enilria
OAG Changes 10/13/2019:AS Exits SJC-TUS;AA Jan Cuts;F9 Extension
Sun Oct 13, 2019 2:06 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
Bahamas Hurricane effects?
3M FLL-FPO NOV 1.9>0.8[3]
3M FLL-MHH NOV 1.3>0[2] DEC 1.3>0.5[3]
*3M FLL-TCB NOV 0.3>0[0.4] DEC 0.3>0[0.6] JAN 0.3>0[0.8]
3M MCO-MHH NOV 0.2>0[0.0] DEC 0.4>0.2[0]
3M MHH-PBI NOV 0.2>0[0] DEC 0.4>0.2[0.4]
7H AIN-ATK NOV 0.9>0.3[0.9] DEC 0.9>0.3[0.9] JAN 0.9>0.3[0.9] FEB 0.9>0.3[0.9] MAR 0.9>0.3[0.9] APR 0.9>0.3[0.9] MAY 0.9>0.3[0.9] JUN 0.9>0.3[1.3] JUL 0.9>0.3[1.3]
7H AIN-BRW NOV 1.7>2[1.8] DEC 1.7>2[1.7] JAN 1.7>2[1.7] FEB 1.8>2[1.8] MAR 1.8>2[1.8] APR 1.8>2[1.8] MAY 1.7>2[1.7] JUN 1.8>2[1.3] JUL 1.7>2[1.3]
7H ATK-BRW NOV 1.7>2[1.8] DEC 1.7>2[1.7] JAN 1.7>2[1.7] FEB 1.8>2[1.8] MAR 1.8>2[1.8] APR 1.8>2[1.8] MAY 1.7>2[1.7] JUN 1.8>2[1.3] JUL 1.7>2[1.3]
7H BTI-SCC NOV 0.8>1.1[0.9] DEC 0.8>1.2[0.8] JAN 0.8>1.2[0.8] FEB 0.8>1.2[0.9] MAR 0.9>1.2[0.8] APR 0.9>1.2[0.9] MAY 0.8>1.1[0.8] JUN 0.9>1.2[0.8] JUL 0.9>1.2[0.8]
7H NUI-SCC NOV 1.4>2[1.4] DEC 1.4>2[1.4] JAN 1.4>2[1.4] FEB 1.4>2[1.4] MAR 1.4>2[1.4] APR 1.4>2[1.4] MAY 1.4>2[1.4] JUN 1.4>2[1.3] JUL 1.4>2[1.4]
9X HNL-JHM NOV 0>1.9[0] DEC 0>3[0] JAN 0>0.5[0]
AA ALB-PHL JAN 6>5[5]
AA ATL-CLT JAN 8>7[8]
AA ATL-DFW JAN 8>7[7]
AA ATL-MIA DEC 8>7[7] JAN 8>6[7] FEB 8>7[7]
AA ATL-ORD JAN 5>4[4]
AA ATL-PHL JAN 6>4[5] FEB 6>5[5]
AA ATL-PHX JAN 2>1.3[1.8]
AA AUA-PHL MAY 0.7>0.9[0.7]
AA AUS-DFW JAN 11>10[11]
AA AVL-CLT FEB 7>8[6] MAR 7>8[7]
AA AVP-CLT JAN 3>4[3] FEB 3>4[3] MAR 3>4[4] APR 3>4[4] MAY 3>4[4] JUN 3>4[4] JUL 3>4[4]
AA AVP-PHL JAN 4>3[3]
AA BDL-DFW JAN 1.8>0.7[1.8]
AA BDL-MIA DEC 1.5>1.1[1.0]
AA BDL-ORD JAN 4>3[4]
AA BDL-PHL JAN 3>4[4] FEB 3>4[5] MAR 3>5[5]
AA BGR-DCA JAN 3>1.9[1.6]
AA BGR-PHL JAN 5>4[4]
AA BHM-CLT FEB 7>8[7] MAR 7>8[7]
AA BHM-DFW JAN 7>5[5] FEB 7>6[5]
AA BHM-PHL JAN 3>1.9[2.0]
AA BNA-CLT JAN 7>8[8] FEB 7>9[8] MAR 7>9[8] APR 7>9[8] MAY 7>9[7] JUN 7>9[7] JUL 7>9[7]
AA BNA-LAX JAN 1.4>2[1.3] FEB 1.0>1.3[1.9]
AA BNA-PHL JAN 5>3[4] FEB 6>5[4]
AA BOS-DCA JAN 13>10[12] FEB 14>12[14]
AA BOS-DFW JAN 6>5[5]
AA BOS-JFK JAN 5>3[4] FEB 6>5[4]
AA BOS-LGA JAN 11>9[10]
AA BOS-ORD JAN 6>5[6]
AA BOS-PHL JAN 11>9[11]
AA BTV-PHL JAN 5>4[4]
AA BUF-CLT JAN 4>3[3]
AA BWI-CLT JAN 9>8[7]
JFK cuts keep rolling forward
*AA BWI-JFK JAN 4>1.0[1.0] FEB 5>3[1.0]
AA BWI-PHX DEC 1.7>1.3[1.7] JAN 2>0.2[1.6] FEB 2>1.6[1.7]
AA CHA-CLT FEB 6>7[6] MAR 6>7[7] APR 6>7[8] MAY 6>7[6] JUN 6>7[6] JUL 6>7[6]
AA CHA-PHL JAN 1.0>0.6[0]
AA CHS-PHL JAN 5>3[3] FEB 5>4[3]
AA CLE-CLT FEB 6>7[7] MAR 6>7[7] APR 6>7[7] MAY 6>7[7] JUN 6>7[6] JUL 6>7[6]
AA CLE-DFW JAN 4>2[3]
*AA CLE-JFK JAN 1.6>0[3] FEB 2>1.2[3]
AA CLT-DAY JAN 6>5[6] FEB 6>5[6] MAR 6>5[6] APR 6>5[6]
AA CLT-DEN FEB 6>5[5] MAR 7>5[5]
AA CLT-DSM JAN 3>4[3] FEB 3>4[3] MAR 3>4[3]
AA CLT-EWN JAN 6>5[5] FEB 6>5[6] MAR 6>5[6] APR 6>5[5] MAY 6>5[5] JUN 6>5[5] JUL 6>5[5]
AA CLT-EWR JAN 9>8[6]
AA CLT-FLO FEB 4>3[3] MAR 4>3[3]
AA CLT-IAH JAN 6>5[5]
AA CLT-LYH JAN 6>7[5] FEB 6>7[6] MAR 6>7[6]
AA CLT-MDT FEB 5>6[6] MAR 5>6[6]
AA CLT-MIA JAN 7>9[8] FEB 7>9[8] MAR 7>9[8]
AA CLT-MLB JAN 3>4[3]
AA CLT-MOB FEB 4>5[4] MAR 4>5[4]
AA CLT-PHF JAN 6>5[5]
AA CLT-PIT JAN 9>8[8] FEB 9>8[8] MAR 9>8[8]
AA CLT-PVD JAN 5>4[4] FEB 5>4[4] MAR 5>4[4]
AA CLT-ROA MAR 7>8[7] APR 7>8[8] MAY 7>8[7] JUN 7>8[7] JUL 7>8[7]
AA CLT-ROC JAN 4>3[3] FEB 4>3[4] MAR 4>3[4] APR 4>3[4] MAY 4>3[4] JUN 4>3[4] JUL 4>3[4]
AA CLT-RSW JAN 6>5[5]
AA CLT-SAV JAN 9>8[8]
AA CLT-SEA MAR 4>3[3]
AA CLT-SFO JAN 5>4[4] FEB 5>4[4] MAR 5>4[4]
AA CLT-SGF JAN 3>4[3] FEB 3>4[3]
AA CLT-SLC JAN 1.0>0.8[0.9]
AA CLT-SMF JAN 1.0>0.8[0.9]
AA CLT-SRQ JAN 5>4[3] FEB 5>4[4] MAR 5>4[4]
AA CLT-STL MAR 6>7[6]
AA CLT-TYS FEB 7>8[7] MAR 7>8[7]
AA CMH-JFK JAN 1.8>1.0[1.0] FEB 2>1.6[1.0]
AA CMH-PHL JAN 6>5[5] FEB 7>6[5]
AA CMH-PHX JAN 2>1.0[1.7] FEB 2>1.4[1.9]
AA CRP-DFW JAN 8>7[6]
AA CVG-PHL JAN 6>4[5] FEB 6>5[5]
AA CYS-DFW JAN 1.0>1.8[1.0] FEB 1.0>1.4[1.0]
AA CZM-MIA JAN 0.7>1.0[0.7]
AA DAY-PHL JAN 5>4[4]
AA DCA-EYW JAN 1.0>1.3[1.2] FEB 1.0>1.2[1.1]
AA DCA-JFK JAN 4>2[4]
AA DCA-LGA JAN 10>9[9]
AA DCA-MYR FEB 0.2>0.6[1.0] MAR 0.1>0.8[1.0] APR 0.1>0.9[1.0]
AA DCA-YYZ JAN 3>1.8[2]
AA DEN-DFW DEC 10>9[8] JAN 10>9[8] FEB 10>9[9]
AA DEN-MIA JAN 3>2[3]
AA DEN-PHL JAN 1.1>0.6[0.9] FEB 1.0>0.8[1.4]
AA DFW-DTW JAN 5>4[4]
AA DFW-ELP DEC 9>8[8] JAN 9>8[8]
AA DFW-FLL JAN 7>6[6]
AA DFW-GRK JAN 7>6[5]
AA DFW-HSV JAN 6>5[4]
AA DFW-JAN JAN 7>5[5]
AA DFW-JAX JAN 6>5[4]
*AA DFW-JFK JAN 4>1.4[3] FEB 4>3[3]
AA DFW-LAS JAN 12>10[9] FEB 12>11[9]
AA DFW-LAX JAN 15>14[13] FEB 15>14[13]
AA DFW-LGA JAN 12>11[11]
AA DFW-LIT JAN 9>8[8]
AA DFW-LRD JAN 5>4[3]
AA DFW-MAF JAN 8>7[7]
AA DFW-MCI JAN 8>7[6]
AA DFW-MCO DEC 11>10[9] JAN 10>9[9]
AA DFW-MFE JAN 8>6[7]
*AA DFW-MGA JUN 0.8>0[0.0] JUL 0.9>0[0]
AA DFW-MIA DEC 12>11[10]
AA DFW-MSP JAN 6>5[5]
AA DFW-PBI DEC 4>3[2]
AA DFW-PEK JAN 1.0>0.5[1.0]
AA DFW-PHX DEC 13>12[12]
AA DFW-PNS JAN 5>4[4]
AA DFW-RDU JAN 6>4[5]
AA DFW-RIC JAN 2>3[2]
AA DFW-SAN JAN 9>8[8]
AA DFW-SAT DEC 11>10[10] JAN 11>10[10]
AA DFW-SDF JAN 6>5[5]
AA DFW-SEA JAN 7>6[6]
AA DFW-SFO JAN 9>8[8]
AA DFW-SHV JAN 6>5[6]
AA DFW-SJT JAN 6>5[4]
AA DFW-SNA JAN 9>8[8]
AA DFW-TPA DEC 7>6[7] JAN 7>6[7]
AA DFW-TYS JAN 5>4[4]
AA DFW-YVR JAN 2.0>1.2[1.9] FEB 2>1.6[1.9]
AA DFW-YYZ JAN 3>2[2]
AA DSM-PHL JAN 1.8>1.0[2] FEB 2>1.6[2]
AA DTW-PHL JAN 6>4[4] FEB 6>5[5]
AA EWR-ORD JAN 6>4[5]
AA EWR-PHX JAN 4>2[3] FEB 4>3[3]
AA FWA-PHL JAN 1.8>1.0[1.6] FEB 2>1.6[1.8]
AA GGT-MIA MAY 1.0>1.8[1.1]
AA GJT-PHX JAN 4>3[2] FEB 4>3[2] MAR 4>3[2]
AA GRR-MIA JAN 1.0>0.7[0.7]
AA GRR-PHL JAN 3>2.0[2]
AA GSO-PHL JAN 4>3[4]
AA GSP-PHL JAN 3>2[2]
AA HSV-ORD JAN 1.0>1.4[0.9] FEB 1.0>1.2[0.9]
AA HVN-PHL JAN 3>1.6[2]
AA IAH-ORD JAN 4>3[3]
AA IAH-PHL JAN 3>2[2.0]
AA IAH-PHX JAN 4>3[4]
AA ILM-PHL JAN 3>2[1.8]
AA IND-PHL JAN 6>5[5]
AA IPT-PHL JAN 3>1.9[1.1]
AA ISP-PHL JAN 3>1.6[2]
AA JAX-ORD JAN 3>1.5[1.9] FEB 3>2[1.8]
AA JAX-PHL JAN 3>2[3]
*AA JFK-LAS JAN 1.9>0.3[1.9] FEB 2>1.2[1.9]
AA JFK-LAX JAN 11>10[11]
AA JFK-MAD JAN 0.3>0.5[1.0]
AA JFK-MIA JAN 8>7[6]
AA JFK-ORD DEC 1.5>1.0[1.4]
AA JFK-ORF JAN 2>1.2[1.7] FEB 2>1.6[1.7]
*AA JFK-PHL JAN 4>0.3[1.0] FEB 5>3[1.0]
AA JFK-PHX JAN 6>5[4]
*AA JFK-PIT JAN 3>1.0[1.0] FEB 4>3[1.0]
*AA JFK-RDU JAN 4>2[4] FEB 4>3[4]
AA JFK-RIC JAN 3>2[0]
*AA JFK-SAN DEC 0.5>0[1.8] JAN 1.0>0.5[1.2]
AA JFK-SAT DEC 1.0>0.7[0]
AA JFK-SKB MAY 0>0.2[0.0]
AA JFK-YUL JAN 1.7>0.9[2] FEB 2>1.6[2]
*AA JFK-YYZ JAN 1.6>0[2] FEB 2>1.2[2]
AA LAS-ORD JAN 5>4[4]
AA LAX-MSY JAN 2.0>1.2[2] FEB 2>1.6[2]
AA LAX-PHL JAN 5>7[5] FEB 5>6[6]
AA LAX-RDU JAN 1.0>0.8[0.8]
AA LAX-SDF JAN 1.0>0.8[0] FEB 1.0>0.7[0]
AA LEX-PHL JAN 3>1.6[2] FEB 3>2[2]
AA LGA-MSP JAN 2>1.7[1.6]
AA LGA-ORD DEC 10>9[11] JAN 12>10[12]
AA LGA-ORF JAN 3>2[3]
AA LGA-PWM JAN 1.6>0.9[1.6]
AA MAO-MIA MAR 1.0>0.7[1.0] APR 1.0>0.7[1.0]
AA MCI-ORD JAN 6>5[6]
AA MCI-PHL JAN 3>1.9[2]
AA MCI-PHX JAN 2>1.7[2]
AA MCO-MIA JAN 7>6[9]
AA MEM-PHL JAN 3>1.9[2.0]
AA MHT-PHL JAN 5>4[5] FEB 6>5[5]
AA MIA-MID JAN 0.8>1.1[0.7]
AA MIA-ORD DEC 10>9[9]
AA MIA-PHX JAN 3>4[3]
AA MIA-SFO JAN 4>3[4]
AA MIA-TPA JAN 6>5[7]
AA MIA-UVF APR 1.2>2[1.0] MAY 1.0>2[1.0]
AA MIA-YYZ JAN 3>1.7[3]
AA MKE-PHL JAN 4>3[3] FEB 5>4[3]
AA MRY-PHX JAN 3>4[3]
AA MSP-ORD JAN 6>5[7]
AA MSP-PHL JAN 3>1.2[3] FEB 4>3[2]
AA MSY-PHL DEC 3>2.0[2] JAN 3>1.1[1.6] FEB 3>2[1.7]
AA MYR-PHL JAN 0.8>0.4[1.0] MAR 0.9>1.6[2] MAY 3>4[2] JUN 3>4[2] JUL 3>4[2]
AA OKC-PHL JAN 1.8>1.0[2.0] FEB 2>1.6[2]
AA OMA-PHL JAN 1.8>1.0[1.8] FEB 2>1.6[1.9]
AA ORD-PHL JAN 9>8[8]
AA ORD-PIA JAN 1.9>3[2] FEB 1.8>2[1.9]
AA ORD-SEA JAN 3>2.0[3]
AA ORD-SFO JAN 5>4[5]
AA ORD-SMF DEC 1.5>1.1[1.0]
AA ORD-TUS DEC 3>2[1.9]
AA ORD-TYS JAN 1.8>1.5[2.0]
AA ORD-XNA JAN 5>4[4]
AA ORF-PHL JAN 6>5[6]
AA PDX-PHX DEC 4>3[4] JAN 4>3[5]
AA PHF-PHL JAN 3>2[2]
AA PHL-PIT JAN 6>4[5]
AA PHL-PVD JAN 5>3[4] FEB 6>5[4]
AA PHL-PWM JAN 6>5[5]
AA PHL-RDU JAN 6>4[5] FEB 6>5[5]
AA PHL-RIC JAN 7>5[5]
AA PHL-SAN JAN 3>2.0[1.1]
AA PHL-SAT DEC 1.4>1.0[1.0] JAN 1.2>0.3[1.0] FEB 1.0>0.6[1.0]
AA PHL-SAV JAN 3>2[2]
AA PHL-SBY JAN 3>2[3]
AA PHL-SCE JAN 5>4[4]
AA PHL-SDF JAN 4>2.0[2] FEB 4>3[2]
AA PHL-SEA JAN 1.0>0.6[0.6] FEB 1.0>0.8[0.8]
AA PHL-SFO JAN 5>4[3]
AA PHL-TPA JAN 6>5[4]
AA PHL-TYS JAN 3>2[2]
AA PHL-YOW JAN 3>1.9[3]
AA PHL-YUL JAN 3>1.8[3] FEB 3>2[3]
AA PHL-YYZ JAN 5>4[4]
AA PHX-PIT JAN 1.2>1.6[1.8] FEB 1.0>1.2[1.8]
AA PHX-RDU DEC 1.8>0.9[0]
AA PHX-SAF JAN 1.2>1.6[0.8] FEB 1.0>1.2[0.9]
AA PHX-SBA JAN 5>4[4]
AA PHX-SEA JAN 4>2[4]
AA PHX-SFO JAN 5>3[5] FEB 5>4[5]
AA PHX-SMF JAN 5>4[5]
What is this?
AN AUS-TSM DEC 0>0.2[0] JAN 0>0.5[0] FEB 0>0.4[0] MAR 0>0.4[0]
AN DAL-TSM DEC 0>0.2[0] JAN 0>0.5[0] FEB 0>0.4[0] MAR 0>0.4[0]
AN HHR-SQL NOV 0>0.4[1.6]
AN OAK-SBA NOV 0>0.2[1.6]
AN SBA-SQL NOV 0>0.5[1.3]
AS LAS-SJC JAN 0>0.3[0.2]
AS RDU-SEA MAY 1.0>1.3[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0]
AS SAN-SLC MAY 2>1.0[1.0] JUN 2>1.0[1.0] JUL 2>1.0[1.0]
AS SEA-TPA MAY 1.4>2[1.4] JUN 1.0>2[1.1] JUL 1.0>2[1.0]
*AS SJC-TUS FEB 0.3>0[1.0] MAR 0.5>0[1.0] APR 0.5>0[1.0] MAY 0.5>0[1.0] JUN 0.5>0[1.0] JUL 0.5>0[1.0]
DI LGW-MIA APR 0.7>1.0[1.0]
DI LGW-SFO JUN 0.7>1.0[0.7] JUL 0.7>1.0[0.7]
DL CVG-YYZ MAR 0.5>0[0.6]
DL DTW-PDX JAN 1.0>0.8[1.0] FEB 1.0>0.7[1.0]
DL DTW-SJU APR 0.5>0.2[0]
DL IND-JFK MAR 2>3[2.0] APR 2>3[2] MAY 2>3[1.9]
DL JFK-KEF APR 1.0>0.7[0.7]
DL JFK-SJU MAY 2>1.5[1.5] JUN 2>1.5[1.5] JUL 2>1.5[1.5]
DL LGB-SLC FEB 5>4[4]
DL MSP-RIC JAN 1.2>0.9[1.5] FEB 1.1>0.8[1.5]
DY CDG-JFK MAY 1.0>1.3[1.0] JUN 1.0>1.3[1.0] JUL 1.0>1.3[1.0]
DY CDG-LAX APR 1.0>1.4[1.1] MAY 1.0>1.4[1.2] JUN 1.0>1.4[1.1] JUL 1.0>1.4[1.1]
DY LAX-OSL APR 0.3>0.6[0.3] MAY 0.3>0.6[0.3] JUN 0.3>0.6[0.3] JUL 0.3>0.6[0.3]
APR is only partially for sale, so ignore
F9 ABQ-DEN MAR 0.2>0.5[0] APR 0>0.3[0]
F9 ATL-DEN MAR 0.4>1.0[1.0] APR 0>0.7[1.1]
F9 ATL-EWR MAR 0.4>1.0[0] APR 0>0.7[0]
F9 ATL-ISP MAR 0.2>0.5[0] APR 0>0.3[0]
F9 ATL-LAS MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 ATL-LAX MAR 0.2>0.5[0.4] APR 0>0.3[0.4]
F9 ATL-LGA MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 ATL-MCO MAR 0.7>2[1.0] APR 0>1.5[1.0]
F9 ATL-MIA MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 ATL-PHL MAR 0.2>0.5[0] APR 0>0.4[0.0]
F9 ATL-RDU MAR 0.4>1.0[0] APR 0>0.7[0]
F9 ATL-SFO MAR 0.2>0.5[0.6] APR 0>0.4[0.6]
F9 ATL-SJU APR 0>0.2[0.3]
F9 ATL-SLC MAR 0.2>0.5[0.4] APR 0>0.3[0.4]
F9 ATL-TPA MAR 0.2>0.5[0] APR 0>0.3[0]
F9 ATL-TTN MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 AUS-DEN MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 AUS-IAD MAR 0.2>0.5[0.7] APR 0>0.3[0.7]
F9 AUS-LAS MAR 0.4>1.0[0.9] APR 0>0.7[0.9]
F9 AUS-ONT MAR 0.2>0.5[0] APR 0>0.3[0]
F9 AUS-SAN MAR 0.2>0.5[0.3] APR 0>0.4[0.3]
F9 AUS-SFO MAR 0.2>0.5[0] APR 0>0.4[0]
F9 BDL-MCO MAR 0.2>0.5[0] APR 0>0.6[0.0]
F9 BDL-MIA MAR 0.2>0.5[0] APR 0>0.3[0]
F9 BFM-DEN MAR 0.2>0.4[0] APR 0>0.3[0]
F9 BIL-DEN MAR 0.2>0.4[0] APR 0>0.3[0]
F9 BMI-MCO MAR 0.2>0.4[0.4]
F9 BNA-DEN MAR 0.2>0.5[1.0] APR 0>0.4[1.0]
F9 BOS-DEN APR 0>0.7[0.0]
F9 BOS-MCO MAR 0.3>0.9[0] APR 0>0.7[0.3]
F9 BOS-MIA MAR 0.2>0.5[0] APR 0>0.4[0]
F9 BOS-RDU MAR 0.2>0.5[0] APR 0>0.3[0]
F9 BUF-MCO MAR 0.4>1.0[0.9] APR 0>1.0[0.9]
F9 BUF-RSW MAR 0.2>0.5[0.4] APR 0>0.6[0.4]
F9 BWI-DEN MAR 0.2>0.5[0.3] APR 0>0.4[0.6]
F9 BWI-MCO MAR 0.2>0.5[0] APR 0>0.4[0.3]
F9 BZN-DEN MAR 0.2>0.6[0.6] APR 0>0.4[0.5]
F9 CID-DEN MAR 0.2>0.5[0.3] APR 0>0.6[0.3]
F9 CLE-CUN MAR 0.2>0.4[0.4] APR 0>0.3[0.4]
F9 CLE-DEN MAR 0.2>0.5[0.4] APR 0>0.3[0.6]
F9 CLE-FLL MAR 0.1>0.3[0] APR 0>0.2[0]
F9 CLE-MCO MAR 0.5>1.5[1.3] APR 0>1.2[1.3]
F9 CLE-MIA MAR 0.2>0.5[0] APR 0>0.4[0]
F9 CLE-PHX MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 CLE-PUJ MAR 0.2>0.5[0.4] APR 0>0.3[0.4]
F9 CLE-RSW MAR 0.7>2[1.0] APR 0>1.5[1.0]
F9 CLE-TPA MAR 0.7>1.7[0.9] APR 0>1.2[0.9]
F9 CLT-DEN MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 CLT-LAS MAR 0.4>1.0[0] APR 0>0.7[0]
F9 CLT-MCO MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 CLT-PHL MAR 0.4>1.0[0.5] APR 0>0.7[0.5]
F9 CMH-MCO MAR 0.2>0.5[0.4]
F9 COS-LAS MAR 0.5>1.5[0.9] APR 0>1.0[0.9]
F9 COS-MCO MAR 0.2>0.5[0.6] APR 0>0.3[0.6]
F9 COS-PHX MAR 0.5>1.5[0.9] APR 0>1.0[0.9]
F9 CUN-CVG APR 0>0.2[0.3]
F9 CUN-DEN MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 CUN-IND MAR 0.1>0.3[0] APR 0>0.2[0]
F9 CUN-MCI MAR 0.2>0.5[0.4] APR 0>0.3[0.4]
F9 CUN-ORD MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 CUN-PHL MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 CUN-STL MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 CVG-DEN MAR 0.2>0.5[0.6] APR 0>0.4[0.6]
F9 CVG-FLL MAR 0.2>0.5[0] APR 0>0.4[0]
F9 CVG-MCO MAR 0.5>1.5[1.0] APR 0>1.2[1.0]
F9 CVG-MIA MAR 0.2>0.5[0] APR 0>0.4[0]
F9 CVG-MSY MAR 0.1>0.3[0] APR 0>0.2[0]
F9 CVG-PHX MAR 0.2>0.5[0.6] APR 0>0.3[0.6]
F9 CVG-RSW MAR 0.5>1.3[1.0] APR 0>0.9[1.0]
F9 CVG-SRQ MAR 0.2>0.5[0] APR 0>0.3[0]
F9 DCA-DEN MAR 1.1>3[3] APR 0>2[3]
F9 DEN-DSM MAR 0.2>0.6[0.6] APR 0>0.4[0.6]
F9 DEN-FAT MAR 0.2>0.4[0.4] APR 0>0.3[0.4]
F9 DEN-FLL MAR 0.4>1.0[0.6] APR 0>0.7[1.0]
F9 DEN-FSD MAR 0.2>0.5[0.6] APR 0>0.3[0.6]
F9 DEN-HRL MAR 0.1>0.4[0.4] APR 0>0.3[0.4]
F9 DEN-IAH MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 DEN-IND MAR 0.2>0.5[0.4] APR 0>0.6[0.4]
F9 DEN-LAS MAR 1.4>4[3] APR 0>3[4]
F9 DEN-LAX MAR 0.7>2[1.4] APR 0>1.7[1.6]
F9 DEN-MCI MAR 0.2>0.5[0.4] APR 0>0.3[0.4]
F9 DEN-MCO MAR 0.8>2[2] APR 0>1.7[2]
F9 DEN-MEM MAR 0.2>0.5[0.6] APR 0>0.3[0.6]
F9 DEN-MIA MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 DEN-MKE MAR 0.2>0.5[0.4] APR 0>0.4[0.5]
F9 DEN-MSN MAR 0.2>0.5[0.6] APR 0>0.3[0.5]
F9 DEN-MSY MAR 0.2>0.5[1.0] APR 0>0.4[1.0]
F9 DEN-OKC MAR 0.2>0.5[0.5] APR 0>0.3[0.5]
F9 DEN-ONT MAR 0.4>1.0[0.4] APR 0>0.7[0.5]
F9 DEN-ORD MAR 0.4>1.0[1.4] APR 0>0.7[1.5]
F9 DEN-ORF MAR 0.1>0.3[0.3] APR 0>0.2[0.3]
F9 DEN-PDX MAR 0.4>1.0[1.0] APR 0>1.0[1.1]
F9 DEN-PHL MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 DEN-PHX MAR 1.1>3[2] APR 0>2[3]
F9 DEN-PNS MAR 0.2>0.5[0.3] APR 0>0.3[0.5]
F9 DEN-PSP MAR 0.2>0.5[0.5] APR 0>0.3[0.5]
F9 DEN-RDU MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 DEN-RSW MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 DEN-SAT MAR 0.2>0.5[1.0] APR 0>0.4[1.0]
F9 DEN-SFO MAR 0.7>2.0[1.6] APR 0>1.5[1.8]
F9 DEN-SLC MAR 0.7>2[2] APR 0>1.5[3]
F9 DEN-SMF MAR 0.2>0.5[0.6] APR 0>0.3[0.6]
F9 DEN-SNA MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 DEN-STL MAR 0.2>0.5[1.1] APR 0>0.4[1.2]
F9 DEN-TPA MAR 0.5>1.5[1.6] APR 0>1.2[1.6]
F9 DEN-TUS MAR 0.2>0.5[0.5] APR 0>0.3[0.5]
F9 DEN-TYR MAR 0.1>0.3[0] APR 0>0.2[0]
F9 DEN-XNA MAR 0.2>0.5[0] APR 0>0.3[0]
F9 DFW-LAS MAR 0.2>0.5[0] APR 0>0.4[0]
F9 DFW-MCO MAR 0.2>0.5[0] APR 0>0.4[0]
F9 DFW-PHL MAR 0.2>0.5[0] APR 0>0.4[0.0]
F9 DSM-MCO MAR 0.2>0.4[0.3]
F9 DSM-PHX MAR 0.2>0.5[0.4]
F9 DTW-LAS MAR 0.4>1.0[0] APR 0>0.7[0.0]
F9 DTW-MCO MAR 0.4>1.0[1.3] APR 0>0.7[1.2]
F9 DTW-MIA MAR 0.2>0.5[0] APR 0>0.4[0]
F9 DTW-PHX MAR 0.2>0.5[0] APR 0>0.4[0]
F9 DTW-RSW MAR 0.2>0.5[0.4]
F9 EWR-LAS MAR 0.4>1.0[0] APR 0>0.7[0]
F9 EWR-MCO MAR 0.7>2[0] APR 0>1.5[0]
F9 EWR-MIA MAR 0.7>2[0] APR 0>1.5[0]
F9 EWR-PBI MAR 0.4>1.0[0] APR 0>0.7[0]
F9 EWR-PHX MAR 0.4>1.0[0] APR 0>0.7[0]
F9 EWR-SJU MAR 0.2>0.5[0] APR 0>0.4[0]
F9 FAR-PHX MAR 0.2>0.5[0]
F9 FLL-ISP MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 FLL-TTN MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 GEG-LAS MAR 0.3>0.7[0.3] APR 0>0.5[0.3]
F9 GRB-MCO MAR 0.2>0.5[0] APR 0>0.4[0]
F9 GRR-MCO MAR 0.2>0.5[1.0] APR 0>0.3[1.0]
F9 GRR-PHX MAR 0.1>0.3[0.3]
F9 GRR-RSW MAR 0.2>0.5[0.6] APR 0>0.3[0.6]
F9 GRR-TPA MAR 0.2>0.5[0.4] APR 0>0.3[0.4]
F9 GSP-MCO MAR 0.2>0.5[0] APR 0>0.3[0]
F9 HSV-MCO MAR 0.1>0.3[0.4] APR 0>0.2[0.4]
F9 IAH-LAS MAR 0.3>0.7[0] APR 0>0.5[0.0]
F9 IAH-MCO MAR 0.2>0.5[0] APR 0>0.3[0.0]
F9 IND-LAS MAR 0.2>0.6[0.6] APR 0>0.4[0.6]
F9 IND-MCO MAR 0.2>0.6[0.6] APR 0>0.4[0.6]
F9 IND-RSW MAR 0.2>0.5[0.6]
F9 ISP-MCO MAR 0.5>1.6[1.4] APR 0>1.1[1.4]
F9 ISP-PBI MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 ISP-RSW MAR 0.4>1.0[0.4] APR 0>0.9[0.4]
F9 ISP-TPA MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 LAS-LAX MAR 0.4>1.0[0] APR 0>0.7[0]
F9 LAS-MCO MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 LAS-MIA MAR 0.4>1.0[0] APR 0>0.7[0]
F9 LAS-MKE MAR 0.2>0.5[0.6] APR 0>0.3[0.5]
F9 LAS-ORD MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 LAS-PDX MAR 0.2>0.6[0] APR 0>0.4[0]
F9 LAS-PHL MAR 0.4>1.0[0] APR 0>0.7[0.0]
F9 LAS-PHX MAR 0.7>2[0] APR 0>1.5[0]
F9 LAS-RDU MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 LAS-RNO MAR 0.2>0.6[0] APR 0>0.4[0]
F9 LAS-SAN MAR 0.4>1.0[0] APR 0>0.7[0.0]
F9 LAS-SEA MAR 0.2>0.6[0] APR 0>0.4[0]
F9 LAS-SFO MAR 0.4>1.0[0.4] APR 0>0.7[0.4]
F9 LAS-SJC MAR 0.3>0.8[0.3] APR 0>0.6[0.3]
F9 LAS-SMF MAR 0.4>1.0[0.4] APR 0>0.7[0.4]
F9 LAS-SNA MAR 0.4>1.0[0] APR 0>0.7[0]
F9 LAS-STL MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 LAS-TPA MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 LGA-MCO MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 LGA-MIA MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 MBJ-PHL MAR 0.1>0.3[0.3] APR 0>0.2[0.3]
F9 MCI-MCO MAR 0.2>0.4[0]
F9 MCO-MDT MAR 0.2>0.5[0.4] APR 0>0.6[0.4]
F9 MCO-MKE MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 MCO-MSN MAR 0.2>0.5[0.4]
F9 MCO-MSP MAR 0.2>0.5[0.7]
F9 MCO-MSY MAR 0.2>0.5[0.7] APR 0>0.4[0.7]
F9 MCO-OKC MAR 0.1>0.3[0.3] APR 0>0.2[0.3]
F9 MCO-OMA MAR 0.2>0.5[0.3]
F9 MCO-ONT MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 MCO-ORD MAR 0.5>1.5[1.6] APR 0>1.2[1.5]
F9 MCO-PIT MAR 0.2>0.5[0] APR 0>0.3[0]
F9 MCO-PVD MAR 0.4>1.0[0.7] APR 0>0.9[0.8]
F9 MCO-PWM MAR 0.2>0.5[0.6] APR 0>0.6[0.7]
F9 MCO-RDU MAR 0.4>1.0[1.0] APR 0>0.6[1.1]
F9 MCO-SAN MAR 0.4>1.0[0] APR 0>0.7[0]
F9 MCO-SAT MAR 0.2>0.4[0.3]
F9 MCO-SDF MAR 0.2>0.5[0.3]
F9 MCO-SJU MAR 0.4>1.0[0.5] APR 0>0.7[0.5]
F9 MCO-STL MAR 0.4>1.0[1.0] APR 0>0.7[1.2]
F9 MCO-SYR MAR 0.2>0.6[0.6] APR 0>0.7[0.6]
F9 MCO-TTN MAR 0.6>1.9[1.6] APR 0>1.5[1.7]
F9 MCO-TYS MAR 0.1>0.3[0] APR 0>0.2[0]
F9 MIA-ORD MAR 0.4>1.0[0.9] APR 0>0.7[0.8]
F9 MIA-PHL MAR 0.4>1.3[0.7] APR 0>1.3[0.7]
F9 MIA-RDU MAR 0.4>1.0[0] APR 0>0.7[0]
F9 MKE-PHX MAR 0.2>0.5[0.6] APR 0>0.3[0.6]
F9 MKE-RSW MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 MKE-TPA MAR 0.4>1.0[0.6] APR 0>0.7[0.6]
F9 MSP-RSW MAR 0.2>0.5[0.4]
F9 MSP-TPA MAR 0.2>0.5[0.6]
F9 MSY-PHL MAR 0.2>0.5[0.7] APR 0>0.3[0.7]
F9 MYR-TTN MAR 0>0.2[0] APR 0>0.3[0.4]
F9 OMA-RSW MAR 0.2>0.4[0.3]
F9 ORD-PUJ MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 ORD-PVR APR 0>0.2[0.3]
F9 ORD-RSW MAR 0.4>1.0[0.7] APR 0>0.4[0.7]
F9 ORD-TPA MAR 0.4>1.0[1.0] APR 0>0.7[1.0]
F9 PBI-PHL MAR 0.2>0.5[0.4] APR 0>0.6[0.4]
F9 PBI-TTN MAR 0.5>1.3[1.0] APR 0>0.7[1.0]
F9 PHL-PUJ MAR 0.2>0.4[0.4] APR 0>0.3[0.4]
F9 PHL-RSW MAR 0.7>2[1.0] APR 0>1.3[1.0]
F9 PHL-SJU MAR 0.4>1.0[0.5] APR 0>0.7[0.6]
F9 PHL-TPA MAR 0.7>2[1.2] APR 0>1.7[1.1]
F9 PHX-SAN MAR 0.4>1.0[0] APR 0>0.7[0]
F9 PHX-SLC MAR 0.4>1.0[0] APR 0>0.7[0]
F9 PVD-RSW MAR 0.2>0.5[0.3] APR 0>0.5[0.3]
F9 PVD-TPA MAR 0.2>0.5[0.6] APR 0>0.4[0.6]
F9 PWM-RSW MAR 0.2>0.6[0.3] APR 0>0.7[0.3]
F9 PWM-TPA MAR 0.2>0.5[0.4] APR 0>0.5[0.4]
F9 RDU-TTN MAR 0.2>0.5[0.3] APR 0>0.4[0.3]
F9 RSW-SYR MAR 0.2>0.5[0.4] APR 0>0.6[0.4]
F9 RSW-TTN MAR 0.4>1.0[0.7] APR 0>0.9[0.7]
F9 SJU-TPA APR 0>0.2[0]
F9 SRQ-TTN MAR 0.2>0.5[0] APR 0>0.4[0]
*FI KEF-SFO MAY 0.4>0[0.6] JUN 0.6>0[0.6] JUL 0.6>0[0.6]
G3 BSB-MIA FEB 1.0>0.6[1.0] MAR 1.0>0.6[1.0] APR 1.0>0.6[1.0] MAY 1.0>0.5[1.0] JUN 1.0>0.6[1.0]
G3 FOR-MCO JAN 1.0>0.6[1.0] FEB 1.0>0.4[1.0] MAR 1.0>0.4[0.7] APR 1.0>0.4[0.6] MAY 1.0>0.4[0.2] JUN 1.0>0.4[0.4]
G3 FOR-MIA JAN 1.0>0.4[1.0] FEB 1.0>0[1.0] MAR 1.0>0[0.6] APR 1.0>0[0.4] MAY 1.0>0[0] JUN 1.0>0[0.2]
I4 JNU-KLW NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0]
I4 JNU-KTN NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5] FEB 0.5>0[0.5] MAR 0.5>0[0.5] APR 0.5>0[0.5] MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5]
I4 JNU-PSG NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0]
I4 KLW-KTN NOV 5>3[5] DEC 5>3[5] JAN 5>3[5] FEB 5>3[5] MAR 5>3[5] APR 5>3[5] MAY 5>3[5] JUN 5>3[5] JUL 5>3[5]
I4 KTN-PSG NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5] FEB 0.5>0[0.5] MAR 0.5>0[0.5] APR 0.5>0[0.5] MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5]
KG DEN-TEX DEC 1.0>1.3[0] FEB 1.0>1.7[0.5] MAR 1.0>1.7[1.0]
*NK AUS-BNA MAR 0>0.2[0] APR 0>0.7[0]
*NK AUS-CUN MAR 0>0.5[0] APR 0>0.4[0]
*NK AUS-EWR MAR 0>0.2[0] APR 0>0.7[0]
*NK AUS-MCO MAR 1.0>1.5[1.0] APR 0.7>1.1[1.0]
*NK BNA-CUN MAR 0>0.5[0] APR 0>0.3[0]
*NK BNA-EWR MAR 0>0.6[0] APR 0>0.7[0]
*NK BNA-LAX MAR 0>0.6[0] APR 0>0.7[0]
*NK BNA-MCO MAR 1.0>1.5[0] APR 0.7>1.0[0]
OZ HNL-ICN APR 0.7>1.0[0.7] MAY 0.7>1.0[0.9] JUN 0.7>1.0[0.7] JUL 0.7>1.0[0.7]
TS FLL-YUL MAY 0.2>0.6[0.1] JUN 0.2>0.6[0.2] JUL 0.3>0.7[0.3]
TS MCO-YUL MAY 0.2>0.5[0.1] JUN 0.2>0.4[0.2] JUL 0.3>0.6[0.3]
*TS SAN-YUL JUN 0>0.2[0] JUL 0>0.4[0]
UA ABE-ORD MAR 3>2[2]
UA ABQ-ORD MAR 1.9>1.1[1.1]
UA AEX-IAH MAR 3>2[3]
*UA ANC-LAX JUN 0>0.4[0] JUL 0>1.0[0]
UA BDL-ORD MAR 4>2[4]
UA BOI-DEN MAR 5>4[4]
UA BOS-ORD MAR 8>7[6]
UA BTV-ORD MAR 4>2[2]
UA BUF-ORD MAR 4>2[3]
*UA CLE-FLL MAY 1.0>0.2[0] JUN 1.0>0[0] JUL 1.0>0[0]
UA CLT-IAH MAR 5>4[4]
UA CMH-EWR MAR 7>6[5]
UA CMH-IAH MAR 4>3[4]
UA CMH-ORD MAR 8>6[7]
UA COD-DEN JUL 3>4[4]
UA DEN-HDN APR 3>2[1.7]
UA DEN-HNL JUN 1.0>1.9[1.0] JUL 1.0>2[1.0]
UA DEN-MSO JUN 4>3[4] JUL 4>3[4]
UA EWR-GRR MAR 3>2[1.9]
UA FLL-IAD MAR 2>3[2]
UA HRL-IAH DEC 5>4[4]
UA IAD-NAS DEC 0.1>0.5[0.1]
UA LAX-PSC JAN 1.0>0.6[0] FEB 1.0>0.8[0]
UA LAX-SBP FEB 3>4[3]
UA MKG-ORD FEB 2>3[2]
UA ORD-PDX MAR 4>3[3]
UA ORD-RAP MAR 0.9>0.1[0.0]
UA ORD-SAT MAR 3>4[4]
UA ORD-SMF MAR 3>2[1.9]
VH MDE-MIA DEC 1.0>1.3[0] JAN 0.9>1.2[0.8] APR 0>0.6[0.4] MAY 0>0.6[0.3]
WG MCO-YYZ DEC 0>0.3[0.8] JAN 0>0.5[1.0] FEB 0>0.4[0.8] MAR 0>0.4[0.7]
WN LAS-LGB FEB 0.6>1.4[3]
Art at ISP
Re: OAG Changes 10/13/2019:AS Exits SJC-TUS;AA Jan Cuts;F9 Extension
Sun Oct 13, 2019 2:13 pm
So it looks like AA is cutting ISP to PHL to near nothing. 1-2 a day is not a good sign, unless they are replacing it with DCA or CLT...if they leave, no major service to ISP. Just WN and F9, and I would never ever fly F9....
sprxUSA
Sun Oct 13, 2019 2:25 pm
AN is Advanced Air and seems doing Texas-Taos,NM ski service. They use King Air 350 for their EAS service into Silver City, NM; but doubt they would use that for this. Last year was flown with 328jet, iirc, but by some other provider.
Gem State Airlines..."we have a gem of an airline"
MIflyer12
Sun Oct 13, 2019 2:26 pm
So much for 'These are just temporary AA cuts at JFK due to the runway closure. Watch - everything will come back.'
MO11
AN is Advanced Air. It is taking over the Taos Air services which were operated by Ultimate Air earlier this year (scheduled charter). It also operates all of the flights for Surf Air; it appears that some of those flights have spilled into the OAG.
RJNUT
Sun Oct 13, 2019 2:28 pm
What is this?
Taos Air is dropping Ultimate Jet Charter for their sub-service and going with Advanced Air Charters I guess that means switch from FRJ Dornier Jet to a King Air from AUS and Dallas to Taos
Aliqiout
Sun Oct 13, 2019 2:36 pm
This is Taos Air operated by Advanced Air, on Dornier 328's
Good to see continued commitment to SAF-PHX by AA.
peak86
Didn't take long for AS to respond on SEA-TPA...
And UA 2x daily on DEN-HNL next summer!
jplatts
Sun Oct 13, 2019 2:39 pm
AA adding ISP-ORD or ISP-DFW is a possibility as AA already serves both of these hubs nonstop from other destinations in the Northeast.
DL adding ISP-ATL, ISP-BOS, and ISP-DTW are also possibilities as DL already serves other secondary commercial airports such as BUR, MDW, DAL, HOU, LGB, SWF, PHF, OAK, ONT, SNA, SJC, HPN, and ORH.
Ishrion
Sun Oct 13, 2019 2:47 pm
I truthfully don’t understand everyone’s obsession over ISP. Why does AA have to add ISP from other hubs?
DFW-SYR isn’t even served, yet SYR has AA service from 4 different hubs in addition to BOS.
LHUSA
Sun Oct 13, 2019 2:50 pm
Nice to see DEN-HNL twice daily. Is this a first?
SANFan
Sun Oct 13, 2019 2:52 pm
Air Transat showing SAN-YUL service was discovered on the TS website a few days ago and has been discussed a bit; no press release has been issued so far to anyone's knowledge.
According to the website's schedules, they will be using 738s and A321s on the 3x-weekly flights. Seasonal or year-round is unknown.
It will be interesting to see if this route actually begins next June. I hope it does!
bb
AirFiero
Sun Oct 13, 2019 3:12 pm
Didn’t WN go 2x/daily on that route? If so, they ran AS off that route.
Ishrion
Sun Oct 13, 2019 3:13 pm
Has AA DFW-TLV still not been loaded? AA said it would be available for purchase on the 10th...
SANFan
Sun Oct 13, 2019 3:22 pm
Interesting. I assume the SJC-Vegas flight is for the annual electronics show as that is not a regular route of AS.
Also, SAN-SLC was just increased last Sunday to daily-double service for most of 2020 (Feb thru July) and this week AS is backing it off. Someone at Route Planning in SEA got a little overzealous on their keyboard I guess.
Likewise, SJC-TUS last week showed a decrease in the route but it was still there at least; this week, it's gone completely...
bb
SANFan
Sun Oct 13, 2019 3:26 pm
Interesting. I assume the SJC-Vegas flight is again this year for the annual electronics show as that is not a regular route of AS.
bb
jasoncrh
Sun Oct 13, 2019 3:27 pm
A little random, but building on the F9 extension. Does anybody know if they will bring den-sdf back? They’re dropping it (seasonally?) in December and flying den-mco through this extension. This year they flew den-sdf every month. Is f9 exiting sdf entirely?
RJNUT
Sun Oct 13, 2019 3:37 pm
Nice to see additional frequency DEN-TEX on KG for peak season. Must have a freed up DO328 due to RIW/SHR drops in January.
DEN1895
Sun Oct 13, 2019 4:03 pm
I believe it is, this past summer was the first year of two 777s (HNL and OGG). They are still both showing in the schedule in addition to a new 757 on the HNL route earlier in the morning.
MO11
Sun Oct 13, 2019 4:07 pm
It will be the same 328JET as last season.
SFOtoORD
Sun Oct 13, 2019 4:21 pm
Shows the power of the DEN hub. If I had to connect to Hawaii I’d probably choose DEN over SFO or LAX.
KLMatSJC
Sun Oct 13, 2019 4:26 pm
Yes, SJC-LAS is for CES. 8 flights over 5 days. I think SJC-TUS was cut with the other announcements last week and there might have been an error in filing.
A318/19/20/21/21N A332/3 A343/5 A388 B712 B722 B732/3/4/7/8/9/9ER B744/4M B752/3 B762ER/3/3ER/4ER B772/E/L/W B788 CRJ2/7/9 Q400 EMB-120 ERJ-135/140/145/145XR/175 DC-10-10 MD-82/83/88/90
Long Live the Tulip, Cactus, and Redwood
KLMatSJC
Sun Oct 13, 2019 4:28 pm
RJNUT wrote:
What is this?
Advanced Air Charter does Surf Air flights as well, which explains the other 3.
FLYKTPA
Sun Oct 13, 2019 4:45 pm
Alaska’s TPA flight was actually 2x daily last fall-winter/spring too. Crazy how there’s gonna be 3x daily now in a market some users on here insisted would never see nonstops.. :)
Huge fan of Tampa International Airport
evank516
Sun Oct 13, 2019 4:59 pm
Do you realize how densely populated Long Island is compared to the area surrounding Syracuse. There's no comparison.
Ishrion
Sun Oct 13, 2019 5:03 pm
Yet... American only serves it from PHL, which is now being reduced.
Both UA and DL don't even serve the airport. It's just Southwest/Frontier.
maximairways
Sun Oct 13, 2019 5:16 pm
Lots of UA ORD cuts?
jfklganyc
Sun Oct 13, 2019 5:24 pm
The FAA and Port Authority need to step in and seize the excess slots from AA at JFK
This isn’t right any longer
Beyond the BS runway excuse
Other airlines want those slots and they are stifling competition
Just shed the slots, go down to 60 or so flights and call it a day
Scarebus34
Sun Oct 13, 2019 5:31 pm
jfklganyc wrote:
The FAA and Port Authority need to step in and cease the excess slots from AA at JFK
Scott Kirby is salivating at the thought...
Varsity1
Sun Oct 13, 2019 5:32 pm
JFK really is handicapped on capacity right now. Any kind of weather event brings the airport into a halt.
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
Scarebus34
Sun Oct 13, 2019 5:41 pm
That can be said about any NY area airport...it's more so the airspace, not the airport.
LHUSA
Sun Oct 13, 2019 5:51 pm
[twoid][/twoid]
Not a major reduction compared to previous year, the figure in the brackets, actually some small increases
Scarebus34
Sun Oct 13, 2019 5:54 pm
I would guess Max related - they can always add back into the schedule but its a lot more challenging to take out after tickets have been sold. Probably being careful not to over promise during Spring Break period.
hiflyeras
Sun Oct 13, 2019 6:21 pm
Can't believe that AA will be down to 2x daily SEA-ORD...it seems like they used to run 4-5 flights per day on that route. Meanwhile, AS has grown to 5x daily.
jplatts
There are actually a few more domestic routes that could be added by B6 out of JFK such as JFK-CLE, JFK-DFW, JFK-DTW, JFK-MSP, and JFK-BNA if B6 can acquire extra slots at JFK.
tphuang
Sun Oct 13, 2019 6:25 pm
Thanks enilria
Really? This is pretty weak even to their hubs. JFK might not stick around. Other routes, we'd need to see if they add this back after MAX issues.
As I posted in the JetBlue thread, AA is down about 10% in yield relative to DL/B6 in the past 2 years and 7% in just the past year. That shows how much their pricing power in NYC has slid. The slide that started when they started cutting at JFK has really picked up the pace the past year. And their pricing power will keep sliding as important market like SEA/SAN/LAS have basically stopped flying in the past year. Not sure what's the point of keep YUL/YYZ/CLE/CMH/PIT/PHL around in their schedule if they continue to cut international flying and transcon. The idea that they can somehow wait 5 years for A321XLR to turn things around is extremely optimistic.
I do wonder how long is AA going to be able to keep these JFK slots. I'm sure they can still sell those for value. The MAX grounding is just an excuse. There is no reason for them to keep some of these routes going if they schedule them and then cut them for many months.
Also including LGA here, because the next phase of cuts will be there. Without the ff, those LGA slots are going to really hemorrage
That was a fast response. I presume the cuts are made to help re-allocate capacity to SEA.
That's a pretty quick cut after they made an announcement on JFK-SJU. Are they giving up a LGB slot to WN?
I understand NK has more growth than most airlines, but still seems to be strange they can keep adding this many routes without many cuts.
Given what I've seen their yield here and their lack of commitment to CLE, not a surprise they don't run it in summer time.
FlyingElvii
Sun Oct 13, 2019 7:04 pm
"What is this?
AN DAL-TSM DEC 0>0.2[0] JAN 0>0.5[0] FEB 0>0.4[0] MAR 0>0.4[0]"
Taos Air Branded scheduled charter.
Last year it was operated by Ultimate, but they had crew issues, that caused problems.
Is Key Lime running it this year?
Sancho99504
Sun Oct 13, 2019 7:14 pm
Really surprised that AA is cutting so much from SEA. No more JFK, which during the busy season was 2-3 daily, PHX is going down to 2 daily, which was 6-7 not too long ago. PHL, has 3-4 daily during busy season. The only AA hub that doesn't see a reduction is CLT and LAX. Wonder if DL and AS will backfill some of this, especially MIA/FLL and PHX?
kill 'em all and let God sort 'em out-USMC
rnav2dlrey
Sun Oct 13, 2019 7:19 pm
UA going 4>2 on BDL-ORD is rough, especially after they've already cut BDL-EWR completely.
usflyer msp
Sun Oct 13, 2019 7:51 pm
It does seem like AA cut PHL massively for Jan. I wonder what is behind that?
jplatts
Sun Oct 13, 2019 7:54 pm
AA is still facing a plane shortage in its mainline narrowbody fleet since AA had retired its last MD-80's last month in addition to the 737 MAX not yet back in service.
enilria
Sun Oct 13, 2019 8:30 pm
tphuang wrote:
Thanks enilria
Good comments.
I agree with everybody on AA JFK slots. This is a total scam that they can block these slots from competitors. Port of NY needs to tell them MAR1 they fly the slots or lose them. ...at the risk of being told I always attack AA! Lol. I don’t think I’ve been accused of that one yet.
Thanks to everybody on the AN explanation.
Spirit did do some cuts a week or two ago, so I suppose that was part of the funding here.
AVLAirlineFreq
Sun Oct 13, 2019 8:38 pm
Just doing a quick scan, it seems like quite a few AA CLT routes see a frequency increase.
jplatts
Sun Oct 13, 2019 8:48 pm
In addition to AA reducing frequencies on DFW-SEA, WN is also reducing DAL-SEA nonstop service from year-round to seasonal starting in January 2020.
DL re-adding DFW-SEA nonstop service is a possibility as DFW is one of the top destinations that DL doesn't currently serve nonstop from its SEA hub. Other individuals have also said in the Airliners.net forums that DL still has a FF base in the DFW area, even though DFW had been dehubbed by DL almost 15 years ago.
evank516
Sun Oct 13, 2019 9:08 pm
AA has had fluctuation on the route for a while. DL used to fly to ATL and CVG in the mid-2000s with CR7s to ATL and a mix of CRJs and CR7s to CVG, not to mention DL Express flew to MCO and FLL before Song. AA flew to ORD, CO flew to CLE, and ALB and WN was a power house there. There is a market there, and frankly DL was quite large at JFK and LGA back during this time as well. It's the only NYC area airport that doesn't see DL.
MSPNWA
Sun Oct 13, 2019 9:43 pm
It's a legit reason because of the MAX. It may be a convenient reason to trim the weakest flights when forced to cut capacity due to loss of aircraft, but something has to give when dozens of aircraft are out of service. Do you really expect them to cut at DFW, ORD, MIA, PHL, CLT, LAX, etc. instead?
I would to like to see someone try to force AA to give up JFK slots when the have the MAX reasoning to fall back on. Good luck with that one.
jplatts
Sun Oct 13, 2019 9:48 pm
I agree with your point regarding AA not currently using some of its JFK slots as AA is facing a mainline narrowbody plane shortage due to both the retirement of its MD-80's and the 737 MAX not yet back in service.
tphuang
Sun Oct 13, 2019 9:53 pm
They got special exemption for the runway issue. All that has done is leading them to cut more flights and become even less competitive in NYC. They are not getting any more exemption so they better use the slots or lose them.
jplatts
Sun Oct 13, 2019 10:10 pm
There are actually a few more domestic nonstop routes such as JFK-BHM, JFK-MCI, JFK-SDF, JFK-MKE, JFK-SMF, and JFK-STL that could be added by DL if DL can acquire extra slots at JFK.
Sancho99504
Mon Oct 14, 2019 12:49 am
Was really surprised that SEA-TPA was added before DFW or IAH, especially since it wasn't on the radar. I think DFW may come soon now that Ed has finally decided to encroach on AA, friendship with Parker be damned.
