F737NG
Two AA flights diverted to Dublin
Mon Oct 21, 2019 3:45 pm
Per BBC news, AA729 and AA787 both diverted into DUB earlier today due to medical emergencies.
https://www.bbc.com/news/uk-50128483
The 729 flight divert was caused by a 'chemical spillage'.
Despite initial re-scheduling of a 15:00 departure, 729 doesn't appear to have left DUB as yet.
If "two crew members and one passenger went to hospital for evaluation", how can AA729 operate without a full compliment of crew? Does AA over-provide the 1:50 cabin crew requirement for TATL flights?
Rookie87
Re: Two AA flights diverted to Dublin
Mon Oct 21, 2019 4:11 pm
AA729 can't leave without minimum 8 crew. AA schedules 9 on there and most likely reassigned FAs in DUB, (assumption).
dopplerd
Mon Oct 21, 2019 4:19 pm
This article actually uses a photo of an American A330 in a story about an American A330! It is a -200 instead of a -300 but I'm willing to give them a pass on that point.
BY1881
Mon Oct 21, 2019 4:27 pm
In exceptional circumstances you operate 1 under legal minimum crew compliment when down route. How ever you need to have 1 crew member per 50 passengers so potentially you might need to offload some passengers.
CriticalPoint
Mon Oct 21, 2019 4:42 pm
It’s based on seats not passengers
readytotaxi
Mon Oct 21, 2019 4:57 pm
CNN are reporting that it was a spill in the galley.
Why are they using something that strong?
Growing older, but not up.
wjcandee
Mon Oct 21, 2019 5:05 pm
Maybe they weren't. Ever sit near the galley when an FA is working on her nails? The smell is awful. Perhaps an FA had some chemicals for her personal use, or some such.
PI4EVR
Mon Oct 21, 2019 5:11 pm
AA729 will remain overnight in DUB and continue to PHL tomorrow morning. AA787 in now airborne and enroute to CLT w/an ETA a bit after 8pm.
BY1881
Mon Oct 21, 2019 10:30 pm
I didn’t take into account the differences between the FAA and CAA.
Cointrin330
Mon Oct 21, 2019 10:57 pm
ABC News reported that the fumes came from a cleaning product, left onboard by the cleaning crew at LHR and it spilled.
LimaFoxTango
Mon Oct 21, 2019 11:07 pm
I'd like to think FA's know better than to use nail polish on an aircraft.
You are said to be a good pilot when your take-off's equal your landings.
wjcandee
Tue Oct 22, 2019 4:55 am
I would too. But unless they're in there sniffing it, they're using it (and/or remover).
robt760
Tue Oct 22, 2019 5:58 am
The “chemical” was Ammonia.
acentauri
Tue Oct 22, 2019 6:30 am
That'll surely do it. Funny they are even permitted to use ammonia, or an ammonia based cleaner inside of an inflight commercial aircraft.
OSL777FLYER
Tue Oct 22, 2019 8:06 am
Although you need a 1:50 cabin crew. Not necessarily all doors have to be "manned". I have flown on flights where they have told me that they were short staffed and one door was "unattended" in other words, passengers were given extra briefings.This particular incident was on a B777-300ER.
HOWEVER, this is only allowed if the aircraft is returning to its base. e.g. if an AA flight is returning to the U.S from Europe, they would be allowed to do this.
ALSO, the 1:50 rule can be broken, if the flight is not full, passengers will then be moved to other parts of the aircraft. This also applies to return to base flights only.
Example: an A320 from BA (not that the airline matters) with 130 passengers on board is flying LHR- MAD-LHR, In MAD, a cabin crew member becomes ill and is unable to fly the return leg, the aircraft can still do so with 3 instead of 4 cabin crew members, but passengers will then be moved away from e.g one of the exits at the back.
jersey777
Tue Oct 22, 2019 9:58 am
Flight Attendants do not use nail polish on the plane. It is a volatile liquid and prohibited. If a passenger uses nail polish we are required to asked them to stop.
twicearound
Tue Oct 22, 2019 10:05 am
Ignore him, he's a notorious FA basher
F737NG
Tue Oct 22, 2019 12:24 pm
I'm almost impressed!
Yep, that's rather noxious stuff.
Easy to forget some of their materials on-board, but it's going to result in a b*****ing for those cleaners.
Yet AA 729 had two crew members who took ill and required hospital observation. I was a little surprised that AA was still going to operate the flight later in the day.
In theory, they must've had crew over and above the legal limit, if they could lose two cabin crew and still thought they would be in a position where they were legal to fly.
wjcandee
Tue Oct 22, 2019 12:54 pm
OMG, now THAT'S funny!
OSL777FLYER
Tue Oct 22, 2019 7:26 pm
On long-haul flights, they are usually always well over the legal limit due to more attention being required in business and first class.
I was on an LH flight from FRA-DXB in January and they had 15 cabin crew onboard. And as we all know, a B747-400 does not seat 750 people.
FluidFlow
Tue Nov 19, 2019 7:33 am
The BBC is challenging the story of AA for the diversion citing anonymous sources that the aircraft was actually in bad shape and that the reason was a broken APU and that AA knew of the broken APU days before.
https://www.bbc.com/news/business-50461302
Phoenix757767
Tue Nov 19, 2019 1:09 pm
That would be false, under ETOPS you can’t dispatch the plane with an inop APU.
Plane in bad shape? A little dramatic I would say.
ilovepabst
Tue Nov 19, 2019 4:48 pm
Can absolutely be dispatched with APU inop for ETOPS provided other items aren't deferred such as IDGs.
CriticalPoint
Tue Nov 19, 2019 4:52 pm
I’m not going to challenge you because of your experience and the MEL is aircraft and airline specific. However you cannot make blanket statements like “you cannot dispatch with an INOP APU on ETOPS flights..”. There are restrictions for sure but you can dispatch ETOPS with an INOP APU. For example United 787s are restricted to ETOPS 180.
Phoenix757767
Tue Nov 19, 2019 5:10 pm
“ 'No connection'
American Airlines claims the odour, which caused two cabin crew to pass out, "was not related to the APU" because the unit was "not operational during this time period and did not operate during this flight".
https://www.bbc.com/news/business-50472901
apodino
Tue Nov 19, 2019 5:30 pm
An A330 can be absolutely be dispatched under ETOPS 120 with an inoperable APU and it happens all the time. A 777 or 787 has more electrical and pneumatic redundancies so they can still go ETOPS 180 even with an inoperable APU. I call BS on this story, as it’s another Aviation article written by someone who knows nothing about aviation looking for clicks.
NWAESC
Tue Nov 19, 2019 5:41 pm
I’m not going to challenge you because of your experience...
What experience is that?
"Nothing ever happens here, " I said. "I just wait."
CriticalPoint
Tue Nov 19, 2019 5:47 pm
I have no reason to doubt that he is a mechanic for AA.
NWAESC
Tue Nov 19, 2019 5:50 pm
I see. Well, maybe he/she will weigh in and confirm/deny that.
jumbojet
Tue Nov 19, 2019 6:56 pm
obviously not working on APU's or any other critical component.
Phoenix757767
Tue Nov 19, 2019 7:18 pm
At LUS we didn’t dispatch the A330 on an ETOPS flight with an inop APU. But they did have the option.
“ No IAW with MEL 49-1. “do not operate on ETOPS flights in excess of 120 min”.
I’m checking on the oil consumption numbers now
Phoenix757767
Tue Nov 19, 2019 7:57 pm
At AA
“ The GPM states that aircraft may not be dispatched for ETOPS flights if an engine/APU exceeds the “high oil consumption limits” as stated in GPM 08-08; table 08,08-2. For the A330 APU that’s 0.60 pints per hour”
NWAESC
Tue Nov 19, 2019 9:20 pm
Are you an AMT? Just curious.
BA777FO
Tue Nov 19, 2019 10:23 pm
Wow. Maybe this is why AA is so keen to dump the A330s in favour of 787s and 777s which can still do 180 minutes ETOPS with an APU u/s.
That said, if the APU was u/s, it wouldn't have diverted, it simply wouldn't have dispatched (if the AA MEL states that it cannot). If a problem developed with the APU in flight then the crew would consult/run the appropriate checklist. Aside from an APU fire that won't extinguish I can't imagine the A330 would require a land at nearest suitable for any other reason. Unless you lose engine generator and your APU is inop but then it really isn't your lucky day!
Phoenix757767
Tue Nov 19, 2019 10:35 pm
They aren’t dumping the 330s, the 333 retirements were pushed back and there are no plans to retire the 332
NWAESC
Tue Nov 19, 2019 11:20 pm
At AA
Who are you quoting here?
Phoenix757767
Wed Nov 20, 2019 3:21 am
At AA
AA’s A330 maintenance manual ETOPS Procedure
NWAESC
Wed Nov 20, 2019 3:30 am
Thanks. How’d you access it?
alpine1989
Wed Nov 20, 2019 3:46 am
That is simply bloody rubbish. An A330 can absolutely be dispatched 120 ETOPS with inop APU per the MEL. It is amazing the folks that make statements on this website with no operational knowledge whatsoever. Read the bloody MEL folks.
Phoenix757767
Wed Nov 20, 2019 3:57 am
They can dispatch it company policy is more strict than the MEL.
NWAESC
Wed Nov 20, 2019 10:26 am
Welcome to the internet, where anyone can pretend to be anything-even an AMT at AA.
FlyingColours
Wed Nov 20, 2019 11:19 am
I think we are getting sidetracked into a discussion about the ETOPS dispatch regs for an inoperative APU rather than focusing on the fact that two crew fell unconscious on a flight due to an odour which the airline claimed was washing up liquid and won't comment further.
Not being funny, I seriously doubt Fairy Liquid is to blame here...
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
