rikkus67
This just in: First AC A220 out of paint
Fri Nov 08, 2019 3:11 pm
What a beauty! Canadian proud! Just one "small" error for the eagle-eyed. I give it 5 seconds for someone to point it out. (You had ONE JOB, paint shop....)
https://fly.airbus.com/2qCw7wU
A slight refresh will be in store, I am sure!
AC.WA.CP.DL.RW.CO.WG.WJ.WN.KI.FL.SK.ACL.UA.US.F9
JannEejit
Re: This just in: First AC A220 out of paint
Fri Nov 08, 2019 3:18 pm
Well the Airbus page says it 'rolled out of paint hangar' when in fact it appears to still be in the hangar... :lol:
Whiteguy
Fri Nov 08, 2019 3:19 pm
Looks fine, what’s the issue?
FluidFlow
Fri Nov 08, 2019 3:20 pm
Check the logo
VSMUT
Fri Nov 08, 2019 3:24 pm
Check the logo
What's with the logo?
Whiteguy
Fri Nov 08, 2019 3:26 pm
Check the logo
On the tail? What about it?
Ishrion
00:21 there’s a hole in the logo?
Polot
Fri Nov 08, 2019 3:27 pm
VSMUT wrote:
FluidFlow wrote:
Check the logo
The logo is mirrored versus how it should be. The stem should be to the left and the opening on the circle to the right.
L and R templates must have accidentally been switched.
Karlsands
Fri Nov 08, 2019 3:29 pm
They all have that gap in the circle
T4thH
Fri Nov 08, 2019 3:31 pm
It is mirror-inverted.
And back to the paint shop.... :rotfl:
FluidFlow
Polot wrote:
VSMUT wrote:
FluidFlow wrote:
Check the logo
Interestingly the logo next to the right front door is correct. So yeah they must have switched the templates.
TWA302
Fri Nov 08, 2019 3:32 pm
It isn't a "hole" it is one of the runway turn off lights.
qqflyboy
It appears the maple leaf logo is backward on the tail. The opening at the bottom of the stem should be on the right, not the left. If you look more closely, the maple leaf at the forward part of the fuselage was applied correctly.
The views expressed are mine alone and do not necessarily reflect my employer’s views.
OccupiedLav
Fri Nov 08, 2019 3:44 pm
Is the logo being backwards really worth the cost to have it corrected? It's not even noticeable unless you know the livery like the back of your hand, and it doesn't look bad. I guess if you're Air Canada, you might as well get it corrected since you paid for it. Virgin Atlantic has their planes painted in the wrong non-metallic red occasionally, and they don't do anything about it.
Polot
Fri Nov 08, 2019 3:48 pm
It will probably be corrected before delivery.
For a while after VS first introduced their current livery they had to switch to a non-metallic red because the metallic paint they originally chose was prematurely delaminating. Many of the A330s were delivered in the non metallic paint. VS eventually found a more robust metallic red and switched to that.
adamh8297
Fri Nov 08, 2019 3:55 pm
Hope to see it on BOS-YYC someday!
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CA, CO, CX, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WE, WN
2019: CX BOS-HKG, WE HKG-HKT, CA HKT-PEK-EWR, B6 EWR-BOS
godsbeloved
Fri Nov 08, 2019 4:09 pm
It seems to be ok on the portside
Verstuurd vanaf mijn SM-A920F met Tapatalk
ACCS300
Fri Nov 08, 2019 4:36 pm
Bet AC is anxious to get these delivered and deployed ASAP in light to their MAX nightmare. While the MAX is grounded these will be the only AC narrow-bodies to carry the current hard product, seats, current PTVs etc..
ACCS300
Fri Nov 08, 2019 4:39 pm
Yes worth the cost, it looks terrible and it's noticeable, I doubt AC will want this obvious error on their launch A220.
wrongwayup
Fri Nov 08, 2019 5:14 pm
Ok I'm as much of a 220 fanboy as any, and ex-AC multi-year "Elite" frequent flier, but "terrible" and "noticeable" as adjectives are a little over the top. Airbus will probably fix it FOC, but it's also entirely possible that the paint spec from Air Canada had this error in it and Airbus painted per the drawing.
rikkus67
Fri Nov 08, 2019 6:46 pm
Agreed. This was a minor painting accident, and will likely be corrected VERY quickly. It's just too bad someone didn't catch it before it was posted! Although to some this may not be a big deal, when it is your inaugural aircraft, all those small aesthetics have to be correct. For that matter, it won't be the first painting error on an aircraft...and it certainly won't be the last!
Skywatcher
Fri Nov 08, 2019 6:54 pm
Nobody except Airliners.net members would notice.
Aeronews
Fri Nov 08, 2019 6:55 pm
Airbus has removed the painting video from their FB and Twitter, for sure because of this painting mishap.
ODwyerPW
Fri Nov 08, 2019 7:08 pm
it's all white with black engines a black tail and a basic nearly symmetrical red maple leaf. not much to look at.
learning never stops.
ODwyerPW
Fri Nov 08, 2019 7:09 pm
A320FlyGuy
Fri Nov 08, 2019 7:17 pm
The tail isn’t even visible in that picture.....
My other car is an A320-200
runway23
Fri Nov 08, 2019 7:39 pm
Airbus took the original picture down. It was the following:
Polot
Fri Nov 08, 2019 7:40 pm
LOL someone at Airbus noticed.
The picture use to be of the tail looking forward and they had a link to a video. They changed the PR.
Edit: here is the original pic: https://www.airbus.com/search.image.htm ... mage-all-3
spinotter
Fri Nov 08, 2019 7:51 pm
Well, thank heavens that some of us are clever enough to spot the stupidities that arise in the world.
Dominion301
Fri Nov 08, 2019 8:01 pm
LOL someone at Airbus must have read this a.net thread!
I was scratching my head at the top of this thread wondering what's the matter, as I only saw the modified Airbus PR.
lightsaber
Fri Nov 08, 2019 8:22 pm
I was so excited it was close to delivery...
LoL on a flipped maple leaf...
Lightsaber
Flu+Covid19 is bad. Consider a flu vaccine, if not for yourself, to protect someone you care about.
rikkus67
Fri Nov 08, 2019 8:48 pm
Actually, It is highly noticeable, especially when it is on an approximately 6 metre/20 foot tall tail. The original 1965 Rondelle, and the update from the early 90's (which is what is used today) ALWAYS has that small opening on the right.
For a refresher, here is the original 1965 version: https://preview.tinyurl.com/y2n9rzw6
Vasu
Sat Nov 09, 2019 2:00 am
I still maintain, Most people (and I’m on A.net) wouldn’t notice the paint issue. But it’s a lovely aircraft in a lovely paint scheme.
And it will be fixed... so, happy days!
dampfnudel
Sat Nov 09, 2019 8:09 am
The A220 looks good in the AC livery.
A313 332 343 B703 712 722 732 73G 738 739 741 742 744 752 762 76E 764 772 AT5 CR9 D10 DHH DHT F27 GRM L10 M83 TU5
speedbird52
Sat Nov 09, 2019 8:14 am
Drop dead gorgeous. I feel like Air Canada is one of those airlines who have never had a bad livery.
scbriml
Sat Nov 09, 2019 8:43 am
What even that ghastly toothpaste effort?
winstonlegthigh
Sat Nov 09, 2019 9:01 am
I really miss the previous livery.
Never has gravity been so uplifting.
Reddevil556
Sat Nov 09, 2019 11:13 am
I agree, AC is the Delta of Canada. Very boring, dull livery. At least at MSP I get to see Sun Country and Southwest with some colorful liveries. Heck even Spirit is refreshing to see.
I think the A220 would look slick in the old AC livery.
Jumped out of: C130H, C130J, C17A, C212, CH47, and UH60. Bucket list: C160, A400, C2
golfradio
Sat Nov 09, 2019 3:44 pm
Can't be just a simple re-paint. It's the tail, won't the rudder have to rebalanced?
CSeries forever. Bring back the old site.
WN732
Sat Nov 09, 2019 5:23 pm
I actually enjoyed the Crest Pro Health livery. It looked great especially on the widebodies.
AWNP
Sat Nov 09, 2019 5:33 pm
Agree, the AC livery is one of the most boring out there. The A220 is a beautiful plane though.
trees
Sat Nov 09, 2019 5:56 pm
I’m still waiting for AC to tell us the cockpit paint was just a cheeky gag and remove it.
aerolimani
Sat Nov 09, 2019 6:28 pm
:mrgreen:
Fixed:
AvroLanc
Sat Nov 09, 2019 6:37 pm
It was for selfies......
707, 717, 727, 732, 734, 737 ,738, 7M8, 742, 744, 767, 773, 789.
DC8, 9,10, MD80 ,L1011 ,HSTrident, BAC111, DHComet.
DH8-100, 400, CRJ100,200,700, EM75,90, A310,319,320,321,333
longhauler
Sat Nov 09, 2019 6:46 pm
One thing not really apparent in pictures, is how incredibly shiny this new paint is. Honestly, they must have put a dozen layers of clear coat gloss on it, as years later it is still shiny and clean. You can still adjust your tie and comb your hair in your reflection on the engine nacelle a couple years in.
At the official “unveiling”, it was indicated that the cockpit window effect was to emulate the B.C. totem pole thunder bird. They had an easel with an A321 nose with a thunderbird totem pole shadowed behind it.
It’s not going anywhere anytime soon.
speedbird52
Mon Nov 11, 2019 8:52 am
Yeah. To me it was quite pretty
Motorhussy
Mon Nov 11, 2019 10:15 am
I love the thunderbird motif imbuing the cockpit in deep thought. I also love the simple elegance of the new AC livery.
I detested the previous Crest glacial melt.
The A220 looks smashing in the home team colours.
come visit the south pacific
yyztpa2
Mon Nov 11, 2019 12:54 pm
aerolimani wrote:
:mrgreen:
Fixed:
It wasn't done incorrectly on this side. Only on the other side. This video shows.
https://m.youtube.com/watch?v=q4FvgELfolc
AirnerdTX
Mon Nov 11, 2019 1:03 pm
Give me a red and a black sharpie...
steeler83
Mon Nov 11, 2019 1:52 pm
Austin Powers comes to mind when watching that video - approaching the 26-28 second mark:
"Yes, alright, looking good, yes, yes... NO!! NO!!"
Glad they rectified the error When do you guys think they'll hit 1,000 orders for the A220? They seem to be selling like hotcakes!
Do not bring stranger girt into your room. The stranger girt is dangerous, it will hurt your life.
