777Mech
WN2574 diverts to MGE (Dobbins ARB, GA)
Wed Sep 18, 2019 4:16 am
Any info? I don't think there's any facilities there to handle pax.
I know ATL had weather, but surely they had better alternates.
WN732
Re: WN2574 diverts to MGE (Dobbins ARB, GA)
Wed Sep 18, 2019 4:25 am
Perhaps this was more of a fuel situation. Or the possibility that they would run into the same conditions at the published alternate. And I am sure that everyone and their mother would be heading to the same alternates.
usflyguy
Wed Sep 18, 2019 4:34 am
They landed. Passengers disembarked. Passengers bussed the 25 mins to ATL. If you look at a tracking website, you’ll see it circled ATL half a dozen times. Divert to a further airport, wait, and potentially cancel or divert close by that is easily with a quick drive. Hmmmmm...
My post is my ideas and my opinions only, I do not represent the ideas or opinions of anyone else or company.
ilovelamp
Wed Sep 18, 2019 4:54 am
ATL had an unforecast TS about 2100-2200. Many flights airborne without alternate fuel. CHA got slammed with mainline Delta diversions.
alasizon
Wed Sep 18, 2019 5:07 am
If they that easily had a bus available and ready to go for passengers, then this is likely a playbook procedure/plan for WN in ATL to help with operational recovery and they chose to execute it rather than diverting farther away and possibly running the risk of not being able to get the pax to ATL same day.
777Mech
Wed Sep 18, 2019 5:33 am
There's a question of who does the ground handling and fueling for them. There is no FBO, only Lockheed Martin and the Air Force are there.
Varsity1
Wed Sep 18, 2019 12:57 pm
They can drive a fuel truck from an FBO at a nearby airport.
The Air Force will also refuel with the right release of liability and fees. It's common for diversions to places like Thule. It's really expensive unless you're flying on a government control like K4 or GTI do.
MIflyer12
Wed Sep 18, 2019 2:15 pm
Says the armchair dispatcher/PIC...completely unproductive comment. You have no idea what was going on up there.
Better is subjective - and open to judgement at the time even by dispatchers.
It's fair to say that ATL diversions to Robbins ARB are less common than CHA/BHM/MGM/GSP, is it not?
GalaxyFlyer
Wed Sep 18, 2019 2:16 pm
Almost certainly, the airlines have arrangements made for support at bases. Most bases have a stair truck or two, fueling is easy.
GF
sprxUSA
Wed Sep 18, 2019 2:18 pm
Probably get the same ground support as a charter into/out of a military base.
Gem State Airlines..."we have a gem of an airline"
Oilman
Wed Sep 18, 2019 2:37 pm
I’ve lived in Atlanta for a long time and have never heard of a diversion to Robbins. Their fuel situation must have been very tight. There’s irony here, too. I bet there were a handful of people on the plane who live in Northwest Atlanta. A lot of folks would like regular commercial service there, too.
Edited because I can’t spell
jayspilot
Wed Sep 18, 2019 2:38 pm
This must have been a stressful event for the flight crew and I would be very curious to see the fuel remaining onboard after landing.
They look to have done 3 approaches (two at atl for different runways and one at Dobbins) before actually landing the Jet on the ground on the 4th one from the number of circles on the flightaware report. that's a lot of low level fuel burn.
glad all worked out
Oilman
Wed Sep 18, 2019 2:43 pm
Does anyone know where the plane is now? Flightaware and Flightradar24 don’t show N743SW departing MGE. It also looks like Southwest flew an extra section (WN9016) to cover the next leg, ATL-MCO, instead of WN2574.
Edited because I still can’t spell.
jayspilot
Wed Sep 18, 2019 2:44 pm
also with regards to CHA diversions, I count 12 mainline DL.. those fueling delays look like they were 3 hours long.
commpilot
Wed Sep 18, 2019 2:52 pm
For the amount of DOD flying SWA does on a near daily basis, it is probably very easy to have gotten services in such a non standard diversion.
capitalflyer
Wed Sep 18, 2019 3:08 pm
Looking at Flightaware, looks like it is expected in MCI for an evening flight to DEN. FR24 shows it on the ground at Dobbins still. Crew may have timed out so couldn't wait and move the aircraft to ATL later. I assume they will bus a crew over from ATL later to take it to MCI? Interesting they can afford to leave an aircraft sitting all day.
GalaxyFlyer
Wed Sep 18, 2019 4:23 pm
It’s DOBBINS ARB, Robins AFB (with one B) is near Macon.
GF
capitalflyer
Wed Sep 18, 2019 4:27 pm
FR24 has it heading to ATL in the next few minutes.
drdisque
Wed Sep 18, 2019 6:00 pm
Interestingly, MCN took zero diversions last night and AGS only took 2 (that may have been all they had the ramp space to handle).
ScottB
Wed Sep 18, 2019 6:24 pm
WN does quite a few military charters in the overnight hours so there's a decent shot their dispatchers are familiar with MGE. And their nearest station is BHM which no doubt was already pretty busy. Diverting to MGE was probably no more disruptive than going to an airport they don't serve which would have had dozens of DL aircraft on the ground waiting for ATL to reopen.
flyXJT
Wed Sep 18, 2019 6:27 pm
Its not exactly as easy as that. Nearly all into-plane fuel providers and FBO fuel trucks aren't registered for road use, nor do the employees have CDLs to operate a truck full of gas over the road.
It is far more likely that they got fuel from MGE and WN will get it paid on the back end.
litz
Wed Sep 18, 2019 6:38 pm
Dobbins is in Marietta, GA, one of the largest suburbs of Atlanta. There are a half dozen to a dozen bus companies in Marietta alone, literally minutes away. Heck, I wouldn't be surprised to find out more than one of them leases parking lot space from Lockheed right on the property.
The airfield itself is a mere 10 minutes or so off ATL's perimeter highway, and maybe 25 minutes from the ATL airport itself (or more, if traffic ... this is Atlanta, after all).
This was NOT a "land in the boondocks" event. This would be like diverting from O'hare and landing at Midway. Heck, it's probably closer.
KCaviator
Wed Sep 18, 2019 7:17 pm
Diverting to an airport not defined in your OpSpecs (assuming) as an alternate airport is A LOT different than diverting from ORD to MDW, especially it being a military airport.
I’m curious if there’s any WN pilots here than can chime in. Typically if an airport is not defined in your OpSpecs as an alternate airport, you don’t have charts for that airport. At least that’s how it is at my airline.
This, to me, sounds like a worst case scenario. Because of the weather, the crew probably backed themselves into a corner in terms of fuel, with very limited options remaining. It can easily happen when carrying no alternate fuel and an unexpected delay happens. The most important fact is that everyone ended up on the ground safe.
mpdpilot
Wed Sep 18, 2019 7:37 pm
I am not a pilot so maybe this is a dumb question, but with electronic chart apps now, do airlines still really only load their stations and alternates? You would think that with memory being cheap that they would load all airports with runways over a certain length.
On that note too, if WN does all these DOD charters, wouldn't Dobbins be on their list?
One mile of highway gets you one mile, one mile of runway gets you anywhere.
BravoOne
Wed Sep 18, 2019 7:48 pm
Tried to send you a PM but it appears you do not accept incomming mail?
BravoOne
Wed Sep 18, 2019 7:52 pm
Several options, either electronically (JeppView), or via paper. Don't know what system SWA uses.
WN732
Wed Sep 18, 2019 8:06 pm
Generally they would pick an airport that is already a WN station. However, the closest airports to ATL are usually subject to the same weather and/or already flooded with traffic. Sequencing in these situations can be tricky and time consuming. Judging by the hold that they were subject to, they were probably getting too low on fuel to risk any delays while getting to a preferred alternate. Ops would have been able to coordinate their diversion and the pilots would work with their dispatch and ATC to get on the ground.
777Mech
Wed Sep 18, 2019 9:00 pm
You could get from CSG, AGS, MCN, and BHM all in the same day, and all of those had good weather at the time.
I know DL uses MGE as a paper alternate for it's international flights into ATL if the weather is good, but I doubt MGE is in SWA's opspecs.
It does seem like they were on the borderline of emergency fuel. I was stationed at the 94th and it isn't a particularly busy installation. I can't remember a time any commercial aircraft have been at MGE besides a DL 757 for the airshow.
Any troop movement I've ever been a part of, we were bused to ATL for our charter instead of flying directly out of MGE.
Bottom line, this isn't a playbook move for SWA and they backed themselves into a corner with their fuel situation.
747-600X
Wed Sep 18, 2019 10:12 pm
The flight did two missed approaches in KATL. At that point, the crew likely felt that they did not have enough fuel to divert to a more reasonable alternate (KAGS, KCHA, etc.) comfortably. Remember that airlines are only authorized to fly to certain airports, so even though there may have been relatively close civilian airports, the crew and dispatcher may not have been readily aware of them. Many Southwest pilots are former military and they may have known of KMGE and its 10,000-foot runway being so close. They also flew a missed approach attempting to land at KMGE, possibly per a military requirement for verification of an unauthorized aircraft arrival. It's also important to remember that when a crew declares a fuel emergency (and even if they don't), air traffic controllers can provide them with available fields. In this case, ATC may have noted KMGE among others in the area. There aren't many good options near KATL - DeKalb has a 6000' runway and Cobb County Int'l has a 5200' foot runway. Given those choices or KMGE, it's sensible that the crew chose the latter.
KCaviator
Wed Sep 18, 2019 10:43 pm
Believe it or not, we use JeppFD Pro X and do not have access to every airport’s charts. For the most part, we only have access to our normal and alternate airports.
Edit: for clarity, “we” is not WN.
ilovepabst
Thu Sep 19, 2019 12:08 am
Where did the flight originate and was it a completely blown TAF or did ATL even have VCTS in the fcst?
GalaxyFlyer
Thu Sep 19, 2019 12:40 am
Not airline, but I have Jeppesen World coverage for every approach with a 4,000’ runway anywhere in the world on an iPad plus each of the plane’s two file servers also had world coverage. We can display four different airports or four different procedures at once.
GF
BoeingGuy
Thu Sep 19, 2019 2:54 am
Geez, can you please ask that in English? Do you think there is even one other person on A.net who understands those acronyms?
GalaxyFlyer
Thu Sep 19, 2019 3:14 am
I’ll translate for you,
Was the Terminal Area Forecast (TAF) wrong or did the ATL have thunderstorms in the vicinity (VCTS) in the aviation forecast (again, the TAF). For an aviation site, this isn’t a mystery.
GF
bravoindia
Thu Sep 19, 2019 3:22 am
Yesterday was a train wreck with the microburst. This was an emergency fuel situation and they had to land Dobbins. They actually went around the first attempt.
bravoindia
Thu Sep 19, 2019 3:23 am
Yesterday was a train wreck with the microburst. This was an emergency fuel situation and they had to land Dobbins. They actually went around the first attempt. The controller did an excellent job getting them pointed to a piece of pavement.
bravoindia
Thu Sep 19, 2019 3:25 am
They were emergency fuel not min fuel there were no alternates as they expected the last attempt at ATL to be successful the controller suggested Dobbins to which they accepted and the go around was due to them not descending on the glide path appropriately and were too high.
Flaps
Thu Sep 19, 2019 3:43 am
SO 242 was trying to make Dobbins when they went down.
litz
Thu Sep 19, 2019 6:26 pm
242 taught the industry a lot of lessons on handling weather.
Had they not struck a phone pole with a wing, that airplane might have successfully completed its emergency landing on Hwy 92, as well.
They had already touched down and were rolling out when the phone pole was struck by a wing, cartwheeling the airplane into a gas station.
