SteelChair
PW1100G geared turbofan accessory gearbox airworthiness directive
Tue Oct 29, 2019 1:55 pm
Seemingly lost among the hype from the Swiss self imposed grounding, I missed that an airworthiness directive was published that requires replacement of the gearbox.
This appears to be a major hit to PW. They claimed the gearbox was designed for the life of the engine. They said they spent 20 years developing this gearbox and that it was bulletproof. In my opinion, a lot of the problems that the GTF has had to this point have been secondary or tertiary. This seems to me to be a major issue and I'm wondering why there hasn't been any conversation about it or more concern focused upon itm
It appears that this AD affects only the GTF version powering the A320 series.
https://www.flightglobal.com/news/artic ... 0g-461267/
Reason: Title updated
ikramerica
Re: Geared turbofan gearbox airworthiness directive
Tue Oct 29, 2019 2:03 pm
I remember over a decade back there were discussions on a.net about GTF and the major stumbling block everyone mentioned was the longevity and reliability of the gearbox.
lightsaber
Tue Oct 29, 2019 2:07 pm
Please read the article. This is the accessory gearbox. Not the gearbox driving the fan. Issues with accessory gearboxes plague many engines.
Pratt & Whitney says in a statement that it is working in coordination with Airbus, the regulatory authorities and airline customers “to incorporate upgrades improving the reliability of the accessory gearbox in the PW1100G-JM fleet.”
Lightsaber
late edit: It is the main gearbox for most engines. It just isn't the big gearbox. It is a case where industry jargon is out of date for the GTF.
SteelChair
Tue Oct 29, 2019 2:17 pm
The article is very confusingly worded in my opinion. The writer of the article says main gearbox, which leads one to believe they are referring to the fan drive gear. The PW rep says "accessory gearbox."
At any rate, I stand corrected. But it is another disappointment in this engine.
Elementalism
Tue Oct 29, 2019 2:20 pm
I believe we call this teething issues. Sucks though.
Finn350
Tue Oct 29, 2019 2:21 pm
Here is a link to the proposed AD:
https://www.regulations.gov/document?D= ... -0614-0001
The problem seems to stem from an integrated drive generator (IDG) oil pump drive gearshaft assembly P/N 5322630-01 within the main gearbox (MGB).
Erebus
Tue Oct 29, 2019 2:40 pm
Lightsaber
Could we have a correction in the thread title to clarify this?
SteelChair
Tue Oct 29, 2019 2:45 pm
Lightsaber
Why? Is there not a gearbox problem on the GTF engine?
Finn350
Tue Oct 29, 2019 2:52 pm
SteelChair wrote:
Lightsaber
Yes, but "Geared turbofan accessory gearbox airworthiness directive" would be less confusing, as everybody thinks that the problem is with the geared turbofan. Technically "accessory gearbox" is called "main gearbox" which creates further confusion.
Erebus
Tue Oct 29, 2019 3:30 pm
SteelChair wrote:
Lightsaber
There are multiple gearboxes here. Would be nice to specify which one exactly.
WayexTDI
Tue Oct 29, 2019 3:34 pm
Maybe literally if the gear teeth break down...
N212R
Re: Geared turbofan auxiliary gearbox airworthiness directive
Tue Oct 29, 2019 3:59 pm
There is LOST and then there is intentionally buried....you be the judge.
