VV wrote:What? Filled with hydrogen like Hindenburg?
robsaw wrote:The storage density per unit energy of liquid hydrogen vs petroleum fuel is about 1:4. That doesn't include the weight of the much heavier hydrogen storage tanks. Hydrogen can be stored in other ways to avoid the cryogenic requirements for true liquid hydrogen but those have their own complications and inefficiencies.
Or, turn the A380 into a slow-moving airship as someone else alluded to.
MIflyer12 wrote:Paragraphs.
Cars don't suffer from storage container weight like aircraft do. This is the kind of science you should have learned in 8th grade.
morrisond wrote:If you put it into production you would have to figure out how to make Hydrogen cheaply - France seems to have lots of cheap Carbon Free nuclear power at night.
morrisond wrote:
I'm not talking about saving the A380 Program - just saving the tooling so the cross section could be reused in probably a relatively low volume project.
Naincompetent wrote:And even if the electricity is quite cheap, I am not sure that using it for producing hydrogen on that scale would be wise...
morrisond wrote:So what is your solution when the greens demand that we stop burning Carbon in aircraft?
morrisond wrote:I'm not talking about saving the A380 Program - just saving the tooling so the cross section could be reused in probably a relatively low volume project.
Antarius wrote:morrisond wrote:I'm not talking about saving the A380 Program - just saving the tooling so the cross section could be reused in probably a relatively low volume project.
Why would you choose a large and yet inefficient model as your starting point? Picking a quad that was designed and engineered to be stretched, but never did is like picking an a318 or a 736 as a model of efficiency.
bennett123 wrote:Storing Hydrogen in a passenger aircraft with a considerable number of electrical systems.
What could go wrong with that.
morrisond wrote:Sunday morning thinking. Something to discuss.
Lots of hurdles too overcome but with the focus on reducing Carbon emissions it struck me that if you sacrifice the A380 upper deck for Hydrogen Storage it could be a great use for the cross section and a possible future for the Airframe.
I know it would take some time to figure out how to use Hydrogen in Aircraft operations but you could easily convert one of the A380 test airframes to Hydrogen and start a test program to figure out the kinks.
It seems like a great EU research project.
You would also have to optimize the A380 for hydrogen - which would mean a new wing, new gear.
You need cylinder shapes to store Hydrogen - you can't really put it in the wings. You would store it in Cylinders in the upper deck.
However as Hydrogen is so light (1/3 the weight of Jet Fuel for the same range) you could probably get away with 2 bumped up Ge9x's. They were tested to 135K.
The MTOW would probably be a lot closer to 400T then the 575T existing.
New gear - new optimized 80M wing with folding tips that might go out to 90M extended.
Stretch it to 85m as originally envisioned and go to 11W Y class to pick up passenger capacity on the main deck - that's a 13M stretch.
It could get it back to about A388 Capacity.
The tail could probably get a lot smaller due to the longer moment arm and greatly MTOW weight. Lighter gear for sure.
It could work - it's probably a good idea to preserve the tooling to make fuselages.
Time for the EU to fund some research!
Some people think me a Boeing Fan Boy but in reality I just like shiny new metal. This would be exciting but would probably be 10+ years (5 years for test program and then 5+ years to reengineer A380 to take advantage of hydrogen's properties).
capshandler wrote:morrisond wrote:Sunday morning thinking. Something to discuss.
I find it super interesting. You have an almost new platform with almost no commercial value to do hundreds of tests while trying to unveil the so needed future of aviation.
Taking a look to other comments one starts to understand why humanity is doomed. The lack of innovation culture is just impressive. A good open question answered by arrogant noes. The same kind of answers like Galileo got hundreds of years ago. My friends take a look to the innovation learnings of Mr. Bertrand Piccard.
I hope we could at least go for some knowledgeable and constructive criticism by engineers!
TWA772LR wrote:The testing would be a nice feel-good project for the greenies in the EU. And the A380 would make a good testbed because of the upper deck. And the technology has come a long way since the Russians tested it in the 8ps with a TU204.
Antarius wrote:Personally, I think the a380 is far too heavy and inefficient for this project a a359ULR or 78J may be a better test bed.
morrisond wrote:...
Seabear wrote:bennett123 wrote:Storing Hydrogen in a passenger aircraft with a considerable number of electrical systems.
Let me guess....oh, yeah:
morrisond wrote:Seabear wrote:bennett123 wrote:Storing Hydrogen in a passenger aircraft with a considerable number of electrical systems.
You need to read this article to see how safe Hydrogen is - it seems like it's actually quite good. https://hydrogen.wsu.edu/2017/03/17/so- ... ogen-fuel/
All I'm saying is that you might want to save the tooling for the A380 nose and cross section.
It would be perfect for an Hydrogen powered aircraft as you need a big space to carry the needed volume - the full length upper deck would work great.
A non double decker won't really work - no where to put the tanks as you can't really store it in the wings - unless you sacrifice the belly volume.
sciing wrote:bennett123 wrote:Storing Hydrogen in a passenger aircraft with a considerable number of electrical systems.
It is used a rocket fuel. A lighter than air fuel is much safer than anything else.
spacecadet wrote:sciing wrote:bennett123 wrote:Storing Hydrogen in a passenger aircraft with a considerable number of electrical systems.
That's true - there's never been a rocket accident involving hydrogen fuel ignition! /facepalm.
sciing wrote:spacecadet wrote:sciing wrote:It is used a rocket fuel. A lighter than air fuel is much safer than anything else.
Safer than other fuels! I thought that competence level in this forum is that high enough not just on CNN level.
There were never aircraft incidents involving kerosin vapor ignition?
Maybe you may talk the topic seriously?
Otherwise please excuse that I will ignore your nonsense!
jetblueguy22 wrote:capshandler wrote:morrisond wrote:Sunday morning thinking. Something to discuss.
Usually we try to save the dramatics for DTW threads.
Why do we need the A380 to be the test bed? There are probably 50 aircraft on the market that could be tested for such a thing. You scale up projects like this, not down.
Innovation isn’t dead, it’s the fact that we are dealing with advanced materials these days. They need to be tested and understood. It was a lot easier 60 years ago. And a hell of a lot simpler
JayinKitsap wrote:Hydrogen is 33 kWh/kg, jet fuel is 12 so almost 3x the energy per pound. But unless it is liquid it would need to be stored at high pressures. For example H stored at 70F and 1,450 PSI weight is only 0.5 lb/cf, while jet fuel is 50 lb/cf. The volume of 20 US tons of Jet fuel is 800 CF. The volume of 20 US tons of Hydrogen is 80,000 CF. A 77F has a cargo volume is 5,330 CF, so using the entire volume of the 77F it could carry 10,660 lb of compressed hydrogen. This would take a pressure vessel 100' long and 15' in diameter with 2.5" thick high strength steel. It only weighs 473,000 lb, about 2/3 of the 77F MTOW. Well the 77F could take off with this tank, the 5 tons of fuel, and its OEW.
The cryogenic tank for liquid hydrogen would fit but storing liquid at -423F is a bit tricky, its weight liquid is 4.4 lb per cubic foot So even the Saturn V rocket uses RP-1 (a very good jet fuel) verses liquid hydrogen in its 1st stage, but LH in the 2nd and 3rd stage. If it doesn't make sense in a rocket, it does not make sense in an airplane.
Amiga500 wrote:Its an interesting academic exercise, nothing wrong with that. As a test bed for a Cryoplane, an A380 is quite ideal due to the large internal fuselage volume and 4 engines for safety.
For an actual passenger carrying solution assuming technology matured enough? Perhaps as a very loose starting point, but not much more.
A few points
>> Hydrogen is safer than kerosene for aviation. That is quite well understood within the industry. The Hindenburg disaster is pointed to by those who simply haven't read up on the subject.
>> H2 tanks are getting lighter and less prone to embrittlement. But they are still much heavier than JetA tanks.
>> There has been work done by Airbus (and I think Boeing too) on Hydrogen fuel cells replacing the APU on single-aisle and performing a number of other functions alongside that - such as potable water and fuel tank inerting. Nothing has come of it apart from test beds yet.
>> The DLR had the Cryoplane concept based on an old Dornier in the late 90s. Never flew to my knowledge.
>> Density is the big issue as far as primary power would be concerned. There is more hydrogen in a litre of liquid water than there is in a litre of liquid hydrogen!
>> Generation of hydrogen is more efficiently done by an enzyme/bacteria augmented process than hydrolysis (I think the best versions still use some electricity, but much less than conventional hydrolysis).
>> A turbofan will (more or less) happily burn H2 instead of JetA. Obviously details within the injectors and combustor have to change, but its not a fundamental mismatch.
