CO764 wrote:This seems quite serious. The pilots were apparently in a "stalling situation" with a runaway trim and unable to descend. Their Flightaware log shows them climbing through 7000 feet at ~4500fpm with a ground speed of only 160 knots. This brings back chilling memories of last year's Air Astana incident, although thankfully the control problems don't seem anywhere near as drastic. Let's hope the cause of this scary incident is quickly determined.
Cubsrule wrote:My memory is fuzzy, but hadn't the Air Astana airplane just come out of maintenance (sort of like the ZV accident at CLT in 2003)?
LoganTheBogan wrote:Sam Chui reporting on it now.
asuflyer05 wrote:LoganTheBogan wrote:Sam Chui reporting on it now.
Thank God Sam Chui is reporting on it.
KFTG wrote:asuflyer05 wrote:LoganTheBogan wrote:Sam Chui reporting on it now.
Yes thankfully we have a professional spotter on the case, with precisely zero aviation maintenance or operational credentials.
SierraPacific wrote:Major props to the crew for saving the day. This is when countless of hours of sims and studying pays off big time.
I wonder if this was caused by maintenance like the Air Astana or some other issue in the aircraft.
NYPECO wrote:They only had two passengers? Does that happen a lot? I thought the chances of that would be zero at such a large city.
maint123 wrote:Do the air traffic controllers always speak so fast?
Doesn't it create a issue with international pilots, the accent and the fast talking?
alasizon wrote:NYPECO wrote:They only had two passengers? Does that happen a lot? I thought the chances of that would be zero at such a large city.
It is a 22:00 departure from ATL, getting into LGA just after 11PM so not odd to think it might be lightly traveled on certain days.
Miamiairport wrote:At one point one of the pilots seemed a little sacred when the a/c wouldn't descend. The Controller was really nasty the Fire Chief that called for information on the flight.
Karlsands wrote:Miamiairport wrote:At one point one of the pilots seemed a little sacred when the a/c wouldn't descend. The Controller was really nasty the Fire Chief that called for information on the flight.
He wasn’t nasty, he needed to have the frequency cleared for the issue at hand.
DeltaConnection wrote:[photoid][/photoid]Karlsands wrote:Miamiairport wrote:At one point one of the pilots seemed a little sacred when the a/c wouldn't descend. The Controller was really nasty the Fire Chief that called for information on the flight.
He was nasty, as is the case with most ATC in the US in/around major airports. They are generally rude, unhelpful, hysterical, and cause crashes to happen. The only good controller I’ve seen/heard so far was Patrick Harten who helped US Airways 1549.
AABusDrvr wrote:DeltaConnection wrote:[photoid][/photoid]Karlsands wrote:He wasn’t nasty, he needed to have the frequency cleared for the issue at hand.
As an airline pilot that's flown into every major airport in the United States, I disagree with your opinion. The controllers generally do a very good job, every facility has a few that come off as having an attitude, but the majority are great people, and do an amazing job of moving metal around. Your "cause crashes to happen" statement is just silly, and flat out wrong.
wjcandee wrote:Sam Chui didn't add a thing. Discussion on a couple of pilot boards has more details and is interesting.
And from the crew's own description, they had to cut out trim 1/2, switch into direct law and fly it from the FO side, and that put them back in control. They said they were fighting with the plane until they made those changes.
DeltaConnection wrote:AABusDrvr wrote:DeltaConnection wrote:[photoid][/photoid]
Tell that to the victims of Avianca 52, USAir 1493/SkyWest 5569, Aeromexico 498, and PSA 182.
Why don't you give us a list of incidents in the last ten years and get back to us? You also a big user of pay phones? It's almost 2020. Do you gripe about auto manufacturers today as crap and talk about their reliability in 1985?
Go slither back under whatever rock you've been living under since the FAA didn't hire you.
DeltaConnection wrote:Trust me, no one wants to work with the FAA willingly. NTSB, DOT, yes, FAA, no.
This troll can't cite anything more recent than 28 years ago. Everyone involved here seems to have done a tremendous job, flight crew and ATC alike.DeltaConnection wrote:Trust me, no one wants to work with the FAA willingly. NTSB, DOT, yes, FAA, no.
You do know the FAA is an agency of the DOT right?
Poorpilot wrote:wjcandee wrote:Sam Chui didn't add a thing. Discussion on a couple of pilot boards has more details and is interesting.
Embraer’s don’t have direct law, Airbus does.
MachTen wrote:Anyone else noticed that tool who came on the frequency and asked whether they did the QRH and that he had E175 experience? Maybe he was trying to help, but, those guys were fighting for their lives and the last thing they want to hear is someone asking whether they did the QRH. What a tool!
SuseJ772 wrote:Poorpilot wrote:wjcandee wrote:Sam Chui didn't add a thing. Discussion on a couple of pilot boards has more details and is interesting.
I thought the same thing. But if you listen to the ATC the pilot says they are in Direct Law.
http://www.smartcockpit.com/docs/Embrae ... ntrols.pdf Page 19 talks about direct mode.
