Aviation737 wrote:Wow some people are really salty about the 737 and Boeing
Yeah I don't get it. Both the 737 and A320 are great planes. I'm not sure why both can't be celebrated.
GalaxyFlyer wrote:First, for umpteenth time, it’s an amended TC, nothing is grandfathered. Second, the 707 is a different type certificate from the 727 or 737. Amateurs may be otherwise, but they’re different.
GF
rbavfan wrote:LGeneReese wrote:airplanedriver6 wrote:Note that the registration number is listed on the United Fleet Website as the first UA 737-10 aircraft, presumably after certification is complete. I would also suspect the aft emergency exit will be swapped with a fixed plug (with a window) like on UA's 737-900ER and 737-9.
Indeed this aircraft will eventually become UA Ship 7751... still no idea why starting at 51 rather than 01..![]()
Also IIRC the emergency exit is required to remain active.
Because boing list them by manufacture number. They don't start each model at an 01 number.
CALTECH wrote:It has MCAS....
Pudelhund wrote:You are in luck because the -10 doesn’t have MCAS.
flipdewaf wrote:GalaxyFlyer wrote:First, for umpteenth time, it’s an amended TC, nothing is grandfathered. Second, the 707 is a different type certificate from the 727 or 737. Amateurs may be otherwise, but they’re different.
GF
Semantics! It’s launched as if it’s a new plane but gets to use some rules from the 60’s and certificated to standards not acceptable if it were designed today. Call it whatever you want.
Fred
DL747400 wrote:I find it more than a little bit surprising that Boeing placed "737-MAX" titles on the -10s winglet, though it does appear that they may be subtly trying to downplay that through the use of pale gray paint. I wonder how many of the carriers who have ordered the 737-10 MAX are going to specifically ask that no MAX titles be applied to their aircraft?
rbavfan wrote:JetBuddy wrote:This should be a really great transcontinental aircraft. Plenty of space for various configurations. Enough range for any coast to coast route. I think that's where this aircraft will shine.
I don't think we'll see it used much on sub 1000nm routes. The reason is that the long fuselage makes the boarding / deboarding process longer. Which matters less if it's flying longer routes.
Wish you a long and prosperous future, Boeing 737-10.
No it does not. At MDW, DAL if a plane takes longer to load no matter the distance it will cut the number of flights/gate/day.
JetBuddy wrote:rbavfan wrote:JetBuddy wrote:This should be a really great transcontinental aircraft. Plenty of space for various configurations. Enough range for any coast to coast route. I think that's where this aircraft will shine.
You're missing the point.
If you're flying 8 legs a day, and boarding/ deboarding time takes X amount of minutes, the aircraft will spend more of it's day boarding/ deboarding than if the same aircraft flies 3-4 legs per day.
lightsaber wrote:DenverTed wrote:It's a two engine 720.
Funny, but true. What does it say about me that I understood that statement fully.
Lightsaber
rbavfan wrote:flyingclrs727 wrote:flee wrote:The 737-9 is already a slow seller - how many extra new sales will the new gear bring to justify the additional testing/certification costs for a revised undercarriage? Boeing will probably ask customers to order the 737-10 instead.
Southwest is a big customer. The 737-10 MAX is too large to work for WN at MDW due to the short runways. A 737-9 with taller landing gear could allow better runway performance, a higher takeoff weight, and range for the 737-9. With 200 seats it would maximize the number of passengers 4 flight attendants could serve. It could also allow 200 seats between the west coast and Hawaii.
Southwest would need the new landing gear on the -8 to allow flights from midway to any airport. Currently the -800/8 has range limits due to the short runways.
DeltaConnection wrote:Yuck.
Bring back the 757 please.
Revelation wrote:DL747400 wrote:I find it more than a little bit surprising that Boeing placed "737-MAX" titles on the -10s winglet, though it does appear that they may be subtly trying to downplay that through the use of pale gray paint. I wonder how many of the carriers who have ordered the 737-10 MAX are going to specifically ask that no MAX titles be applied to their aircraft?
As already said on this thread, the aircraft's use of color is consistent with the family wide livery update, see earlier links.
Within the livery they could have chosen to use "737" instead of "737 MAX" but clearly they left it in not just on the winglet but also on the nose.
I don't think people should read too much in to this one way or the other.
This event was for the people who worked on the -10, this was not a media event.
I'm confident we'll get a more definitive statement at some point in the future.
And of course airline customers can paint whatever they want onto their aircraft.
reltney wrote:DeltaConnection wrote:Yuck.
Yes indeed. 757 is no doubt a better plane. Ironically, they have the same fuselage . Will Boeing crawl out of the hole and see the light ?
flyboy80 wrote:So the -10 sits up higher on the main gear than the other MAX due to levered gear, correct? I recall reading the MAX fwd landing gear minimum height is a few inches greater than the NG. Are there any modifications to the slide sizes on the main cabin doors being this plane is higher off the ground? Also, engine thrust is the same at the -9MAX?
flipdewaf wrote:flyboy80 wrote:So the -10 sits up higher on the main gear than the other MAX due to levered gear, correct? I recall reading the MAX fwd landing gear minimum height is a few inches greater than the NG. Are there any modifications to the slide sizes on the main cabin doors being this plane is higher off the ground? Also, engine thrust is the same at the -9MAX?
The -10 sits the same height above the ground on the tarmac and only raises mid rotation. If you google “max 10 gear” you’ll find some videos no doubt.
Fred
Oykie wrote:lightsaber wrote:DenverTed wrote:It's a two engine 720.
Lightsaber
It says experienced
JetBuddy wrote:The gear fits into the same wheel wells as the other 737s, so it's an interesting bit of engineering.
I don't believe there are any mods to the slides, since it sits the same height as the others.
And thrust rating is the same as the -9.
DL747400 wrote:I wonder how many of the carriers who have ordered the 737-10 MAX are going to specifically ask that no MAX titles be applied to their aircraft?
iamlucky13 wrote:DL747400 wrote:I wonder how many of the carriers who have ordered the 737-10 MAX are going to specifically ask that no MAX titles be applied to their aircraft?
From a brief check of the database, it doesn't look like many have MAX written on the aircraft anyways, or when they do, it is small and subtle (see the Norwegian example).
Fred
FluidFlow wrote:flipdewaf wrote:flyboy80 wrote:So the -10 sits up higher on the main gear than the other MAX due to levered gear, correct? I recall reading the MAX fwd landing gear minimum height is a few inches greater than the NG. Are there any modifications to the slide sizes on the main cabin doors being this plane is higher off the ground? Also, engine thrust is the same at the -9MAX?
Fred
What if it does not raise, or only on one side?
Relative to other problems, the gears tend to fail quiet often (and this is model or manufacturer independent). From not retracting to collapsing, there is a lot that can go wrong. On top of that they get worked hard and hard landings are not uncommon.
Will the MAX-10 gears have to be checked more often, especially after harder landings?
flipdewaf wrote:FluidFlow wrote:flipdewaf wrote:The -10 sits the same height above the ground on the tarmac and only raises mid rotation. If you google “max 10 gear” you’ll find some videos no doubt.
Fred
My understanding is that its a passive system, effectively an airbag inflated to a given pressure driving a secondary oleo, When the wing increase AoA and so the lift increases during rotation the secondary oleo in unloaded and begins to extend and and this process continues till the oleo is fully extended (I cant remember the max (no pun intended) extension. The only mechanical parts are the additional moving parts when the gear is retracted and extended to make sure the additional oleo is capable of fitting in the the wheel wells. The critical piece of the design is pretty fool proof it seems.
As a piece of problem solving I like it a lot because it manages to deal with a very complex set of constraints without a lot of complexity in the risky areas, the guys that worked on that were clearly working at a level of whole aircraft rather than landing gear level to get the dynamics.
Fred
Fred
Seems a really smart solution. So as long as the oleo stays intact nothing can happen as it is a passive system and a broken oleo should be noticed before take off as it would leak a lot of fluid on the tarmac.
Sooner787 wrote:I just checked Seattle Times website & didn't see story of the rollout posted yet.
Makes me wonder if the 777X first flight will occur without any prior public notice?
scbriml wrote:Airliners.net, don't you just love it? Two opposing "factual" statement, neither offering any evidence to support their claim.CALTECH wrote:It has MCAS....Pudelhund wrote:You are in luck because the -10 doesn’t have MCAS.
So which is it?
Elementalism wrote:The -100 is nearly 50 feet shorter compared to the MAX10. Think the engineers on the -100 project would had ever imagined this model growing to that size?
Is there an option for a door where there arent any windows forward of the engines? Be nice to be able to load this one like the 757.
