Belperflyer
Heathrow runway resurfacing
Sun Nov 03, 2019 9:43 pm
How will Heathrow maintain operations when the runway needs to be resurfaced ?Just wondering after reading about Milan and Dubai
TUGMASTER
Re: Heathrow runway resurfacing
Sun Nov 03, 2019 9:57 pm
It’s done one at at time between the hours of 0000-0500... effectively reducing the airport to single runway ops between these times.
doylebob
Sun Nov 03, 2019 11:01 pm
LHR has a nightly curfew. Runway resurfacing will typically be done (in segments) during these off-hours
Nicoeddf
Mon Nov 04, 2019 1:30 pm
As was done in FRA recently. No big deal.
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
mwhcvt
Mon Nov 04, 2019 1:41 pm
As has been said above thanks to the nightly curfew they as a rule will do it in sections of X metres per night, it’s a very effective ballet of machines, manpower and time
This is a time lapse from a few years ago but worth seeing
https://youtu.be/MsSKsFOAScY
From time to time serious defects will need attention right away, then operations will be suspended there briefly for a temporary patch using a rapid set material that allow rapid return to ops and then come the night time a crew will come in for a permanent fix
Must think up a new one soon, slow moving brain trying to get into gear ;)
CarbonFibre
Mon Nov 04, 2019 2:35 pm
Heathrow does not have a night curfew.
airbazar
Mon Nov 04, 2019 2:50 pm
I wouldn't say it's not a big deal. It's a much bigger deal than at airports that can just close the runway for a month.
Doing the work at night costs more money, lasts longer, and it puts tremendous pressure on everything to be done and out by 5am.
JetBuddy
Mon Nov 04, 2019 2:55 pm
In some places they close down half the runway length. Then operate on the other half which is still long enough for most narrowbody flights. And then switch.
Nicoeddf
Mon Nov 04, 2019 3:21 pm
Yes, some serious planning involved as well as good logistics.
But hardly anything that would bring modern construction to anything like the edge of capability.
SEU
Mon Nov 04, 2019 3:24 pm
Yes, it does.
Cunard
Mon Nov 04, 2019 3:28 pm
I'm sure that your familiar with the night time curfews at LHR but I'll leave it to someone else more informed on the subject who can explain it better than myself!
94 Countries, 327 Destinations Worldwide, 32 Airlines, 29 Aircraft Types, 182 Airports, 335 Flights.
LOT767301ER
Mon Nov 04, 2019 3:35 pm
Yes, it does.
No it doesnt. What are you blabbering about? It only has a quota/noise limit.
JibberJim
Mon Nov 04, 2019 4:11 pm
LOT767301ER wrote:
Yes, it does.
Which is commonly known as a curfew, this is purely a difference of word definition, in English-GB usage there's plenty of use of the word curfew where it's not an absolute ban on something, but simply different regulations, including describing LHR's noise regulations as a curfew. Please don't police language, everyone knew what was being discussed.
peterinlisbon
Mon Nov 04, 2019 5:46 pm
When I worked at LHR, we had a flight leaving at 10pm every night. If there was a delay for whatever reason (late passengers, mechanical problem, etc) the airline had to get special permission to take off after 11pm. I think getting that permission depends on the aircraft type, weight etc. Anyway, let's just say that having 1 runway open is more than enough for LHR during the night and so they can work on it during those times.
