Antaras
Should Boeing revive 787-3 for NMA project instead of re-desiging the 764?
Mon Oct 14, 2019 11:48 am
In my opinion, I think that it will be better for doing if they choose 787-3 for the NMA Project, instead of B767-400.
Boeing can installed better technologies on 783 as comparisons to the rumored 767X, including tinted windows, composite fuselage.
What do you think?
A rendered B787-3 with winglets installed:
737MAXs' winglets would be ideal dor the 787-3.
Edit signature
This is a block of text that can be added to posts you make. There is a 255 character limit.
Nicoeddf
Re: Should Boeing revive 787-3 for NMA project instead of re-desiging the 764?
Mon Oct 14, 2019 11:56 am
What has changed that makes you think a new 787-3 iteration will be the better solution?
The 787 is still a long haul optimised plane with structural weight for 15h flying, not 3-7.
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
Boeingphan
Mon Oct 14, 2019 12:00 pm
Well it's not exactly like the 764 isn't saddled with similar bones? A quick search on flightaware shows most flights in the 9-10hr range.
leleko747
Well, so was the 747, but Boeing could modify it for domestic flights (B747-100SR and 400D versions).
I wonder when people will understand:
Embraer 190 or simply E190, not ERJ-190. E-Jets are NOT ERJs!
Boeing 747-8, not Boeing 747-800. Same goes for 787.
Airbus A320, not Airbus 320.
Airbii does not exist.
IWMBH
Mon Oct 14, 2019 12:11 pm
The 're-design' of the 764 is not actually a redesign, its just the replacement of an outdated engine with a more modern one. The reason the 767 program is still alive and the re-engine makes sense is the freighter-market. The 787 doesn't have that, the plane is designed with light-weight materials not suited for hauling cargo. So, the only market you could target for is the pax market. They did that some years ago with no success, what makes you think it would work this time?
TC957
Mon Oct 14, 2019 12:15 pm
I think with hindsight Boeing should never have dropped the 787-3. Yes, I know the troubles they had with getting the 787 production up & running that caused the 787-3 version to get dropped, but surely it would have sold well in China especially. Lots of 787-8/9's now doing sub-3hr internal China flights, plus ANA using them on many domestics where the -3 was aimed at.
oldannyboy
Mon Oct 14, 2019 12:28 pm
I think the option of 'lightweight' 787/3 de-saddled with all the extra ER-compliant machinery and mechanisms should indeed be looked at... I for one fail to see how a revived 764 would be better...unless of course the re-engine goes ahead anyway for the freighter variant, and thus the pax version comes cheaply as an easily available aside...
keesje
Mon Oct 14, 2019 12:34 pm
It would be a 110t NMA, twice the weight of A321 XLR. With huge cargo capacity at the cost of a 787-8. Maybe it will cost a bit more (off standard) than a 787-8, but it will be be less capable/flexible. So IMO if purchase price, operating cost & fuel consumptions are not that important, this might fly.
B764er
Mon Oct 14, 2019 12:36 pm
The 783 can be built at anytime. It is a modern technology jetliner that will have a slightly reduced range at a lower price (airlines love that) so Boeing should approach the airlines and offer it again. The worst that can happen is a "not interested" reply from them, so no harm done to anyone. The 787 was originally intended as a 767 replacement, and as much as I love the 767, I think it's time to move forward. With the MAX mess that's happening now, It looks like the 737 may have gone as far as it could and may need to be replaced, so now it looks like the NMA is going to be something different than originally planned. It may now be the 783.
par13del
Mon Oct 14, 2019 12:47 pm
The NMA based on what we have heard is around the size of a 767-200, so if we look at the 787-3 from that perspective the a/c is just too large, it cannot be optimized down to size without a new wing and fuselage. Smaller engines could be put on the frame but the weight based on its size is the issue.
The production facilities and methods from the 787 and 777X do exist for a CFRP smaller wing and fuselage which is what I think is required to if the a/c is to be competitive with the A321 in certain segments of the market.
Amiga500
Mon Oct 14, 2019 12:52 pm
Neither is a good option.
Boeing would be safer keeping their money and concentrating on a single aisle replacement for the 737. The cost of which is growing by the week, and Boeing haven't even got to the start line on that program!!
RJMAZ
Mon Oct 14, 2019 1:05 pm
I am a fan of the idea of a 787-6 and 787-7.
It would have to be done right. A unique fully optimised wing and a new fully optimised 55,000lb thrust engine. 767 sized landing gear.
787-6 length 50m oew 100t mtow 170t 5500nm
787-7 length 56m oew 105t mtow 170t 4500nm
787-8 length 56m oew 120t mtow 228t 7300nm
787-9 length 62m oew 129t mtow 254t 7600nm
The 787-6 is actually pretty small in terms of cabin area.
767-300 = 190m2
787-6 = 200m2
A300 = 215m2
767-400 = 221m2
787-7/8 = 232m2
Nicoeddf
Mon Oct 14, 2019 1:36 pm
Exactly - not similar bones. 20 tons empty weight is quite a difference.
Nicoeddf
Mon Oct 14, 2019 1:37 pm
And what a widespread use and success it was!
Nicoeddf
That's it exactly.
VV
Mon Oct 14, 2019 1:38 pm
No.
scbriml
Mon Oct 14, 2019 1:42 pm
IT seems a lot of people have forgotten why the 787-3 was dropped.
ThalesCoelho
Mon Oct 14, 2019 1:47 pm
What the world really need is a real A300neo, a short to medium haul wide-body.
Elementalism
Mon Oct 14, 2019 2:27 pm
Hard to do shrinks. With that said the 767-400 is larger than I would had expected Boeing solution to MOM to be. I was expecting something like a 767-200ER. I dont think there is enough differentiation between the 767-400ER and 787-8.
Scotron12
Mon Oct 14, 2019 2:39 pm
And what would be the cost to the airlines?? Can Boeing produce a 787-3 for 50-60M?
iberiadc852
Mon Oct 14, 2019 2:41 pm
I have been thinking about that for a long time.
But wouldn't it be the same if Boeing gets to make 8ab comfortable enough. in a 767-NEO?
Or even NMA focused on that?
variety is the spice of life; that's what made the "old times" so good
Aptivaboy
Mon Oct 14, 2019 2:42 pm
I"m wondering how much cost has to do with this. A minimal change 767 will likely get to market much, much faster than a completely new 787 version. It will also likely require less certification time (I know, after the MAX debacle that isn't always a good thing) than a new 787 variant. I mean, if the reports are accurate we're mainly looking at strengthening the MLG, a mostly new cockpit and engines. With the penalties and lawsuits from the 737-MAX fiasco starting to pile up, cost might be more of a factor than we're realizing. Bang out a relatively quick variant, push some product out the door, earn some Benjamins. They might earn more cash in the long run with a 787-based product in this niche, but is Boeing thinking about the long term?
leleko747
Mon Oct 14, 2019 3:07 pm
It was not meant to be a sale success, it just had to meet the demands of Japanese operators. Sure, if other airlines decided to buy them, Boeing would certainly sell.
Stitch
Mon Oct 14, 2019 3:23 pm
Exactly.
For those who have forgotten, the 52m wingspan of the 787-3 so impacted the aerodynamic efficiency that the 787-8 outperformed it on stage lengths over 500km. Since even Japan has few 500km stage length missions, they agreed to/decided to swap their orders for the type to the 787-8 and no other operator showed interest into it.
And no, folding wingtips are not an option: there is neither enough span outboard of the control surfaces to allow it nor were the wings designed to allow it.
Momo1435
Mon Oct 14, 2019 3:37 pm
The 787-8 already had a better performance then the 787-3 would have had on short hops. So good luck at making it compete with a plane that has a significantly lower weight.
PacoMartin
Mon Oct 14, 2019 4:01 pm
RJMAZ wrote:
767-400 = 221m2
787-8 = 232m2
The Operating Empty Weight of the B767-400ER is 103.872 tonnes. United 39Polaris + 70Plus® + 131-33E (24,140 US gal / 5,625 nmi)
The Operating Empty Weight of the B787-8 is 119.950 tonnes. United 36Polaris + 70Plus® + 113E (33,340 US gal / 7,355 nmi )
F14TCT
Mon Oct 14, 2019 6:48 pm
The 787-3 is too heavy. Boeing needs to start a brand new line of aircraft that will be the start of some upward commonality.
Nicoeddf
Yeah yeah yeah, I know. And the 767-400ER wasn't meant to be a sale success as well.
N776AU
Mon Oct 14, 2019 7:06 pm
We do. It's called the A330-200.
Careful, doors are closing, and will not reopen. Please wait for the next train.
PhilMcCrackin
Mon Oct 14, 2019 7:08 pm
It's revisionist history just like everyone who forgets why the 757 was cancelled.
texl1649
Mon Oct 14, 2019 7:09 pm
IF Boeing were really considering the 767-400Max concept with GenX, then they'd also be evaluating a new composite wing for the bird. The problem with all this commentary hysteria is precisely that, if you need a new wing with folding tips to make the 767 work as a PAX aircraft again (within gate constraints), you might as well put said wing on the 787.
You'd be re-designing the wings, wing box, many interior bits, tail, supply chain, and avionics/systems for the 767 anyway; why bother? If you (or your customers) do want such a plane, for cargo or pax, PIP the engines for the 787 and throw the wing on it, for goodness sakes. Same cost without the 70's drawbacks.
IWMBH
Mon Oct 14, 2019 7:10 pm
The A332 is the long-range version of the A330, not a wide-body designed for the short to medium haul.
Stitch
Mon Oct 14, 2019 7:15 pm
Yes, an A330-200 can do an A300-600's mission, but like the 787 vs. 767, she carries a significant amount of extra structural weight for the job (~35,000kg worth).
889091
Mon Oct 14, 2019 7:58 pm
One can't help but wonder how much the 737-MAX debacle has affected Boeing's R&D budget.....
texl1649
Mon Oct 14, 2019 8:20 pm
And also, that despite protestations circa 2016, the MAX has now cost the company something on the order of $8-10 billion, vastly less than the NSA alternative then pitched by Boeing leadership for EIS around 2020 (now).
Waterbomber2
Mon Oct 14, 2019 9:42 pm
More like 14 tons, and by the time you are done adding 2 heavier GEnx's, closer to 10 tons, so essentially B764MAX = B788
Nicoeddf
Mon Oct 14, 2019 10:41 pm
Yeah, what's even 8-10% heavier in OEW these days...absolutely the same.
KFTG
Mon Oct 14, 2019 10:51 pm
And how many of those were built?
Kinetic
Mon Oct 14, 2019 11:01 pm
How about reevaluating subcontractors first of all?
Kinetic
Mon Oct 14, 2019 11:07 pm
(To the question itself: Whatever serves short to middle distance routes better.)
XT6Wagon
Tue Oct 15, 2019 12:11 am
The 783 can be reborn *if* folding wingtips can be done. The 788 is already a better 783 as it sits, so the only hope for a specialty model is to regain the ability to use smaller gates without crippling the economics.
I doubt either frame will be used for NMA as they are looking for production costs far closer to narrowbody than widebody.
JayinKitsap
Tue Oct 15, 2019 12:14 am
There really needs to be a good choice for a high capacity moderate range, high cycle airplane - but it was not the 783. All of the weight of the 788 but without the capability. Having a frame able to carry a 100T of extra fuel than the mission requires will not be the most economical planes out there.
LAX772LR
Tue Oct 15, 2019 8:00 am
And those were bought by what, a grand total of two airlines?
...not exactly sure why anyone would use that as a successful example of anything.
:checkmark: :checkmark:
"Folding wingtips" doesn't do squat to address the issue that a full 783 would be twice the weight of even the heaviest A321, but would not carry twice the pax (in comparable configurations) nor offer longer range.
That's a lot of inflexibility to deal with, in exchange for .....well..... nothing.
Smaller gate access isn't going to change that. Which might explain why nobody wanted it.
And before anyone screams "cargo!" as a reflexive counterpoint:
what airline flies enough shorthaul cargo to address the aforementioned? Not the Japanese, who turned it down in the first place. So who?
Nicoeddf
Tue Oct 15, 2019 10:34 am
Absolutely agree with your post.
And the "Cargo" reflex is maybe the most overrated thing on a.net besides Airbus giving planes for free and should Boeing re-start the 757 line.
Ah, by the way, what about a 757Neo? :stirthepot:
dtw2hyd
Tue Oct 15, 2019 10:41 am
Assuming Boeing had allocated R&D dollars prior to the debacle. IMHO, most BCA R&D dollars are being wasted on 777X and other programs including 737MAX suffered.
All posts are just opinions.
leleko747
Tue Oct 15, 2019 12:29 pm
lol you probably missed this post of mine:
hz747300
Tue Oct 15, 2019 1:37 pm
Probably makes sense for a freighter. Is it possible to strengthen a 787 fuselage to be a cargo aircraft? I have an ok view of the cargo ramp from my flat in HK, and I see 747s, 777s, and 767s with the odd A332F here and there--there is probably a spot in the market for an updated 767. How would the re-engined 767 work as a midair refueler?
Keep on truckin'...
Stitch
Tue Oct 15, 2019 1:56 pm
I have read the 787 was designed from the start to have an eventual freighter model (which makes sense) so that should not be an issue.
LAX772LR
Wed Oct 16, 2019 2:36 am
Didn't miss it, just didn't find it applicable... seeing as the 783 *did* have orders, but Boeing see sufficient impetus to push forward and build it.
FLALEFTY
Wed Oct 16, 2019 4:14 am
Reviving the 787-3 would work for the NMA program if Boeing is able to stick to the strict weight budget that they failed to achieve with the early-build 788's. Another hurdle would be deciding on the range for the 783. The Japanese airlines who wanted it were satisfied with 3,500nm. However, if the 783 is going to be a reliable, year-round TATL machine, that range probably would need to be kicked up to around 4,500nm, easily doable, but it would also add weight.
Also, the talk about reviving the 764 and reengining it probably went something like this: FedEx & UPS: "Hey Boeing! What do you have to replace the MD-11F and A306?" Boeing: "Er...How about buying (more) 777F's?" FedEx & UPS: "Nah! Too big & expensive. What else ya' got?" Boeing: "How about more 767F's?" FedEx & UPS: "Nope! We got enough of those." Boeing: "Well, what about a 764F with some new GE engines?" FedEx & UPS: "We'll get back to you. (Hey UPS, do you still have Airbuses' number handy?)"
