BNAMealer wrote:For being a major 500+ flight hub, AA seems to be very RJ heavy and it lacks mainline on a lot of routes out of ORD compared to UA, even in markets where you’d think they’d be able to make 1-2 mainline frequencies work.
A specific example, despite the growth in the market, AA BNA-ORD only sees mainline on occasion. You’d think they’d be able to make a daily A319 work here like UA does.
Does anyone have specific RJ/mainline % of AA’s ORD operation? I’m curious to know.
Italianflyer wrote:I'm going out on a limb here (so please don't rip me if my logic is flawed) but I think it's a combination of geography and demographics. Geographically speaking, Chicago is within 2.5 hours flying time of allot of US & Canadian population centers. Perfectly acceptable for RJ flying and even more so on 170/75s. The demographics come in with ORD being one of the top business O&D markets. You can't offer dawn to dusk frequency and be willing to fly 2/3 empty A320s at 2pm on a Wednesday.... profitably.
chepos wrote:BNAMealer wrote:For being a major 500+ flight hub, AA seems to be very RJ heavy and it lacks mainline on a lot of routes out of ORD compared to UA, even in markets where you’d think they’d be able to make 1-2 mainline frequencies work.
You get your wish, as of next Monday you get a 319 (AA783) between ORD-BNA. As mentioned above, the breakdown between mainline and RJ is in the hub count.
JAMBOJET wrote:FSDan did a great thread on this overall topic:
AA at ORD: 40% mainline
UA at ORD: 43.6% mainline
LAXdude1023 wrote:Its not always bad either. I purposely seek out the E175 as opposed to mainline aircraft. The E145 and CRJ-200 is a completely different story.
davidjohnson6 wrote:If, as seems to be the case, ORD has significantly fewer pax per flight on average than other major airports, it suggests there is probably a substantial excess of runway capacity
PacoMartin wrote:Maybe ORD has large numbers of regional jets because they can. With 7 runways and an 8th under construction they have one more than the next leading contender (DFW with 7 runways). Then DEN, BOS, and DTW have 6 runways.
Southwest Florida International Airport (RSW) has a single 12,000' runway.
77H wrote:Not sure that’s relevant considering only 3-5 are used at any given time.
77H
davidjohnson6 wrote:At what point do the people of Chicago start demanding less noise and fewer flights ?
77H wrote:PacoMartin wrote:Maybe ORD has large numbers of regional jets because they can. With 7 runways and an 8th under construction they have one more than the next leading contender (DFW with 7 runways). Then DEN, BOS, and DTW have 6 runways.
77H
ORDfan wrote:LAXdude1023 wrote:Its not always bad either. I purposely seek out the E175 as opposed to mainline aircraft. The E145 and CRJ-200 is a completely different story.
Haha, I thought I was the only one doing that! E175's are my second favorite narrow-body, only recently supplanted by the A220.
In the past few years, I've started to cross-shop AA and UA on domestic routes for this very reason: I can't stand UA's 737 configuration..legroom so tight its almost unbearable, even on a jump to NYC or BNA. A320s will always get the nod over a 737 for me, but E175's are my #1, for even money or close.
Planeboy17 wrote:77H wrote:PacoMartin wrote:Maybe ORD has large numbers of regional jets because they can. With 7 runways and an 8th under construction they have one more than the next leading contender (DFW with 7 runways). Then DEN, BOS, and DTW have 6 runways.
77H
True, they usually use 5 runways now, 3 for arrivals and 2 for departures, however I think once they complete 9/27 C and the extension of 9/27 L they may use 6 runways.
That’s basically all they can do because the 6 runways will all be East/West while the other 2 will be Northeast/Southwest.
I believe that ORD is the only airport in the world that has the capability of having 4 simultaneous IFR arrivals. 9R, 9L, 10C and 10R.
Hopefully one of our expert ATC people can verify this.
77H
At the moment there are no procedures to simultaneously land 4 parallel RWYs. They are looking into it but not developed yet.
77H
airzona11 wrote:ORD is in a great hub location, is there not a point where AA is doing a good job connection all the points without dumping capacity ? AA UA WN all have huge ORD hubs. AA is able to connect all the dots and then some beyond UA/WN with the smaller RJs. This seems like a great use of RJs.
Midwestindy wrote:BNAMealer wrote:For being a major 500+ flight hub, AA seems to be very RJ heavy and it lacks mainline on a lot of routes out of ORD compared to UA, even in markets where you’d think they’d be able to make 1-2 mainline frequencies work.
It's not really that RJ heavy, considering the markets it serves.
1. Within a ~250 mile radius AA serves: BMI, CMI, MLI, PIA, SPI, CID, DSM, DBQ, ALO, MKE, MSN, ATW, GRB, CWA, LSE, RST, MSP, DTW, GRR, FNT, TVC, LAN, AZO, MQT, IND, FWA, EVV, CVG, CMH, CLE, CAK, TOL, SDF, DAY, and STL, meaning that at least 150 or so flights will have to be on RJs just based on the sheer size of the markets being served and how short the flights are. That's not even including the plethora of similar sized cities in a 350-400 mile radius that can only fill up a RJ, therefore it would be very difficult to raise the % of flights that are mainline above 50%.
2. Furthermore AA has been adding mainline in the past year, OMA/BNA-ORD has mainline, IND/MCI/PIT-ORD currently have 3 mainline flights a day, STL-ORD is nearly all mainline, e.t.c, so there is not a complete void of additional mainline service.
3. UA runs waaaay more CR2s(and 50 seaters in general) in ORD which are the worst type of RJ IMO, so UA's operation is hampered by that.
Plus UA operates RJs on ORD-LGA/DCA/ATL/CLT regularly, so neither AA or UA are immune to using RJs heavily in ORD
BNAMealer wrote:Midwestindy wrote:BNAMealer wrote:For being a major 500+ flight hub, AA seems to be very RJ heavy and it lacks mainline on a lot of routes out of ORD compared to UA, even in markets where you’d think they’d be able to make 1-2 mainline frequencies work.
Those are fair points, but the mainline on the likes of BNA/IND/MSY/CMH, etc, is not always consistent.
All those routes should be able to make at least an A319 work year round.
flight152 wrote:airzona11 wrote:ORD is in a great hub location, is there not a point where AA is doing a good job connection all the points without dumping capacity ? AA UA WN all have huge ORD hubs. AA is able to connect all the dots and then some beyond UA/WN with the smaller RJs. This seems like a great use of RJs.
WN flys into ORD? Need to me.
Planeboy17 wrote:davidjohnson6 wrote:At what point do the people of Chicago start demanding less noise and fewer flights ?
What does this even mean? People who live by airports will always complain about noise no matter how many flights there are. Do you think people that live by Long Beach are any happier than ORD even though they have a fraction of the number of flights?
And how would having more flights overall with smaller capacity aircraft lead to excess runway capacity?
Midwestindy wrote:1. Within a ~250 mile radius AA serves: BMI, CMI, MLI, PIA, SPI, CID, DSM, DBQ, ALO, MKE, MSN, ATW, GRB, CWA, LSE, RST, MSP, DTW, GRR, FNT, TVC, LAN, AZO, MQT, IND, FWA, EVV, CVG, CMH, CLE, CAK, TOL, SDF, DAY, and STL, meaning that at least 150 or so flights will have to be on RJs just based on the sheer size of the markets being served and how short the flights are. That's not even including the plethora of similar sized cities in a 350-400 mile radius that can only fill up a RJ, therefore it would be very difficult to raise the % of flights that are mainline above 50%.
Midwestindy wrote:3. UA runs waaaay more CR2s (and 50 seaters in general) in ORD which are the worst type of RJ IMO, so UA's operation is hampered by that.
GSPSPOT wrote:What gets me about AA being so RJ-heavy at ORD is that from MKE (admittedly ridiculously close to ORD to begin with), AA is exclusively CR2, while UA mixes RJs (small and large) and mainline as large as 739s during the summer on the very same route. Where is the love, AA? Grrrrr….
viewtopic.php?t=1420609
viewtopic.php?f=3&t=1420611
bigb wrote:GSPSPOT wrote:What gets me about AA being so RJ-heavy at ORD is that from MKE (admittedly ridiculously close to ORD to begin with), AA is exclusively CR2, while UA mixes RJs (small and large) and mainline as large as 739s during the summer on the very same route. Where is the love, AA? Grrrrr….
That’s not true with AA running exclusive CR2s to ORD. Skywest and Envoy have ran 70s in and out of MKE to ORD. The only CR2s AA runs out of MKE will probably be to DCA as that is the main CR2 base for AA (PSA).
77H
