jmc1975
Can existing 737MAX airframes be deMAXed?
Sat Sep 14, 2019 5:27 am
Let's assume for a moment that we see a scenario where the 737MAX is not re-certified for airworthiness and is determined to have an inherent design flaw. What would then become of the 200+ existing 737MAX airframes around the world? Would it be financially viable to convert MAX airframes back to 737NGs? Since the 737NG has been a reliable workhorse for 2 decades, Boeing could continue to build 737NGs for its customers, putting its MAX problems behind it, all while investing in R&D for a clean-sheet 737/757 replacement.
flyingclrs727
Re: Can existing 737MAX airframes be deMAXed?
Sat Sep 14, 2019 5:29 am
No!
jmc1975
Sat Sep 14, 2019 5:33 am
flyingclrs727 wrote:
No!
Fascinating insight. Would all of the airframes have to be scrapped?
SanDiegoLover
Sat Sep 14, 2019 5:34 am
No. Boeing will get the 737Max flying one way or the other, period. Why? Because it has to. There is no other way forward, in any real world scenario otherwise. I said the same thing to doubters when the A380 was having massive problems, and again when the 787 was having its well documented fiasco going on.
Andy33
Sat Sep 14, 2019 5:40 am
I suppose you could remove the wings, fit 737NG wings instead with 737NG engine mountings and engines, and then you've got a slightly updated 737NG. But the cost of doing it would be astronomical, it might well be cheaper to build a new plane and use as many parts as can be recovered from MAXs that have not flown in service at all or flown minimal hours. I can't see either happening.
hic787
Sat Sep 14, 2019 5:42 am
The NG and the Max have heaps of subtle differences - so de-maxxing would just not be viable or possible really. In the minuscule chance they never fly again, they'll be scrapped.
flyingclrs727
Sat Sep 14, 2019 5:44 am
No!
Well the whole point of the MAX was the new engines. The size of the engines necessitated the MCAS system. Replacing the engines would require recertifying it with different engines that would be less efficient. The real question is how soon will the world's aviation regulatory agencies recertify the MAX so it can start flying again. It will be fixed.
questions
Sat Sep 14, 2019 6:26 am
No!
Pet peeve. :roll:
DocLightning
Sat Sep 14, 2019 6:36 am
CFM is not planning on producing the CFM56-7b much longer because it will be replaced by the LEAP-1B. Also, this aircraft would be utterly uncompetitive against the A320NEO and no amount of financial compensation from Boeing for additional fuel costs could make up for the fact that it can't cross the Atlantic.
In the extremely unlikely event that the 737-MAX is found to be truly unrecertifiable with no remedy to its deficiencies and Boeing has to scrap the program, all of the existing frames will need to be scrapped. Their engines will not be of use on any other type, real or conceptual, because their design is somewhat suboptimal to begin with. Boeing would then face the prospect of having to develop an NSA from nothing, during which Airbus would be raking in huge amounts of money from the NEO and forced to ramp up production to absurd levels to cover the demand.
-Doc Lightning-
-Carl Sagan
strfyr51
Sat Sep 14, 2019 6:49 am
It would be extensive But they would need to remove the engine Pylons and replace them with the Previous Pylon and engine combination. Boeing really needs to just re-design the 737 with a taller Main gear to accommodate the engine they Have. The 737 was designed around the JT8D and the design is Dated at best.
Siren
Sat Sep 14, 2019 6:58 am
They *did* redesign the landing gear for the MAX - they all have a taller nose gear to accommodate the engine, and Boeing is working on an articulated main gear for the MAX10... DocLightning is absolutely correct in that - it would be nearly impossible to 'deMAX' a MAX... if the plane is truly uncertifiable, they will need to scrap the aircraft. That said, it'll never happen - the planes will be certified again - it is just a matter of time, and a matter of how much engineering changes will need to be done to the already completed frames. I have a strong suspicion that the software package will be the definitive fix, and the aircraft will then quickly go into service.
There are just too many changes up and down the frame for them to simply bolt on new pylons and CFM56s. It could be done - at an astronomical cost probably equaling the cost to build an entirely new frame from scratch, but why modify if the costs are that high? I could see it being done to 'save face', but this is so far into the realm of unlikely, I just can't see it. Mark my words: the MAX will be back in service by this time next year... it must be, or we're looking at a catastrophe that will likely bring down the company, or at least require it to get a government bailout to save it.
kabq737
Sat Sep 14, 2019 7:30 am
This has been discussed multiple times in multiple places. The thread will be locked for housekeeping purposes.
Been on: 320, 321, 333, 733, 73G, 738, 739, 744, 752, 763, 764, 772, 789, C208, CR7, CR9, BE20, MD83, MD88, MD90, E70, E75, E90, TRIM
Flown: SEEKER, C150M C172N, C172R, C172S, C182RG, DA40, PA-46
Airliners.net Forum Moderator
uta999
If the MAX doesn’t fly again, Airbus would take over Boeing and they would build the NEO.
That’s not going to happen, so the MAX needs to be fixed.
Your computer just got better
uta999
