BWIAirport
DL9735 today, A350 ATL-LGA?
Thu Sep 26, 2019 6:57 pm
https://flightaware.com/live/flight/DAL ... /KATL/KLGA
What is the purpose of this flight? Obviously LGA could probably handle the A350 to some extent or they wouldn't be flying the route. Or is it a FlightAware error?
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL, FFT | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
Ishrion
Re: DL9735 today, A350 ATL-LGA?
Thu Sep 26, 2019 7:06 pm
It’s already past departure time, right? DL9735 isn’t showing up on Flightradar24 and FlightStats
NYPECO
Thu Sep 26, 2019 7:23 pm
Im guessing it's a Flightaware glitch. I don't think an A350 could safety operate from LaGuardia without large weight restrictions.
jaybird
Thu Sep 26, 2019 7:24 pm
There was a DL9735 today - this is from Sabre FLIFO:
DL RESPONSE
FLT INFO 9735/26SEP
LOF ARR DEP ETA ON IN ETD OUT OFF ACF ELPD ACCUM MILES
ATL 230P 359
LGA 400P 1.30 783
FACTS-
MEALS/CPT C W Y
ATLLGA NO MEALS
evanb
As far as I can see there are no DL A350s on the ground in ATL at the moment. Also, none scheduled to arrive anytime soon. The next is N513DZ due from ICN as DL 26 at 7:13pm which will depart to ICM as DL 27 at 12:20am.
Polot
Thu Sep 26, 2019 7:27 pm
It’s not just weight, the A350’s wingspan would cause issues at LGA. The 764 is the largest plane that can fit there.
rw774477
Thu Sep 26, 2019 7:37 pm
DC-10's L1011's and A300's used LGA back in the day
jaybird
Thu Sep 26, 2019 7:45 pm
I tried to attach a screen shot from Sabre but it won't paste - so I've played with the spacing so you can see it better. Under ACF - which is aircraft - it shows a 359.
2DL9735
DL RESPONSE
FLT INFO 9735/26SEP
ATL 230P ------------------------------------------- 359
LGA 400P --------------------------------------------------------------1.30 783
FACTS-
MEALS/CPT C W Y
ATLLGA NO MEALS
GalaxyFlyer
Thu Sep 26, 2019 7:51 pm
None had the span of the A350
mcg
Thu Sep 26, 2019 8:33 pm
Public/media relations event?
longhauler
Thu Sep 26, 2019 9:09 pm
Nor the weight.
drdisque
Thu Sep 26, 2019 9:27 pm
Flight disappeared from Flightaware. Likely a FLIFO test/training dummy flight that Flightaware picked up.
twaconnie
Fri Sep 27, 2019 2:37 pm
What's the wing span of 764 vs A350 is there that much difference? And I do know LGA's over water deck's can handle 363,000 with a DC-10 foot print,
KFTG
Fri Sep 27, 2019 2:56 pm
Your point being?
Polot
Fri Sep 27, 2019 4:27 pm
The A350’s wingspan is about 42 feet wider than the 764’s.
