enilria
OAG Changes 11/17/2019:4O Adds CUN-MIA,LAX-MTY;AA Cuts JFK Again;DL Exits PAP;UA Exits ELM, LAX-PSC
Sun Nov 17, 2019 1:48 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
4B DFW-VCT JAN 0.2>1.9[1.0] FEB 0>1.8[1.0] MAR 0>1.9[1.0] APR 0>1.9[1.0] MAY 0>1.8[1.0] JUN 0>1.9[1.0] JUL 0>1.9[1.0] AUG 0>1.8[1.0]
4B IAH-VCT JAN 0.2>1.9[2] FEB 0>1.8[2] MAR 0>1.9[2] APR 0>1.9[2] MAY 0>1.8[2] JUN 0>1.9[2] JUL 0>1.9[2] AUG 0>1.8[2]
4B MCE-SMF JAN 0.2>1.4[0] FEB 0>1.4[0] MAR 0>1.5[0] APR 0>1.4[0] MAY 0>1.5[0] JUN 0>1.4[1.2] JUL 0>1.4[0] AUG 0>1.5[0]
4B PDT-PDX JAN 0.5>3[3] AUG 0>3[4]
**4O CUN-MIA APR 0>0.6[0] MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.6[0] AUG 0>0.6[0]
**4O LAX-MTY JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.5[0] APR 0>0.6[0] MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.6[0] AUG 0>0.6[0]
7H ANC-DUT DEC 0>1.9[0]
*9K BNA-MWA JAN 0>0.2[0] FEB 0>1.7[0] MAR 0>1.7[0] APR 0>1.7[0] MAY 0>1.7[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0]
*9K BNA-OWB JAN 0>0.6[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0]
9K HPN-PVC AUG 1.0>1.5[1.5]
9K MWA-STL FEB 5>3[5] MAR 5>3[5] APR 5>3[5] MAY 5>3[5] JUN 5>3[5] JUL 5>3[5] AUG 5>3[5]
*9K ORD-UIN JAN 0>2[0] FEB 0>3[0] MAR 0>3[0] APR 0>3[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>3[0]
9K OWB-STL JAN 3>2[3] FEB 3>1.0[3] MAR 3>1.0[3] APR 3>1.0[3] MAY 3>1.0[3] JUN 3>1.0[3] JUL 3>1.0[3] AUG 3>1.0[3]
*9K STL-UIN JAN 0>2[0] FEB 0>3[0] MAR 0>3[0] APR 0>3[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>3[0]
AA AGS-DFW MAR 1.0>1.9[0.9] APR 1.0>2[1.2] MAY 1.0>2[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>1.6[1.0]
AA ALB-DCA APR 4>5[4] MAY 4>5[4]
AA ATL-MIA APR 8>9[8] MAY 8>9[8]
AA ATL-ORD FEB 5>4[4]
AA ATL-PHL FEB 5>4[5]
AA ATL-PHX FEB 2>1.0[2]
AA AUS-ORD FEB 4>3[3]
AA AVL-PHL FEB 1.6>1.0[0]
AA BDL-DFW FEB 1.8>0.8[1.9]
AA BHM-PHL FEB 3>1.9[2]
AA BNA-LAX FEB 1.3>1.9[1.9]
AA BNA-PHL FEB 5>4[4]
AA BOS-DCA FEB 12>10[14]
AA hacks the JFK schedule through FEB now
AA BOS-JFK FEB 5>3[4]
AA BOS-LGA FEB 10>9[12]
AA BOS-ORD FEB 7>6[6]
AA BWI-CLT FEB 8>7[7]
AA BWI-JFK FEB 3>1.0[1.0]
AA BWI-MIA FEB 3>1.3[3]
AA BWI-PHX FEB 1.6>0.0[1.7]
AA CLE-DFW FEB 3>2[3]
AA CLE-JFK FEB 1.2>0[3]
AA CLT-CRW MAR 5>4[5] APR 5>4[5] MAY 5>4[5] JUN 5>4[5] JUL 5>4[5] AUG 5>4[5]
AA CMH-JFK FEB 1.6>1.0[1.0]
AA CMH-PHL FEB 6>5[5]
AA CVG-PHL FEB 5>4[5]
AA DCA-EYW APR 0.5>1.1[1.3] MAY 0.3>1.0[0.3]
AA DCA-JFK FEB 3>2[4]
AA DCA-LGA FEB 10>9[11]
AA DCA-MHT APR 3>4[3] MAY 3>4[3]
AA DCA-PBI APR 1.2>2[3] MAY 1.0>2[1.3]
AA DCA-PIT APR 4>5[4] MAY 4>5[4]
AA DCA-YYZ FEB 2>1.8[3]
AA DEN-MIA FEB 3>2[3]
AA DEN-PHL FEB 0.8>0.6[1.4]
AA DFW-FSD FEB 2>3[2]
AA DFW-JFK FEB 3>1.0[3]
AA DFW-LRD FEB 4>3[4]
AA DFW-MIA FEB 11>10[10]
AA DFW-RNO FEB 3>2[1.9]
AA DFW-YVR FEB 1.6>1.0[1.9]
AA DSM-PHL FEB 1.6>1.0[2]
AA DSM-PHX FEB 2>3[3]
AA DTW-LGA APR 4>5[5] MAY 4>5[5]
AA DTW-PHL FEB 5>4[5]
AA EWR-PHX FEB 3>2[3]
AA FLL-PHL APR 4>6[5] MAY 4>6[4]
AA FWA-PHL FEB 1.6>1.0[1.8]
AA GRR-PHL FEB 3>2[2]
AA HSV-ORD FEB 1.2>1.8[0.9]
AA HVN-PHL FEB 2>1.8[3]
AA IAD-LAX FEB 1.6>1.0[1.7]
AA ILM-PHL FEB 3>2[1.8]
AA IND-LAX FEB 0.9>1.5[1.3]
AA IPT-PHL FEB 2>1.3[1.5]
AA JAX-ORD FEB 2>1.7[1.8]
AA JFK-LAS FEB 1.2>0[1.9]
AA JFK-MIA FEB 8>6[6]
AA JFK-ORF FEB 1.6>1.0[1.7]
AA JFK-PHL FEB 3>0[1.0]
AA JFK-PHX FEB 6>5[4]
AA JFK-PIT FEB 3>1.0[1.0]
AA JFK-RDU FEB 3>2[4]
AA JFK-RIC FEB 3>2[0]
AA JFK-SAN FEB 1.0>0.4[1.0]
AA JFK-YUL FEB 1.6>1.0[2]
AA JFK-YYZ FEB 1.2>0[2]
AA LAS-ORD FEB 5>4[4]
AA LAX-MSY FEB 1.6>1.2[2]
AA LAX-PHL FEB 6>7[6]
AA LEX-PHL FEB 2>1.8[2]
AA LGA-MIA FEB 12>11[12]
AA LGA-MSP FEB 2>1.7[1.9]
AA LGA-ORD FEB 12>10[14]
AA LGA-ORF FEB 3>1.8[3]
AA MEM-PHL FEB 3>1.4[2]
AA MIA-RDU MAR 3>5[3] APR 3>5[3] MAY 3>5[3]
AA MIA-TPA FEB 6>4[7]
AA MIA-YYZ FEB 3>1.4[3]
AA MKE-PHL FEB 4>2[3]
AA MSP-PHL FEB 3>1.6[2]
AA MSY-ORD FEB 1.8>2[3]
AA MSY-PHL FEB 2>1.1[1.7]
AA MYR-PHL FEB 1.7>0.9[1.5]
AA OKC-PHL FEB 1.6>1.0[2]
AA OMA-PHL FEB 1.6>1.0[1.9]
AA ORD-ORF FEB 1.5>1.0[1.9]
AA ORD-PHL FEB 8>7[8]
AA ORD-PIA FEB 2>3[1.9]
AA ORD-PIT FEB 5>4[4]
AA ORD-PVD FEB 2>1.8[1.7]
AA ORD-SEA FEB 3>1.8[3]
AA ORD-SUX FEB 3>2[3]
AA PBI-PHL APR 3>5[5] MAY 3>5[3]
AA PDX-PHX FEB 4>3[4]
AA PHL-RSW APR 4>5[4] MAY 4>5[3]
AA PHL-SAN FEB 3>1.9[1.5]
AA PHL-SAT FEB 0.6>0[1.0]
AA PHL-SBY FEB 3>1.9[3]
AA PHL-SDF FEB 3>2[2]
AA PHL-SYR APR 5>6[6] MAY 5>6[5]
AA PHL-TYS FEB 3>1.9[2]
AA PHL-YUL FEB 2>1.8[3]
AA PHX-PIT FEB 1.2>1.8[1.8]
AA PHX-SAF FEB 1.2>1.7[0.9]
AA PHX-SEA FEB 3>2[4]
AA PHX-STS FEB 1.0>1.6[0.9]
AF CDG-SFO MAY 1.7>2[1.7] JUN 1.9>3[1.9] JUL 2>3[2] AUG 2>3[2]
AS ANC-SEA MAY 18>17[17]
AS GEG-SEA MAY 15>14[14]
AS PDX-SEA DEC 20>21[20]
B6 BOS-SDQ FEB 1.4>1.1[1.1]
B6 CUN-FLL JUN 2>3[1.6] JUL 2>3[2] AUG 2>3[2]
B6 FLL-NAS JAN 4>3[4] JUN 3>4[4] JUL 3>4[4] AUG 3>4[4]
B6 FLL-PAP JAN 1.6>1.3[2] FEB 2>1.6[2]
B6 FLL-RIC JUN 1.2>1.5[1.3] JUL 1.0>1.6[1.0] AUG 1.0>1.6[1.0]
B6 HPN-RSW MAR 1.2>2[1.0] APR 1.1>2[1.0]
B6 JFK-PAP JAN 1.8>1.3[2.0]
BA LHR-MIA APR 3>2[3] MAY 3>2[3] JUN 3>2[3] JUL 3>2[3] AUG 3>2[3]
DL ATH-JFK APR 1.0>0.7[0.6]
DL ATL-LOS AUG 0.6>0.8[0.6]
DL ATL-MCI JUN 8>9[9] JUL 8>9[8] AUG 8>9[8]
DL ATL-OAK APR 0.4>0[0]
**DL ATL-PAP JAN 1.0>0.3[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 0.8>0[0.7] MAY 0.7>0[0.7] JUN 0.7>0[0.7] JUL 0.7>0[1.0] AUG 0.7>0[1.0]
DL ATL-PIT JUL 8>9[8] AUG 8>9[8]
DL ATL-PSP APR 0.6>0.3[0]
DL ATL-VCE MAY 0.6>0.4[0.5]
DL ATL-ZRH MAY 0.6>0.4[0.5]
DL AZO-DTW MAY 5>4[5] JUN 5>4[1.8] JUL 5>4[4] AUG 5>4[4]
Airport closure?
*DL CDC-SLC MAR 1.8>0.8[1.7] APR 1.9>0[1.7] MAY 1.8>0[1.9] JUN 1.9>0[3] JUL 1.9>0.7[3]
DL CDG-DTW AUG 2>1.0[2]
DL COD-SLC MAY 0>0.8[0.3]
DL GJT-SLC APR 3>4[3] MAY 3>4[3]
DL JFK-LOS AUG 0.4>0.9[0.4]
DL JFK-TXL APR 0.7>0[0]
DL MSP-RIC APR 3>1.9[1.9]
DL SEA-TUS APR 1.2>0.6[0]
DL SLC-WYS MAY 0.2>1.1[1.0]
DL SLC-YVR APR 1.8>1.0[1.0]
*DY CDG-ORD MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.7[0] AUG 0>0.7[0]
*DY DEN-FCO APR 0>0.3[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0]
*DY FCO-ORD JUN 0>0.6[0] JUL 0>0.5[0] AUG 0>0.6[0]
G3 FOR-MIA JUL 1.0>0[0] AUG 1.0>0[1.0]
*IB IAD-MAD MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.7[0] AUG 0>0.7[0]
J5 AGN-JNU DEC 1.0>0.6[1.0] MAR 0.6>1.0[1.0] APR 0.2>1.0[1.0] MAY 0>1.5[1.4] AUG 0>1.7[3]
J5 AGN-TKE DEC 1.0>0.6[1.0] MAR 0.6>1.0[1.0] APR 0.2>1.0[1.0] MAY 0>0.8[0.7] JUN 0>0.5[0] JUL 0>0.5[0] AUG 0>0.7[0.4]
J5 EXI-JNU MAY 0.1>0.4[0.4] JUN 0.1>0.4[0.4] JUL 0.2>0.5[0.5] AUG 0.1>0.4[0.4]
J5 HNS-SGY MAR 0.2>1.0[1.0]
J5 JNU-SGY MAR 2>3[3] APR 0.2>3[3] AUG 0>6[7]
J5 JNU-TKE DEC 1.0>0.6[1.0] MAR 0.6>1.0[1.0] APR 0.2>1.0[1.0] MAY 0>1.2[1.8] JUN 0>1.5[3] JUL 0>1.5[3] AUG 0>1.3[3]
K3 CGA-KLW DEC 1.5>0[0.8] JAN 1.5>0[0.8] FEB 1.5>0[0.8] MAR 1.5>0[1.7] APR 1.6>0[1.3] MAY 1.5>0[1.7] JUN 1.6>0[1.7] JUL 1.6>0[1.7] AUG 1.5>0[1.7]
K3 CGA-KTB DEC 0.8>0[0.4] JAN 0.8>0[0.4] FEB 0.8>0[0.4] MAR 0.8>0[0.8] APR 0.9>0[0.4] MAY 0.8>0[0.9] JUN 0.9>0[0.8] JUL 0.9>0[0.9] AUG 0.8>0[0.9]
K3 CGA-KTN DEC 0.3>0[0.4] JAN 0.3>0[0.4] FEB 0.3>0[0.4] MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.3>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4]
K3 EDA-KTN DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2] JUL 0.2>0[0.2] AUG 0.2>0[0.2]
K3 EDA-NKI DEC 0.3>0[0.1] JAN 0.3>0[0.1] FEB 0.3>0[0.1] MAR 0.3>0[0.3] APR 0.3>0[0.3] MAY 0.3>0[0.3] JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.3>0[0.3]
K3 HYG-KTN DEC 0.4>0[0.4] JAN 0.4>0[0.4] FEB 0.4>0[0.4] MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.5] JUN 0.4>0[0.4] JUL 0.5>0[0.5] AUG 0.4>0[0.4]
K3 KCC-KTN DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2] JUL 0.2>0[0.2] AUG 0.2>0[0.2]
K3 KCC-WWP DEC 0.3>0[0.1] JAN 0.3>0[0.1] FEB 0.3>0[0.1] MAR 0.3>0[0.3] APR 0.3>0[0.3] MAY 0.3>0[0.3] JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.3>0[0.3]
K3 KLW-KTN DEC 0.7>0[0.8] JAN 0.7>0[0.8] FEB 0.8>0[0.8] MAR 0.8>0[0.8] APR 0.8>0[0.4] MAY 0.7>0[0.5] JUN 0.8>0[0.4] JUL 0.8>0[0.4] AUG 0.8>0[0.4]
K3 KPB-PPV DEC 0.3>0[0.2] JAN 0.3>0[0.2] FEB 0.3>0[0.2] MAR 0.3>0[0.4] APR 0.3>0[0.4] MAY 0.3>0[0.4] JUN 0.3>0[0.4] JUL 0.3>0[0.5] AUG 0.3>0[0.4]
K3 KTB-KTN DEC 1.2>0.8[1.2] JAN 1.2>0.8[1.2] FEB 1.2>0.8[1.2] MAR 1.3>0.8[1.3] APR 1.3>0.9[1.3] MAY 1.2>0.8[1.3] JUN 1.3>0.9[1.3] JUL 1.3>0.9[1.3] AUG 1.3>0.8[1.3]
K3 KTN-MTM DEC 1.6>0[1.3] JAN 1.6>0[1.6] FEB 1.7>0[1.6] MAR 1.7>0[1.7] APR 1.7>0[1.7] MAY 1.6>0[1.7] JUN 1.7>0[1.7] JUL 1.7>0[1.7] AUG 1.7>0[1.7]
K3 NKI-WWP DEC 0.3>0[0.1] JAN 0.3>0[0.1] FEB 0.3>0[0.1] MAR 0.3>0[0.3] APR 0.3>0[0.3] MAY 0.3>0[0.3] JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.3>0[0.3]
LA LIM-MIA JUN 2>3[2] JUL 2>3[2] AUG 2>3[2]
NK MYR-PIT APR 0.3>0.6[0.4] JUN 0>0.3[1.0]
OS BOS-VIE APR 0>0.7[0] MAY 0>0.9[0] JUN 0>0.8[0] JUL 0>0.9[0] AUG 0>0.8[0]
OS LAX-VIE MAY 1.0>0.7[1.0] JUN 1.0>0.7[1.0] JUL 1.0>0.7[1.0] AUG 1.0>0.7[1.0]
OS MIA-VIE APR 0.6>0[0.6] MAY 0.6>0[0.5] JUN 0.6>0[0.6] JUL 0.5>0[0.5] AUG 0.6>0[0.6]
*TK EWR-IST MAY 0>0.2[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
Didn't they say everything was moving to MLB?
*TOM MAN-SFB APR 0.3>0.5[0.4] MAY 0.3>0.6[0.3] JUN 0.3>0.6[0.3] JUL 0.3>0.6[0.3] AUG 0.3>0.5[0.3]
UA AEX-IAH APR 3>1.9[3]
UA AUS-SFO APR 5>6[5]
UA BIL-DEN APR 4>5[4]
UA BOI-DEN APR 4>5[4]
UA BOI-SFO APR 5>6[5]
UA BOS-EWR MAR 11>10[9]
UA BOS-IAD APR 4>5[4]
UA BOS-SFO APR 7>6[7]
UA BUF-IAD APR 4>3[3]
UA BUF-ORD APR 4>3[4]
UA CID-DEN JAN 3>2[1.9]
UA CLE-IAD JAN 4>3[4]
UA COS-LAX APR 2>3[1.6]
UA CVG-IAH APR 4>3[4]
UA CWA-ORD JAN 3>2[2]
UA DAY-DEN JAN 1.8>1.0[1.8] FEB 2.0>1.6[2.0]
UA DCA-ORD APR 14>15[14]
UA DEN-ICT APR 4>5[4]
UA DEN-IND JAN 3>2[3]
UA DEN-LAX APR 7>8[7]
UA DEN-MKE JAN 3>2[2]
UA DEN-MSY APR 4>3[3]
UA DEN-PAE JAN 3>2[0] APR 2>3[2.0]
UA DEN-PSC JAN 3>2[2]
UA DEN-RNO APR 3>4[3]
UA DEN-RSW APR 2>1.0[1.1]
*UA DEN-SAV APR 0>1.0[0] MAY 0>1.0[0]
UA EGE-IAH MAR 0.7>0.9[0.5]
UA EGE-ORD JUN 0.4>0.9[0] AUG 0.5>1.0[0]
**UA ELM-IAD JAN 2>0.3[0] FEB 2>0[0] MAR 2>0[0.1] APR 2>0[2] MAY 2>0[2] JUN 2>0[2] JUL 2>0[2] AUG 2>0[2]
UA EWR-ROC APR 5>4[4]
UA EWR-XNA MAR 0.7>1.0[1.0]
UA FNT-ORD APR 3>1.0[4]
UA IAD-ROA JAN 3>2.0[2]
UA IAD-SAN JAN 3>2[2]
UA IAD-SDF APR 2>3[2]
UA IAH-MTJ MAR 0.9>1.1[1.0]
UA IAH-RIC APR 2>1.0[1.1]
UA LAS-LAX APR 5>4[5]
*UA LAX-PSC JAN 0.6>0.2[0] FEB 0.8>0[0] MAR 1.0>0[0.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0]
UA LAX-PSP APR 1.0>2[1.0] MAY 1.0>1.2[1.0]
UA MIA-ORD JAN 4>3[2]
UA MMH-SFO APR 0.4>1.0[0] MAY 0>0.2[0]
UA MSY-SFO APR 2>1.0[2.0]
UA ORD-PDX JAN 3>2[2]
UA ORD-RAP APR 1.0>0[1.1] MAY 1.0>0.8[1.2]
UA ORD-SEA JAN 4>3[3]
UA ORD-TVC APR 4>3[4]
UA PAE-SFO APR 4>3[4]
UA RDU-SFO APR 2>3[1.7]
WN ATL-AUS FEB 2>1.9[3]
WN ATL-PHL FEB 1.8>1.4[1.9]
WN AUS-ELP FEB 1.8>1.3[1.9]
WN AUS-FLL FEB 1.2>0.7[1.1]
WN AUS-MDW FEB 3>2[3]
WN BHM-BWI FEB 1.0>0.8[1.0]
WN BNA-SJC FEB 1.0>0.8[0]
WN BOI-SJC FEB 1.5>1.0[1.0]
WN BWI-CMH FEB 3>2[3]
WN BWI-MKE FEB 1.8>1.2[1.7]
WN BWI-MSP FEB 1.5>0.9[1.7]
WN BWI-OKC FEB 0.8>0.3[0.9]
WN BWI-PIT FEB 3>2.0[3]
WN BWI-SDF FEB 2>1.9[2]
WN DEN-PIT FEB 1.8>1.3[1.0]
WN DEN-RNO FEB 1.0>0.5[1.0]
WN FLL-SAT FEB 1.0>0.5[1.0]
WN GEG-SAN FEB 0.8>0.3[0]
WN IND-MCI FEB 1.6>1.1[1.6]
WN MCI-MSP FEB 1.4>1.1[1.6]
WN MDW-OAK FEB 1.9>1.3[2]
X4 AGN-JNU DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.5[0] JUN 0>3[0] JUL 0>2[0] AUG 0>2[0]
X4 AGN-TKE DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>0.8[0] JUN 0>0.5[0] JUL 0>0.5[0] AUG 0>0.7[0]
X4 CGA-KLW DEC 0>1.6[0] JAN 0>1.6[0] FEB 0>1.7[0] MAR 0>1.7[0] APR 0>1.7[0] MAY 0>1.6[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0]
X4 CGA-KTB DEC 0>0.8[0] JAN 0>0.8[0] FEB 0>0.8[0] MAR 0>0.8[0] APR 0>0.9[0] MAY 0>0.8[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.8[0]
X4 CGA-KTN DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0]
X4 EDA-KTN DEC 0>0.2[0] JAN 0>0.2[0] FEB 0>0.2[0] MAR 0>0.2[0] APR 0>0.2[0] MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0]
X4 EDA-NKI DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
X4 ELV-JNU DEC 0>0.2[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>1.6[0] JUN 0>3[0] JUL 0>3[0] AUG 0>2[0]
X4 ELV-PEC MAY 0>0.6[0] AUG 0>0.3[0]
X4 EXI-JNU MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0]
X4 GST-JNU MAR 0.4>3[2] AUG 0>5[6]
X4 HNH-JNU DEC 0>3[0] JAN 0>3[0] FEB 0>3[0] MAR 0>4[0] APR 0>5[0] MAY 0>6[0] JUN 0>7[0] JUL 0>7[0] AUG 0>6[0]
X4 HNS-JNU DEC 0>3[0] JAN 0>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>3[0] MAY 0>8[0] JUN 0>8[0] JUL 0>8[0] AUG 0>7[0]
X4 HNS-SGY DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
X4 HYG-KTN DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0]
X4 JNU-KAE DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>2.0[0] JUN 0>2[0] JUL 0>2.0[0] AUG 0>2[0]
X4 JNU-PEC DEC 0>0.8[0] JAN 0>0.8[0] FEB 0>0.9[0] MAR 0>0.8[0] APR 0>0.9[0] MAY 0>1.6[0] JUN 0>3[0] JUL 0>3[0] AUG 0>2[0]
X4 JNU-SGY DEC 0>3[0] JAN 0>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>3[0] MAY 0>7[0] JUN 0>7[0] JUL 0>7[0] AUG 0>6[0]
X4 JNU-SIT DEC 0>1.9[0] JAN 0>1.9[0] FEB 0>2[0] MAR 0>2[0] APR 0>1.9[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0] AUG 0>3[0]
X4 JNU-TKE DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.2[0] JUN 0>1.5[0] JUL 0>1.5[0] AUG 0>1.3[0]
X4 JNU-YXY MAY 0>0.5[0.4] AUG 0>0.4[0]
X4 KAE-SIT DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
X4 KCC-KTN DEC 0>0.2[0] JAN 0>0.2[0] FEB 0>0.2[0] MAR 0>0.2[0] APR 0>0.2[0] MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0]
X4 KCC-WWP DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
X4 KLW-KTN DEC 0>0.8[0] JAN 0>0.8[0] FEB 0>0.8[0] MAR 0>0.8[0] APR 0>0.9[0] MAY 0>0.8[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.8[0]
X4 KLW-SIT DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>2.0[0] JUN 0>2[0] JUL 0>1.9[0] AUG 0>2[0]
X4 KPB-PPV DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
X4 KTB-KTN DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0]
X4 KTN-MTM DEC 0>1.6[0] JAN 0>1.6[0] FEB 0>1.7[0] MAR 0>1.7[0] APR 0>1.7[0] MAY 0>1.6[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0]
X4 NKI-WWP DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0]
ERJ170
Re: OAG Changes 11/17/2019:4O Adds CUN-MIA,LAX-MTY;AA Cuts JFK Again;DL Exits PAP;UA Exits ELM, LAX-PSC
Sun Nov 17, 2019 1:54 pm
enilria wrote:
FAQ
Wow! Impressive! United really picked up the AS slack. I would never have thought 3x to SFO on one carrier.
Aiming High and going far..
tphuang
Sun Nov 17, 2019 2:00 pm
Thanks enilria.
You are right. Looks like DL is completely out of PAP. I don't see any flights out of JFK either. MIA seems to just be AF. Things must be going really bad out there if they can't make it work from ATL. Really interesting that even out of NYC with its large expat population, it can't support even 2 flights a day in January.
MastaHanky
Sun Nov 17, 2019 2:12 pm
enilria wrote:
Airport closure?
The airport will be closed through September 22nd for runway reconstruction.
https://www.stgeorgeutah.com/news/archive/2019/11/16/jmr-cedar-city-regional-airport-runway-project-to-shut-down-commercial-flights-for-4-months-in-2020/#.XdFUbCVlCEc
sunking737
Sun Nov 17, 2019 2:22 pm
TOM changes to MLB in 2021 or 2022
"Don't believe it unless its parked on the ramp, or printed in the schedule...SUBJECT TO CHANGE"
I'm a SUNDUCK......Worked for RC & SY @ MSP
AWACSooner
:banghead: :bomb: :mad:
The screwing of OKC continues by WN.
usairways85
Sun Nov 17, 2019 2:26 pm
AA hacked PHL a bit too. Come on, .6 on PHL-DEN in Feb, give me a break.
jfklganyc
Sun Nov 17, 2019 2:53 pm
You have to wonder how much longer AA can hold out in NY?
Even LGA is seeing cuts.
If I was WN or B6 I would be calling AA about an NYC asset sale.
DL747400
Sun Nov 17, 2019 2:58 pm
Not surprising at all. From a revenue perspective, the majority of the Caribbean is completely garbage. Haiti is just higher on that list.
From First to Worst: The history of Airliners.net.
All posts reflect my opinions, not those of my employer or any other company.
Brickell305
Sun Nov 17, 2019 3:06 pm
Aren’t the AA cuts them now implementing the extension of the MAX grounding thru March?
HPAEAA
Does AA still have a deal in place to protect their JFK slots?
1.4mm and counting...
fanoftristars
Sun Nov 17, 2019 3:07 pm
AA did a real hack job on JFK flights!
"FLY DELTA JETS"
chepos
Sun Nov 17, 2019 3:10 pm
Yes, CX were extended through March 5, 2020.
Fly the Flag!!!!
Brickell305
Re PAP, DL leaving isn’t that surprising. AA (a much stronger airline there) has made major cuts. Dropping both JFK and FLL and even reducing MIA. B6 also has YoY cuts showing in this thread so something must be going on with that market.
BroadwayLimited
Sun Nov 17, 2019 3:13 pm
By my little calculations, this update shows AA down approximately 15 flights at JFK from a year ago, (not month ago, but year ago), and 12 down at LGA.
(This number takes into account the subtractions, plus a couple minor additions).
Last edited by BroadwayLimited on Sun Nov 17, 2019 3:21 pm, edited 1 time in total.
Signed up for Delta and Eastern Frequent Flyer Programs August 30, 1981.
chepos
Sun Nov 17, 2019 3:14 pm
Port Au Prince is a market that really only works from NYC and South Florida in the US. Add any type of instability, which Haiti is prone to and only cities with a large number of Haitian Americans can sustain service (NYC and MIA).
Fly the Flag!!!!
HVNandrew
Sun Nov 17, 2019 3:24 pm
With that, between ELM/BGM/ITH, AA and now UA will have fully consolidated at ITH. DL will be the only carrier left serving all three, and joined at ELM by only G4 (at BGM, DL has been the only carrier since both AA and UA left I believe last year).
BatonOps
Sun Nov 17, 2019 3:39 pm
HVNandrew wrote:
UA has tried ORD, EWR and IAD from ELM. I guess they couldn’t make any of them work.
ITH will benefit from the ELM reduction.
enilria
Sun Nov 17, 2019 3:51 pm
tphuang wrote:
Thanks enilria.
I have to think the issue is just not business traffic and that's what DL mostly cares about. It's not a redemption destination either, so they can't justify it by mollifying their elites with a place to go on vacation. It's nearly a pure ethnic market, although every time I'm in ATL the crowd in the boarding area was church groups going down for a mission. Not a high yield demo either.
Odd to announce such a thing so far in advance. Will it really happen then?
I get these are MAX cuts, but they really should be sticking them elsewhere at this point. It'll be basically a year of not flying these slots soon. Ridiculous.
Apparently there is something of a gentlemen's agreement between the Port Authority and the airlines that allows them to not utilize their slots in these types of situations, unrelated to the runway closure. Somebody needs to file a complaint with DOT and get that struck down.
727LOVER
Sun Nov 17, 2019 4:03 pm
Before the current terminal opened in 1994 I think, I remember when ITH had literally, this small bus terminal. Who would have thought, they would become the busiest of the three!
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
jetlanta
Sun Nov 17, 2019 4:06 pm
enilria wrote:
tphuang wrote:
Thanks enilria.
These decisions don't happen in a vacuum. Haiti is experiencing a serious political crisis.
https://www.nytimes.com/2019/10/20/worl ... lence.html
PHLspecial
Sun Nov 17, 2019 4:13 pm
I think AA in general struggles with DEN from Philly and JFK. Southwest and United got that route pretty locked down.
BatonOps
Sun Nov 17, 2019 4:16 pm
727LOVER wrote:
ITH is currently renovating the terminal. It should be done in a few weeks. Improvements include four jet bridges and a US Customs facility.
Bigant0408
Sun Nov 17, 2019 4:31 pm
I agree and don’t forget about Frontier dirt cheap fares as well on the route
The man who sleeps on the floor doesn’t fall out of bed
enilria
Sun Nov 17, 2019 4:49 pm
jetlanta wrote:
enilria wrote:
tphuang wrote:
Thanks enilria.
Agreed, but Haiti has been different varieties of bad for a really long time. I'm sure they that was merely the last straw. Is Labadee still getting cruises?
BatonOps wrote:
:o Hoping for Delhi and Seoul nonstop?
MARSHAL1
Sun Nov 17, 2019 4:59 pm
Neither UA nor WN serve JFK. AA doesn't fly DEN to any NYC airport.
Normally AA has 2 PHL-DEN while UA has 3 PHL-DEN and WN has 3 PHL-DEN. I wouldn't call 3 flights by any airline as having a route "pretty locked down".
usflyer msp
Sun Nov 17, 2019 5:08 pm
I think AA does ok with the local traffic but the other carriers have the advantage of far greater network connectivity at DEN than AA can offer at PHL.
Sightseer
Sun Nov 17, 2019 5:09 pm
Thanks Enilria!
ERJ170 wrote:
enilria wrote:
FAQ
Indeed. I'm also wondering if perhaps it's to dissuade DL from entering the market. One would think a Bay Area flight would be pretty high on their list from RDU at this point, especially with AS leaving.
jetmatt777
Sun Nov 17, 2019 5:12 pm
Youre correct that they dont serve JFK. But JFK is only 1 out of 3 NYC airports. UA has 8 and 7 flights to EWR and LGA respectively.
SFOtoORD
Sun Nov 17, 2019 5:14 pm
3x daily CDG-SFO for AF during summer is pretty impressive. Not many airlines flying TATL from the West Coast more than 2x daily. Perhaps maybe no A380 this summer?
F9LASDEN
Sun Nov 17, 2019 5:26 pm
F9 has a daily high-density A321 (230 seats) on the route as well, which, as mentioned by Bigant048 above, with their super cheap fares, likely doesn’t help either.
Spirit of the West...A Whole Different Animal...Low Fares Done Right
Prost
Sun Nov 17, 2019 5:37 pm
AA PHX-SEA only has 2 flights? That is prime Arizona travel time as us Seattleites are craving anything that resembles sunshine. I know it’s highly competitive, but you’d think they’d try harder, they have a large hub on one end after all.
9w748capt
Sun Nov 17, 2019 5:59 pm
Seriously - have UA's OKC-IAD and AA's OKC-DCA taken that much traffic away from WN? Pretty drastic cutbacks by WN lately.
Aliqiout
Sun Nov 17, 2019 6:11 pm
Probably pretty hard to compete against AS for SEA POS. Didn't AS just increase frequency on this recently?
babastud
Sun Nov 17, 2019 6:12 pm
Your correct it is impressive. The A380 is still scheduled for one daily while the other two flight are 777W. I believe the additional flight is 3x a week on the summer shoulder and then daily for a few months. I think some of this is picking up the slack from the XL flight that is no longer. I also believe the demand is just there for more seats beyond XL. So good options from SFO to Paris this coming summer.
Brickell305
Sun Nov 17, 2019 6:21 pm
enilria wrote:
tphuang wrote:
Thanks enilria.
But why? If they’ve already identified NYC as the go to place to cut flights while they’re fleet constrained, why should they arbitrarily switch those cuts to another hub?
flyjoe
Sun Nov 17, 2019 6:24 pm
You can understand why reductions continue with the impacts of the political and humanitarian situation. The pull out of the UN peace keeping force in October doesn't help with what little business traffic remains. A mission org I have traveled with to Haiti several times over the years has all but stopped scheduling trips over the next several months. An ongoing bad situation continues to get worse.
LAXdude1023
Sun Nov 17, 2019 6:29 pm
OS cancels MIA in favor of BOS. Interesting...
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
Cointrin330
Sun Nov 17, 2019 6:34 pm
What are you expecting? That AA puts a for sale sign out? And what assets would they sell exactly? In the next downturn, I still see AA buying up B6.
FlyPNS1
Sun Nov 17, 2019 6:42 pm
Well WN also flies OKC-DCA 1x daily. Just a few years ago, there were no flights on OKC-DCA....now there are two daily (1 AA and 1 WN). UA is also adding a 2nd flight on OKC-IAD in April.
jetmatt777
Sun Nov 17, 2019 6:44 pm
Plenty of capacity. Its a short term cut during a low travel demand month. Really not a big deal or some slight against OKC.
admanager
Sun Nov 17, 2019 6:46 pm
Paine continues to see its service being re-balanced after now 9 months of service. Last was AS dropping one LAX to add GEG. .
What will UA do with this slot? Add another Denver or get creative with something like ORD or IAH.
clrd4t8koff
Sun Nov 17, 2019 6:55 pm
Wow, BA continues to cut MIA into peak summer after trimming it for late fall '19 and into winter/spring '20! Looking at a random date (May 15th) there's only 3 flights on BA/AA. How can two large OW hubs see such little service? Seems OS isn't the only struggling on MIA-Europe.
Looking at the same date (May 15th) BA/AA have 5 FLIGHTS, one still an A380, between BOS-LHR and BOS isn't even a OW hub. I'm guessing BOS has definitely overtaken MIA as a larger local market to London.
MSPNWA
Sun Nov 17, 2019 6:57 pm
I clicked on the thread expecting to see AA's JFK-specific cuts. Instead there's system-wide MAX-related cuts. I should have known.
MIflyer12
Sun Nov 17, 2019 7:11 pm
Of course they do... and AA has more connectivity into PHL. This isn't UA hub to UA hub we're talking about, like IAH-DEN.
When we next get a thread 'When is AA going to start TPAC from PHL?' we can all have a good laugh. DEN is the 7th largest domestic O&D airport in the country.
Brickell305
Sun Nov 17, 2019 7:21 pm
1. Summer isn’t peak for LHR-MIA
2. AA is adding a second flight to replace the BA capacity. It just hasn’t been loaded yet.
3. AFAIK MIA-LHR is a larger local market. BOS likely sees that many flights due to connx at the LHR end and due to the fact that due to geography, O&D traffic between the two is less likely to connect via a third city. That is to say, LHR-MIA traffic has a few more logical connecting hubs (ATL, CLT, JFK, etc.) than BOS-LHR would have.
tphuang
Sun Nov 17, 2019 7:24 pm
In the next downturn, AA should worry about chapter 11.
B6 should call AA asap about those JFK slots. If B6 can offer 3 or 4 DCA slots to AA, I'm sure AA would trade a whole lot of JFK slots or some LGA slots for that. Too bad DOJ probably wouldn't allow AA to obtain more DCA slots.
Exactly. AA isn't exactly doing well right now. So in a battle where it's probably running lower margin against an airline with lower cost and have better system wide margin like AS, it's going to have to dial back.
enilria wrote:
tphuang wrote:
Thanks enilria.
But if that's the case, then there is no reason for them to run flights to places like MGA, SAP and GUA out of ATL. All these places are VFR + missionaries. Given how much more O&D there is out of South Florida, DL is always going to be relying more on connections to make these work.
B752OS
Sun Nov 17, 2019 7:31 pm
They were losing money on VIE-MIA. Maybe BOS, with its shorter length, will perform better for them.
BroadwayLimited
Sun Nov 17, 2019 7:41 pm
"AA JFK-LAS FEB 1.2>0[1.9]"
Is this a permanent cut, or a temporary/seasonal cut?
tphuang
Sun Nov 17, 2019 7:54 pm
This looks to be another MAX cut. But now that they've cut this down to 0 for a couple of months, it's hard to see how bringing it in March will result in anything other than extreme low performance.
Same with SAN, which hasn't run for close to a year. I'm really not sure how that can be anything but a disaster if they decide to resume it in March.
I see both SAN/LAS go the direction of JFK-SEA.
