LAXintl
Udvar-Hazy: Boeing planning a B737 MAX 9ER
Fri Oct 11, 2019 6:04 pm
Founder and chairman of ALC Steven Udvar-Hazy says Boeing is planning a B737 MAX-9ER version.
Overall he believes the airframe manufacturers are starting to understand that there is a growing segment where narrowbodies will become preferable for flights upwards 8-hours allowing operators to avoid the complexity and cost associated with widebodies.
https://atwonline.com/aircraft-engines/ ... rrowbodies
Imo such aircraft would be suitable for both full-service carriers seeking more spokes from their hubs, and LCCs looking at fleet simplification and low trip cost.
gatibosgru
Re: Udvar-Hazy: Boeing planning a B737 MAX 9ER
Fri Oct 11, 2019 6:05 pm
Good option for 737/MAX operators to not order the NEO LR/XLR
@DadCelo
ikolkyo
Fri Oct 11, 2019 6:06 pm
Sounds like a MAX 9 with the -10 landing gear and likely higher MTOW. That’d be my initial guess of what such an aircraft would be.
moyangmm
Fri Oct 11, 2019 6:19 pm
That would be an A321/LR killer, similar range, but significantly more efficient. It wouldn't be as capable as XLR though. Still, many would be interested because of its superior fuel burn.
MIflyer12
Complexity?! What, pallet-loading? I'm sure these can be fuel-efficient. I'm sure these can be efficient to manufacture, right alongside existing narrowbodies instead of a separate NMA line. But they make me nostalgic for 1983-era UA 762s when there was some open space above my head and shoulders.
Kikko19
Fri Oct 11, 2019 6:22 pm
Never more than 3 hours in a 737 fuselage. Cannot shrink my shoulders. Maybe if they do it 2+3 I will change my mind
FabienA380
Fri Oct 11, 2019 6:28 pm
That's looking decades ahead. Let's first take the -8 out of sleep and the -7 into service, that alone will take years.
VSMUT
Fri Oct 11, 2019 6:33 pm
:lol:
Thats what people said about the 737-900ER vs the A321. And the 737-9 vs A321NEO. And 737-10 vs A321NEO. And now this? It is laughable to suggest that this frankenstein of a monstrosity is ever going to surpass an A321.
arcticcruiser
Fri Oct 11, 2019 6:36 pm
Simply wrong.
Aptivaboy
Fri Oct 11, 2019 6:37 pm
It's fine in first class! ;)
ikolkyo
Fri Oct 11, 2019 6:43 pm
Exact same cabin as a 757.
redzeppelin
Fri Oct 11, 2019 6:44 pm
I just did DEN-KEF-DEN this week on the 757 (same fuselage dimensions). It wasn't bad at all... but I also had an empty seat next to me both ways.
KarlB737
Fri Oct 11, 2019 6:49 pm
I'm sorry but I believe it is time for an end to making mods to the 737 and calling it a new plane. I'm as big a fan of Boeing as the next guy but its time for a clean sheet on the table to design a new replacement aircraft for the 737. They altered the 737 on the last go around and discovered that the newer bigger engines had to be relocated to deal with newer issues. Then they had to add software to compensate for another issue. Well we know how well that worked out. Again I'm not sitting here knocking Boeing so set that aside. What I'm stating is there comes a time when you need to start over from scratch. Just my 13 cents. Thanks for reading............
arcticcruiser
Fri Oct 11, 2019 6:52 pm
ikolkyo wrote:
N)
Er, no the floor is in a different location in the tube. Taller lower lobe among other things.
Antarius
No it won't. People will buy it, and the duopoly will continue.
Militant Centrist
Let's all just use some common sense
DocLightning
Fri Oct 11, 2019 6:58 pm
For an airline like FR or WN, complexity in the form of having to add a new type to the fleet that has significant limitations on what airports it can serve and what routes it will be profitable.
-Doc Lightning-
-Carl Sagan
DocLightning
Fri Oct 11, 2019 7:06 pm
The cabin internal measurements for the 737 and 757 (and for that matter the 707 and 727) are identical to within 1mm according to the ACAP documents for both types. The fuselages are different below the cabin floor.
-Doc Lightning-
-Carl Sagan
ODwyerPW
Fri Oct 11, 2019 7:07 pm
What's the goal? 200pax single-class at 32/33"pitch, 4000nmi? 168 Y, 12F for 180pax total, 4100nmi? 10 gear to help take-off performance since it will tanker so much more fuel (and weigh more)?
The article is behind a paywall so I can't read the specifics.
It's interesting.. the initial 900 didn't sell well because of a few design shortcomings... later exit row problem fixed, range extended.. and the 900ER did much better!
Now we have the MAX9, that again hasn't done well (release of 10 is testimony to that)…. later.. range extended, take-off performance addressed... and perhaps the MAX9ER will do much better.
learning never stops.
lightsaber
From the OP link“Widebodies are complex and expensive.”
Simplifying the fleet is a virtue. For LCCs, a simple long haul expansion, in a fairly high density, would sell.
For those complaining, but MINT or an equivalent seat.
Due to the huge lead times for design, build, and certification, now is the time to start for 2023 EIS.
I've been waiting for that offering.
Lightsaber
5 months without TV. The best decision of my life.
oschkosch
Fri Oct 11, 2019 7:08 pm
what does the ER stand for? Extra Risk? ;)
Gesendet von meinem SM-G950F mit Tapatalk
:stirthepot: :airplane: "This airplane is designed by clowns, who in turn are supervised by monkeys" :airplane: :stirthepot:
ewt340
Fri Oct 11, 2019 7:21 pm
So, less capable A321XLR. With less range and less passengers?
Agrajag
Fri Oct 11, 2019 7:25 pm
To be fair, they dont burn much fuel in the carparks of Seattle.
The plural of anecdote is anecdotes, not data.
Slartibartfast had a point
marcogr12
Fri Oct 11, 2019 7:28 pm
That's all very well and very optimistic for Boeing but shouldn't they solve the MAX-issue first before they start making plans about ER versions etc..? I mean they still have no idea when the MAX will be SAFE to fly again..Every 2-3 months,it gets pushed to a new date by another 2-4 months...
Flying is breathing..no planes no life..
EMB170
Fri Oct 11, 2019 7:29 pm
[quote="oschkosch"]what does the ER stand for? Extra Risk? ;)
:lol: Dying.
But seriously. If you're a full-service airline (with few exceptions), you're probably not going to want to use a 7M9ER across the Atlantic or on longhaul. When you get up into those stage lengths, these days, more and more airlines are returning to 3-class (or even 4-class) cabins with J/W/Y+/Y...and if you don't offer W, your product on a hypothetical 7M9ER looks inconsistent with the remainder of your longhaul fleet (I'm looking at you, AC).
But what would an honest W product, such as WT+, Premium+, or Premium Select look like on a narrowbody? Either you'd have to go the route that DL did on the 75H (and not offer J and thus risk losing those travelers) or you offer a Mint-style J, then a DL-style W, and regular Y, at which point you run the risk of there being too few seats that weigh too much for the jet to make a profit.
If anything, it's just another ringing endorsement for NMA, IMO.
IND ORD ATL MCO PIT EWR BUF CVG DEN RNO JFK DTW BOS BDL BWI IAD RDU CLT MYR CHS TPA CID MSP STL MSY DFW IAH AUS SLC LAS
Qf648
Fri Oct 11, 2019 7:30 pm
It’s because with the drain on finances at Boeing (viz 737 max) that NMA is effectively dead.
Hence the need to eke more out of the 767 and 737 while NSA becomes a priority.
Antarius
Considering they're a giant company, one would assume every single person working there isnt working on the same thing all the time.
The MAX is in testing, so there's no reason the commerical and design teams can't start thinking about something else.
Militant Centrist
Dutchy
:rotfl: :rotfl: :rotfl: :rotfl:
But seriously, Boeing should get the MAX in the air again, before thinking about new versions.
I must admit, though, it is intreging, I always though the -9 would fade away into history and the -8M and -10M would remain. This might give it a new lease of life.
ODwyerPW
Fri Oct 11, 2019 7:31 pm
Or another way to look at it... with the 10's cantilevered gear, a Boeing single isle 200+ pax plane that can confidently take-off, un-restricted, out of Midway, JohnWayne, Hobby offered to existing 737 operators? a Boeing single isle 200+ pax plane that can make meaningful North to South America connectons confidently, offered to existing 737 operators?
Lots depends on the MAX rts. We'll see.
smokeybandit
Fri Oct 11, 2019 7:36 pm
Right, because there's so much more shoulder space in Y on a widebody.
MSPNWA
Fri Oct 11, 2019 7:41 pm
Would seem to be a good idea not so much to gain customers, but to retain existing 737 customers. There's some meat on the MAX-9 bone now that the -10 improvements are available.
Antarius
Fri Oct 11, 2019 7:44 pm
:rotfl:
Hopefully they offer the LR (Low Risk) version too!
Militant Centrist
musman9853
Fri Oct 11, 2019 7:47 pm
i mean what about a 757? or a 777? most airlines have very similar seat widths across the board.
Welcome to the City Beautiful.
patrickjp93
Fri Oct 11, 2019 7:56 pm
Nah, we have AT LEAST 3 more iterations to go. Next step is a composite supercritical wing, then full-time telescoping landing gear so we can fit even bigger engines and just leave them extended EXCEPT for an evacuation scenario (which would have the engines touch the ground, but not bear weight), and then 1 more for good measure and good luck to make it lucky #7.
patrickjp93
Fri Oct 11, 2019 7:58 pm
Well, on a 787 there's less, a 10-abreast 777-300 even less, but there's more on an A350 and much more on a 777-200 and a ridiculous 20" across for a 9-abreast 777-300.
VS11
Fri Oct 11, 2019 8:07 pm
Boeing has needed a response for the popular A321NEO/LR/XLR for some time now. If this is it, it is better than nothing.
Sooner787
Fri Oct 11, 2019 8:27 pm
I could see Southwest and United for starters being interested.... maybe Alaska as well.
gatibosgru
Fri Oct 11, 2019 8:30 pm
Could be great for United out of EWR.
@DadCelo
md11sdf
Fri Oct 11, 2019 8:31 pm
At this point, maybe Boeing should just develop SOMETHING NEW and, after FIFTY YEARS, close the 737 line...
LOUISVILLE KENTUCKY: Where your camera looks just like a stinger missile to the Airport Police!!
TMccrury
I done 7.5 hours on a 757 from MIA to LPB in "comfort plus" aisle seat. It was ok but not something I would want to do much of. Granted then, I weight 95 pounds more than I do now still, I have trouble on 7 hour flights. I'm starting to look at minimum economy plus or whatever the offering happens to be.
fcogafa
Fri Oct 11, 2019 8:37 pm
With this and the 767 news it does sound like a two aircraft '797' alternative is being considered. With the backlog of the A321 getting longer and the its delivery delays, a 737 alternative sounds a good plan.
Boeingphan
Fri Oct 11, 2019 8:38 pm
Enough is enough with the 737. Boeing literally and figuratively run it into the ground. NSA is whats needed yet they keep trotting out the old tattered vet and sprinkle a little shine on it.
gatibosgru
Fri Oct 11, 2019 8:39 pm
Make$ $en$e though. Clean sheets aren't cheap.
@DadCelo
DDR
Fri Oct 11, 2019 8:50 pm
I agree. I'm sure there are even people at Boeing that, after the MAX debacle, are thinking the same thing.
If Boeing had just bit the bullet years ago and raised the damned landing gear, they would have avoided many of the problems they are facing today.
UA444
Fri Oct 11, 2019 9:01 pm
Boeing’s microwave is working great up in Seattle apparently
astuteman
Fri Oct 11, 2019 9:27 pm
I have to admit that this was the first thought that went through my mind.
Accepting that both proposals are currently speculation, a 767-400 NEO, and 737-9ER would mean that NMA will have become history.
Certainly a cheaper solution than an all-new widebody when the business case is so marginal
Antarius
Fri Oct 11, 2019 9:30 pm
The 320 series is 30 years old. The 767 is closing in on 40.
So, are we arbitrarily drawing a line at 50? Why can't the above be closed out too?
Militant Centrist
tphuang
Fri Oct 11, 2019 9:39 pm
Seems like bad idea. A220xlr would have similar casm and fewer seat to fill. A321xlr will have range advantage. Didn't they find 738 to be the best aircraft to extend range? I guess it's casm isn't competitive enough.
It does fill like Boeing would only think of launching such a program of it thinks nma case is weak.
highflier92660
Fri Oct 11, 2019 9:40 pm
Eight hours crawling along at .78 Mach. There will undoubtedly be a gross weight increase which adds to more curvature-of-the-Earth takeoffs and an initial altitude of around FL 310.
When is a CEO at Boeing going to have the courage of initiating a clean-sheet aircraft?
ODwyerPW
Fri Oct 11, 2019 9:48 pm
When the board of directors permits it.
Kikko19
Fri Oct 11, 2019 10:04 pm
Well a32x is better, a330 8 abreast even better for long ones . A220 the best for short hops. Even crj900 is better than 737 :). Cannot find worse can than that... Oh wait the 777 10x is even worse!
