thebigz
Weird cabin layout SAS A321LR
Fri Nov 22, 2019 12:50 pm
Danish insideflyer.dk https://insideflyer.dk/seat-map-sas-airbus-a321lr has published a seatmap for the new SAS A321LR that will be delivered next year and used for transatlantic flights between CPH-BOS.
But seriously, that is one weird layout in business with a 2+2 and 1+1 layout every other row.
Would it not be better to have 2+1 on all rows? With 7 rows it would mean one less seat in business but it would be a more logical layout I think.
Is there any other similar layouts out there?
keesje
Re: Weird cabin layout SAS A321LR
Fri Nov 22, 2019 12:55 pm
Jetblue Mint.
Someone83
Fri Nov 22, 2019 12:56 pm
It is the same layout and the same seats as both AerLingus and TAP has
twicearound
Fri Nov 22, 2019 12:57 pm
That's a pretty standard layout for a narrowbody. TAP, BA, JetBlue, FlyDubai, Aer Lingus all use that layout and similar seat type on their A321, 757, and 737.
737max8
Fri Nov 22, 2019 12:58 pm
I feel like you answered your own question. If this layout fits 1 more seat then it is better. Revenue $$$
The thoughts and opinions expressed in my comments do not represent that of any airline or affiliate.
Flown on: 717 733 734 735 736 737 738 739 7M8 744 744ER 752 753 762 763 772 773ER 788 789 A220 A319/20/21 A332 A333 A339 A343 A346 A359 A388
vhqpa
Fri Nov 22, 2019 1:00 pm
It's a great way to cater to both pairs and solo travelers
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
Slash787
Fri Nov 22, 2019 1:11 pm
Even Flydubai has the same layout for its new business class.
AB330
Fri Nov 22, 2019 1:12 pm
BA Medium-haul A321 have a 1-2 or 2-1 layout depending which row the seat is.
https://www.britishairways.com/en-gb/in ... atmap.html
VSMUT
Fri Nov 22, 2019 1:47 pm
AFAIK, Check-in.dk had an article on it. SAS is not adopting the TAP and Aer Lingus layout. They are going for 3 seats in each row, so 2+1 then 1+2 then 2+1 etc. I don't know if there is perhaps a toilet or galley on the left side, leading to this seat map.
keesje
Fri Nov 22, 2019 1:52 pm
I always wondered, is 2-2-2-2-2 angled, like AA and Delta not more efficient than 1-2-1-2-1? .
VSMUT
Fri Nov 22, 2019 2:08 pm
That is how La Compagnie and British Airways equipped their A321LR and A318. IMHO, if they are going to have 2+2 at all, they might as well go all in.
bx737
Fri Nov 22, 2019 2:18 pm
The Aer Lingus/TAP etc configuration is space saving with lie flat seats. If you remove the seats and lie passengers down, the person on their own has the feet of those behind him/her beside their head. Also this way, more seats have direct aisle access, for the 16 business class seats, 10 have direct aisle access as opposed to 8 with a 2+2 layout.
Someone83
That is not what they seat map shows, and would only give 21 seats, and not 22 as SAS has
fromheretohere9
Fri Nov 22, 2019 2:45 pm
When did British Airways get a A321LR ??
ikolkyo
Fri Nov 22, 2019 2:50 pm
[threeid][/threeid]
He means it respectively. A321LR applies to LaCompagnie and A318 to BA....
upintheair2019
Fri Nov 22, 2019 3:09 pm
flydubai on their 737 MAXs (2-1-2-1). They call the single seat "Throne Seat".
Miguel1982
Fri Nov 22, 2019 3:15 pm
I guess that doing seven rows of 2-2 > 1-1 > 2-2 and so on gets you one extra seat when compared to TAP and other's 2-1 > 1-2 > 2-1. That would match SAS's expected 22 seats.
EMB170
Fri Nov 22, 2019 3:20 pm
Plus they can charge extra for the single seats, like B6 does.
IND ORD ATL MCO PIT EWR BUF CVG DEN RNO JFK DTW BOS BDL BWI IAD RDU CLT MYR CHS TPA CID MSP STL MSY DFW IAH AUS SLC LAS
MAH4546
Fri Nov 22, 2019 3:59 pm
They can, but they don’t. And JetBlue absolutely does not.
a.
CRJ900
Fri Nov 22, 2019 4:36 pm
So, nothing revolutionary about their biz class, then. But their SAS Plus will be 2+2 seating - that must be a first on a narrowbody. The article mentions that this is much better than the 2+3+2 on the A333/A343 and 2+4+2 on the A359.
Total seat count on SAS A321LR is 159 seats but two biz class seats will be blocked as crew rest, so 157 seats for sale.
Come, fly the prevailing winds with me
readytotaxi
Fri Nov 22, 2019 4:46 pm
keesje wrote:
Jetblue Mint.
Would BA ever offer that as a Club Europe standard? NO ! :hissyfit:
Growing older, but not up.
BrianDromey
Fri Nov 22, 2019 5:07 pm
AFAIK that layout is only for US transcontinental flights on premium heavy routes, it is far from system wide. B6 offer no premium cabin at all on the majority of their flight and no equivalent to CE in terms of lounges or catering on these flights either. You are just not comparing like with like. BA do offer a very similar layout on flights of similar length, like Amman, Beirut, Cairo, Moscow and Tel Aviv.
EI offer this exact layout on certain A321LR operated LHR-DUB and LHR-SNN, if those routes are of any use to you.
bluefltspecial
Fri Nov 22, 2019 6:15 pm
This statement does not make any sense.
I am unaware if the aircraft can effectively operate more than 8 hours in one direction even in that configuration, which is I think around the time where EASA will require a 3rd pilot.
When you need a third pilot you would only need to block out one seat for rest purposes, not two. I'm sure we're all aware that as of now, we still need two pilots in the cockpit for operations, the third would be on the rest break.
For example, OSL/CPH/ARN-JFK would be about 7 hours, the return flight Eastbound is only about 6.
Even if you start to push the aircraft to +4000 mile routes like ARN-IAD, OSL-ORD, or CPH-PIT you're still looking at similar flight times, nothing that requires a 3rd pilot.
Perhaps someone can enlighten us as to when SAS pilot contracts require a 3rd pilot at a certain point?
Save a horse, ride a Fly-boy....
SASViking
Fri Nov 22, 2019 6:52 pm
Not entirely true. Currently the CPH-EWR flights SAS currently operate are scheduled for 8h30m outbound and 7h40m inbound at the shortest of flights. The shortest LH route SAS have is CPH-BOS, on which the A321LR will operate. They are scheduled to 8h25m outbound and 7h40 inbound.
Types flown: A319, A320, A32N, A321, A332, A333, A343, AT43, AT75, AT76, B717, B732, B735, B736, B737, B738, B752, B753, CRJ9, DC10, DH4D, DHC3, E135, E145, E175, E190, E195, F100, MD11, MD81, MD82, MD87, RJ1H
VSMUT
Sat Nov 23, 2019 2:19 am
It is between 11 and 13 hours allowable flight duty time under EASA, depending on time of departure. Absolutely no need for relief crew unless they start sending the same crew back and forth on the same day.
RawSushi
Sat Nov 23, 2019 3:25 am
This is not weird at all. It's the most efficient way to support lie-flat seats on narrow-bodies. The staggered layout allows the passenger behind to slot his/her legs in between the two seats in front when lying flat, thereby allowing for shorter seat pitch and therefore more rows to be fitted. Singapore Airlines will be using this layout too.
dampfnudel
Sat Nov 23, 2019 9:16 am
And occasionally pairs who would rather be solo. :D
A313 332 343 B703 712 722 732 73G 738 739 741 742 744 752 762 76E 764 772 AT5 CR9 D10 DHH DHT F27 GRM L10 M83 TU5
MoKa777
Sat Nov 23, 2019 10:15 am
I've always wondered, with the paired seats in a staggered config like this, how easy is it to get out from the window seat if the person next to you has their seat fully flat?
Is it easier or more difficult when you compare it to getting out of the window seat in a similar situation with a conventional 2-2 full-flat config? By conventional I mean the previous QR 777 J seat, LATAM 2-2-2 J, BA A318 J, etc.
And, while I'm on this, how does the Diamond J seat (pictured above by Keesje) compare in this regard?
Never be proud. Always be grateful.
USAirKid
Sat Nov 23, 2019 10:22 am
[code][/code]AFAIK, what makes it look weird on the seat map is the solo seat is shown as being a window seat, with the aisle seat behind it being shown as having a full bit of leg room.
Its a normal seat layout with a poor/weird seat map.
kanye
Sat Nov 23, 2019 12:52 pm
I'm sure the two seats for crew rest are for the cabin crew to sit down a bit during the long day. Their normal seats in the galley are as comfortable as piece of Wood.
dtremit
Sat Nov 23, 2019 3:24 pm
Indeed -- this is nice to see, and I hope it sets a trend for narrowbody Y+ service.
jfk777
Sat Nov 23, 2019 3:29 pm
The SAS A321neo LR has 22 J and 12 Y+ so it's going to be premium with very low density. While a very different layout than Aer Lingus and TAP which have fewer J class seats, SAS is doing what works for them. Interesting configuration, I hope other airlines are as adventurous as SAS with their A321neo LR's.
reidar76
Sat Nov 23, 2019 3:48 pm
The question is if this 2+2 in SAS Plus is to good, and not enough differentiated from SAS Business class. We are not talking about a 12 hour flight, but more like 6 to 8 hours. Some people might go for SAS Plus instead of SAS Business.
They could have gone for 2+3 in SAS Plus. A321 is more than wide enough for five abreast premium economy. South African has some A319 with five abreast premium seating.
DominoxX
Sat Nov 23, 2019 4:13 pm
the single seats cost more?
Thank u, next.
SASViking
Sat Nov 23, 2019 5:05 pm
No
CobaltScar
Sat Nov 23, 2019 11:54 pm
I will miss the widebody on that route. oh well.
Is there dedicated cabin crew rest seats on that plane or do they have to hang out in the galleys all flight?
rbavfan
Sun Nov 24, 2019 12:16 am
Actually BA uses the 1-2 to 2-1 alternating layout.
StudiodeKadent
Sun Nov 24, 2019 3:05 am
I agree with you. A standard premium economy product can fit 5-abreast in both a 737 and an A320 fuselage (and 4 abreast in an A220 fuselage).
I wonder why they didn't go for it. Either there must have been a net density penalty for the 'kink' in the aisle, or the 'kink' in the aisle in the middle of the plane must have greatly increased load/unload times, or perhaps the 5-abreast PE weighed a lot more than going 4-abreast and this went past some sort of limit (although I'm not sure how much of an impact this could really have).
aemoreira1981
Sun Nov 24, 2019 3:11 am
I can't help but imagine that B6 might try this layout on its A321LR, but with only 15 J (International), and 12 international-style W, and 2 rows of Y+ aft of W plus the exit row by R3/L3, and then Y at 32"/18". (I see B6 maintaining one A321neo Cabin Flex door layout fleet-wide). I actually love this layout by SK to replicate the wide-body hard product into a narrow-body.
fessor
Sun Nov 24, 2019 9:44 am
Think its a good layout for this plane still lot of premium seats but at the same time not to premium seats that would make the planes useful out of secondary airports.
I hope the 321lr will be a succes and SK will order more or maybe 321XLR
CobaltScar
Sun Nov 24, 2019 2:12 pm
No, I don't think they will use this layout for their trans atlantic planes. There is already a better layout.
twicearound
Mon Dec 02, 2019 12:14 pm
It's the exact same seat and layout. Don't just rely on seat maps. Please look at photos. I've been in both the JB and BA cabin. The BA cabin is staggered because of the galley config. otherwise, identical seat, identical space, identical cabin.
EI321
Mon Dec 02, 2019 2:03 pm
Aer Lingus also uses this same 2-2 / 1-1 business layout on the 757 since 2014.
