simairlinenet
Winglets - Why aren't others following United?
Tue Nov 12, 2019 7:19 pm
United seems to be leading U.S. carriers (and maybe the world?) on winglet installations:
-All 737s have Split Scimitar winglets
-All the sCO 757s have Scimitar winglets (and all the sUA have blended winglets)
-All the 767-300ERs have blended winglets
Have other airlines adopted as much as United? I can’t think of other airlines that have invested as much:
-737s: other airlines have Split Scimitars, but not fleet-wide—is this correct?
-757s: have any other airlines done Scimitar winglets?
-767s: other airlines have blended winglets, but not fleet-wide—is this correct?
DylanHarvey
Re: Winglets - Why aren't others following United?
Tue Nov 12, 2019 7:28 pm
Icelandair have Scimitar's on all if not most of their 752's.
trpmb6
Tue Nov 12, 2019 7:32 pm
Winglets have costs associated with them. Have to get the most bang for the buck to make up for the small improvement per cycle on fuel economy. It's a long term investment with a high upfront cost and when fuel costs are cheap there isn't much incentive to do that.
gatibosgru
Tue Nov 12, 2019 7:38 pm
I wonder why they haven't added sharklets to the A320s? Delta doesn't seem to feel any urgency to refurb for the most part, although I believe all their 763s have blended winglets.
@DadCelo
jetblastdubai
Tue Nov 12, 2019 7:39 pm
United also has a longer average stage length so they're able to tap into more of the savings since their planes spend more duty time in cruise.
tjwgrr
Tue Nov 12, 2019 7:46 pm
IIRC, FedEx acquired some 752s w/ winglets and had them removed.
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
Spacepope
Tue Nov 12, 2019 7:49 pm
You can only retrofit sharklets on A32x aircraft above LN 1200. UA has 28 A319 and 58 A320 older than that, which is not a small portion of the fleet.
gatibosgru
Tue Nov 12, 2019 8:06 pm
Did not know that! Thanks for the info, would you happen to know what makes retrofitting pre LN 1200 not possible?
@DadCelo
Spacepope
Tue Nov 12, 2019 8:11 pm
IIRC it's got to do with Airbus making constant incremental changes to their designs tather than new generations. The wing internal structure was changed past LN 1200 and while sharklets conceivably *could* be added (since they were tested on one of the A320 prototypes which was originally built as a -100) there is a ton of expensive wing work that would need to be done and certified and nobody is gonna spring for that. It's kinda similar to why you dont see 737-400s with winglets even though the -500 and -300 can have them.
northstardc4m
Tue Nov 12, 2019 8:21 pm
I thought the 737-400 didn't get winglets only because no one wanted to step up to pay the STC costs? Same as the -600?
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
737max8
Tue Nov 12, 2019 8:32 pm
WN is almost done with the entire 207 airplane 737-800 fleet.
However doing 500+ 737-700 at this point is not worth it, but a large number are getting them.
The thoughts and opinions expressed in my comments do not represent that of any airline or affiliate.
Flown on: 717 733 734 735 736 737 738 739 7M8 744 744ER 752 753 762 763 772 773ER 788 789 A220 A319/20/21 A332 A333 A339 A343 A346 A359 A388
trees
Tue Nov 12, 2019 8:38 pm
AA and DL are fleet-wide blended winglets
Spacepope
Tue Nov 12, 2019 9:33 pm
Sorry that's what I was getting at. The return on the costs of the STC and retrofit were no bueno. Same with sub-1200 A320s apparently, it's really just not financially viable to save a bit of fuel on these remaining early birds.
N649DL
Tue Nov 12, 2019 9:41 pm
DL actually has a few retrofitted 757s that don't have them. I was on N670DN on ATL-MCO last month and didn't have them and yet had a brand new interior.
United1
Tue Nov 12, 2019 9:49 pm
As someone else mentioned while winglets are not cheap UA gets a bigger bang for its buck as its stage length is quite a bit longer than AA, DL or WN. Just to be pedantic the 737-900s (non-ERs) have blended winglets vs split Scimitars. For only 12 aircraft I am sure the additional STC was prohibitively expensive.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
BWIAirport
Tue Nov 12, 2019 9:56 pm
All AS 737s minus a few ancient 739 non-ERs have split scimitars and have had them since like 2015
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
joeljack
Why in the world would FexEx remove them? Wasted fuel and greenhouse gas emissions.
GalaxyFlyer
Tue Nov 12, 2019 9:58 pm
On the low hours flown and short legs, the winglets probably cost fuel.
GF
Veigar
Tue Nov 12, 2019 10:03 pm
Are you sure about that.
At LAS I saw an AS 787 land (looked like an -800) in the older livery with no winglets at all and the cockpit eyebrows still there.
Also, Sun Country has some raw 73G (no winglets) and some 738s with no winglets at all either. Let alone splits
Revelation
Tue Nov 12, 2019 10:09 pm
Famously (or not) the KC-46A tanker based on 767 has no winglets for similar reasons, they just did not earn their way on to the airplane.
Even though these aircraft will presumably be flying for 50+ years like KC-135, they mainly tend to fly short hops and no where near as many hours as commercial airliners so they aren't worth the expense and the weight they add to the airplane.
Vctony
Tue Nov 12, 2019 10:18 pm
The AS 737-900s(nonER) have the eyebrow windows and no winglets.
DualQual
Tue Nov 12, 2019 10:58 pm
The non ER 900s have split scimitars.
There's no known cure for stupid
DualQual
Tue Nov 12, 2019 11:02 pm
Got any proof for that or just emotaposting? I don’t believe the winglet airplanes fit within the confines of the ramp parking spaces. Also, on a shorter stage length the extra weight of the winglet doesn’t save any gas and may actually cost more gas to carry.
rbavfan
Tue Nov 12, 2019 11:23 pm
Jet Blue has added sharklets. But they are limited by production line number for easy upgrade. Early wings need to be strengthened. Later wings designed for them to be added.
Stitch
Tue Nov 12, 2019 11:38 pm
FedEx does not add winglets to their new-build 767-300Fs (the ones they acquired from LAN had/have them) and it has been said this is due to both ramp space and the average stage-lengths not making it worthwhile. This could be the case with their 757s, as well.
Bostrom
Tue Nov 12, 2019 11:40 pm
To save weight? Removing them makes the plane about 250 kg lighter.
United1
Tue Nov 12, 2019 11:45 pm
When the heck did that happen?
rbavfan
Tue Nov 12, 2019 11:53 pm
The wings were strengthend from LN1200. Would cost to much in structure weight to upgrade them.
seahawks7757
Wed Nov 13, 2019 12:04 am
There are only three, they were the test aircraft for the 737-900 program. N302AS, N303AS and N305AS. The rest have splits fleet wide.
xxcr
Fedex fly short routes, so the extra weight of the winglets would actually cost them more.
seahawks7757
Wed Nov 13, 2019 12:07 am
This is incorrect. There are only three with out winglets, they were the test aircraft for the 737-900 program. N302AS, N303AS and N305AS. The rest of the 900’s have splits. The non ER are N3**AS. The ER’s are N4**AS and N2**AK. The AK ones are NOT etops equipped along with the 900’s.
rbavfan
Wed Nov 13, 2019 12:11 am
The KC46A has modified wingtips for its specific use.
Whiteguy
Wed Nov 13, 2019 12:17 am
The majority of WestJets 800s have scimitar winglets, a couple 800s and all 700s have blended winglets and no winglets on the 600 of course. WestJet was supposed to be the launch customer for the 600 winglets but the cost overran the savings as they were doing much of the short haul flying.
AirKevin
Wed Nov 13, 2019 12:25 am
Not entirely correct. Here's three different -900s with split scimitar winglets. I also flew on a -900 with split scimitar winglets just last September.
Captain Kevin
seahawks7757
Wed Nov 13, 2019 12:36 am
Along with the Alaska none er 900’s also have splits. Just those three test frames have no winglets, 302, 303 and 305.
packmedic
Wed Nov 13, 2019 12:39 am
As others have said, all -900s (ERs and non-ERs) have splits except for 302, 303, and 305. All -800s have them as well. While the -700s do not have the split scimitars, they all have the blended winglets
A319 A320 A321 A321N A332 A333 A359 A388 AT72 B717 B733 B734 B734C B735 B73G B738 B739 B744 B752 B763 B764 B772 B789 B78X CRJ2 CRJ7 CRJ9 DH8D E135 E140 E145 E170 E175 E190 MD80 MD90
ParkFSI
Wed Nov 13, 2019 1:01 am
I “ heard “ years ago wing lets increased static build up. Also on smaller aircraft they would fludder with ice.
Thread killer
tareias128
Wed Nov 13, 2019 1:28 am
And Luxair also have Split Scimitar winglets on the 738/73G fleet.
Enviado do meu Aquaris U Plus através do Tapatalk
B757Forever
Wed Nov 13, 2019 1:58 am
Ship 670 had previously been on the retirement list. When the price of oil dropped and the economy improved, it (along with other 757 aircraft) was given an H check, a new interior and stayed in the fleet. DL didn't see a reasonable ROI for winglets at that point and decided not to make that capital expenditure.
The Rolls Royce Dart. Noise = Shaft Horsepower.
MIflyer12
Wed Nov 13, 2019 2:09 am
Anybody with a good handle on direct costs (purchase and fitment, but not lost flight hours) and payback period with oil at $60/barrel and 1500-mile stage lengths for a 757? (Or other example.)
aemoreira1981
Wed Nov 13, 2019 2:17 am
FedEx also removed the winglets from the former Azerbaijan B763 freighters as well. The ex-LAN B763s were returned to LATAM with winglets.
cschleic
Wed Nov 13, 2019 2:32 am
...having to do with the number of each type, correct? The same STC cost spread over, say, 50 vs. 250 of a type makes the big cost difference.
intotheair
Wed Nov 13, 2019 3:47 am
Winglets on the 767 still look so odd to me. It's like seeing a dog walking on its hind legs.
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 CRK Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
Revelation
Wed Nov 13, 2019 3:57 am
Do tell, I don't see anything akin to winglets on KC46A e.g. https://leehamnews.com/wp-content/uploa ... Parker.jpg -- are you referring to military lighting / camera / etc ?
Pinto
Wed Nov 13, 2019 4:12 am
All of United's 737 NGs have Split Scimitar winglets
strfyr51
Wed Nov 13, 2019 4:22 am
The KC-46 dies not have winglets but it does have the raked wing tips which are aerodynamically superior, The USAF had no need to fit yjr KC-46 into any airport Gate space so they took the Raked wingtips. Which be accounts is superior to the winglets,
trees
Wed Nov 13, 2019 6:10 am
Yes, I was talking about the 767’s. They have actually removed winglets from some of the 757’s
Spacepope
Wed Nov 13, 2019 6:11 am
It most certainly does not.
jumpseat67
Wed Nov 13, 2019 6:27 am
Sorry, incorrect. All 757s have blended winglets.
JoseSalazar
Wed Nov 13, 2019 6:36 am
Thinking about the P-8 I assume?
Users browsing this forum: 8herveg, ajs123uk, Baidu [Spider], David_itl, dstblj52, FRAGateway, Gemuser, indywa, Jack, KIRFlyer, MD80MKE, N649DL, Opus99, qf789, sabenapilot, sassiciai, skyymarc, TEALflyer, Toinou and 226 guests
