adipasqu
SFO Ops Sunday: Landing on the 01's?
Sat Oct 26, 2019 11:30 pm
Hello All,
We are expected to get some strong winds in the San Francisco Bay Area out of the NNE tomorrow (steady at 20 mph, gusting to 45-60 in San Bruno, not too far from the airport), which should put landings on the 01's. Any SFO'ers have any insight if SFO Ops is going to put landings on the 01's on Sunday? Millbrae BART Parking Lot anyone for some great spotting???
707 712 722 732 733 734 735 73G 738 739 741 742 744 752 753 762 763 764 772 773 D9S D10 319 320 321 332 M80 M82 M83 M87 M88 M90 SF3 ERJ CRJ
maps4ltd
Re: SFO Ops Sunday: Landing on the 01's?
Sat Oct 26, 2019 11:35 pm
Like, over the mountains 1s?
Delta Gold Medallion
Scarebus34
Sat Oct 26, 2019 11:36 pm
No. They’ll likely land on the 10s until the winds switch back around to the NNW and then go back to the 28s.
KSFO 262130Z 2622/2724 29014KT P6SM SCT200
FM270500 29008KT 6SM FU FEW040
FM271200 02015G29KT P6SM FEW035 WS015/02040KT
FM271700 02017G26KT P6SM SKC WS020/02037KT
FM272100 35012G20KT P6SM SKC WS020/02030KT
adipasqu
Sat Oct 26, 2019 11:49 pm
Circle to land on the 01's. They use the normal bridge approach, break it off, then circle around San Mateo, Foster City, Burlingame, and Millbrae to line up on the 01's visually.
maps4ltd
Sun Oct 27, 2019 1:26 am
Nice.
Chasensfo
Sun Oct 27, 2019 1:53 am
As much as I love seeing that approach more than almost anything in life, I've been told by some of the sups that the winds have to be damn near sustained 40 knots before they'll do that. Landing 01s always screwed up SFO, but the new taxiways by 1R from the EMAS construction REALLY screw stuff up. The approach hold for landing traffic is all the way by the fire station near the South Ramp. Look on Google maps and imagine how long it would take to "squeeze" out a departure from that holding point, down Alpha, up Alpha 1, roll, rotate...not good when you have an endless line of planes in a visual landing pattern and 3-4 hour ATC delays. There is a crazy line for 01L too and no one can park since everyone is late and planes can't take off so they last time they closed one of the 28s and lined it up with airplanes because they ran out of pavement. They've only landed 01s for more than a few aircraft once since the construction, I've seen the winds 35 knots straight down the 01s and pilots request the 01s and ATC says "no".
Basically, 36+ knots from 350-030, plausible chance but not a sure thing with less than 40. Winds 330-350 or 030-050, very unlikely unless it is a once a decade kind of crazy windstorm like we had on December 30th 2014, which was the last time the 01s have been the active runway for landing. All other landings on the 01s since then have been one off events when they switch from the 28s to the 10s and send a few guys around to 01R or when a VX A320 had a fuel emergency with winds down the 01s...or when a PC-12 just dropped out of the sky and landed NORDO on 01L with a jetBlue Airbus in it's landing roll out on 19L next door. You know, SFO stuff. :)
It is damn impressive, though.
as739x
Sun Oct 27, 2019 2:39 am
What's not helping the matter of circling to the 01's is visibility is forecasted in the TAF to be around 5mi. The circle to land (a visual) usually begins at 6mi from the field. This will added more un-needed challenge to the approach or make it unusable. Scarebus is probably right that the 10's will be the desired approach to back it up with an RNAV. IF, they do land the 1's we expect some nice pics ChasenSFO
timz
Sun Oct 27, 2019 8:32 pm
As it turned out, no landings on runways 10 on Sunday morning?
Chasensfo
Sun Oct 27, 2019 8:55 pm
Nope, winds were gusting well over 30 knots between 350 and 020 and they never stopped landing 28s. :(
