enilria
OAG Changes 11/3/2019:AA Exits MIA-CMW/HOG/SCU/SNU/VRA,JFK-SEA;B6 Exits FLL-CMW/HOG/SNU;NK and WN Extension
Sun Nov 03, 2019 3:28 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M FLL-FPO DEC 1.8>1.1[3] JAN 1.9>1.0[3]
3M FLL-MHH DEC 0.5>0.3[3] JAN 1.3>0.7[3]
3M MCO-MHH JAN 0.4>0[0] FEB 1.0>0.8[0.7]
3M MHH-PBI JAN 0.4>0[0.7] FEB 0.8>0.6[0.9]
*9K BOS-RUT DEC 3>1.3[3] JAN 3>0[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[3] MAY 3>0[3] JUN 3>0[3] JUL 3>0[3] AUG 3>0[3]
AA BDL-LAX MAR 0.9>0[0.9] APR 1.0>0[0.9]
AA CHO-ORD MAR 3>2[2] APR 3>2[2] MAY 3>2[3] JUN 3>2[3] JUL 3>2[3] AUG 3>2[3]
AA CLT-PLS MAY 1.5>2.0[1.4] JUN 1.4>2.0[1.5] JUL 1.4>2[1.4] AUG 1.2>1.5[1.2]
Cuba law change
**AA CMW-MIA DEC 1.0>0.3[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0]
AA COS-ORD FEB 0.6>0[1.4] MAR 1.0>0[1.8]
AA CUN-DFW JUN 5>7[6] JUL 5>7[6] AUG 5>6[6]
AA CUN-JFK JUN 1.0>1.8[1.0] JUL 1.0>1.9[1.0] AUG 1.0>1.5[1.0]
AA CYS-DFW JAN 1.8>1.0[1.0] FEB 1.4>1.0[1.0]
AA DFW-PLS JUN 0.3>0.9[0.3] JUL 0.3>1.0[0.3] AUG 0.2>0.5[0.2]
AA DFW-SJD JUN 4>5[4] JUL 4>5[4]
AA DFW-TRC MAR 2>1.1[2] APR 2>1.0[2] MAY 2>1.0[2] JUN 2>1.0[2] JUL 2>1.0[1.9] AUG 2>1.0[2]
**AA HOG-MIA DEC 1.0>0.3[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0]
*AA JFK-SEA APR 0.8>0[0.9] MAY 1.0>0[0.0] JUN 1.0>0[0.1] JUL 1.0>0[0.0] AUG 1.0>0[0]
AA MIA-PLS MAR 3>2[3] APR 3>2[3] MAY 3>2[3]
AA MIA-POS MAR 3>2[3]
**AA MIA-SCU DEC 1.0>0.3[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0] APR 1.0>0[0] MAY 1.0>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0]
**AA MIA-SNU DEC 1.1>0.3[1.1] JAN 1.0>0[1.1] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.8] JUL 1.0>0[2] AUG 1.0>0[2]
AA MIA-STX JUN 1.0>1.5[1.0] JUL 1.0>1.5[1.0] AUG 0.8>1.0[0.8]
**AA MIA-VRA DEC 1.0>0.3[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0]
AA ORD-TYS MAR 2>3[2] APR 2>3[2.0]
AA PHX-PSP MAR 5>6[6]
AS GEG-SEA APR 15>14[14]
AS PDX-SEA APR 20>19[16]
AS PDX-SFO APR 8>7[8]
AS PUW-SEA APR 4>5[4]
AS SNA-STS MAR 1.0>1.4[1.0] APR 1.0>2[1.0] MAY 1.0>2[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>2[1.0]
B6 ATL-FLL DEC 2>3[2]
B6 BDL-PBI JAN 1.0>1.7[1.8] FEB 1.0>2[1.5] MAR 1.0>1.2[1.0]
B6 BDL-RSW JAN 1.0>1.7[1.0] FEB 1.0>2[1.0] MAR 1.0>1.2[1.0]
B6 BOS-CHS FEB 1.0>2.0[1.5] MAR 1.0>1.4[2]
B6 BOS-MCO MAR 9>8[7] APR 9>8[7]
B6 BOS-SAN MAR 1.9>3[1.8] APR 1.9>3[1.9]
B6 BOS-SJC MAR 1.0>0.7[1.0]
B6 BOS-SRQ FEB 1.2>1.4[1.5]
B6 BQN-JFK FEB 0.6>0.8[0.5] MAR 0.5>0.7[0.5] APR 0.5>1.0[0.5]
Cuba law change
**B6 CMW-FLL DEC 1.0>0.3[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 0.3>0[1.0]
B6 EWR-MCO JAN 6>7[6]
B6 EWR-SJU JAN 0.9>1.3[1.0] FEB 1.0>1.5[1.0] MAR 1.0>1.5[1.0] APR 1.0>1.5[1.0]
B6 EWR-STI JAN 1.0>2[1.4] FEB 1.0>2.0[1.0] MAR 1.0>2.0[1.0] APR 1.1>2.0[1.0]
B6 EWR-TPA FEB 2>3[2]
Cuba law change
**B6 FLL-HOG DEC 1.0>0.3[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 0.3>0[1.0]
B6 FLL-KIN DEC 3>4[2]
B6 FLL-LAS JAN 1.0>1.6[1.0] FEB 1.0>1.9[1.0] MAR 1.0>1.2[1.0]
B6 FLL-MBJ DEC 1.6>2[1.0]
Weakness in PUJ continues
B6 FLL-PUJ FEB 0.8>0.4[1.0] MAR 1.0>0.4[1.0] APR 1.0>0.5[1.0]
Cuba law change
**B6 FLL-SNU DEC 1.0>0.3[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 0.3>0[1.0]
B6 HPN-RSW JAN 1.0>1.7[1.0] FEB 1.0>2[1.0] MAR 1.0>1.2[1.0] MAY 1.0>2[1.0] JUN 0.3>0.7[1.0]
B6 LGB-SEA FEB 1.4>1.7[1.0] MAR 1.0>1.6[1.6] APR 1.1>1.6[1.9]
B6 MCO-SJO JAN 1.4>1.0[1.8]
DL ABY-ATL JUN 3>4[3] JUL 3>4[3] AUG 3>4[3]
DL ATL-BQK JUN 3>4[3] JUL 3>4[3] AUG 3>4[3]
DL ATL-CSG JUL 4>5[4] AUG 4>5[4]
DL ATL-DHN JUL 4>5[4] AUG 4>5[4]
DL ATL-HHH JUN 3>4[3] JUL 3>4[3] AUG 3>4[3]
DL ATL-RNO MAY 1.0>0.7[0]
DL ATL-SDQ APR 2>1.3[1.1] MAY 2>1.0[1.0] JUN 2>1.0[1.0] JUL 2>1.0[1.0] AUG 2.0>1.0[1.0]
DL ATL-TVC JUN 0>0.2[0.4] JUL 0>0.5[0.7] AUG 0>0.6[0.5]
DL ATL-VLD JUN 3>4[3] JUL 3>4[3] AUG 3>4[3]
DL CDG-DTW APR 1.0>1.4[1.4]
DL DTW-PVR MAR 0.8>0.5[1.0]
DL DTW-RSW AUG 3>2[2]
DL FLL-MSP MAY 2>1.6[1.0] JUN 2>1.6[1.0] JUL 2>1.6[0.9] AUG 2>1.3[0.8]
DL JFK-MEX JAN 1.2>2.0[1.0]
DL LAS-PDX JUL 2>3[0] AUG 2>3[0]
DL LAX-MEX JAN 1.5>4[1.0]
DL MSP-PUJ APR 0.4>0.1[0.2]
DL MSP-RSW JUL 2>1.6[1.2] AUG 2>1.3[1.1]
DL MSP-TPA AUG 3>2[1.9]
DL MSP-TUS MAY 1.0>0.6[0.4]
EI DUB-EWR FEB 1.0>0.8[0.6]
F9 DEN-FLL DEC 1.0>0.5[0]
F9 MCO-SAN DEC 0.9>0.5[0.5]
*HA HND-HNL APR 1.6>3[1.6] MAY 1.5>3[1.5] JUN 1.6>3[1.6] JUL 1.5>3[1.6] AUG 1.6>3[1.6]
JUN is a partial month, and APR was previously partial month. Look at May.
NK ACY-ATL APR 0>0.3[0] JUN 0>0.3[1.0]
NK ACY-FLL APR 2>3[3] JUN 0>0.6[1.7]
NK ACY-MCO APR 1.8>2[2] JUN 0>0.6[2]
NK ACY-MYR APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ACY-RSW APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK ACY-TPA APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-AUS APR 0.7>1.0[0] MAY 0>1.0[0.3] JUN 0>0.3[1.0]
NK ATL-BOS APR 0.3>0.6[0.4] JUN 0>0.3[1.0]
NK ATL-BWI APR 1.4>2[2] JUN 0>0.9[3]
NK ATL-CLE APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-DFW APR 0.7>1.3[1.0] MAY 0>2[2.0] JUN 0>0.6[2]
NK ATL-DTW APR 1.4>2[2] JUN 0>0.9[3]
NK ATL-EWR APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-FLL APR 4>6[5] MAY 0>5[4] JUN 0>1.5[4]
NK ATL-IAH APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-LAS APR 1.4>2[1.0] MAY 0>2[1.0] JUN 0>0.6[1.4]
NK ATL-LAX APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-MCO APR 1.4>2[2] JUN 0>0.6[2.0]
NK ATL-MSP APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-ORD APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-PHL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ATL-TPA APR 1.4>1.7[1.5] MAY 0>1.0[1.6] JUN 0>0.3[1.9]
NK AUS-BNA APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK AUS-BWI APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK AUS-CUN MAY 0>0.6[0]
NK AUS-DEN APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK AUS-DTW APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK AUS-EWR APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK AUS-FLL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK AUS-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK AUS-LAX APR 0.7>1.0[0] JUN 0>0.3[1.0]
NK AUS-MCO APR 1.1>1.6[1.0] MAY 0>1.6[1.0] JUN 0>0.5[1.0]
NK AUS-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK AUS-ORD APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK AVL-MCO APR 0.5>0.8[0.6] MAY 0>1.0[0.6] JUN 0>0.3[0.6]
NK AXM-FLL MAY 0>0.4[0.5]
NK BDL-FLL APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK BDL-MCO APR 1.4>2[2] JUN 0>0.6[2]
NK BDL-MYR APR 0.7>1.3[0.6] MAY 0>2[1.3] JUN 0>0.6[1.3]
NK BNA-BWI APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK BNA-CUN MAY 0>0.4[0]
NK BNA-EWR APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK BNA-FLL APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK BNA-LAS APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK BNA-LAX APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK BNA-MCO APR 1.0>1.4[0] MAY 0>1.4[0] JUN 0>0.4[0]
NK BNA-MSY APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK BNA-TPA APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK BOG-FLL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BOG-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BOS-BWI APR 0>0.6[2] JUN 0>0.6[2]
NK BOS-CLE APR 0>0.3[0] JUN 0>0.3[1.0]
NK BOS-DFW APR 0>0.3[0] JUN 0>0.3[1.0]
NK BOS-DTW APR 0>0.3[0] JUN 0>0.3[1.0]
NK BOS-FLL APR 1.4>2[2] JUN 0>0.6[2]
NK BOS-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BOS-MCO APR 1.4>2[2] JUN 0>0.6[2]
NK BOS-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BOS-MYR APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BOS-ORD APR 0>0.3[0] JUN 0>0.3[1.0]
NK BOS-RDU APR 0.7>1.0[0] JUN 0>0.3[1.0]
NK BOS-SJU MAY 0>0.5[0]
NK BUR-LAS APR 1.4>2[0] MAY 0>2[0] JUN 0>0.6[1.1]
NK BWI-CLT APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0.4]
NK BWI-CUN APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-DEN APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-DFW APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-DTW APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-FLL APR 2>3[3] JUN 0>0.9[3]
NK BWI-IAH APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-JAX APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-LAX APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-MBJ APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-MCO APR 2>3[3] MAY 0>2[3] JUN 0>0.7[2]
NK BWI-MSP APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK BWI-MYR APR 0.6>1.1[1.0] MAY 0>1.6[1.5] JUN 0>0.5[1.6]
NK BWI-ORD APR 0.7>1.3[1.0] MAY 0>2[2.0] JUN 0>0.6[2]
NK BWI-RDU APR 0.7>1.0[0] MAY 0>1.0[1.2] JUN 0>0.3[2]
NK BWI-SEA APR 0>0.3[0] JUN 0>0.3[1.0]
NK BWI-TPA APR 0.7>1.0[1.7] MAY 0>1.0[1.6] JUN 0>0.3[1.6]
NK CAK-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CLE-CUN MAY 0>0.6[0]
NK CLE-DFW APR 0>0.3[0] JUN 0>0.3[1.0]
NK CLE-FLL APR 1.1>1.7[1.5] MAY 0>2[1.0] JUN 0>0.6[1.0]
NK CLE-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CLE-LAX APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CLE-MCO APR 1.8>3[1.5] MAY 0>3[1.0] JUN 0>0.8[1.9]
NK CLE-MYR APR 0.3>0.6[0.4] JUN 0>0.3[1.0]
NK CLE-TPA APR 0.7>1.0[1.0] MAY 0>1.0[0.0] JUN 0>0.3[0]
NK CLO-FLL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CLT-EWR APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0.4]
NK CLT-FLL APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0.4]
NK CLT-MCO APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0.4]
NK CMH-FLL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CMH-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CMH-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CMH-MYR MAY 0>0.6[0.5]
NK CUN-DFW APR 0.3>0.6[0.4] JUN 0>0.3[1.0]
NK CUN-DTW APR 0.7>1.0[1.0] MAY 0>1.0[0.2] JUN 0>0.3[0.2]
NK CUN-FLL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK CUN-IAH APR 0.3>0.6[0.4] JUN 0>0.3[1.0]
NK CUN-PHL APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK CUN-PIT MAY 0>0.4[0]
NK DEN-DFW APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DEN-FLL APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK DEN-IAH APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DEN-LAS APR 1.4>2[1.0] MAY 0>2[2.0] JUN 0>0.6[2]
NK DEN-LAX APR 0>0.3[0] JUN 0>0.3[1.0]
NK DEN-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DEN-MSP APR 0>0.3[0] JUN 0>0.3[1.0]
NK DEN-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DEN-ORD APR 0.7>1.3[1.0] MAY 0>2[2.0] JUN 0>0.6[2]
NK DFW-DTW APR 0.7>1.3[1.0] MAY 0>2[1.4] JUN 0>0.6[1.4]
NK DFW-FLL APR 2>3[2] JUN 0>0.9[3]
NK DFW-LAS APR 3>4[4] JUN 0>1.2[4]
NK DFW-LAX APR 1.4>3[2] JUN 0>1.2[4]
NK DFW-LGA APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DFW-MCO APR 1.4>2[2] JUN 0>0.9[3]
NK DFW-MSP APR 0>0.3[0] JUN 0>0.3[1.0]
NK DFW-MSY JUN 0>0.3[1.0]
NK DFW-ORD APR 0.7>1.3[1.0] MAY 0>2[2.0] JUN 0>0.6[2]
NK DFW-PHL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DFW-PHX APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DFW-SAN APR 0>0.3[0] JUN 0>0.3[1.0]
NK DFW-SEA APR 0>0.3[0] JUN 0>0.3[1.0]
NK DFW-SJD MAY 0>0.6[0.5]
NK DFW-TPA APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DTW-FLL APR 2>3[2] JUN 0>0.6[2]
NK DTW-IAH APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DTW-JAX APR 0.5>0.8[1.0] JUN 0>0.3[1.0]
NK DTW-LAS APR 3>4[3] MAY 0>4[3] JUN 0>1.2[3]
NK DTW-LAX APR 0.7>1.3[1.0] MAY 0>2[2.0] JUN 0>0.6[2]
NK DTW-LGA APR 1.4>2[2] JUN 0>0.6[2]
NK DTW-MCI APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DTW-MCO APR 3>4[4] JUN 0>0.9[3]
NK DTW-MSP APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DTW-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK DTW-MYR APR 0.7>1.0[1.0] MAY 0>1.0[1.2] JUN 0>0.3[1.0]
NK DTW-OAK APR 0>0.3[0] JUN 0>0.3[1.0]
NK DTW-PHL APR 0>0.3[0] JUN 0>0.3[1.0]
NK DTW-RDU JUN 0>0.2[1.0]
NK DTW-RSW JUN 0>0.3[0.9]
NK DTW-SAN APR 0>0.3[0] JUN 0>0.3[1.0]
NK DTW-SEA APR 0>0.3[0] JUN 0>0.3[1.0]
NK DTW-TPA MAY 0>1.0[0.9] JUN 0>0.3[0.9]
NK EWR-FLL APR 1.7>2[2] JUN 0>0.6[2]
NK EWR-IAH APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK EWR-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK EWR-MCO APR 2>3[3] JUN 0>0.9[3]
NK EWR-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK EWR-MYR APR 0.4>0.7[0.6] JUN 0>0.3[1.0]
NK EWR-RSW APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK EWR-SDQ APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK EWR-SJU MAY 0>0.5[0]
NK EWR-TPA APR 0.7>1.0[0.3] MAY 0>1.0[0] JUN 0>0.3[0]
NK FLL-GUA APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-GYE APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-IAH APR 0.7>1.3[1.0] MAY 0>2[2.0] JUN 0>0.6[2]
NK FLL-KIN APR 0.5>0.8[0.7] JUN 0>0.3[1.0]
NK FLL-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-LAX APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-LBE APR 0.7>1.0[1.0] JUN 0>0.3[0.9]
NK FLL-LGA APR 3>4[4] JUN 0>1.2[4]
NK FLL-LIM APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-MBJ APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-MCO APR 1.4>2[2] JUN 0>0.6[2]
NK FLL-MDE APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-MGA APR 0.7>1.0[0.6] JUN 0>0.3[1.0]
NK FLL-MSY APR 1.4>2[2] MAY 0>2[2.0] JUN 0>0.6[2]
NK FLL-MYR APR 0.7>1.1[1.0] MAY 0>1.4[1.3] JUN 0>0.4[1.3]
NK FLL-ORD APR 2>3[2] MAY 0>3[2] JUN 0>0.9[2]
NK FLL-PAP APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-PHL APR 2>3[2] MAY 0>3[2] JUN 0>0.9[2]
NK FLL-PIT APR 1.4>2[1.0] MAY 0>2[1.0] JUN 0>0.6[1.0]
NK FLL-PTY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-PUJ APR 0.3>0.6[0.4] JUN 0>0.3[1.0]
NK FLL-RDU APR 0.7>1.0[0] JUN 0>0.3[1.0]
NK FLL-RIC APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-SAP APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-SDQ APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK FLL-SJO APR 1.4>1.7[2] MAY 0>1.0[1.9] JUN 0>0.5[1.9]
NK FLL-SJU MAY 0>0.5[0.6]
NK FLL-STI MAY 0>0.6[0.5]
NK FLL-STX MAY 0>0.2[0.4]
NK FLL-TPA APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK GSO-MCO APR 0.7>1.0[0.6] MAY 0>1.0[0.6] JUN 0>0.3[0.6]
NK IAG-MYR APR 0.3>0.5[0.4] JUN 0>0.2[0.7]
NK IAH-LAS APR 1.4>2[2] JUN 0>0.6[2]
NK IAH-LAX APR 1.4>2[2] JUN 0>0.6[2]
NK IAH-MCO APR 2>3[2] MAY 0>3[2] JUN 0>0.9[2]
NK IAH-MSP APR 0>0.3[0] JUN 0>0.3[1.0]
NK IAH-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK IAH-OAK APR 0>0.3[0] JUN 0>0.3[1.0]
NK IAH-ORD APR 1.4>2[2] JUN 0>0.6[2]
NK IAH-SAN APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK IAH-SEA APR 0>0.3[0] JUN 0>0.3[1.0]
NK IAH-SJD MAY 0>0.6[0.5]
NK IAH-TPA APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK IND-LAS APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK IND-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK IND-RSW APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK IND-TPA APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
NK JAX-ORD APR 0.5>0.8[1.0] MAY 0>1.0[0.9] JUN 0>0.3[0.7]
NK KIN-MCO MAY 0>0.4[0.5]
NK LAS-LAX APR 2>3[3] JUN 0>0.9[3]
NK LAS-MCI APR 0.7>1.3[1.0] MAY 0>2[1.0] JUN 0>0.6[1.0]
NK LAS-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAS-MSP APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK LAS-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAS-OAK APR 2>3[3] JUN 0>1.2[4]
NK LAS-ORD APR 2>3[3] JUN 0>0.9[3]
NK LAS-PDX APR 1.4>2[2] JUN 0>0.9[3]
NK LAS-PHL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAS-PIT APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAS-SAN APR 2>3[3] MAY 0>3[4] JUN 0>0.9[4]
NK LAS-SEA APR 1.4>2[3] MAY 0>3[4] JUN 0>0.9[4]
NK LAS-SMF APR 2>3[0] MAY 0>3[0] JUN 0>0.9[1.1]
NK LAS-TPA APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAX-MCI APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAX-MSP APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAX-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAX-OAK APR 0.7>1.3[2] MAY 0>2[2.0] JUN 0>0.6[2]
NK LAX-ORD APR 1.4>2[2] JUN 0>0.6[2]
NK LAX-PHL APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LAX-PIT APR 0.7>1.3[1.0] MAY 0>2[1.0] JUN 0>0.6[1.0]
NK LBE-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK LBE-MYR APR 0.7>1.1[0.9] JUN 0>0.4[1.4]
NK LGA-MYR APR 0.7>1.3[2] JUN 0>0.6[2]
NK LGA-ORD APR 0.7>1.3[2] JUN 0>0.6[2]
NK MBJ-MCO MAY 0>0.4[0.5]
NK MCI-MCO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MCO-MSP APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MCO-MSY APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MCO-ORD APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK MCO-PHL APR 2>3[3] JUN 0>0.9[3]
NK MCO-PIT APR 1.4>2[1.0] MAY 0>2[1.0] JUN 0>0.6[1.0]
NK MCO-RDU APR 0.7>1.0[0] JUN 0>0.3[1.0]
NK MCO-RIC APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MCO-SDQ APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MCO-SJO APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MCO-SJU APR 0.7>1.2[1.0] MAY 0>1.5[1.4] JUN 0>0.5[1.8]
NK MSY-ORD APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MSY-PHL MAY 0>0.6[0.5]
NK MSY-RDU APR 0.7>1.0[0] JUN 0>0.3[1.0]
NK MSY-TPA APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MYR-ORD APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK MYR-PHL APR 0.4>0.7[0.6] JUN 0>0.3[1.0]
NK OAK-ORD APR 0>0.3[0] JUN 0>0.3[1.0]
NK ORD-RDU JUN 0>0.2[1.0]
NK ORD-RSW APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK ORD-SAN APR 0.7>1.0[1.0] JUN 0>0.3[1.0]
NK ORD-SEA APR 0>0.3[0] JUN 0>0.3[1.0]
NK ORD-TPA APR 1.4>1.7[2] JUN 0>0.3[1.0]
NK PHL-SJU APR 0.7>1.0[0] MAY 0>1.0[0.1] JUN 0>0.3[0.5]
OZ ICN-SFO MAR 1.0>0[1.0] APR 1.0>0.5[1.0]
SV JED-LAX APR 0.7>0.4[0.4] MAY 0.7>0.4[0.4] JUN 0.7>0.4[0.7] JUL 0.7>0.4[0.7] AUG 0.7>0.5[0.7]
UA ABQ-ORD JAN 1.2>0.8[2] FEB 1.0>0.6[1.5]
UA ACT-IAH JAN 0>0.2[0.3]
UA ACV-SFO MAY 4>3[3] JUN 4>3[3] JUL 4>3[3] AUG 4>3[4]
UA ASE-DEN APR 5>6[5]
UA ATL-ORD APR 7>8[7] MAY 7>8[6] JUN 7>8[7] JUL 7>8[7] AUG 7>8[6]
UA BDL-ORD APR 3>4[4]
UA BOI-DEN APR 5>4[4]
UA BTV-ORD APR 2>3[3] MAY 3>4[4] JUN 3>4[4] JUL 3>4[4] AUG 3>4[4]
UA BZN-ORD APR 1.0>2[2]
UA CLE-IAH APR 3>4[5] MAY 3>4[5] JUN 3>4[5] JUL 3>4[5] AUG 3>4[5]
UA CRP-IAH JAN 7>6[5]
UA DCA-ORD APR 14>12[14]
UA DEN-GTF JAN 1.4>2[2] FEB 1.7>2[2]
UA DEN-MSY APR 3>4[3]
UA DEN-MTJ APR 3>4[3]
UA DEN-ONT APR 1.9>3[1.9] MAY 1.8>3[2] JUN 1.9>3[2] JUL 1.9>3[2] AUG 1.8>3[2.0]
UA DEN-PHX APR 5>7[6]
UA DEN-PSC APR 3>2[3]
UA DEN-PSP APR 4>5[5]
UA DEN-RSW APR 1.1>2[1.1] MAY 1.0>1.2[1.1]
UA DEN-SAF APR 3>4[3] MAY 3>4[3] JUN 3>4[3] JUL 3>4[3] AUG 3>4[3]
UA DEN-SEA APR 6>5[4]
UA DEN-TUL APR 4>5[5] MAY 4>5[5] JUN 4>5[4] JUL 4>5[4] AUG 4>5[3]
UA DFW-ORD APR 8>7[6]
UA DSM-IAH JAN 3>2[2]
UA DTW-EWR APR 7>6[6]
UA ECP-IAH APR 3>2[2]
UA EUG-SFO APR 5>4[4] MAY 5>4[4] JUN 5>4[4] JUL 5>4[4] AUG 5>4[4]
UA EWR-EYW APR 2>3[2]
UA EWR-FRA APR 2>1.2[1.0]
UA EWR-GRR APR 3>2[1.9]
UA EWR-GSO APR 5>4[4] MAY 5>4[4] JUN 5>4[4] JUL 5>4[4] AUG 5>4[4]
UA EWR-GSP APR 4>3[3] MAY 4>3[3] JUN 4>3[3] JUL 4>3[3] AUG 4>3[3]
UA EWR-IAD APR 6>7[6] MAY 6>7[6] JUN 6>7[6] JUL 6>7[6] AUG 6>7[6]
UA EWR-MCO APR 10>12[11]
UA EWR-MEM APR 4>3[4] MAY 4>3[4] JUN 4>3[3] JUL 4>3[3] AUG 4>3[3]
UA EWR-MIA APR 7>8[6]
UA EWR-MKE APR 4>3[3]
UA EWR-MYR APR 0.2>1.1[1.3]
UA EWR-OKC APR 1.0>0[1.0] MAY 1.0>0.8[1.0]
UA EWR-OMA APR 3>1.9[3] MAY 3>1.8[3] JUN 3>1.9[3] JUL 3>1.9[3] AUG 3>1.8[3]
UA EWR-ORF APR 6>5[4]
UA EWR-PNS AUG 1.0>0.5[1.0]
UA EWR-SFO APR 15>14[13]
UA EWR-SYR APR 5>4[3]
UA EWR-YHZ APR 3>2[2]
UA FAR-ORD APR 4>3[3]
UA FLL-IAD APR 2>3[2]
UA FLL-ORD APR 4>5[4]
UA FNT-ORD APR 4>3[4]
UA FSD-ORD APR 5>4[4]
UA GPT-IAH APR 3>4[3] MAY 3>4[3] JUN 3>4[2] JUL 3>4[3] AUG 3>4[3]
UA GRR-IAH JAN 1.7>1.1[1.0]
UA GVA-IAD APR 1.0>0.8[0.8]
UA HSV-IAH APR 4>3[3]
UA IAD-ILM APR 2>3[2.0] MAY 2>3[1.9] JUN 2>3[2.0] JUL 2>3[2] AUG 2>3[2]
UA IAD-ITH APR 1.9>3[2] MAY 1.8>3[3] JUN 1.9>3[3] JUL 1.9>3[3] AUG 1.8>3[3]
UA IAD-LAS APR 3>2[2]
UA IAD-LAX APR 8>7[7]
UA IAD-MCI APR 2>3[2] MAY 2>3[2] JUN 2>3[2] JUL 2>3[2] AUG 2>3[2]
UA IAD-MIA APR 1.0>2[1.0] MAY 1.0>1.2[0]
UA IAD-MSY APR 2>3[3]
UA IAD-OKC APR 1.0>2[1.0] MAY 1.0>2[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>2[1.0]
UA IAD-PHX APR 1.0>2[1.0] MAY 1.0>1.2[1.0]
UA IAD-PVD APR 4>3[3]
UA IAD-SRQ APR 2>1.0[0]
UA IAD-SYR APR 3>4[3] MAY 3>4[4] JUN 3>4[3] JUL 3>4[3] AUG 3>4[3]
UA IAH-JAX APR 5>4[4] MAY 5>4[4] JUN 5>4[4] JUL 5>4[4]
UA IAH-LBB APR 4>3[3]
UA IAH-LCH APR 3>4[3] MAY 3>4[3] JUN 3>4[1.9] JUL 3>4[1.9] AUG 3>4[3]
UA IAH-MKE APR 3>1.9[2]
UA IAH-MUC APR 1.0>0.8[0.9]
UA IAH-PBI APR 1.0>2[1.0] MAY 1.0>1.2[1.0]
UA IAH-PDX APR 2>3[3] MAY 2>3[3] JUN 2>3[3] JUL 2>3[3] AUG 2>3[2]
UA IAH-PIT APR 6>5[5]
UA IAH-PSP APR 2>3[3] MAY 0.5>0.7[0]
UA IAH-RIC JAN 1.9>1.2[1.0] APR 3>2[1.1]
UA IAH-SAN APR 5>6[5]
UA IAH-SAV JAN 1.7>1.2[1.2]
UA IAH-SDF APR 4>3[4] MAY 4>3[4] JUN 4>3[3] JUL 4>3[3] AUG 4>3[3]
UA IAH-SHV APR 5>4[4] MAY 5>4[4] JUN 5>4[4] JUL 5>4[4] AUG 5>4[4]
UA IAH-SLC APR 4>5[4]
UA IAH-TUL APR 6>7[7] MAY 6>7[7] JUN 6>7[7] JUL 6>7[7] AUG 6>7[7]
UA IAH-TUS APR 3>4[4]
UA IAH-TYS APR 4>3[3]
UA JAC-SFO MAR 1.0>1.2[1.9]
UA JAX-ORD APR 1.0>3[3] MAY 1.0>3[3] JUN 1.0>3[3] JUL 1.0>3[3] AUG 1.0>3[3]
UA MCI-ORD APR 1.4>6[6] MAY 1.4>6[6] JUN 1.4>6[6] JUL 1.4>6[6] AUG 1.4>6[6]
UA MKG-ORD FEB 3>2[2]
UA ORD-UIN JAN 1.7>0.3[1.7] FEB 1.7>0[1.7] MAR 1.7>0[1.7] APR 1.7>0[1.7] MAY 1.7>0[1.7] JUN 1.7>0[1.7] JUL 1.7>0[1.7] AUG 1.7>0[1.7]
VB GDL-LAX JAN 1.1>1.5[1.1] FEB 1.0>1.4[0.6] MAR 1.0>1.7[0.8] APR 1.0>1.5[1.0] MAY 1.0>1.7[1.0]
WN ABQ-AUS APR 0.6>1.3[0.4] MAY 0>1.3[0.4] JUN 0>0.2[0.6]
WN ABQ-BWI APR 0.5>1.5[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.7]
WN ABQ-DAL APR 2>5[5] JUN 0>1.0[5]
WN ABQ-DEN APR 1.5>4[3] JUN 0>0.7[3]
WN ABQ-HOU APR 1.3>3[3] JUN 0>0.6[3]
WN ABQ-LAS APR 1.7>4[4] JUN 0>0.8[3]
WN ABQ-LAX APR 1.2>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN ABQ-MCI APR 0.4>0.9[1.0] JUN 0>0.2[1.0]
WN ABQ-MDW APR 0.6>1.7[1.8] JUN 0>0.4[1.6]
WN ABQ-OAK APR 0.7>2[2] MAY 0>2[3] JUN 0>0.5[3]
WN ABQ-PHX APR 3>6[5] MAY 0>6[5] JUN 0>1.2[5]
WN ABQ-SAN APR 0.7>1.7[1.9] MAY 0>1.7[1.8] JUN 0>0.4[2]
WN ABQ-SJC APR 0.4>0.9[0.1] MAY 0>0.8[0.1]
WN ALB-BWI APR 2>5[5] MAY 0>5[4] JUN 0>1.0[5]
WN ALB-DEN APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN ALB-FLL APR 0.5>1.1[1.0] MAY 0>1.0[1.1] JUN 0>0.2[0.3]
WN ALB-MCO APR 0.9>2[2] MAY 0>1.8[2.0] JUN 0>0.4[1.4]
WN ALB-MDW APR 0.7>1.9[2] JUN 0>0.4[2]
WN ALB-TPA APR 0.6>1.2[1.1] JUN 0>0.2[1.0]
WN AMA-DAL APR 1.5>4[4] MAY 0>3[4] JUN 0>0.7[4]
WN AMA-HOU APR 0.1>0.6[0] MAY 0>0.8[0]
WN AMA-LAS APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN ATL-AUS APR 1.2>3[3] MAY 0>4[3] JUN 0>0.7[2]
WN ATL-BNA APR 1.8>4[4] JUN 0>0.9[4]
WN ATL-BWI APR 3>7[6] MAY 0>6[5] JUN 0>1.3[6]
WN ATL-CLE APR 0.7>1.7[1.9] MAY 0>1.7[1.8] JUN 0>0.4[1.8]
WN ATL-CMH APR 1.2>3[3] MAY 0>3[2] JUN 0>0.6[3]
WN ATL-CUN MAY 0>0.3[1.0]
WN ATL-DAL APR 3>6[5] MAY 0>6[5] JUN 0>1.1[5]
WN ATL-DCA APR 1.7>4[4] JUN 0>0.8[4]
WN ATL-DEN APR 2>5[4] MAY 0>4[3] JUN 0>0.9[5]
WN ATL-FLL APR 2>5[5] JUN 0>1.0[4]
WN ATL-GSP APR 1.2>3[3] JUN 0>0.6[3]
WN ATL-HOU APR 3>6[6] MAY 0>6[5] JUN 0>1.1[6]
WN ATL-IAD APR 1.2>3[3] JUN 0>0.6[2]
WN ATL-IND APR 1.2>3[3] JUN 0>0.6[3]
WN ATL-JAX APR 1.2>3[3] JUN 0>0.6[3]
WN ATL-LAS APR 1.3>3[4] JUN 0>0.6[2]
WN ATL-LAX APR 1.2>3[3] MAY 0>3[2] JUN 0>0.6[2]
WN ATL-LGA APR 2>5[5] JUN 0>1.0[5]
WN ATL-MCI APR 1.3>3[4] MAY 0>3[4] JUN 0>0.7[4]
WN ATL-MCO APR 3>6[5] MAY 0>6[5] JUN 0>1.2[5]
WN ATL-MDW APR 3>6[6] MAY 0>7[6] JUN 0>1.3[6]
WN ATL-MEM APR 0.8>1.8[0] MAY 0>1.7[0] JUN 0>0.4[0]
WN ATL-MKE APR 0.8>1.8[2.0] MAY 0>1.7[1.9] JUN 0>0.4[1.6]
WN ATL-MSY APR 1.7>4[4] MAY 0>4[3] JUN 0>0.7[4]
WN ATL-OAK APR 0.4>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.0]
WN ATL-PBI APR 0.8>1.9[1.9] MAY 0>1.8[1.6] JUN 0>0.4[1.7]
WN ATL-PHL APR 0.9>3[3] JUN 0>0.6[2]
WN ATL-PHX APR 1.2>3[2] MAY 0>3[1.6] JUN 0>0.6[2.0]
WN ATL-PIT APR 1.2>3[2] JUN 0>0.5[2]
WN ATL-PUJ MAY 0>0.3[1.0]
WN ATL-RDU APR 1.2>3[3] JUN 0>0.6[3]
WN ATL-RIC APR 1.2>3[3] JUN 0>0.6[3]
WN ATL-RSW APR 0.9>2[2] JUN 0>0.4[1.8]
WN ATL-SAN APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN ATL-SAT APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.9]
WN ATL-STL APR 1.7>4[4] JUN 0>0.8[4]
WN ATL-TPA APR 3>6[6] MAY 0>6[5] JUN 0>1.2[5]
WN AUA-FLL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN AUS-BNA APR 1.4>4[3] MAY 0>4[3] JUN 0>0.8[3]
WN AUS-BOS APR 0>0.6[1.0] JUN 0>0.2[0.9]
WN AUS-BWI APR 1.2>3[2] JUN 0>0.5[3]
WN AUS-CUN APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN AUS-DAL APR 4>9[10] JUN 0>1.9[10]
WN AUS-DCA APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN AUS-DEN APR 2>6[5] JUN 0>1.1[6]
WN AUS-ELP APR 0.9>3[3] JUN 0>0.6[3]
WN AUS-FLL APR 0.9>1.6[1.3] MAY 0>1.3[1.1] JUN 0>0.2[1.8]
WN AUS-HOU APR 2>5[5] JUN 0>1.0[5]
WN AUS-HRL APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN AUS-LAS APR 1.7>4[4] MAY 0>4[3] JUN 0>0.8[4]
WN AUS-LAX APR 1.2>3[3] JUN 0>0.6[1.9]
WN AUS-LBB APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN AUS-MCI APR 0.5>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.0]
WN AUS-MCO APR 1.3>3[2] MAY 0>3[2] JUN 0>0.6[3]
WN AUS-MDW APR 1.7>4[3] MAY 0>4[3] JUN 0>0.7[4]
WN AUS-MSY APR 1.2>3[3] JUN 0>0.6[3]
WN AUS-OAK APR 0.5>1.1[1.1] MAY 0>1.0[1.1] JUN 0>0.2[1.3]
WN AUS-PHX APR 1.7>4[5] JUN 0>0.8[4]
WN AUS-RDU APR 0.4>0.9[0] MAY 0>1.0[0]
WN AUS-SAN APR 1.2>3[3] JUN 0>0.5[3]
WN AUS-SJC APR 1.1>3[2] JUN 0>0.5[2]
WN AUS-SMF APR 0.4>0.9[1.0] MAY 0>0.8[1.0]
WN AUS-STL APR 0.8>1.9[2.0] JUN 0>0.4[1.9]
WN AUS-TPA APR 0.9>2[1.3] MAY 0>1.9[1.1] JUN 0>0.4[1.4]
WN BDL-BWI APR 2>5[7] MAY 0>5[7] JUN 0>1.1[6]
WN BDL-DEN APR 0.4>0.9[1.1] JUN 0>0.2[1.0]
WN BDL-FLL APR 0.5>1.1[1.1] MAY 0>1.2[1.1] JUN 0>0.2[0.3]
WN BDL-MCO APR 1.4>3[3] JUN 0>0.6[2]
WN BDL-MDW APR 0.7>2[3] JUN 0>0.5[3]
WN BDL-RSW APR 0.4>1.1[1.1] MAY 0>1.2[1.1] JUN 0>0.2[0.3]
WN BDL-STL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN BDL-TPA APR 0.9>2[3] JUN 0>0.6[2]
WN BHM-BWI APR 0.4>1.4[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.1]
WN BHM-DAL APR 0.9>2[1.9] MAY 0>2.0[1.9] JUN 0>0.4[1.8]
WN BHM-HOU APR 0.8>1.9[1.9] JUN 0>0.4[1.8]
WN BHM-LAS APR 0.4>1.0[1.0] JUN 0>0.2[0.3]
WN BHM-MCO APR 1.0>2[2] JUN 0>0.4[2]
WN BHM-MDW APR 0.8>1.9[1.9] JUN 0>0.4[1.9]
WN BHM-TPA APR 0.9>2[1.9] MAY 0>1.9[1.8] JUN 0>0.4[1.3]
WN BNA-BOS APR 1.5>4[3] JUN 0>0.7[3]
WN BNA-BUF MAY 0>0.3[0]
WN BNA-BUR APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0.7]
WN BNA-BWI APR 3>6[6] JUN 0>1.2[6]
WN BNA-CHS APR 0.6>1.8[1.2] MAY 0>2[1.2] JUN 0>0.4[1.5]
WN BNA-CLE APR 0.9>3[3] JUN 0>0.6[3]
WN BNA-CLT APR 0.8>1.9[1.9] JUN 0>0.4[1.8]
WN BNA-CMH APR 0.9>2[2] MAY 0>2.0[2] JUN 0>0.4[2.0]
WN BNA-DAL APR 3>6[5] MAY 0>6[5] JUN 0>1.2[5]
WN BNA-DCA APR 1.7>4[4] JUN 0>0.8[4]
WN BNA-DEN APR 3>6[5] JUN 0>1.1[6]
WN BNA-DTW APR 1.1>3[2.0] MAY 0>3[2.0] JUN 0>0.6[3]
WN BNA-ECP APR 1.0>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN BNA-FLL APR 3>5[4] JUN 0>0.8[4]
WN BNA-HOU APR 1.7>4[4] JUN 0>0.8[4]
WN BNA-JAX APR 1.3>3[3] JUN 0>0.6[3]
WN BNA-LAS APR 1.4>4[3] MAY 0>4[3] JUN 0>0.8[3]
WN BNA-LAX APR 1.2>3[3] MAY 0>3[2] JUN 0>0.6[2]
WN BNA-LGA APR 1.7>4[3] MAY 0>4[3] JUN 0>0.8[3]
WN BNA-MCI APR 1.7>4[4] JUN 0>0.8[4]
WN BNA-MCO APR 3>7[5] MAY 0>7[5] JUN 0>1.2[5]
WN BNA-MDW APR 3>6[7] JUN 0>1.3[7]
WN BNA-MKE APR 0.9>2[2] MAY 0>2[2.0] JUN 0>0.4[2.0]
WN BNA-MSP APR 0.7>1.7[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.6]
WN BNA-MSY APR 1.7>4[3] JUN 0>0.8[4]
WN BNA-OAK APR 0.4>1.0[1.0] MAY 0>1.0[1.1] JUN 0>0.2[1.0]
WN BNA-PHL APR 1.1>3[3] JUN 0>0.6[3]
WN BNA-PHX APR 1.7>4[4] JUN 0>0.8[3]
WN BNA-PIT APR 0.9>2[2] JUN 0>0.4[2]
WN BNA-PNS APR 0.9>2[2] JUN 0>0.4[2]
WN BNA-RDU APR 1.2>3[3] JUN 0>0.6[3]
WN BNA-RSW MAY 0>0.3[0.1]
WN BNA-SAN APR 0.9>2[2] MAY 0>2[1.9] JUN 0>0.4[1.9]
WN BNA-SAT APR 1.2>3[1.9] MAY 0>2[1.9] JUN 0>0.5[1.9]
WN BNA-SJC APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0.7]
WN BNA-STL APR 1.5>4[3] JUN 0>0.7[3]
WN BNA-TPA APR 3>5[4] JUN 0>0.8[5]
WN BOI-DEN APR 1.1>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN BOI-GEG APR 0.7>1.7[1.9] MAY 0>1.7[1.8] JUN 0>0.4[1.8]
WN BOI-LAS APR 0.9>2[1.9] MAY 0>2[1.8] JUN 0>0.5[2]
WN BOI-OAK APR 0.9>2[2] JUN 0>0.4[2]
WN BOI-PHX APR 0.6>1.1[1.0] JUN 0>0.2[1.0]
WN BOI-SAN APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN BOI-SJC APR 0.7>1.7[0.9] MAY 0>1.5[0.9] JUN 0>0.3[1.6]
WN BOI-SMF APR 0.4>1.4[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.0]
WN BOS-BWI APR 4>10[9] MAY 0>10[9] JUN 0>2[9]
WN BOS-CMH APR 0.3>1.3[1.5] JUN 0>0.4[1.7]
WN BOS-DAL APR 0>0.6[1.0] JUN 0>0.2[1.0]
WN BOS-DEN APR 0.8>2[3] JUN 0>0.6[3]
WN BOS-HOU APR 0.4>1.0[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.0]
WN BOS-MDW APR 1.7>4[4] MAY 0>5[4] JUN 0>1.0[5]
WN BOS-STL APR 1.2>3[3] MAY 0>4[3] JUN 0>0.7[4]
WN BUF-BWI APR 2.0>5[5] MAY 0>5[6] JUN 0>1.2[5]
WN BUF-DEN APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0.7]
WN BUF-FLL APR 0.9>1.4[1.3] JUN 0>0.2[0.3]
WN BUF-LAS APR 0.4>1.1[1.9] MAY 0>1.2[1.9] JUN 0>0.2[1.2]
WN BUF-MCO APR 1.6>4[4] MAY 0>4[3] JUN 0>0.8[1.6]
WN BUF-MDW APR 0.8>2[3] JUN 0>0.6[3]
WN BUF-PHX APR 0.5>1.1[1.0] JUN 0>0.2[1.0]
WN BUF-TPA APR 1.1>2[3] MAY 0>2[2.0] JUN 0>0.4[1.4]
WN BUR-DAL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN BUR-DEN APR 1.2>3[1.9] MAY 0>4[1.9] JUN 0>0.7[3]
WN BUR-HOU APR 0.4>1.0[0.9] MAY 0>1.0[0.9] JUN 0>0.2[0.9]
WN BUR-LAS APR 5>11[9] MAY 0>11[10] JUN 0>2[10]
WN BUR-MDW APR 0.4>1.0[0.9] MAY 0>1.0[0.9] JUN 0>0.2[1.4]
WN BUR-OAK APR 6>13[11] MAY 0>13[11] JUN 0>3[12]
WN BUR-PDX APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN BUR-PHX APR 3>7[6] MAY 0>7[6] JUN 0>1.5[6]
WN BUR-SFO APR 2>5[5] MAY 0>5[4] JUN 0>1.1[5]
WN BUR-SJC APR 5>11[10] JUN 0>2[10]
WN BUR-SLC APR 0.4>0.9[1.0] MAY 0>0.8[1.0]
WN BUR-SMF APR 4>11[9] MAY 0>10[8] JUN 0>2[9]
WN BWI-CHS APR 1.4>4[3] MAY 0>4[3] JUN 0>0.8[4]
WN BWI-CLE APR 1.2>3[3] MAY 0>4[3] JUN 0>0.8[3]
WN BWI-CLT APR 1.5>4[3] JUN 0>0.7[3]
WN BWI-CMH APR 1.6>4[4] JUN 0>0.8[4]
WN BWI-CUN APR 1.0>2[2] JUN 0>0.4[2]
WN BWI-CVG APR 1.2>3[3] JUN 0>0.6[3]
WN BWI-DAL APR 2>5[4] MAY 0>5[4] JUN 0>1.0[4]
WN BWI-DEN APR 2>6[5] MAY 0>5[4] JUN 0>1.1[5]
WN BWI-DTW APR 1.2>3[3] MAY 0>3[2] JUN 0>0.6[3]
WN BWI-ECP APR 0.1>0.7[0.9] MAY 0>1.2[1.1] JUN 0>0.2[1.2]
WN BWI-FLL APR 4>10[10] MAY 0>11[10] JUN 0>2[9]
WN BWI-GRR APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN BWI-GSP APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN BWI-HOU APR 1.7>4[4] JUN 0>0.8[5]
WN BWI-IND APR 1.6>4[3] MAY 0>4[3] JUN 0>0.8[3]
WN BWI-ISP APR 1.8>5[5] MAY 0>5[4] JUN 0>1.1[4]
WN BWI-JAX APR 2>4[4] JUN 0>0.8[4]
WN BWI-LAS APR 1.8>5[5] JUN 0>1.0[4]
WN BWI-LAX APR 1.2>3[3] MAY 0>3[2] JUN 0>0.8[3]
WN BWI-MBJ APR 0.9>2[2] JUN 0>0.4[2]
WN BWI-MCI APR 1.2>3[3] JUN 0>0.6[3]
WN BWI-MCO APR 5>11[10] MAY 0>11[10] JUN 0>2[9]
WN BWI-MDW APR 3>8[7] JUN 0>1.5[7]
WN BWI-MEM APR 0.5>1.6[1.7] MAY 0>1.8[1.9] JUN 0>0.4[1.3]
WN BWI-MHT APR 2>5[6] JUN 0>1.2[6]
WN BWI-MKE APR 1.1>3[3] JUN 0>0.5[3]
WN BWI-MSP APR 0.7>1.8[1.9] JUN 0>0.4[1.9]
WN BWI-MSY APR 1.7>4[3] MAY 0>4[3] JUN 0>0.8[4]
WN BWI-NAS MAY 0>0.3[0.1]
WN BWI-OAK APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN BWI-OKC APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN BWI-ORF APR 1.9>5[5] JUN 0>1.0[5]
WN BWI-PBI APR 2>4[3] MAY 0>4[3] JUN 0>0.8[2]
WN BWI-PHX APR 1.3>3[3] JUN 0>0.6[2]
WN BWI-PIT APR 1.2>3[3] JUN 0>0.6[3]
WN BWI-PUJ APR 0.6>1.3[1.3] JUN 0>0.2[1.9]
WN BWI-PVD APR 2>5[6] JUN 0>1.2[6]
WN BWI-PWM APR 1.3>3[3] JUN 0>0.6[4]
WN BWI-RDU APR 3>7[6] MAY 0>7[6] JUN 0>1.5[6]
WN BWI-ROC APR 1.2>3[3] JUN 0>0.6[3]
WN BWI-RSW APR 2>6[5] MAY 0>6[5] JUN 0>1.2[4]
WN BWI-SAN APR 1.2>3[3] JUN 0>0.6[2]
WN BWI-SAT APR 0.9>3[3] JUN 0>0.6[3]
WN BWI-SDF APR 1.2>3[3] MAY 0>3[4] JUN 0>0.6[4]
WN BWI-SJC APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN BWI-SJU APR 0.5>1.1[1.1] JUN 0>0.2[1.0]
WN BWI-SLC APR 0.4>1.0[1.0] JUN 0>0.2[1.6]
WN BWI-SMF APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN BWI-STL APR 1.7>4[4] JUN 0>0.8[4]
WN BWI-TPA APR 4>9[8] MAY 0>8[7] JUN 0>1.7[7]
WN BZE-FLL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN BZE-HOU APR 0.4>1.0[1.0] JUN 0>0.2[1.1]
WN CHS-DAL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN CHS-DEN MAY 0>0.3[0.1]
WN CHS-HOU APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN CHS-MDW APR 0.8>1.9[2.0] JUN 0>0.4[2]
WN CHS-STL MAY 0>0.3[0.1]
WN CLE-DEN APR 0.8>1.8[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.5]
WN CLE-LAS MAY 0>0.3[1.0]
WN CLE-MDW APR 1.9>4[4] JUN 0>0.9[4]
WN CLE-MKE APR 0.7>1.6[1.6] MAY 0>1.5[1.6] JUN 0>0.3[1.5]
WN CLE-PHX APR 0.6>1.2[1.4] MAY 0>1.2[1.1] JUN 0>0.2[1.1]
WN CLE-STL APR 1.1>3[2.0] MAY 0>3[2.0] JUN 0>0.5[3]
WN CLT-DAL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN CLT-HOU APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN CLT-MDW APR 1.1>3[3] JUN 0>0.6[3]
WN CMH-DAL APR 0.6>1.1[1.1] MAY 0>1.0[1.1] JUN 0>0.2[1.2]
WN CMH-DCA APR 0.7>1.7[1.9] MAY 0>1.7[1.9] JUN 0>0.4[1.8]
WN CMH-DEN APR 0.9>1.6[1.3] MAY 0>1.3[1.1] JUN 0>0.2[1.7]
WN CMH-FLL APR 0.7>1.3[1.1] MAY 0>1.2[1.0] JUN 0>0.2[1.0]
WN CMH-HOU APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN CMH-LAS APR 0.9>2[2] JUN 0>0.4[1.3]
WN CMH-MCO APR 2>4[5] MAY 0>4[3] JUN 0>0.8[3]
WN CMH-MDW APR 2>5[5] JUN 0>1.1[5]
WN CMH-PHX APR 0.6>1.2[1.1] MAY 0>1.0[1.1] JUN 0>0.2[1.1]
WN CMH-RSW APR 1.4>2[2] MAY 0>1.5[1.1] JUN 0>0.3[1.3]
WN CMH-STL APR 0.8>1.9[3] MAY 0>2.0[3] JUN 0>0.4[2]
WN CMH-TPA APR 1.6>3[2] JUN 0>0.5[3]
WN CRP-HOU APR 1.5>4[4] MAY 0>3[4] JUN 0>0.7[4]
WN CUN-DEN APR 0.5>1.2[1.2] JUN 0>0.2[1.3]
WN CUN-FLL APR 0.9>2[2] JUN 0>0.4[2]
WN CUN-HOU APR 1.3>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN CUN-MDW APR 0.6>1.4[2] MAY 0>1.6[2] JUN 0>0.3[1.6]
WN CUN-STL APR 0.4>1.0[1.0] JUN 0>0.2[0.5]
WN CVG-DEN APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN CVG-MCO MAY 0>0.3[0]
WN CVG-MDW APR 1.8>4[5] MAY 0>4[5] JUN 0>0.9[5]
WN CZM-HOU APR 0.9>2[0] MAY 0>2[0] JUN 0>0.4[0]
WN DAL-DCA APR 2>5[5] JUN 0>1.0[5]
WN DAL-DEN APR 4>9[7] MAY 0>8[7] JUN 0>1.7[7]
WN DAL-DTW APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-ECP APR 0.8>1.9[2] JUN 0>0.4[2]
WN DAL-ELP APR 1.7>4[4] JUN 0>0.8[4]
WN DAL-FLL APR 1.9>4[3] MAY 0>4[3] JUN 0>0.8[3]
WN DAL-HOU APR 8>19[19] MAY 0>18[19] JUN 0>4[19]
WN DAL-IND APR 0.6>1.2[1.1] MAY 0>1.2[1.1] JUN 0>0.2[1.3]
WN DAL-LAS APR 3>6[5] MAY 0>6[4] JUN 0>1.1[5]
WN DAL-LAX APR 2>5[5] JUN 0>0.9[5]
WN DAL-LBB APR 2>5[5] JUN 0>1.0[5]
WN DAL-LGA APR 2>5[5] JUN 0>0.9[5]
WN DAL-LIT APR 0.9>2[3] MAY 0>2[3] JUN 0>0.4[3]
WN DAL-MAF APR 1.9>4[4] JUN 0>0.9[4]
WN DAL-MCI APR 3>6[6] JUN 0>1.1[6]
WN DAL-MCO APR 3>5[4] MAY 0>5[4] JUN 0>1.0[4]
WN DAL-MDW APR 3>8[7] MAY 0>8[7] JUN 0>1.5[7]
WN DAL-MEM APR 0.9>2[3] MAY 0>2[3] JUN 0>0.4[3]
WN DAL-MKE APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-MSP APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-MSY APR 3>7[7] JUN 0>1.4[7]
WN DAL-OAK APR 0.7>1.7[1.9] MAY 0>1.7[1.9] JUN 0>0.4[1.9]
WN DAL-OMA APR 0.5>1.1[1.3] MAY 0>1.1[1.2] JUN 0>0.2[1.1]
WN DAL-ONT APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-PHL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-PHX APR 3>7[6] MAY 0>7[6] JUN 0>1.4[6]
WN DAL-PIT APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-PNS APR 0.1>0.6[0.8] JUN 0>0.2[1.2]
WN DAL-RDU APR 0.5>1.1[1.1] MAY 0>1.2[1.1] JUN 0>0.2[1.2]
WN DAL-SAN APR 1.7>4[4] JUN 0>0.8[4]
WN DAL-SAT APR 4>9[10] JUN 0>1.9[9]
WN DAL-SDF APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-SJC APR 1.0>2[1.7] MAY 0>2[1.7] JUN 0>0.5[1.7]
WN DAL-SLC APR 0.6>1.1[1.0] JUN 0>0.2[1.0]
WN DAL-SMF APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DAL-STL APR 3>6[6] JUN 0>1.1[6]
WN DAL-TPA APR 1.5>3[3] JUN 0>0.6[3]
WN DAL-TUL APR 1.5>3[4] MAY 0>3[4] JUN 0>0.7[4]
WN DCA-FLL APR 1.0>2[2] JUN 0>0.4[2]
WN DCA-HOU APR 1.3>3[3] JUN 0>0.6[3]
WN DCA-MCI APR 0.8>1.9[1.9] MAY 0>2[1.9] JUN 0>0.4[1.8]
WN DCA-MCO APR 1.0>2[2] JUN 0>0.4[2]
WN DCA-MDW APR 3>6[6] JUN 0>1.2[6]
WN DCA-MKE APR 0.9>2[1.9] MAY 0>2[1.9] JUN 0>0.4[1.8]
WN DCA-MSY APR 0.9>2[2] JUN 0>0.4[2]
WN DCA-OKC APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DCA-OMA APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DCA-PVD APR 0.8>1.9[2] MAY 0>1.8[2] JUN 0>0.4[2]
WN DCA-STL APR 1.7>4[4] JUN 0>0.8[4]
WN DCA-TPA APR 1.0>2[2] JUN 0>0.4[2]
WN DEN-DSM APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN DEN-DTW APR 0.7>1.7[1.7] JUN 0>0.4[1.8]
WN DEN-ELP APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DEN-FLL APR 1.4>2[1.6] MAY 0>1.5[1.1] JUN 0>0.2[1.4]
WN DEN-GEG APR 0.9>2[2] MAY 0>2[1.9] JUN 0>0.4[2]
WN DEN-GRR APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DEN-HOU APR 3>7[6] JUN 0>1.5[7]
WN DEN-IAD APR 1.2>3[3] JUN 0>0.6[3]
WN DEN-IND APR 1.3>3[4] JUN 0>0.7[4]
WN DEN-JAX APR 0.5>1.1[1.0] JUN 0>0.2[1.0]
WN DEN-LAS APR 5>11[9] JUN 0>2[9]
WN DEN-LAX APR 3>8[7] JUN 0>1.5[7]
WN DEN-LBB APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DEN-LGA APR 1.5>3[3] JUN 0>0.7[3]
WN DEN-LGB MAR 0>0.5[0.3]
WN DEN-MCI APR 3>7[6] JUN 0>1.3[6]
WN DEN-MCO APR 2>4[3] MAY 0>4[3] JUN 0>0.8[4]
WN DEN-MDW APR 4>9[9] JUN 0>1.9[9]
WN DEN-MEM APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DEN-MKE APR 1.6>4[4] JUN 0>0.7[4]
WN DEN-MSP APR 2>5[4] JUN 0>1.1[5]
WN DEN-MSY APR 1.3>3[3] JUN 0>0.6[3]
WN DEN-OAK APR 2>5[5] JUN 0>1.1[5]
WN DEN-OKC APR 1.2>3[3] JUN 0>0.6[3]
WN DEN-OMA APR 1.3>3[3] MAY 0>4[3] JUN 0>0.7[3]
WN DEN-ONT APR 1.2>3[1.9] MAY 0>3[1.9] JUN 0>0.7[2]
WN DEN-ORF MAY 0>0.3[0]
WN DEN-PDX APR 2>5[4] JUN 0>0.9[5]
WN DEN-PHL APR 1.2>3[2] JUN 0>0.5[3]
WN DEN-PHX APR 5>12[12] JUN 0>3[10]
WN DEN-PIT APR 0.8>1.4[1.0] JUN 0>0.2[2]
WN DEN-PVR APR 0.6>1.1[1.1] JUN 0>0.2[0.9]
WN DEN-RDU APR 0.8>1.9[2] MAY 0>2[2.0] JUN 0>0.4[2]
WN DEN-RNO APR 1.1>3[1.9] MAY 0>3[1.9] JUN 0>0.6[2]
WN DEN-SAN APR 3>7[6] MAY 0>7[6] JUN 0>1.4[6]
WN DEN-SAT APR 1.4>3[2] MAY 0>3[2] JUN 0>0.6[3]
WN DEN-SDF APR 0.4>1.0[1.0] JUN 0>0.2[1.1]
WN DEN-SEA APR 1.5>5[3] MAY 0>5[3] JUN 0>1.1[4]
WN DEN-SFO APR 1.6>4[3] MAY 0>4[3] JUN 0>0.9[4]
WN DEN-SJC APR 1.6>4[4] JUN 0>0.9[4]
WN DEN-SJD APR 0.6>1.3[1.3] JUN 0>0.2[1.2]
WN DEN-SLC APR 3>6[6] JUN 0>1.3[6]
WN DEN-SMF APR 2.0>5[4] MAY 0>5[4] JUN 0>1.0[4]
WN DEN-SNA APR 2>4[5] MAY 0>4[5] JUN 0>0.7[4]
WN DEN-STL APR 2>6[5] JUN 0>1.1[6]
WN DEN-TPA APR 1.8>4[3] MAY 0>3[2] JUN 0>0.6[2]
WN DEN-TUL APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.9]
WN DEN-TUS APR 1.3>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN DSM-LAS APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN DSM-STL APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.8]
WN DTW-LAS MAY 0>0.3[1.0]
WN DTW-MDW APR 1.5>4[4] JUN 0>0.9[4]
WN DTW-PHX APR 0.6>1.2[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.0]
WN DTW-STL APR 1.0>3[1.9] MAY 0>3[1.9] JUN 0>0.5[2]
WN ECP-HOU APR 0.5>1.2[1.1] MAY 0>1.3[1.1] JUN 0>0.2[1.2]
WN ECP-STL APR 0.5>1.1[1.0] MAY 0>1.2[1.1] JUN 0>0.2[1.3]
WN ELP-HOU APR 1.2>3[3] JUN 0>0.6[3]
WN ELP-LAS APR 1.0>2[2] JUN 0>0.4[2]
WN ELP-LAX APR 0.7>1.7[1.6] JUN 0>0.4[1.8]
WN ELP-PHX APR 1.2>3[3] JUN 0>0.6[3]
WN ELP-SAN APR 0.4>1.0[1.1] MAY 0>1.0[1.1] JUN 0>0.2[1.0]
WN ELP-SAT APR 0.9>2[1.9] MAY 0>2.0[1.9] JUN 0>0.4[2]
WN FLL-GCM APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN FLL-HAV APR 1.3>3[3] JUN 0>0.6[3]
WN FLL-HOU APR 1.7>4[3] MAY 0>4[3] JUN 0>0.8[3]
WN FLL-IND APR 1.1>2[1.3] MAY 0>2.0[1.0] JUN 0>0.4[1.1]
WN FLL-ISP APR 0.4>1.0[1.3] MAY 0>1.0[1.1] JUN 0>0.2[0.5]
WN FLL-LAS APR 0.4>1.0[1.0] JUN 0>0.2[0.9]
WN FLL-MBJ APR 0.9>2[2] JUN 0>0.4[2]
WN FLL-MCI APR 1.1>1.8[1.4] MAY 0>1.3[1.1] JUN 0>0.2[1.3]
WN FLL-MCO APR 1.5>3[5] MAY 0>3[4] JUN 0>0.7[4]
WN FLL-MDW APR 2>5[4] JUN 0>0.8[4]
WN FLL-MKE MAY 0>0.3[0.1]
WN FLL-MSY APR 1.2>3[3] JUN 0>0.6[3]
WN FLL-NAS APR 0.9>2[2] JUN 0>0.4[2]
WN FLL-PHL APR 0.5>1.1[1.0] JUN 0>0.2[0.4]
WN FLL-PHX APR 0.6>1.2[1.0] JUN 0>0.2[1.0]
WN FLL-PIT APR 0.9>1.7[1.3] MAY 0>1.5[1.1] JUN 0>0.3[1.2]
WN FLL-PLS APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN FLL-PUJ APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN FLL-PVD APR 0.6>1.3[1.5] MAY 0>1.3[1.2] JUN 0>0.3[0.6]
WN FLL-RDU APR 0.6>1.2[1.1] MAY 0>1.2[1.1] JUN 0>0.2[1.1]
WN FLL-SAT APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN FLL-SJO APR 0.5>1.1[1.0] JUN 0>0.2[1.0]
WN FLL-SJU APR 0.7>1.5[1.0] MAY 0>1.5[1.0] JUN 0>0.3[1.2]
WN FLL-STL APR 1.5>3[2] MAY 0>2[1.8] JUN 0>0.4[2]
WN FLL-TPA APR 1.9>4[5] MAY 0>4[5] JUN 0>0.9[4]
WN GCM-HOU MAY 0>0.3[0]
WN GEG-LAS APR 0.9>2[2] MAY 0>2[1.9] JUN 0>0.4[2.0]
WN GEG-OAK APR 0.9>1.9[2] JUN 0>0.4[1.9]
WN GEG-PHX APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN GEG-SAN APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0.7]
WN GEG-SJC APR 0.4>1.0[0.9] MAY 0>1.0[0.9] JUN 0>0.2[0.9]
WN GEG-SMF APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN GRR-MDW APR 1.2>3[3] JUN 0>0.6[2]
WN HAV-TPA APR 0.5>1.1[1.1] MAY 0>1.2[1.1] JUN 0>0.2[1.2]
WN HNL-ITO APR 1.7>4[0] MAY 0>4[0] JUN 0>0.8[0]
WN HNL-KOA APR 1.7>4[0] MAY 0>4[3] JUN 0>0.8[4]
WN HNL-LIH APR 1.7>4[0] MAY 0>4[0] JUN 0>0.8[0]
WN HNL-OAK APR 0.9>2[2] JUN 0>0.4[2]
WN HNL-OGG APR 1.7>5[0.4] MAY 0>6[4] JUN 0>1.2[4]
WN HNL-SAN APR 0>0.4[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN HNL-SJC APR 0.4>1.0[0] MAY 0>1.0[0.9] JUN 0>0.2[1.0]
WN HNL-SMF APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN HOU-HRL APR 2.0>5[5] JUN 0>1.0[5]
WN HOU-IND APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.9]
WN HOU-JAX APR 0.8>1.8[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.0]
WN HOU-LAS APR 2>5[5] JUN 0>1.0[5]
WN HOU-LAX APR 2>5[5] JUN 0>1.0[5]
WN HOU-LBB APR 0.1>0.6[0.0] MAY 0>0.8[0]
WN HOU-LGA APR 1.2>3[3] JUN 0>0.6[3]
WN HOU-LIR APR 0.5>1.1[1.0] JUN 0>0.2[1.2]
WN HOU-LIT APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN HOU-MAF APR 1.5>4[4] MAY 0>3[4] JUN 0>0.7[4]
WN HOU-MBJ APR 0.4>1.0[0.8] MAY 0>1.0[0.7] JUN 0>0.2[1.2]
WN HOU-MCI APR 1.2>3[3] JUN 0>0.6[3]
WN HOU-MCO APR 2>6[4] MAY 0>6[4] JUN 0>1.2[5]
WN HOU-MDW APR 3>7[6] MAY 0>7[6] JUN 0>1.3[6]
WN HOU-MEM APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.8]
WN HOU-MKE APR 0.4>1.4[1.0] MAY 0>1.5[1.0] JUN 0>0.3[1.0]
WN HOU-MSY APR 4>9[9] MAY 0>9[10] JUN 0>1.9[9]
WN HOU-OAK APR 1.1>3[1.9] MAY 0>3[2] JUN 0>0.5[2]
WN HOU-OKC APR 1.9>5[4] JUN 0>0.9[4]
WN HOU-OMA APR 0.5>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.0]
WN HOU-PHX APR 2>6[5] MAY 0>6[5] JUN 0>1.2[4]
WN HOU-PIT APR 0.4>1.1[1.7] MAY 0>1.1[1.6] JUN 0>0.2[1.2]
WN HOU-PNS APR 0.4>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.0]
WN HOU-PVR APR 0.5>1.1[1.0] JUN 0>0.2[1.2]
WN HOU-RDU APR 0.5>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.0]
WN HOU-SAN APR 1.2>3[3] MAY 0>3[1.9] JUN 0>0.6[2]
WN HOU-SAT APR 3>6[5] MAY 0>6[5] JUN 0>1.2[5]
WN HOU-SDF APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN HOU-SJC APR 0.4>1.0[1.6] JUN 0>0.2[1.0]
WN HOU-SJD APR 0.9>2[1.2] MAY 0>2.0[1.1] JUN 0>0.4[1.3]
WN HOU-SJO APR 0.5>1.1[1.0] JUN 0>0.2[1.0]
WN HOU-STL APR 1.7>4[4] JUN 0>0.8[4]
WN HOU-TPA APR 1.7>4[3] MAY 0>4[3] JUN 0>0.8[3]
WN HOU-TUL APR 1.2>3[3] JUN 0>0.6[3]
WN ICT-LAS APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN ICT-PHX APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN ICT-STL APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.8]
WN IND-LAS APR 1.4>3[3] JUN 0>0.6[3]
WN IND-LAX APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN IND-MCI APR 0.7>1.7[1.7] MAY 0>1.5[1.7] JUN 0>0.3[1.8]
WN IND-MCO APR 2>4[4] JUN 0>0.8[4]
WN IND-MDW APR 0.4>1.0[1.7] MAY 0>1.0[1.7] JUN 0>0.2[1.2]
WN IND-PHX APR 1.1>2[2] JUN 0>0.4[1.4]
WN IND-RSW APR 1.9>3[3] MAY 0>1.6[1.4] JUN 0>0.3[1.5]
WN IND-TPA APR 1.6>3[3] JUN 0>0.6[3]
WN ISP-MCO APR 1.2>3[3] MAY 0>3[2] JUN 0>0.6[3]
WN ISP-PBI APR 1.0>2[2] MAY 0>2.0[1.5] JUN 0>0.4[1.8]
WN ISP-TPA APR 0.5>1.1[1.2] JUN 0>0.2[1.1]
WN JAX-MDW APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN KOA-OAK APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN KOA-OGG APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN KOA-SJC APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN LAS-LAX APR 5>11[10] MAY 0>11[9] JUN 0>2[10]
WN LAS-LBB APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN LAS-LGB FEB 1.6>2[3] MAR 0.6>1.6[3] APR 0.3>0.5[3] MAY 0>0.6[3]
WN LAS-LIT APR 0.4>1.0[1.0] MAY 0>1.0[1.1] JUN 0>0.2[1.1]
WN LAS-MAF APR 0.5>1.1[1.1] JUN 0>0.2[1.2]
WN LAS-MCI APR 1.9>4[4] JUN 0>0.8[4]
WN LAS-MCO APR 0.9>2[2] JUN 0>0.4[2]
WN LAS-MDW APR 4>9[9] MAY 0>9[8] JUN 0>1.8[8]
WN LAS-MKE APR 1.4>3[3] JUN 0>0.6[2]
WN LAS-MSY APR 0.7>1.9[2.0] JUN 0>0.4[1.9]
WN LAS-OAK APR 4>9[9] MAY 0>9[8] JUN 0>1.7[9]
WN LAS-OKC APR 0.9>2[2] JUN 0>0.4[1.9]
WN LAS-OMA APR 1.3>3[3] JUN 0>0.6[3]
WN LAS-ONT APR 1.7>5[4] MAY 0>5[4] JUN 0>1.0[4]
WN LAS-PDX APR 2.0>5[4] MAY 0>5[4] JUN 0>1.0[4]
WN LAS-PHX APR 5>11[10] MAY 0>11[10] JUN 0>2[10]
WN LAS-PIT APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[0.7]
WN LAS-RDU APR 0.4>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.1]
WN LAS-RNO APR 4>11[10] MAY 0>11[10] JUN 0>2[9]
WN LAS-SAN APR 5>11[11] JUN 0>2[11]
WN LAS-SAT APR 1.7>4[4] JUN 0>0.7[4]
WN LAS-SDF APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN LAS-SEA APR 0.9>3[3] JUN 0>0.6[3]
WN LAS-SFO APR 3>6[6] MAY 0>7[6] JUN 0>1.3[6]
WN LAS-SJC APR 5>11[10] MAY 0>11[10] JUN 0>2[10]
WN LAS-SLC APR 2>5[5] JUN 0>1.1[5]
WN LAS-SMF APR 4>10[8] MAY 0>9[8] JUN 0>1.9[7]
WN LAS-SNA APR 2>6[6] MAY 0>5[6] JUN 0>1.1[5]
WN LAS-STL APR 1.7>4[4] JUN 0>0.8[4]
WN LAS-TPA APR 0.5>1.1[1.9] MAY 0>1.2[1.9] JUN 0>0.2[0.7]
WN LAS-TUL APR 0.5>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.2[1.1]
WN LAS-TUS APR 1.4>4[3] MAY 0>4[3] JUN 0>0.7[3]
WN LAX-MCI APR 1.2>3[3] JUN 0>0.6[3]
WN LAX-MDW APR 2>5[6] MAY 0>6[5] JUN 0>1.2[5]
WN LAX-MKE APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN LAX-MSY APR 1.0>2[3] MAY 0>1.7[1.9] JUN 0>0.4[1.7]
WN LAX-OAK APR 5>13[12] MAY 0>13[11] JUN 0>3[12]
WN LAX-PDX APR 0.4>1.0[2] MAY 0>1.0[2] JUN 0>0.2[2]
WN LAX-PHX APR 4>9[8] JUN 0>1.7[8]
WN LAX-RNO APR 1.2>3[3] JUN 0>0.5[3]
WN LAX-SAT APR 0.7>1.8[1.9] JUN 0>0.4[1.6]
WN LAX-SFO APR 3>8[9] MAY 0>8[9] JUN 0>1.7[8]
WN LAX-SJC APR 4>11[10] JUN 0>2[10]
WN LAX-SJD MAY 0>0.3[1.0]
WN LAX-SLC APR 1.2>3[3] MAY 0>3[2] JUN 0>0.6[3]
WN LAX-SMF APR 4>8[8] JUN 0>1.7[8]
WN LAX-STL APR 1.3>3[3] JUN 0>0.6[3]
WN LAX-TUS APR 1.2>3[3] JUN 0>0.6[3]
WN LGA-MCI APR 0.7>1.3[1.9] MAY 0>1.0[1.9] JUN 0>0.2[1.8]
WN LGA-MDW APR 2>7[6] MAY 0>7[6] JUN 0>1.5[6]
WN LGA-MSY APR 0.4>1.1[1.0] MAY 0>1.2[1.0] JUN 0>0.2[1.0]
WN LGA-STL APR 1.2>3[3] MAY 0>4[3] JUN 0>0.7[3]
WN LGA-TPA APR 0.7>1.8[1.7] MAY 0>1.8[1.7] JUN 0>0.4[1.7]
WN LGB-OAK APR 1.7>4[4] JUN 0>0.8[4]
WN LGB-SJC APR 1.6>4[3] JUN 0>0.8[4]
WN LGB-SMF APR 1.6>4[4] JUN 0>0.8[4]
WN LIH-OAK APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN LIH-SJC APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN LIT-PHX APR 0.4>1.0[1.0] JUN 0>0.2[1.1]
WN LIT-STL APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.8]
WN MBJ-MCO MAY 0>0.3[1.0]
WN MCI-MCO APR 1.6>3[2] JUN 0>0.4[3]
WN MCI-MDW APR 3>8[7] MAY 0>8[7] JUN 0>1.5[7]
WN MCI-MKE APR 0.7>1.7[1.7] MAY 0>1.6[1.7] JUN 0>0.3[1.8]
WN MCI-MSP APR 0.7>1.6[1.7] MAY 0>1.5[1.7] JUN 0>0.3[1.7]
WN MCI-MSY APR 0.5>1.2[1.1] MAY 0>1.3[1.1] JUN 0>0.2[1.2]
WN MCI-OAK APR 0.4>0.9[0.8] MAY 0>0.8[0.9]
WN MCI-PHX APR 2>5[4] JUN 0>0.8[3]
WN MCI-RDU APR 0.4>0.9[1.0] JUN 0>0.2[1.0]
WN MCI-SAN APR 0.8>1.8[1.9] MAY 0>1.7[1.9] JUN 0>0.4[1.7]
WN MCI-SAT APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN MCI-STL APR 1.5>4[4] MAY 0>3[4] JUN 0>0.7[3]
WN MCI-TPA APR 1.2>1.9[1.6] MAY 0>1.3[1.2] JUN 0>0.3[1.8]
WN MCO-MDW APR 4>9[8] MAY 0>8[7] JUN 0>1.6[8]
WN MCO-MEM APR 1.0>1.7[1.4] MAY 0>1.3[1.1] JUN 0>0.2[1.3]
WN MCO-MHT APR 0.9>3[3] MAY 0>3[2] JUN 0>0.6[1.6]
WN MCO-MKE APR 2>4[4] JUN 0>0.6[3]
WN MCO-MSY APR 1.8>4[4] MAY 0>4[5] JUN 0>0.8[4]
WN MCO-ORF APR 0.5>1.1[1.2] JUN 0>0.2[1.3]
WN MCO-PHL APR 1.4>3[4] JUN 0>0.7[3]
WN MCO-PHX APR 0.6>1.3[1.3] JUN 0>0.2[1.4]
WN MCO-PIT APR 2>5[5] MAY 0>5[4] JUN 0>1.0[4]
WN MCO-PVD APR 1.4>4[4] JUN 0>0.8[3]
WN MCO-RDU APR 1.4>3[3] JUN 0>0.6[3]
WN MCO-RIC MAY 0>0.3[0]
WN MCO-ROC APR 0.6>1.3[1.7] MAY 0>1.3[1.0] JUN 0>0.2[1.0]
WN MCO-SAN APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN MCO-SAT APR 0.9>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[2]
WN MCO-SDF APR 0.6>1.2[1.1] JUN 0>0.2[1.3]
WN MCO-SJU APR 1.1>2[2] JUN 0>0.4[3]
WN MCO-STL APR 2>5[4] MAY 0>4[5] JUN 0>0.8[4]
WN MDW-MEM APR 0.7>1.8[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.8]
WN MDW-MHT APR 0.4>1.1[2] MAY 0>1.3[3] JUN 0>0.2[3]
WN MDW-MSP APR 3>6[7] JUN 0>1.3[7]
WN MDW-MSY APR 1.7>4[4] JUN 0>0.8[4]
WN MDW-OAK APR 1.2>3[3] MAY 0>4[3] JUN 0>0.7[3]
WN MDW-OKC APR 0.5>1.1[1.0] JUN 0>0.2[1.0]
WN MDW-OMA APR 2>6[5] JUN 0>1.1[4]
WN MDW-ONT APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN MDW-ORF APR 0.4>1.1[1.1] MAY 0>1.2[1.1] JUN 0>0.2[1.4]
WN MDW-PHL APR 2.0>5[6] JUN 0>1.1[5]
WN MDW-PHX APR 4>8[8] JUN 0>1.4[7]
WN MDW-PIT APR 1.9>4[4] JUN 0>0.9[4]
WN MDW-PUJ APR 0.5>0.8[0.7] MAY 0>0.6[0.5]
WN MDW-PVD APR 0.4>2[3] JUN 0>0.6[3]
WN MDW-RDU APR 1.2>3[4] JUN 0>0.7[4]
WN MDW-RSW APR 3>5[4] JUN 0>0.8[3]
WN MDW-SAN APR 1.7>4[4] JUN 0>0.8[4]
WN MDW-SAT APR 1.2>3[2] MAY 0>3[2.0] JUN 0>0.5[2]
WN MDW-SDF APR 1.2>3[3] MAY 0>3[4] JUN 0>0.7[4]
WN MDW-SEA APR 0.8>1.9[3] MAY 0>1.8[2] JUN 0>0.4[3]
WN MDW-SFO APR 0.7>1.8[2] MAY 0>1.8[1.9] JUN 0>0.4[1.2]
WN MDW-SJC APR 0.4>1.4[1.6] JUN 0>0.4[1.6]
WN MDW-SJD APR 0.3>0.6[0.6] MAY 0>0.6[0.5]
WN MDW-SLC APR 0.9>2[2] JUN 0>0.4[2]
WN MDW-SMF APR 0.4>1.0[1.0] JUN 0>0.2[1.6]
WN MDW-STL APR 3>7[7] JUN 0>1.5[7]
WN MDW-TPA APR 3>7[5] MAY 0>6[5] JUN 0>1.3[5]
WN MDW-TUS APR 0.5>1.1[1.0] MAY 0>1.0[1.1] JUN 0>0.2[1.0]
WN MEM-TPA APR 0.5>1.1[1.0] JUN 0>0.2[1.0]
WN MHT-TPA APR 0.6>1.6[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.4]
WN MKE-PHX APR 1.9>4[3] JUN 0>0.8[2]
WN MKE-RSW MAY 0>0.3[0.1]
WN MKE-STL APR 0.8>1.9[1.9] MAY 0>2.0[1.8] JUN 0>0.4[1.8]
WN MKE-TPA APR 1.4>2[1.6] MAY 0>1.5[1.1] JUN 0>0.3[1.1]
WN MSP-OAK APR 0.4>1.0[0.9] MAY 0>1.0[0.9] JUN 0>0.2[0.7]
WN MSP-PHX APR 1.1>2[1.7] MAY 0>2[1.2] JUN 0>0.4[1.8]
WN MSP-STL APR 0.8>2[3] MAY 0>2[3] JUN 0>0.5[3]
WN MSY-OAK APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN MSY-PHX APR 0.6>1.3[1.5] MAY 0>1.3[1.2] JUN 0>0.2[1.1]
WN MSY-SAN APR 0.4>0.9[1.1] MAY 0>1.0[1.7] JUN 0>0.2[1.2]
WN MSY-SAT APR 0.7>1.8[1.0] MAY 0>1.8[1.0] JUN 0>0.4[1.5]
WN MSY-STL APR 1.0>2[2] MAY 0>2[2.0] JUN 0>0.4[2]
WN MSY-TPA APR 1.4>3[3] JUN 0>0.6[3]
WN OAK-OGG APR 0.9>2[1.5] JUN 0>0.4[2]
WN OAK-ONT APR 3>7[7] MAY 0>6[7] JUN 0>1.3[7]
WN OAK-PDX APR 3>6[6] MAY 0>6[5] JUN 0>1.3[6]
WN OAK-PHX APR 3>6[7] JUN 0>1.1[6]
WN OAK-PVR MAY 0>0.3[0.5]
WN OAK-RNO APR 0.8>1.8[2] MAY 0>1.7[1.8] JUN 0>0.4[1.8]
WN OAK-SAN APR 5>12[11] JUN 0>2[11]
WN OAK-SAT APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN OAK-SEA APR 3>6[6] JUN 0>1.3[6]
WN OAK-SJD MAY 0>0.3[0.7]
WN OAK-SLC APR 1.2>3[3] JUN 0>0.6[3]
WN OAK-SNA APR 3>6[7] MAY 0>6[7] JUN 0>1.2[7]
WN OAK-STL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN OGG-SAN APR 0>0.6[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN OGG-SJC APR 0.4>1.0[0] MAY 0>1.0[0.2] JUN 0>0.2[1.0]
WN OGG-SMF APR 0.4>1.0[0] MAY 0>1.0[0] JUN 0>0.2[0]
WN OKC-PHX APR 1.2>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN OKC-STL APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.9]
WN OMA-PHX APR 1.9>3[3] JUN 0>0.4[1.5]
WN OMA-SAN APR 0.4>0.9[0] MAY 0>0.8[0]
WN OMA-STL APR 1.2>3[3] JUN 0>0.6[3]
WN ONT-PDX APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN ONT-PHX APR 3>6[6] JUN 0>1.3[6]
WN ONT-SFO APR 1.5>4[0] MAY 0>4[0] JUN 0>0.8[2]
WN ONT-SJC APR 2.0>5[5] JUN 0>0.9[4]
WN ONT-SMF APR 3>7[6] MAY 0>7[6] JUN 0>1.5[6]
WN PDX-PHX APR 1.9>4[3] JUN 0>0.6[4]
WN PDX-SAN APR 0.4>1.0[3] MAY 0>1.0[2] JUN 0>0.2[3]
WN PDX-SJC APR 3>6[6] MAY 0>6[5] JUN 0>1.2[6]
WN PDX-SMF APR 2.0>5[5] MAY 0>5[4] JUN 0>0.9[5]
WN PDX-STL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN PHL-PHX APR 0.4>1.0[1.0] JUN 0>0.2[0.9]
WN PHL-STL APR 1.1>3[3] JUN 0>0.5[3]
WN PHL-TPA APR 0.9>2[3] JUN 0>0.4[1.6]
WN PHX-PIT APR 0.5>1.1[1.0] JUN 0>0.2[1.0]
WN PHX-RDU APR 0.4>1.0[0.4] MAY 0>1.0[0.3] JUN 0>0.2[0.8]
WN PHX-RNO APR 0.9>2[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.9]
WN PHX-SAN APR 5>11[11] MAY 0>11[10] JUN 0>2[10]
WN PHX-SAT APR 1.3>3[3] JUN 0>0.6[3]
WN PHX-SDF APR 0.4>1.0[1.0] JUN 0>0.2[1.1]
WN PHX-SEA APR 1.7>4[4] JUN 0>0.8[4]
WN PHX-SFO APR 2>5[5] JUN 0>0.9[5]
WN PHX-SJC APR 3>7[6] MAY 0>6[7] JUN 0>1.3[6]
WN PHX-SLC APR 3>6[6] MAY 0>6[5] JUN 0>1.3[5]
WN PHX-SMF APR 3>6[6] MAY 0>6[5] JUN 0>1.3[5]
WN PHX-SNA APR 3>6[6] JUN 0>1.1[6]
WN PHX-STL APR 1.8>4[4] MAY 0>4[3] JUN 0>0.8[3]
WN PHX-TPA APR 0.6>1.1[1.0] JUN 0>0.2[1.0]
WN PHX-TUL APR 0.6>1.3[1.3] MAY 0>1.3[1.1] JUN 0>0.2[1.4]
WN PIT-RSW APR 0.9>1.6[1.3] MAY 0>1.5[1.1] JUN 0>0.3[1.2]
WN PIT-STL APR 0.4>1.5[1.1] MAY 0>1.8[1.1] JUN 0>0.4[1.2]
WN PIT-TPA APR 1.4>3[2] MAY 0>3[2] JUN 0>0.5[2]
WN PVD-TPA APR 0.8>1.4[1.9] MAY 0>1.2[1.5] JUN 0>0.2[1.7]
WN RDU-STL APR 0.8>2[1.9] JUN 0>0.4[2]
WN RDU-TPA APR 0.9>2[2] MAY 0>2[3] JUN 0>0.4[2]
WN RIC-TPA MAY 0>0.3[0]
WN RNO-SAN APR 1.2>3[3] MAY 0>3[2.0] JUN 0>0.6[3]
WN RNO-SJC APR 1.0>2[2] JUN 0>0.5[2]
WN ROC-TPA APR 0.4>1.0[1.2] JUN 0>0.2[0.4]
WN RSW-STL APR 1.2>2[2] MAY 0>1.6[1.9] JUN 0>0.3[1.6]
WN SAN-SAT APR 0.7>1.8[1.9] JUN 0>0.4[1.7]
WN SAN-SEA APR 0.4>1.0[2] MAY 0>1.0[2.0] JUN 0>0.2[2]
WN SAN-SFO APR 3>8[8] JUN 0>1.5[7]
WN SAN-SJC APR 6>15[14] MAY 0>14[13] JUN 0>3[14]
WN SAN-SJD APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN SAN-SLC APR 0.8>1.8[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.8]
WN SAN-SMF APR 6>14[13] JUN 0>3[13]
WN SAN-STL APR 0.8>1.9[2] MAY 0>1.9[2] JUN 0>0.4[2]
WN SAN-TUS APR 0.9>2[1.9] MAY 0>2[1.9] JUN 0>0.4[2.0]
WN SAT-STL APR 0.9>2[2] JUN 0>0.4[2]
WN SAT-TPA APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN SDF-TPA APR 0.6>1.3[1.1] MAY 0>1.1[1.0] JUN 0>0.2[1.2]
WN SEA-SJC APR 1.8>4[4] JUN 0>0.9[4]
WN SEA-SMF APR 1.8>4[4] JUN 0>0.9[5]
WN SEA-STL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN SFO-STL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN SJC-SLC APR 0.8>1.8[1.8] JUN 0>0.4[1.8]
WN SJC-SNA APR 4>10[11] MAY 0>10[11] JUN 0>2[10]
WN SJC-STL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN SJC-TUS APR 0.4>0.9[0.9] MAY 0>0.8[0.9]
WN SJD-SMF MAY 0>0.3[0.1]
WN SJU-TPA APR 0.3>0.6[0.5] MAY 0>0.6[0.5]
WN SLC-SMF APR 0.4>1.0[1.0] JUN 0>0.2[1.1]
WN SLC-STL APR 0.4>0.9[0] MAY 0>0.8[0]
WN SMF-SNA APR 2>6[6] JUN 0>1.1[6]
WN SMF-STL APR 0.4>1.0[1.0] JUN 0>0.2[1.0]
WN STL-TPA APR 1.5>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN STL-TUL APR 0.8>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.4[1.8]
Y4 DEN-GDL FEB 0.4>0.7[0.4] MAR 0.4>0.7[0.4]
Y4 DEN-MEX FEB 0.4>0.9[0.4] MAR 0.5>0.9[0.5]
enilria
Re: OAG Changes 11/3/2019:AA Exits MIA-CMW/HOG/SCU/SNU/VRA,JFK-SEA;B6 Exits FLL-CMW/HOG/SNU;NK and WN Extension
Sun Nov 03, 2019 3:29 pm
I thought it had posted 2 hours ago, but it was sitting on the CAPTCHA check. :mad: :hot:
Dominion301
Sun Nov 03, 2019 3:33 pm
I wonder who won the RUT EAS contract? 9K have had that for what 15 years?
RJNUT
Sun Nov 03, 2019 3:38 pm
that's the market the are going to introduce the Tecnam Traveler on. Must be a mis-file. Maybe don't have proper coding yet for that A/C type?
AVLAirlineFreq
Sun Nov 03, 2019 3:50 pm
Had this been previously announced? MAX related?
enilria
Sun Nov 03, 2019 3:51 pm
I bet that is it. That type probably doesn't have a valid code yet.
enilria
Sun Nov 03, 2019 3:52 pm
Appears to only by MAR/APR.
Chuska
Sun Nov 03, 2019 3:57 pm
UA DEN-SAF APR 3>4[3]...indef
SAF keeps on growing!
jetbluefan1
Sun Nov 03, 2019 4:49 pm
Thanks enilria!
Looks like B6 is redeploying the FLL-Cuba planes to ATL/KIN/MBJ during the holiday season. I wonder if that will stick around more permanently. Interesting to see FLL-LAS go up to 2x, and all that additional EWR and BDL capacity. FLL transcon and Northeast-Florida trunk routes seem to be particular areas of strength.
Any thoughts on whether AA’s reduction on MIA-PLS/POS are MAX-related? B6 mgmt cited soft LatAm demand (RASM was down high single digits in this reason over Q3), so If not, I wonder if this is just AA reflecting some of those same observations.
Cointrin330
Sun Nov 03, 2019 5:21 pm
Sad to see AA drop JFK-SEA (the cut is now permanent).
MIflyer12
Sun Nov 03, 2019 5:25 pm
No boost to MIA-HAV by AA, in frequency or gauge, to offset the other MIA-Cuba cuts?
MAH4546
Re: OAG Changes 11/3/2019:AA Exits MIA-C MW/HOG/SCU/SNU/VRA,JFK-SEA;B6 Exits FLL-CMW/HOG/SNU;NK and WN Extension
Sun Nov 03, 2019 5:40 pm
With what slots? US carriers are no longer allows
to fly outside of Havana, but still only allowed a combined 20 daily Havana flights, and they are all used up.
a.
Aliqiout
Sun Nov 03, 2019 5:45 pm
Four daily is pretty impressive. If there is much more growth the size of the terminal will become an issue. I wonder how long before DL or AS start service.
avi8
Sun Nov 03, 2019 5:54 pm
Nice growth at IAD by UA. It’s nice to see that long forgotten hub slowly gain more flights. At one point it was the equivalent of AA’s JFK hub nowadays (big difference between both of them obviously).
avi8
Brickell305
Sun Nov 03, 2019 6:01 pm
jetbluefan1 wrote:
Thanks enilria!
AA flies three daily to POS in heavy season. Carnival season ended in March last year so they flew three daily thru March. It ends in February this year so they run three daily thru Feb. AA only loaded Max cuts thru January IIRC so it’s not that. Dunno what’s up with PLS.
Ionosphere
Sun Nov 03, 2019 6:08 pm
I'm surprised UIN decided to drop UAX/OO in favor of 9K.
ckfred
Sun Nov 03, 2019 6:20 pm
I could see AA dropping ORD-COS in the summer, but you would think that in the winter, AA would want a round trip from ORD to every Colorado airport near a ski resort.
MIflyer12
Sun Nov 03, 2019 6:22 pm
Upgauging, then? The 6x 738 in the schedule for Monday, 1/13/20, hardly represents AA heaviest metal.
Ishrion
Sun Nov 03, 2019 6:25 pm
Don’t they have to reapply to switch aircraft?
atrude777
Sun Nov 03, 2019 8:23 pm
Quincy posted an article earlier about how the city was very unhappy with the on time factor with United/SkyWest to ORD.
Quincy saw on average a 40% on time rate for UIN-ORD and considered it to be abysmal and they never saw this with Cape Air.
Now with 9K returning to UIN, UIN gets two destinations, STL and ORD, and they still get an interline connection with AS/UA/DL/AA at STL and ORD, and American will put their code share flight UIN-STL/ORD with Cape Air.
That's why UIN voted for Cape Air over SkyWest.
Alex
DeltaRules
Sun Nov 03, 2019 8:27 pm
Does NK have partial month reporting which leads to incomplete months like WN or has NK made its three year-round CMH flights less-than-daily?
A310/319/320/321/333, ARJ, BN2, B717/722/73S/733/734/735/73G/738/739/744/757/753/767/763/764/777, CR1/2/7/9, DH6, 328, EM2/ERJ/E70/E75/E90, F28/100, J31, L10/12/15, DC9/D93/D94/D95/M80/M88/M90/D10, SF3, SST
Rdh3e
Sun Nov 03, 2019 8:28 pm
Pray tell, what resort is COS close to? (Worth flying to)
Rdh3e
Sun Nov 03, 2019 8:31 pm
Alex
Despite all that, OO still carried 60% more passengers than 9K for the last 12 months of data vs the last 12 months of 9K.
Rememberthe80
Sun Nov 03, 2019 9:53 pm
UA back to 4 daily's on the GPT run! All E145, however on the UA website it shows a 90 minute turn between the 3rd arrival into GPT that turns back out as the last flight, that stands out as very long out station sit for a non RON plane.
CMHtraveler
Mon Nov 04, 2019 12:02 am
Per Enilria’s header above the NK flights:
“JUN is a partial month, and APR was previously partial month. Look at May.”
Looks like other than a very slight uptick in the frequency of MSY flights, the CMH NK schedule is unchanged.
cs03
Mon Nov 04, 2019 12:18 am
Tecnam P2012 ICAO code is P212.
FlyingElvii
Mon Nov 04, 2019 1:29 am
I think this likely tells the tale. They may have been in danger of losing service completely by busting the subsidy cap.
“For the week of Thanksgiving, SkyWest's website Thursday night, indicated around 181 passengers have booked a seat over the course of 24 flights for the week.”
https://khqa.com/news/local/quincy-flig ... in-the-air
FlyingElvii
Mon Nov 04, 2019 1:33 am
Alex
Wow... But I do understand it. Close-in flights from the small cities are the first ones screwed when ORD goes into a program. Cape can use the low altitude escape routes in and out, while a CRJ likely cannot.
FlyingElvii
Mon Nov 04, 2019 1:35 am
That third outbound can very likely turn into the 4th outbound to ORD in the spring/summer.
SANFan
Mon Nov 04, 2019 1:45 am
Thank you for all your efforts, Enilria.
Can anyone update me on the status or existence of AA's SAN-JFK? I see SEA-JFK this week appears to be (permanently?) disappearing but I've lost track of the latest on SAN-JFK. (Seems to that about every other week one or the other of the routes is on here, usually with an extension of "0" flights.)
Of course SEA also has AS flying to JFK, in addition to DL and B6, while SAN only has the latter 2 so maybe AA is dropping SEA before SAN?
bb
kavok
Mon Nov 04, 2019 2:23 am
Thanks for the update. I see HA HND-HNL is going to 3x daily? Does that mean HND-KOA is going away? I thought, with the new HND slot, that HA was operating HNL 2.5x daily, and KOA 0.5x daily. Boosting HNL to 3.0x implies no more HND-KOA.
tphuang
Mon Nov 04, 2019 3:51 am
I'm thinking they will either be more aggressive at getting A320 reconfigs done. Or more likely, I think some additions from late April will be announced soon. And given that nothing has been updated so far for May, I'm hoping that means new routes. It's almost like the B6 management is afraid of making a mistake so trying these short term adds to the schedule. Really strange to me.
Rdh3e
Mon Nov 04, 2019 4:47 am
What ORD service are you referencing?
Ishrion
Mon Nov 04, 2019 5:52 am
KOA-HND is still available for booking. Would U.S. carriers have to apply to transfer a HND frequency (pre-existing) to another city?
enilria
Mon Nov 04, 2019 2:11 pm
jetbluefan1 wrote:
Thanks enilria!
Brickell305 wrote:
jetbluefan1 wrote:
Thanks enilria!
I thought PLS had seen a lot of lost service since the hurricane.
The way the report works is it divides the ops for the month by the number of days to get average daily flights. Because some carriers don't file a normal 330 day advance schedule you get this situation when they file a partial month. So they were probably filed through April 20th or so which made 1 RT into .7 RT and then filed through around June 10th which gave June .3 trips. MAY shows no change which means that they loaded 1 roundtrip which was flat from last year and thus not shown. It's messy, but there is no good way to do it without a lot of custom work by me. The way to fix it would be to choose a week in each month to use and move that week based upon how far they filed their schedule, but retrieving data like that from the source is almost impossible or at least a massive amount of work. So, it is what it is. The other problem with using a single week is that sometimes there is a holiday in that week which creates even bigger problems.
bb
I believe what is happening is that they have basically not flown it for months and seem to be taking bookings as of now for FEB or MAR and beyond, however, what has been happening is that they have been doing a rolling bait and switch where they drop it when it gets within maybe 120 days and then push the return of the nonstop further out. They are doing this with a large number of JFK flights and blaming it on the MAX when they could just spread the MAX cuts out around their massive network and it would be nearly invisible.
But what is the 3 letter IATA code? Perhaps one is not approved yet, or Cape Air doesn't know what the correct code is?
My understanding based upon the Delta HND slots in past instances is that they have to be reapproved and could be lost to another carrier.
cs03
Mon Nov 04, 2019 2:33 pm
The IATA code is T12 (from Expert Flyer)
enilria
Mon Nov 04, 2019 2:48 pm
They will probably fix it next week I'd think
Rememberthe80
Mon Nov 04, 2019 2:53 pm
It could be service that has not been announced yet.
Rdh3e
Mon Nov 04, 2019 2:59 pm
That's silly. Inferring a new route because there is a 90 minute sit in the IAH schedule? C'mon now.
Rememberthe80
Mon Nov 04, 2019 7:22 pm
90 mins in an outstation is a long time for a 50 seater not RON.
RyanairGuru
Mon Nov 04, 2019 7:45 pm
It's not particularly unusual at an outstation that's only an hour flying time from a banked hub. AA do it a lot. Despite their operation at DFW being a disaster they seem to prefer keeping the flights from the close-in stations on the ground rather than spread out the in-bound arrivals. It's crazy IMHO.
Worked Hard, Flew Right
Brickell305
Tue Nov 05, 2019 8:39 am
enilria wrote:
jetbluefan1 wrote:
Thanks enilria!
Brickell305 wrote:
jetbluefan1 wrote:
Thanks enilria!
bb
As far as I’m aware, PLS hasn’t received any major damage from any recent hurricane. In fact, AA announced plans to increase service from its other hubs.
enilria
Tue Nov 05, 2019 3:17 pm
Brickell305 wrote:
enilria wrote:
jetbluefan1 wrote:
Thanks enilria!
bb
PLS lost a lot of service right after the hurricane. If you google Dorian Turks Caicos you will see there were warnings and such. I don't know if any damage was done. Perhaps a big resort was hit? Seems like too much of a coincidence.
ordbosewr
Tue Nov 05, 2019 5:15 pm
PLS had a huge downturn after Dorian. It is slowly getting back to pre-dorian levels.
All of the big resorts in Provo got hit a little bit and got closed for some time. We have been to Provo a few times and it is a great place, but was expensive before....
FSDan
Tue Nov 05, 2019 5:20 pm
I was wondering about that too...
This is my signature until I think of a better one.
FSDan
Tue Nov 05, 2019 5:24 pm
bb
AA's also generally stronger in SAN than they are in SEA. SEA's one of the weakest major markets for AA, which isn't surprising given where their hubs are located. So, given the competition and their overall market position, I'm not surprised JFK-SEA would go away before JFK-SAN would.
tphuang
Tue Nov 05, 2019 5:35 pm
FSDan wrote:
bb
both SAN/SEA are marginal market now. SEA was doing worse though. I don't see how not flying SAN for almost a year is going to work out for AA.
