ElroyJetson wrote:https://www.yahoo.com/finance/news/aircraft-engines-hitting-technical-limits-073538633.html
Fascinating article about the Trent 1000 engines and the technical problems posed. It certainly raises some interesting questions. I would love to know folks opinions on this who have some technical expertise.
Key quote from the article:
"The high-pressure turbine blades in a Trent 1000 passenger jet engine have to withstand temperatures far above the melting point of the nickel alloy from which they’re made. It’s a fiendish technical challenge for the engine’s British manufacturer, Rolls-Royce Holdings Plc — comparable to trying to stop an ice cube melting inside a kitchen oven on full blast. The solution found by the company’s engineers was to blow cool air through tiny holes in the blades. Unfortunately this clever approach has encountered some unexpected problems.
Boeing 787 aircraft operated by British Airways, Norwegian Air Shuttle, Virgin Atlantic and others have been grounded in recent months for inspections and repairs because the Trent 1000 engine blades have been degrading faster than anticipated. It’s the type of problem that’s becoming common in the industry as the demands placed on engines become ever greater."
ElroyJetson wrote:The solution found by the company’s engineers was to blow cool air through tiny holes in the blades. Unfortunately this clever approach has encountered some unexpected problems.
zeke wrote:The issue with the blades has nothing to do with cooling, it is the new coating that they have on the blades that is being eaten away by acid in the atmosphere as a result of pollution.
2175301 wrote:zeke wrote:The issue with the blades has nothing to do with cooling, it is the new coating that they have on the blades that is being eaten away by acid in the atmosphere as a result of pollution.
Are you sure about that? A lot of airlines have grounded their 787's due to RR engine issues... and many of them are not in areas that are considered highly polluted like parts of Asia and India are.
It seems to me that the Trent 1000 could not handle even some of the cleanest air...
Have a great day,
zeke wrote:ElroyJetson wrote:The solution found by the company’s engineers was to blow cool air through tiny holes in the blades. Unfortunately this clever approach has encountered some unexpected problems.
Not sure what is so special about this, it’s found in all large engines that I am aware of.
zeke wrote:2175301 wrote:zeke wrote:The issue with the blades has nothing to do with cooling, it is the new coating that they have on the blades that is being eaten away by acid in the atmosphere as a result of pollution.
Have a great day,
Yes it has been widely reported that pollution is causing acid which is eating the protective coating on the blades, and this is causing issues with the blades as the coating is designed to protect them. The largest source for this pollution is power stations and where oil and gas are produced, the worst areas are China, India, NW USA, and the Middle East.
https://so2.gsfc.nasa.gov/
ElroyJetson wrote:"The high-pressure turbine blades in a Trent 1000 passenger jet engine have to withstand temperatures far above the melting point of the nickel alloy from which they’re made. It’s a fiendish technical challenge for the engine’s British manufacturer, Rolls-Royce Holdings Plc — comparable to trying to stop an ice cube melting inside a kitchen oven on full blast. The solution found by the company’s engineers was to blow cool air through tiny holes in the blades. Unfortunately this clever approach has encountered some unexpected problems.
ElroyJetson wrote:[The GE engines on 787's do not appear to be having the same issues as the Trent 1000. The question is why?
2175301 wrote:[the information about NW USA is out of date.
2175301 wrote:The air over the USA, Canada, the Northern Atlantic, and Europe is largely free of any historic sulfur and other pollution issues now. So why were the Trent 1000 engines failing? Your pollution argument does not hold up there.
zeke wrote:ElroyJetson wrote:[The GE engines on 787's do not appear to be having the same issues as the Trent 1000. The question is why?
Who said they don’t suffer from premature erosion of the blade coatings ? It is still is very much an active area of research for GE.2175301 wrote:[the information about NW USA is out of date.
I should have written NE, it is not out of date, you can see individual known bad power plants in this map
https://bit.ly/30inNie
Or try this link
https://www.google.com/maps/d/u/1/viewe ... 094853&z=4
While the US has improved, the issue is the shear volume of power plants.2175301 wrote:The air over the USA, Canada, the Northern Atlantic, and Europe is largely free of any historic sulfur and other pollution issues now. So why were the Trent 1000 engines failing? Your pollution argument does not hold up there.
Doesn’t matter, even aircraft in New Zealand where the air is significantly cleaner than the US or Europe have eroded blades, as the aircraft fly to areas of high pollution.
The engines are not failing very often at all these days, your premise “ So why were the Trent 1000 engines failing?” is not true. The engines are being picked up on inspections and getting changed out, but that is not unique to RR.
2175301 wrote:zeke wrote:ElroyJetson wrote:[The GE engines on 787's do not appear to be having the same issues as the Trent 1000. The question is why?
Or try this link
Zeke: I think we may have to agree to disagree... From a jet age historical perspective the S02 emissions of the US and Europe are at an all time low. These are not areas of "high pollution" You should have seen the data from the 1970's.
Within the USA sulfur reductions started in the early 1970's. The US Navy changed their ships from "Bunker C" - the high sulfur residue oil from refineries, and certain specific high sulfur crude oils, which had to be heated to even pump it, to "Navy Distillate (ND)." I know that as a fact as I reported onboard a ship in the fall of 1975 as a new US Navy " A-School" graduate from their steam propulsion school (a few months after graduating from High School). The ship had been converted to ND 2 years earlier and was still struggling with fuel leaks (Bunker C self sealed small leaks; ND ate out those Bunker-C based seals); and we still had Bunker C residue in the bottom of the fuel tanks that had to be cleaned out in the 1977 overhaul period.
I've started working in coal fired power plants in 1982... when the industry was being forced to retrofit scrubbers and convert to lower sulfur coals. As a Power Plant Superintendent in the late 1980's (small municipal power plant) I made the decision to change to a higher cost but significantly lower sulfur coal for my plant. The State Public Utility Commission accepted that as a reasonable decision without asking any questions except why had the fuel prices gone up - and automatically passed the increased fuel cost onto the customers. That plant was closed a few years later due to other issues... and that was my last time on staff in a coal fired power plant (I've been in them as a contractor). I then moved to Nuclear Power after a stint working for vendors, etc. Many of the plants I worked at had Gas Turbine generating units, and older boilers that had been converted to either clean oil or natural gas - which were mainly used for short term operations and peaking units (did not run most of the time).
Right now there are less than half the number of coal fired power plants in the USA (and I presume Europe) as there was back in the mid 1980's; and their numbers keep dwindling in the USA as relative low cost natural gas with higher efficiency combined cycle power plants are replacing them.
So you see "high levels" of SO2 pollution. I see historic lows... and I also see that the previous generation of jet engines did not have these kinds of problems up to recent times even when the SO2 levels were much higher.
I agree with you that the issue is the blade coating is not standing up to the higher temperatures in the engines. I do not agree with you that the problem in the United States, Europe, and certain other parts of the world are from "highly" polluted air; given how much the pollution levels have declined. I think its more that the RR engineers missed on designing this coating for realistic applications.
Now China, India, and certain other parts of the world are different. I had personal friends who in the late 1980's to early 1990's went to China and India to build new coal fired power plants. No precipitators or bag-houses for particulate control. High sulfur coals. No SO2 scrubbers of any kind. When I asked them didn't the Chinese and Indians know about Power Plant pollution effects and how most of it could be controlled at a reasonable cost... (you could cut about 75% of the emissions towards the US and European standards with modest additions to a plant, it tripled the added cost to go for the next 25% which was required in the US and I presume Europe) and was told that "they" didn't care. They wanted old fashioned just send everything up the stack - cheapest to build (and lower efficiency too) power plants as they needed all the electrical generation they could get. Those governments did not even try to control pollution at any level, or even buy the highest efficiency coal fired power plant technology. Had they just done the easy and relatively cheap 75% reductions it would have massively changed what they have now. You see the results now of those decisions in the late 1980's and early 1990's in China and India (and a few other areas).
Have a great day,
Edited to add: In the 1970's and 1980's the parts of the Midwest and Eastern US had what was called "Acid Rain" and it obviously was affecting a lot of buildings, forests, lakes, rivers, etc.
If I travel to those areas now the old timers will remember it if you ask about it... but, I have not heard anyone talk about "acid rain" in a couple of decades now in the USA.
2175301 wrote:Now China, India, and certain other parts of the world are different.
ElroyJetson wrote:This thread kinda got derailed talking about pollution versus the problems with the Trent 1000. If pollution was the sole causal factor wouldn't all engines suffer the same blade erosion as the Trent?
The GE engines in the 787 are not having the same issues to anywhere near the degree of the Trent 1000. Again why?
boeingbus wrote:The A330NEO's engines are a derivative of the Trent 1000. Will those engines also experience degradation? Will TP face the same engine issues? If not, why not?
Also, Boeing touted how the 787 can perform engine swaps during the 787 design phase. This is predominantly for lessors? Did that feature make its way to production? If so, why haven't airlines opted for this? RR must be on top of this issue. I know they lost NZ as they chose GE for their 787-10.
flipdewaf wrote:RR do have a new format of cooling holes introduced on the T1000 (i believe its no the TXWB too) whereby the holes are cut into the blades to be round where they meet the internal path and migrating to rectangular the closer to the surface of the blade they get and creating a slot whereby they all effectively join up along(near) to the leading edge of the blade. This in theory creates a more uniform and laminar flow over the surface.
https://www.soue.org.uk/souenews/issue7/osney.html
So whilst all (pretty much) aero turbines have cooling there are subtle differences and nuances.
Fred
Revelation wrote:The reason for the failure is not clear. It could be that RR missed something in design or test, or they knew they were taking a risky approach and just misjudged the ultimate outcome.
Or try this link
william wrote:Wait till the Utlrafan comes out. Maybe unrealistic demands are being placed on these aerospace companies.
Or try this link
I have to question the validity of your data here. Your links indicate dozens of oil power plants in the US. That is simply not the case. Oil is less than 1% of US electricity production and that is mostly in Alaska and Hawaii. The one supposed oil plant I looked into on that map (Gibson City Energy Center) is actually a gas plant.
sciing wrote:boeingbus wrote:The A330NEO's engines are a derivative of the Trent 1000. Will those engines also experience degradation? Will TP face the same engine issues? If not, why not?
Do you really think that if you would get the answer in detail by RR you would be able to understand?
boeingbus wrote:Also, Boeing touted how the 787 can perform engine swaps during the 787 design phase. This is predominantly for lessors? Did that feature make its way to production?
lowbank wrote:sciing wrote:boeingbus wrote:The A330NEO's engines are a derivative of the Trent 1000. Will those engines also experience degradation? Will TP face the same engine issues? If not, why not?
He is not going to get an answer. I understand that the T7000 is not going to work as hard on the 330neo.
The article is being way to simplistic. The RB211-524 has turbine blades with cooling holes drilled in them.
If you google about the 524 that flew through a volcanic cloud, all four engines cut out.
I spoke to a couple of guys that stripped those engines, all the cooling holes had been blocked and they were amazed the blades didn’t melt after the pilots got the engines relit and got them to an airport.
Turbine temperatures are key to turbine life.
Talking in general terms, a turbine life is 5000 cycles. 10 degrees over temp in the turbine is going to reduce your life around 800-1000 cycles.
Now the T1000 does not have that issue, but just illustrate what we are dealing with.
When the turbine is running at over 2000 degrees it’s a small increase, but a big impact.
sciing wrote:ElroyJetson wrote:"The high-pressure turbine blades in a Trent 1000 passenger jet engine have to withstand temperatures far above the melting point of the nickel alloy from which they’re made. It’s a fiendish technical challenge for the engine’s British manufacturer, Rolls-Royce Holdings Plc — comparable to trying to stop an ice cube melting inside a kitchen oven on full blast. The solution found by the company’s engineers was to blow cool air through tiny holes in the blades. Unfortunately this clever approach has encountered some unexpected problems.
Here my 20 years knowledge of what I learned as graduated material scientist.
The coating on the blades is called TBC, Temperature Barrier Coating, usually ceramics. Below you have bonding coating usually made of refractory metals like Ta or Pt or an intermetalic compound (with high melting point) and then the single crystalline Nickel based superalloy blades.
So what is written in the article is nothing special for RR. The goal is always to go to the highest temperature as possible.
The material system is very complex. I guess there are 10000 PhDs based on that topic and 100000 papers;-)
Ronaldo747 wrote:boeingbus wrote:Also, Boeing touted how the 787 can perform engine swaps during the 787 design phase. This is predominantly for lessors? Did that feature make its way to production?
IIRC even before flight test it became clear that the engine swap is not possible as originally advertised.
uta999 wrote:How has the A350 version of the Trent avoided all these problems?
Can’t the tech there make its way to the 787 somehow?
How did Boeing get the very short straw from RR?
Antaras wrote:It seems kinda like most of the engine manufacturers all have products with problems.
RR: problems with Trent 1000 equipped on B787.
PW: bunches of problems on GTF engines that are installed on A220 and A320neo families.
GE: facing troubles on the gigantic GE9x, which delayed the B777X's development.
ElroyJetson wrote:The only material i know if that can reliably handle the core temperatures of newer engines are cremarics. However cremarics are exceeding brittle and difficult to machine. I am not a gas turbine expert but simple physics says the greater the temperature difference between the hot internal core and the cold air bypass the greater "work" i.e. efficiency of the engine.
However my assumption is the core temps of these new generation engines are hitting the limits of existing standard materials. I would love Lightsaber or others with genuine knowledge to comment.
kjeld0d wrote:ElroyJetson wrote:The solution found by the company’s engineers was to blow cool air through tiny holes in the blades.Antaras wrote:It seems kinda like most of the engine manufacturers all have products with problems.
Seems like we are getting to the limit of turbine technology. What is next?
