drdisque
Interesting Diversion: Ultimate Jet Charters E135 CLT-PDK diverts in good weather
Fri Sep 20, 2019 7:58 pm
https://flightaware.com/live/flight/UJC ... /KCLT/KPDK
aircraft circled near Atlanta-Peachtree Dekalb maybe a dozen times, in the meantime a Citation, a Cirrus, and a Navajo all landed at PDK
KPDK METAR: KPDK 201853Z 14007KT 10SM CLR 26/11 A3027 RMK AO2 SLP237 T02560111
Then the aircraft then left the holding pattern and appeared to divert to LZU (Lawrenceville-Gwinnett County), although flightaware isn't showing an arrival there yet and flightradar24 doesn't have anything on the flight at all.
Weird flight. The only reason I can think for a long hold and then diversion on a clear weather day would be a gear problem, but with a gear problem you'd think they'd divert to a larger field like ATL rather than a smaller field like LZU.
EDIT: Flightaware now confirms the aircraft landed at LZU at 3:43 PM, 44 minutes after ending the holding pattern.
GalaxyFlyer
Re: Interesting Diversion: Ultimate Jet Charters E135 CLT-PDK diverts in good weather
Fri Sep 20, 2019 8:01 pm
Brake or flap problem and needed more runway than ?pdk.
GF
drdisque
Fri Sep 20, 2019 8:09 pm
GF
PDK and LZU both have 6,000 ft. runways.
Gulfstream500
Fri Sep 20, 2019 8:14 pm
GF
Probably an issue with PDK’s long runway. Maybe an aircraft blew a tire on the long runway?
Thinking of a good signature is hard...
drdisque
Fri Sep 20, 2019 8:25 pm
Gulfstream500 wrote:
GF
That could be it, everything else this afternoon appears to have landed on rwy 34 (4000 ft), including aircraft you would think would want the longer runway were it available (Citation CJ3, Citation Excel, King Air).
https://flightaware.com/live/flight/N52 ... /KBHM/KPDK
Varsity1
Fri Sep 20, 2019 8:31 pm
A cirrusjet went off the runway a PDK.
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
Antarius
GF
Found this NOTAM
PDK DEKALB-PEACHTREE!PDK 09/021 PDK TWY G BTN APCH END RWY 21R AND RWY 03R/21L CLSD 1909181000-1909272300
But dont know enough to know if this contributed/caused it?
2019: SIN HKG NRT DFW IAH HOU CLT LGA JFK SFO SJC EWR SNA EYW MIA BOG LAX ORD DTW OAK PVG BOS DCA IAD ATL LAS BIS CUN PHX OAK SYD CVG PHL MAD ORY CDG SLC SJU BQN MHT YYZ STS BIS DOH BLR KTM MFM MEX MSY BWI DEN
