T4thH
Asiana Airlines Airbus A350 Engine Issues Prompts Diversion
Mon Nov 11, 2019 4:03 pm
https://simpleflying.com/asiana-airlines-a350-issue/
This is now the third in-flight engine shut down.
First was regarding a broken fuel pipe, to stop the leaking and to shut down the fuel pump, the jet engine fueled by the tank has had to be shut down.
Second was an engine failure (minor)
Third (this one) seems to be again an issue with the engine fuel system (and not with the jet engine itself).
LY777
Re: Asiana Airlines Airbus A350 Engine Issues Prompts Diversion
Mon Nov 11, 2019 4:06 pm
Another new generation jet with issues...
Flown:717,727,732,733,734,735,738,73H,742/744/748,752,753,762/2ER/763/3ER,772/77E/773/77W, 788, 789, DC8,DC10,E190,E195,MD83,MD88, L1011, A3B2,A319,A320-100/200,A321,A332/A333,A343,A388
T4thH
Mon Nov 11, 2019 5:22 pm
A350 is still doing far better than expected. The Trent XWB engine is just the wet dream (and unbelievable how bad in comparison the Trent 1000 is). The number of issues e.g. is in the normal range, comparable to many other jet families, since prolonged time on duty. So your statement is just wrong.
LY777
Mon Nov 11, 2019 5:35 pm
3 IFSD in a rather short period of time is not negligible.
ITSTours
Mon Nov 11, 2019 5:57 pm
HL7579 has already returned to ICN. A replacement was available at MNL, I guess?
T4thH
Mon Nov 11, 2019 5:58 pm
No, it is around 3 failures in one year timeline., the first was around one year ago. It is still fulfilling all ETOPS criteria. Around every day there is an in flight shut down somewhere in the world. This is part of the job, jet engines will always fail and systems connected to the engines will fail, so engines have to be shut down. Of course, they could always do better.
Uncontained failures and high amount failures in short time as seen for the PW1000G family on the A320 in areas with high air pollution (so as example India) or as seen for the PW1524G of the A220-300 of Swiss in last few month, the RR Trent 1000 issues for the B787; these are critical.
rbavfan
Mon Nov 11, 2019 6:07 pm
Over nearly a year it's not unusual.
RB211trent
Mon Nov 11, 2019 6:22 pm
Just a quick look on the Aviation Herald website shows a list of Inflight shutdowns and various other aircraft and engine issues. What makes this one different to start a discussion?
lightsaber
Mon Nov 11, 2019 6:34 pm
Interesting. Fuel systems seem to be the common thread. Not a big deal, but the major subsystem needs some attention.
Nothing dramatic. The LEAP, PW1xxx , and T1000 were all worse.
Lightsaber
Winter is coming.
Mon Nov 11, 2019 6:45 pm
The article doesn’t actually say there was an issue with the engine, just that they shut an engine down. Considering another poster has suggested the aircraft is already back in ICN makes me think it wasn’t an engine issue.
T4thH
Mon Nov 11, 2019 7:27 pm
An in flight shutdown of an engine is an in flight shutdown. ETOPS certification does not care, why it has been shut down. The difference is of course, a broken engine is regular highly expensive, a million of $ is nothing...
And yes, "fuel systems" sounds like some external issue, independent of the jet engine itself, so something with leaking pipes or fuel tanks, broken down fuel pump e.g.
rbavfan
Mon Nov 11, 2019 8:34 pm
That it's Ariliners.net, not Aviation harold.
Tue Nov 12, 2019 4:15 am
I am well aware of how EDTO works, and it is not as cut and dry as you think. Besides you claim in your thread title “Asiana Airlines Airbus A350 Engine Issues Prompts Diversion”, no evidence has been presented to suggest there was an engine issue.
You also have not provided any evidence of the other engine problems you claim that have occurred.
The Trent XWB has had the best EIS of any large engine in the past two decades.
mjoelnir
Tue Nov 12, 2019 4:29 am
http://avherald.com/h?article=4cf14f72&opt=0
that is the story in the avherald: failure in the engine fuel system
T4thH
Tue Nov 12, 2019 7:14 am
To avoid a misunderstanding. This is the title of the link, I have not modified it. And yes, you are right, I shall have better modified the title in this single case, as it is misleading, I prefer not to do this. Regarding the other cases, sorry, I have perhaps expected too much, that it is regular knowledge. I can search for them, but only after work, so in several hours.
ITSTours
Tue Nov 12, 2019 7:50 am
HL7579 has by the way been flying without a delay. https://www.flightradar24.com/data/aircraft/hl7579
So what was the problem? Let's wait for the report, I guess?
Tue Nov 12, 2019 2:49 pm
I follow A350 events closely, I am not aware of these events.
There is published TAB (Temporary Abnormal Behavior) on the newer A350s in the fuel quantity indication and onboard fuel sensing which requires the crew to reset both the fuel quality monitoring systems before start. If the crew failed to perform this action before start it can result in a false fuel leak suspected ECAM, which can drive the crew to shutdown an engine and divert.
This may explain the quick return to service, essentially a known issue, with a known way to resolve. It simply maybe new crew to the aircraft that were not aware of the TAB (much the same as OEBs on older Airbus aircraft).
tommy1808
Tue Nov 12, 2019 2:53 pm
OT, but not worth a thread, but since you are an A350 Pilot. How does information regarding incidents and accidents get to pilots, before it yielded a directive? Just if they are curious or in a structured fashion?
Best regards
Thomas
Tue Nov 12, 2019 3:02 pm
Via the electronic “manual” updates and also with updates from the in house technical boffins.
ikramerica
Tue Nov 12, 2019 3:06 pm
Don’t call me harold.
maint123
Tue Nov 12, 2019 3:45 pm
3 issues vs more than 120 in a year for the PW powered Neos.
