a19901213 wrote:Answer is easy. To cater the transit passengers from South East Asia.
One example would be KHH. Flight arrives in NRT around 2:30pm and people travelling onward to destinations in US.
This has been quite a good business for JAL.
clrd4t8koff wrote:a19901213 wrote:Answer is easy. To cater the transit passengers from South East Asia.
I understand wanting to cater to SE Asia. But if that’s the case then why do ORD & DFW leave in the morning? Wouldn’t they want to capture the same SE Asia traffic?
RyanairGuru wrote:clrd4t8koff wrote:a19901213 wrote:Answer is easy. To cater the transit passengers from South East Asia.
AA have an evening departure from NRT to both DFW and ORD (on the days it operates). With a metal neutral neutral JV JAL can put passengers on AA metal and optimise their own schedule, which isn't possible to JFK and BOS
Dieuwer wrote:There is no reason for JL to spend close to 20 hours on the ground at BOS.
Just look at KE. They arrive early and depart early. And have a similar length flight.
jfk777 wrote:Dieuwer wrote:There is no reason for JL to spend close to 20 hours on the ground at BOS.
JAL does what is good for JAL, apart from this JFK 77W, all their other US flights turn around in a few hours. Planes spending 12 to 24 hours at Foreign airports happen all the time. AT LAX two Virgin Australia 77W spend 18 hours daily, the same with two Qantas A380, QF even has a hangar at LAX.
IN Buenos Aires and Sao Paulo planes from the USA spend all day their, its looks like a US airline parking lot, AA even has hangars at both EZE and GRU.
AT Johannesburg the same for the European airlines, many BA and Virgin planes spend all day there.
All the daytime JFK and ORD to LHR flights spend the night in the UK and fly out first thing in the morning.
What to you is "irregular" flight operations is actually quite normal.
Dieuwer wrote:jfk777 wrote:Dieuwer wrote:There is no reason for JL to spend close to 20 hours on the ground at BOS.
I did not write "irregular" anywhere in my post.
Care to comment on KE vs. JL?
Fuling wrote:Let's also remember that A LOT of JL (and NH) aircraft only do a few flights a day, and rest up overnight at HND/NRT as well. Earlier this year one of JL's B777-200ER only operated HND-SHA-HND for weeks on end, meaning it was on HND ground 16:45-09:20. JL and NH are more focused on the customer flows and markets that work best for them rather than increasing utilisation. On that note NH operates JFK with a HND-JFK-NRT and vv rotation.
notconcerned wrote:Fuling wrote:Let's also remember that A LOT of JL (and NH) aircraft only do a few flights a day, and rest up overnight at HND/NRT as well. Earlier this year one of JL's B777-200ER only operated HND-SHA-HND for weeks on end, meaning it was on HND ground 16:45-09:20. JL and NH are more focused on the customer flows and markets that work best for them rather than increasing utilisation. On that note NH operates JFK with a HND-JFK-NRT and vv rotation.
I'm surprised that JL isn't following NH's rotation HND-JFK-NRT. Previously JL operated 77W from HND and 789 from NRT so they couldn't rotate, but now it's 2x daily 77W from TYO. Unless JL likes to keep their aircraft based in a single airport.
And JL HND long-haul operation isn't as robust as NH, the only 77W long-haul flights are HND-JFK/SFO/LHR/CDG.
RTNOBLE wrote:The poster's question is what makes BOS and JFK different from the rest of the markets it operated in, not why would an airline park a plane for 20hrs.
jfk777 wrote:notconcerned wrote:Fuling wrote:Let's also remember that A LOT of JL (and NH) aircraft only do a few flights a day, and rest up overnight at HND/NRT as well. Earlier this year one of JL's B777-200ER only operated HND-SHA-HND for weeks on end, meaning it was on HND ground 16:45-09:20. JL and NH are more focused on the customer flows and markets that work best for them rather than increasing utilisation. On that note NH operates JFK with a HND-JFK-NRT and vv rotation.
JAL's 77W do rotate the Haneda flights go back to Narita, as an early afternoon departure. The NRT flight arrives late in the day spends the night and goes to HND as late morning flight.
aemoreira1981 wrote:I get why JL would use a B77W on NRT-JFK (JL4/3) (need for first-class), but why not move the return to midnight for connections at NRT in the morning? (It used to be a B788, but then it got upgauged back to B77W except for two-off B789s, as the B789 would be under 180 seats if there was first class in their 2-4-2 Dreamliner configuration in Y.)
