VV wrote:tommy1808 wrote:VV wrote:
Correct, but do most airlines in Europe need the range capability?
Useful pretty much ends at 2000nm ....
Best regards
Thomas
Exactly.
So why would you carry more weight when you do not need the range capability?
KlimaBXsst wrote:I think in terms of history. Since the dawn of the Jet Age in the 50’s, I cannot really think of any major European or North American, legacy, mainline, or flag carrier that has gone with a 4 abreast coach cabin as a SUBSTANTIAL and MAJORITY (20%~50%) part of their jet travel fleet business model.
Caravelles, DC 9-30s, BAC 111’s, and Fokker 100’s were pretty much the smallest airliners operating for these sorts of carriers that made up a substantial portion of the airlines fleets and these were all 5 abreast, unless in a premium cabin configuration.
Times have changed since the dawn of the Jet Age. We have had deregulation, tremendous increase in fuel prices, ULCC’s, regional outsourcing, new aircraft interiors designs, de-flagging of state supported carriers, 9/11.
I do not think airlines can succeed using the exact same paradigms and business as usual prism, in a society more nimble, mobile, and technology driven, thus requiring fleets to be shifted rapidly to where the business is, or fits that airlines particular business model against the upstart competition.
The age of Dinosaurs may be extinct.
GalaxyFlyer wrote:
The two planes are different. The EMB an extension of its regional jet which has hobbled it in the US. The A220 is designed as a mainline plane—longer legs, room for expansion (-300 and possible -500) and 2-3 seating.
tomcat wrote:
There is not much point looking at the 195E2 in isolation since it has a high degree of commonality with the 190E2.
tphuang wrote:
You always need to sell at loss in the beginning. Once you get enough sale, you can lower production cost through higher volume and turn those losses to profits.
I am sure the initial a220 to JetBlue will be at loss.
aviationaware wrote:
And on the downside the E2 is 20% heavier than the previous generation. Absolutely unacceptable design failure.
VV wrote:
By the way the thrust usage of the engine will be lower on E2 and thus the maintenance cost should be better. That's what drives the COC better on E2 even on per seat basis.
E195E2:
OEW: 35,7 t, MTOW 61,5 t, length 41,5m, wing span 35,1 m, fan diameter 73 inch, range 2600 nm = 4600 km,
A220-100:
OEW: 35,2 t, MTOW 63,0 t, length 35,0 m, wing span 35,1 m, fan diameter 73 inch, range 3400 nm = 6300 km,tomcat wrote:
While the A220-100 may be the better plane, the E195-E2 may be the better plane for an airline with E175-E2s and E190-E2s.tphuang wrote:
I can't judge if you are right, but E-Jets and CRJs did o.k..aviationaware wrote:
The E2 has longer wing and better engines than E1. The new B777 will also be heavier. However considering the A220-100 has the same OEW, you may still be right. A220-100 fuselage has more diameter, for this E195-E2 is longer.
You are right for E175-E2.
Fan diameter, thrust and OEW of E195-E2 and A220-100 are more or less same.
lightsaber wrote:Embraer must sell more. Now 95% of the engine costs are common with the A220, so that will not be an issue (as 80% of engine costs are also common with the business jet engines that sell forever). But nacelles and many actuators are custom. So is the cockpit, cabin pressurization system, galleys and lavs. PiPs take volume to fund as they are done on a profit potential (sell x PiPs at Y profit to recover Z investment in R&D with surplus profit).
The only E2 model that will sell in higg volume is the E2-195. ATP pilots have more opportunities and will seek better opportunities. The era, in MOL's words, of shaking a tree and having qualified pilots drop out is over.
The E2 needs needs orders. JetBlue was a major black eye. The only way to recover is sales volume which means cost cutting (merging with Boeing) to enable profitable discounted sales.
I worry for the E2 as it is the 717 revisited.
Lightsaber
GmvAfcs wrote:
A220 wins in flexibility for cabin and range. E195E2 is slightly more economical. And this is due specially because of higher aspect ratio wings on E2, and maintenance is expected to be lower as well since E2 has 1000/10000 A and C checks, while A220 has 850/8500 FH.
lightsaber wrote:...
The E2-195 is the main model as it is the sales volume, it has 123 firm+ commitments. There are only 38 E2-190 on firm order and the E2-175 is going into flight testing having lost the one conditional customer.
As to calls on dumping, all early aircraft are sold at a loss. As sales volume increases, production coats drop 13% for every doubling of production.
Lightsaber
VV wrote:...
The engines for E195-E2 (PW1900G) and for A220/C Series (PW1500G) are basically identical.
However, E195-E2 requires lower take-off thrust and climb thrust, thus the thrust usage is significantly lower on the E195-E2.
As a consequence, the E195-E2 engines runs cooler and thus the damage of each cycle is much lower than the engine of the A220.
It means PW1900G on the E195-E2 will have longer life on wing, thus lower maintenance cost when expressed it on per flying hour basis.
In addition, PW will have to sell PW1900G engine at lower pricing too.
tphuang wrote:...
B6 has found in its own evaluation that A220-300 fuel burn is less than that of E90 and that it's overall cost is about the same as E90, making the CASM 30% lower. It has just slightly higher CASM than the current 200 seat A321CEO in service with B6. They estimate A220-300 will drop system wide CASM by 5%! I don't see how E2 beat that.
Sokes wrote:While the A220-100 may be the better plane, the E195-E2 may be the better plane for an airline with E175-E2s and E190-E2s.
Sokes wrote:GmvAfcs wrote:...VV wrote:...
If A220-100 and E195-E2 have same OEW, nearly same engines and same wingspan, why should take off/ climb thrust with same payload over same mission be different?
Sokes wrote:Is the assumed average mission length of B6's A220-300s the same as the average mission length of the old E190?
ExMilitaryEng wrote:(Slightly off topic)
Due to the A220 having excess range for many markets (for Europe by example), we may pretend that a simple strech (that hypothetical "A220-500"), basically trading range for more capacity should be an excellent fit for markets like Europe. Again, that would be a CASM killer machine.
That same logic was applied by Embraer for the E195E2 (versus the E190E2)
FWIW, more design work was performed (when under Bombardier) on such a stretch than admitted. I'm sure VV knows more on this, but can't discuss.
VV wrote:I think Airbus will always tout A220 better payload-range capability, but in places like Europe, range capability for such small aircraft doesn't have much value.
KlimaBXsst wrote:Embraer’s E2 breakeven figure compared to
Airbus’ A220 breakeven figure?
Any #s?
scbriml wrote:VV wrote:I think Airbus will always tout A220 better payload-range capability, but in places like Europe, range capability for such small aircraft doesn't have much value.
Yet European airlines have ordered twice as many A220 as E2s. Curious.
But are those assumptions correct?
What about the frontal cross section (aerodynamic).?
Think about it again deeply.
VV wrote:scbriml wrote:VV wrote:This being said, I expect surprises in the US and in Europe in the coming year. I do not know which airline would consider E195-E2, but I heard through the grapevine there are some interesting on-going campaigns.
scbriml wrote:
Unless and until scope rules change, sales prospects in the US would seem to be poor at best.
Sokes wrote:tphuang wrote:...
Wikipedia tells that Jetblue will receive it's first A220 in 2020.
I struggle to believe that the A220-300 has only slightly worse CASM than A321-CEO, as this would reflect in more orders for the A220-300.
Do you have a source?
tphuang wrote:I think we are expecting a220 to have longer average stage length and higher utilization than e90.
Currently expected to get 1, 6, 8 a220 over next 2020-2022.
I have posted in other threads my calculation on casm. It's generally based on the numbers b6 have passed out. A220 is the a320 replacement for them.
Sokes wrote:tphuang wrote:I think we are expecting a220 to have longer average stage length and higher utilization than e90.
That's why I was asking.
If the average stage length of an E190 is 1000 nm and of an A220 is 1500 nm, then it's not surprising that the A220 has a fantastic CASM compared to E190.
Best regards
Thomas
Exactly.
Best regards
Thomas
Exactly.
So the E2 might appeal more to European carriers more focused on optimal weight/range discipline while the range flexibility of the A220 might appeal a little more to a North American carrier like DL. Of course, that’s not to say that some of those those European carriers wouldn’t mind having the option of using A220s on some of their African/ME routes.
So, Delta is operating the A220-100 outside the scope clause. Other airlines can potentially decide to do the same.
docmtl wrote:Hi, folks
I'm wondering whether the market battle between Airbus A220 vs Boeing E-195 E2 is already won by Airbus...
A220: More than 500 units already ordered, major airlines in NA, Europe and Asia on board with this plane.
E-195E2: Just launched with Azul (Brazilian company, very close to Embraer), and a few more companies, no NA customer, no major order as yet.
With Boeing struggling to cope with the B737 Max grounding, B737 NG structural cracks, can the new Boeing Brasil stand up to the challenge and turn this commercial battle around ?
Your thoughts are most welcome
docmtl
VV wrote:Several days ago Runway Girl Network issued an article about the E195-E2 presentation tour in the US.
https://runwaygirlnetwork.com/2019/11/0 ... it-hunter/
Which airlines could be interested by the E195-E2 in the US?
The aircraft used for the tour is the same shown at Paris air show this year. I had the chance to visit it accompanied by a very kind Embraer marketing guy.
VV wrote:But are those assumptions correct?
Amiga500 wrote:VV wrote:But are those assumptions correct?
You need to think about it a bit more. Your also showing up yourself for what you were not in
But anyway, in take-off and climb out, fuselage drag is a negligible proportion of the overall drag polar.
tphuang wrote:lol, C series has great CASM and per trip cost according to an actual airline that will operate it, total cost said to be 30% lower than E90 (so E90 cost is 40% higher than A220-300). And you keep repeating embraer managements line that it's cost are not superior to E2
ExMilitaryEng wrote:FWIW, more design work was performed (when under Bombardier) on such a stretch than admitted. I'm sure VV knows more on this, but can't discuss.
VV wrote:The main advantage of the C Series is not it's cost on per seat or per trip basis, but it's payload-range capability.
VV wrote:A simple stretch of the CS300 would have excellent per seat cost. It's max range would be around 2400-2500 nmi. This version would be the right size for the C Series.
Amiga500 wrote:VV wrote:The main advantage of the C Series is not it's cost on per seat or per trip basis, but it's payload-range capability.
Agreed.VV wrote:A simple stretch of the CS300 would have excellent per seat cost. It's max range would be around 2400-2500 nmi. This version would be the right size for the C Series.
If they did the stretch, then the likes of Easyjet could have a single type covering the market from 110 to 180 seats. That means airlines can have their cake and eat it with regards right-sizing and MX simplification.
VV wrote:Would Airbus sacrifice it's A320neoo to provide the room for the hypothetical simple stretch of CS300. It really hard to believe they would do it.
VV wrote:Just to add something. I believe they should do something about the C Series landing performance.
Just saying.
lightsaber wrote:VV wrote:Just to add something. I believe they should do something about the C Series landing performance.
Just saying.
Why? 1387m at MLW for A220-100
1509m for A220-300
1240 m E2-190
1412 m E2-195
Lightsaber
Amiga500 wrote:VV wrote:Would Airbus sacrifice it's A320neoo to provide the room for the hypothetical simple stretch of CS300. It really hard to believe they would do it.
If they can make more profit on an A220 (which could be partially a result of selling an A321 in that build slot instead of an A320)... why wouldn't they?
If that A220-500 sale means Boeing didn't sell a 737, why on earth wouldn't they?
VV wrote:lightsaber wrote:VV wrote:Just to add something. I believe they should do something about the C Series landing performance.
Just saying.
1509m for A220-300
1240 m E2-190
1412 m E2-195
Lightsaber
Why?
Well you will know perhaps one day.
VV wrote:Why?
Think about it again calmly.
Amiga500 wrote:VV wrote:Why?
You've offered no compelling argument for your case.
I expect you will continue to offer no compelling argument for your case either as to do so would show you up.
