>1.9[1.6]
WN CMH-OAK DEC 0.6>0.9[0.4]
WN CMH-RSW DEC 1.9>3[2]
WN CMH-TPA DEC 3>4[3]
WN DAL-DTW DEC 1.3>1.6[1.0]
WN DAL-HOU DEC 17>16[17]
WN DAL-IND DEC 1.5>1.9[1.5]
WN DAL-OMA DEC 1.5>1.8[1.3]
WN DAL-PIT DEC 1.3>1.7[1.1]
WN DAL-RDU DEC 1.3>1.7[1.2]
WN DAL-SAT DEC 8>7[8]
WN DEN-EWR DEC 1.8>0.9[1.9]
WN DEN-LAS DEC 8>7[8]
WN DTW-PHX DEC 1.0>0.5[1.0]
WN EWR-MDW DEC 5>2[5]
WN EWR-PHX DEC 0.9>0.5[1.0]
WN EWR-STL DEC 1.8>0.9[1.9]
WN FLL-ISP DEC 1.3>1.6[1.4]
WN FLL-LAS DEC 0.7>1.0[0.5]
WN FLL-PIT DEC 1.6>2.0[1.4]
WN GEG-SJC DEC 1.0>0.6[1.0]
WN GEG-SMF DEC 1.3>1.6[1.2]
WN HOU-PHL DEC 0.9>0.5[0.1]
WN HOU-RDU DEC 1.4>1.8[1.3]
WN HOU-SLC DEC 1.0>0.5[1.0]
WN HOU-SMF DEC 1.0>0.5[0.1]
WN IND-OAK DEC 0.3>0.6[0.9]
WN IND-RSW DEC 1.8>2[2]
WN IND-TPA DEC 2>3[2]
WN ISP-TPA DEC 1.5>1.8[1.3]
WN LAS-MAF DEC 1.4>1.8[1.3]
WN LAS-MCO DEC 1.6>1.3[1.8]
WN LAS-MDW DEC 7>6[7]
WN LAS-OMA DEC 1.6>1.9[2]
WN LAS-PDX DEC 4>3[4]
WN LAS-PHX DEC 9>7[9]
WN LAS-SAN DEC 8>7[9]
WN LAS-TUL DEC 1.4>1.8[1.2]
WN LAX-OMA DEC 0.9>0.5[0.9]
WN LAX-PDX DEC 1.8>1.4[2]
WN LAX-TPA DEC 0.9>0.5[1.0]
WN LIT-PHX DEC 0.9>0.5[0.9]
WN MCI-MKE DEC 1.7>1.4[1.6]
WN MCI-PDX DEC 0.3>0.7[0.9]
WN MCI-RDU DEC 0.9>0.6[1.0]
WN MCI-STL DEC 3>2[3]
WN MCO-MEM DEC 1.6>2.0[1.5]
WN MCO-OAK DEC 0.6>0.9[0.9]
WN MCO-SAT DEC 1.6>2.0[1.5]
WN MCO-SDF DEC 1.5>1.9[1.5]
WN MCO-SJC DEC 0.6>0.9[0.9]
WN MCO-SMF DEC 0.6>0.9[1.0]
WN MDW-MHT DEC 1.4>1.7[2]
WN MDW-OKC DEC 1.4>1.8[1.2]
WN MDW-ORF DEC 1.5>1.8[1.5]
WN MDW-PDX DEC 2.0>1.5[2.0]
WN MDW-PVD DEC 1.6>2.0[2]
WN MDW-SJC DEC 1.4>1.7[1.5]
WN MDW-SLC DEC 1.8>2[2]
WN MKE-RSW DEC 1.3>1.7[1.3]
WN MSY-OAK DEC 0.6>0.9[1.0]
WN MSY-PHX DEC 1.6>1.2[1.6]
WN MSY-SAN DEC 0.6>0.9[1.0]
WN ONT-PHX DEC 6>5[6]
WN PHL-TPA DEC 1.8>2[2.0]
WN PHX-SAN DEC 10>9[10]
WN PHX-TUL DEC 1.6>1.9[1.6]
WN PIT-RSW DEC 1.3>1.7[1.2]
WN PVD-TPA DEC 1.5>1.8[1.4]
WN RNO-SJC DEC 1.6>1.2[1.6]
WN ROC-TPA DEC 0.5>0.9[1.0]
WN RSW-STL DEC 1.8>2[1.9]
WS BOS-YYZ OCT 3>2[3] NOV 3>1.9[3] DEC 3>2[3] JAN 3>2.0[3] FEB 3>2[3] MAR 3>2[3] APR 3>2[3]
WS HNL-YVR DEC 1.9>2[2]
WS HNL-YYC DEC 0.3>0[0.2]
WS LAS-YWG NOV 0.3>0.0[0.3] DEC 0.3>0[0.3]
WS OGG-YEG DEC 0.2>0[0.3]
WS OGG-YYC DEC 0.7>0.5[1.0]
WS PHX-YQR NOV 0.3>0.0[0.4] DEC 0.4>0[0.5]
WS PHX-YWG NOV 0.3>0.1[0.6] DEC 0.3>0[0.5]
WS PHX-YXE NOV 0.3>0.0[0.4] DEC 0.4>0[0.4]
WS PHX-YYZ NOV 0.4>0.1[0.6] DEC 0.4>0[0.5]
Cointrin330
Re: OAG Changes 9/8/2019:DL Adds PDX-LAS,SEA-BZN, Shifts NRT to HND;SY Exits PVD;UA Ends CHA-IAD,EWR-DAY/YOW,EGE-IAD
Sun Sep 08, 2019 12:28 pm
Wow, no AA JFK cuts in this round.
BA744PHX
Thanks for the weekly update, this is very odd all these route are flying from October 27 - November 3rd than cut until January. I assume this is an error?
RL757PVD
Sun Sep 08, 2019 12:31 pm
There’s an article that references a seasonal suspension of PVD. I heard the summer flights did well and they are short on aircraft this winter so we will have to see when they extend their schedule next if things are back or not.
Experience is what you get when what you thought would work out didn't!
tomaheath
Sun Sep 08, 2019 12:46 pm
I thought I had read an article about how some were going well with others not so much. https://www.providencejournal.com/news/ ... Dqblllbs_M
pmanni1
Sun Sep 08, 2019 12:55 pm
This was started a year ago with 5 flights a day. Already dwindled down to 3.
BlatantEcho
Sun Sep 08, 2019 1:18 pm
PDX-LAS on Delta. That’s pretty strange.
Non hub route. And isn’t sun country starting this?
Wonder where that came from.
tphuang
Sun Sep 08, 2019 1:23 pm
Good morning and thanks enilria!
interesting move here of reducing on a shuttle route to add capacity on MCO. Guess this is result of cutting JFK-MCO.
Not sure why AA is reducing frequencies on these important northeastern shuttles
PDX is looking to me more and more like a focus city vs places like SJC/BNA. As I've said before, if DL really wants to catch up to AS at SEA, it needs to start attacking PDX.
leaving this to AC maybe?
this is really weak. At this rate, AC will be chasing them out of BOS.
tphuang
Sun Sep 08, 2019 1:24 pm
that's called cuts during holiday season. Everyone does it.
MIflyer12
Sun Sep 08, 2019 1:31 pm
PDX boosters want more flights. You can't assume they'll all be by AS. There are four AS A320s making the trip tomorrow. There's not so much logical connectivity xxx-PDX-LAS as to think it's not primarily O&D. LAS is a very large O&D market; DL has other non-hub flights, including half a dozen destinations in California.
pmanni1
Sun Sep 08, 2019 1:38 pm
DL is the only competition on this route and they aren't doing any holiday cuts. Still 10x daily in December.
CarlosSi
Sun Sep 08, 2019 1:48 pm
Wuuut, but PDX ain’t no focus city!
*trikert*
They really should be though. Delta’s logic is absurd. I don’t mean to stir the pot here :stir:
tphuang
Sun Sep 08, 2019 1:50 pm
Just take a look At January, it's back to 5x. I don't know what the big deal is. DL runs 12 or 13x during other month. Everyone cuts these types of routes around holiday season.
sprxUSA
Sun Sep 08, 2019 1:52 pm
Why the * for ISN-MSP? Just switching to new airport (XWA) like UA last week. Nothing interesting about that.
Gem State Airlines..."we have a gem of an airline"
ericm2031
Sun Sep 08, 2019 1:54 pm
SY already flies it. F9 is starting in November. Delta will be the 6th carrier (AS/DL/F9/WN/NK/SY).
EvanWSFO
Sun Sep 08, 2019 1:56 pm
Perhaps someone missed last week's discussion on this new code?
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
ANA787
Sun Sep 08, 2019 1:58 pm
The new LAS flights connect perfectly to/from the new PDX-HND flights. In fact it seems Delta is prioritizing this connection flight- when doing a dummy booking, LAS-PDX-HND-PDX-LAS always comes up first. I wouldn’t be surprised to see DL add additional flights at PDX to support the HND flights- possibly SAN, SJC, SFO, PHX, ANC.
sunking737
Sun Sep 08, 2019 1:59 pm
SY will have a smaller fleet this winter. They are retiring the -700. Replacement -800 are not coming online like they had planned due to the airline they are coming from have not received the MAX replacements. They are only getting 2 HV birds this year too. They will have 28 vs 32/34 like they thought
"Don't believe it unless its parked on the ramp, or printed in the schedule...SUBJECT TO CHANGE"
I'm a SUNDUCK......Worked for RC & SY @ MSP
maps4ltd
Sun Sep 08, 2019 2:10 pm
In the same vein as LAS-LGB, LAS-SAN, LAS-SNA, and LAS-SEA. DL's built up a nice little west coast operation.
Next flights:
AA1003 STL-ORD Airbus A319 November 25
AA3170 ORD-ASE Bombardier CRJ-700 November 25
AA3247 ASE-ORD Bombardier CRJ-700 November 29
AA1960 ORD-STL Airbus A319 November 29
phllax
Sun Sep 08, 2019 2:55 pm
They are ending SNA-LAS due to the annual slot re-allocation, so this just shifts the airplanes to another close market.
Dominion301
Sun Sep 08, 2019 3:19 pm
Doubt it. More MAX-related cuts. Several routes have been cut one month and back the next. WS were late to the cancel MAX flying until 2020 party. This is the result.
Indeed, leaving YOW-EWR solely to AC. Still, that’s -2/day frequency = -40% capacity change, ouch! I doubt AC will add a frequency or upgauge to a CR9 either. So right when UA will be bringing back YOW-ORD, they drop EWR. YOW can’t catch a break. I guess this is another example of consumers benefiting from JVs. :lol:
DLASFlyer
Sun Sep 08, 2019 3:39 pm
UA tried and failed a couple years ago with IAD-JAC so the IAD-EGE cut is not too surprising.
COflyerBOS
Sun Sep 08, 2019 3:41 pm
Another Southern city cut at IAH by United after years of service. I know lots of folks with USC connections who aren’t going to be thrilled.
Planeboy17
Sun Sep 08, 2019 3:49 pm
Thank you all for these informative posts. This is why I still enjoy this website so much, when informed people post factual information without prejudice that helps to clarify questions like these that are brought up.
It’s reaffirming to know that there are many people on this site who are not just well informed but can deliver it a rather objective and non combative way.
SANFan
Sun Sep 08, 2019 4:20 pm
Re: PDX-LAS on DL adds.
IMO, PDX is just late to the LAS-party. As others have posted, several w/c cities already have Vegas service on DL; e.g., SAN-LAS began Dec 2016 with 3 daily r/t and now we see ~4.
I doubt it has anything to do with turning PDX into a focus city or a major TYO connecting point. Just adding some service in a large O&D market, similar to several other cities already seeing the service.
bb
Rdh3e
Sun Sep 08, 2019 4:53 pm
It's MAX cuts. January is at 5 because they haven't cut the MAX from the schedule yet.
sprxUSA
Sun Sep 08, 2019 5:03 pm
Well the same people that saw last week are probably same ones always looking at this, so I am sure they saw the various XWA notes and comments then. Additionally, odd ISN end was an *, but XWA add was not LOL.
Great to see all of this info each week, and certainly glad Enrila compiles it as well! Makes my day and almost the only useful posts on here these days.
enilria
Sun Sep 08, 2019 5:04 pm
[twoid][/twoid]
It is what they filed. All I know.
enilria
Sun Sep 08, 2019 5:05 pm
Same thought. I guess FFP burn destination needed to build loyalty.
enilria
Sun Sep 08, 2019 5:07 pm
Switching airports isn’t a big deal? I’d say it is a huge deal.
enilria
Sun Sep 08, 2019 5:10 pm
<eye roll> it’s a new airport. I can spare them an *. If B6 switched from ORD to MDW that’s def an *.
kavok
Sun Sep 08, 2019 5:12 pm
Agreed. We have several threads about airlines switching from NRT to HND, so some definitely find the switching of airports interesting. I doubt anyone is questioning the starred DL switches from NRT to HND this week in this week’s list.
Cubsrule
Sun Sep 08, 2019 5:17 pm
Indeed, but the larger point holds: until the MAX situation is resolved, it’s tough to read too much into the cuts.
Cactusjuba
Sun Sep 08, 2019 5:19 pm
Don't forget LAS-SJC too.
steex
Sun Sep 08, 2019 5:25 pm
I can see both sides of this one. Switching from NRT to HND is a commercial decision that was made by the airlines with a competitive process, so finally knowing the results/schedules of this is definitely news. The entire process provides some insight into the airlines' strategies, and I think that window is what people find most interesting for this thread.
The switch from ISN to XWA is also interesting in that new airports are interesting, but we're not seeing any commercial route decisions made as a result at this point - one airport closes and the other opens, so it's really just a transfer of ALL flights. It's not as though some flights are staying at ISN and the switch indicates anything about strategy.
Ultimately, though, I don't see how the inclusion or exclusion of "*" matters at all for any route - no two people will ever universally agree on what is interesting and enilria is marking what he finds interesting, not what he we thinks everyone else will definitely find interesting.
airtechy
Sun Sep 08, 2019 5:28 pm
So after all the NRT > HND shifts, will Delta have any flights into NRT? Hope they have as good a Sky Club at HND as the one at NRT.
N649DL
Sun Sep 08, 2019 5:30 pm
Not terribly surprising considering DL is flying LAS-SJC/SAN/SNA already. I think this is just for regional demand to go to LAS only, especially with DL flying LGB-LAS starting next month.
Odd I just checked wiki and I'm surprised RDU-LAS is only seasonal considering it's a focus city.
braniff2hav
Sun Sep 08, 2019 6:00 pm
Funny SY, just launched PVD-MSY I think this week ... I'd think it would do well here for the S. Louisiana peak season.
jetlanta
Sun Sep 08, 2019 6:21 pm
*trikert*
Delta's logic is perfectly fine. You just don't understand THEIR definition of a focus city. FYI..the largest unnerved market from Las Vegas is Tokyo. And Delta no longer has connections beyond Tokyo for the PDX flight. So...
Midwestindy
Sun Sep 08, 2019 6:43 pm
RDU-LAS is only just now starting in January, so I don't know if it is actually seasonal, I presume it will be year-round
jetlanta wrote:
*trikert*
bb
*trikert*
I think this has more to do with LAS than PDX......... In the past year DL/KL have added/announced PDX, LGB, RDU, and AMS from LAS, in addition to added frequencies on other routes. Looks like they are building up LAS and serving almost every major market on the west coast: SEA, PDX, LGB, SNA, LAX, SLC, SJC, SAN, and maybe more to come...
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
DeltaRules
Sun Sep 08, 2019 6:48 pm
Can anyone see the equipment that's listed on DAY-IAD after EWR is dropped? That route had a Dash 8 on it at one point not too long ago, but is running with an E75 and a CRJ right now.
A310/319/320/321/333, ARJ, BN2, B717/722/73S/733/734/735/73G/738/739/744/757/753/767/763/764/777, CR1/2/7/9, DH6, 328, EM2/ERJ/E70/E75/E90, F28/100, J31, L10/12/15, DC9/D93/D94/D95/M80/M88/M90/D10, SF3, SST
Jet-lagged
Sun Sep 08, 2019 7:10 pm
Even though we knew it was coming and Delta’s presence in Tokyo is less than it used to be, IMHO their switching routes from NRT to HND is a big deal and rates an asterisk.
Some years back two of Narita’s old fashioned circular terminals would be surrounded by UAL and NW and then Delta planes. At one time quads and tri-jets. From the observation deck an aviation sight to behold. No Delta at Narita marks the end of an era.
Jshank83
Sun Sep 08, 2019 7:15 pm
This has to be a misfile right?[
RWA380
Sun Sep 08, 2019 7:28 pm
DL is offering two OO operated E-175's on this route, up against mainline on every other carrier. The only market from PDX with 2 ULCC's & six carriers, very interesting & lots of O/D.
707 717 720 727-1/2 737-1/2/3/4/5/6/7/8/9 747-1/2/3/4 757-2/3 767-2/3/4 777-2/3 DC8 DC9 MD80/2/7/8 D10-1/3/4 M11 L10-1/2/5 A300/310/320
AA AC AQ AS BA BD BN CO CS DL EA EZ HA HG HP KL KN MP MW NK NW OZ PA PS QX RC RH RW SA TG TW UA US VS WA WC WN WP YS 8M
tphuang
Sun Sep 08, 2019 7:36 pm
I disagree. LAS is a huge bloodbath between WN and NK going forward. I really don't see DL getting involved in that. i see this as DL is positioning itself as the legacy airline of choice in the west coast. And serving a major O&D like LAS is a great way to serve its ff.
Midwestindy
Sun Sep 08, 2019 7:56 pm
tphuang wrote:
I disagree. LAS is a huge bloodbath between WN and NK going forward. I really don't see DL getting involved in that. I see this as DL is positioning itself as the legacy airline of choice in the west coast. And serving a major O&D like LAS is a great way to serve its ff.
How is what I am saying different from that?
peak86
Sun Sep 08, 2019 7:57 pm
It isn't just WN/NK... it's F9, SY, of course G4, and now DL looks like they're getting wrapped up in this. Obviously there's a ton of demand to/from LAS, but it'll be interesting to see how any potential economic downturn impacts that the next time around... last time, Vegas turned into a ghost town
lavalampluva
Sun Sep 08, 2019 7:58 pm
If MSP-PVD was successful I wouldn’t be surprised if DL didn’t pick it up.
Remind me to send a thank you note to Mr. Boeing.
AVLAirlineFreq
Sun Sep 08, 2019 8:03 pm
The CAE-IAH cut is really close in. Weird. Misfile?
And is the ILM-ORD cut permanent, or just going seasonal?
Rdh3e
Sun Sep 08, 2019 9:00 pm
It appears they loaded the flights but have zero's out inventory on them. They are not selling seats. The lack of clarity and poor accuracy of their schedules makes one wonder if they had an intern doing the MAX reductions...
