rbavfan
Re: Boeing 737 Max 10 Rollout
Sat Nov 23, 2019 8:03 am
DenverTed wrote:
It's a two engine 720.
Actually the 737-9 is closer to the 720 series
720:
136’ 2” long, Total thrust per side 24000 to 34000 lb. st. depending on model, 3650nm range, 149 pass.
737-9:
138’ 4” long, Total thrust per side up to 29317 lb. st., 3550nm range.
737-10:
143’ 8” long, Total thrust per side up to 29317 lb. st., 3300nm range.
Put the same seats on the -9 as the 720 had & the 9 could match the range of the 720 as well.
rbavfan
Sat Nov 23, 2019 8:06 am
ShamrockBoi330 wrote:
So am I right in remembering this one does not need MCAS due to higher landing gear, so engines not moved forward similar to 7/8/9?
No engines in same places. Landing gear allows for greater rotation angle on T-O for substantial reduction in T-O to 50 ft. specs vs old gear.
rbavfan
Sat Nov 23, 2019 8:10 am
Stitch wrote:
hiflyeras wrote:
What's with all the missing windows around where the cabin divider would be? Mid-cabin lav?
Most likely.
AC/heat ducting goes through that area.
flyingclrs727
Sat Nov 23, 2019 8:16 am
flee wrote:
flyingclrs727 wrote:
TTailedTiger wrote:
Will this be likely to take away sales from the -9? I'm guessing this will have much better runway performance with the enhanced landing gear.
I wouldn't be surprised if the new landing gear were fitted to a 737-9. If the 737-9 could fly from MDW with a full load of 200 passengers and cargo to any commercial airport in the US with improved field performance due to the MAX 10 landing gear, it would be great for WN.
The 737-9 is already a slow seller - how many extra new sales will the new gear bring to justify the additional testing/certification costs for a revised undercarriage? Boeing will probably ask customers to order the 737-10 instead.
Southwest is a big customer. The 737-10 MAX is too large to work for WN at MDW due to the short runways. A 737-9 with taller landing gear could allow better runway performance, a higher takeoff weight, and range for the 737-9. With 200 seats it would maximize the number of passengers 4 flight attendants could serve. It could also allow 200 seats between the west coast and Hawaii.
rbavfan
Sat Nov 23, 2019 8:34 am
Southwest would need the new landing gear on the -8 to allow flights from midway to any airport. Currently the -800/8 has range limits due to the short runways.
flyingclrs727
Sat Nov 23, 2019 8:57 am
But what about the 737-8 MAX with the short field.performance package?
dampfnudel
Sat Nov 23, 2019 9:10 am
Oykie wrote:
lightsaber wrote:
:rotfl:
Funny, but true. What does it say about me that I understood that statement fully.
Lightsaber
It says experienced ;-)
Which sounds better than the other word. ;)
A313 332 343 B703 712 722 732 73G 738 739 741 742 744 752 762 76E 764 772 AT5 CR9 D10 DHH DHT F27 GRM L10 M83 TU5
MileHFL400
Sat Nov 23, 2019 9:29 am
Wasn’t there tall of Boeing launching a -9 ER?
Thanks and best Regards
AA
PANAMsterdam
Sat Nov 23, 2019 9:55 am
See kids, this is what happens if you eat your vegetables and drink your glass of milk every day! :weightlifter:
Every country has an airline. The world has Pan Am.
KliptWings
Sat Nov 23, 2019 10:16 am
Is the door aft of the wing identical to the 757 door in the same position? Ie hinged on the bottom sill?
flyingphil
Sat Nov 23, 2019 11:15 am
Didn’t the MAX10 fail its evacuation test? Or this that another a.net rumour?
Also makes me wonder why all the 737MAX’s aren't fitted with the new extendable main landing gear?
LGeneReese
Sat Nov 23, 2019 3:42 pm
airplanedriver6 wrote:
Note that the registration number is listed on the United Fleet Website as the first UA 737-10 aircraft, presumably after certification is complete. I would also suspect the aft emergency exit will be swapped with a fixed plug (with a window) like on UA's 737-900ER and 737-9.
Indeed this aircraft will eventually become UA Ship 7751... still no idea why starting at 51 rather than 01.. :scratchchin:
Also IIRC the emergency exit is required to remain active.
Revelation
Sat Nov 23, 2019 4:08 pm
Not sure why this thought would pop up. Clearly -8 and -9 are already certified, it'd be costly to do the certification work to add the new gear. Also gear would cost more to produce and would add an additional maintenance burden for operators. -7 and -8 seem fine without it, -9 will probably die off with regard to orders because -10 will work better in most people's fleets. I suppose if someone wants a -9 with better field performance they could do the work to certify the gear, but that customer would have to be making a big order to justify it. As above, the only one that seems big enough to justify that would be WN, but it seems to me Boeing won't even think about such a thing till all the MAXes are back in the air.
DenverTed
Sat Nov 23, 2019 4:11 pm
720:
737-9:
737-10:
Your right, the -9 is a 720, the -10 is the 707. And the -8 is the 727. There's the rebrand, ala the MD-95 is a 717.
Dano1977
Sat Nov 23, 2019 4:20 pm
It looks like a tail strike waiting to happen.
The average EU official - he has the organising ability of the Italians, the flexibility of the Germans and the modesty of the French. And that's topped up by the imagination of the Belgians, the generosity of the Dutch.
Revelation
Time to update the family photo (707, 717, 727, 737, 747, 757, 767, 777) ?
Ref: https://twitter.com/3topaviation/status ... 2427589632
Nice to see great-granddad B-47 off to the right of the photo!
NeBaNi
Sat Nov 23, 2019 4:21 pm
Looks great! I always thought the shorter 737s (-100, -500, -600) looked squat, but the -MAX10 really makes the 737 look all grown up!
DL747400
Sat Nov 23, 2019 4:53 pm
Just another -MAX model with MCAS. Assuming they ever get this plane back in service, I will avoid this one just like all other -MAX with MCAS models.
Just hoping and that DELTA never orders these monstrosities. There could very well be a significant competitive advantage to quietly getting the word out that DELTA is a MAX-free airline.
Airbus narrowbodies are my friend.
From First to Worst: The history of Airliners.net.
All posts reflect my opinions, not those of my employer or any other company.
JetBuddy
Sat Nov 23, 2019 5:16 pm
This should be a really great transcontinental aircraft. Plenty of space for various configurations. Enough range for any coast to coast route. I think that's where this aircraft will shine.
I don't think we'll see it used much on sub 1000nm routes. The reason is that the long fuselage makes the boarding / deboarding process longer. Which matters less if it's flying longer routes.
Wish you a long and prosperous future, Boeing 737-10.
don0245
Sat Nov 23, 2019 5:21 pm
You got it!!
kiowa
Sat Nov 23, 2019 5:23 pm
It's not a bad "looking" aircraft but I am sure it will be as uncomfortable as the airlines can make an aircraft. A clean slate aircraft from Boeing would have been much prefered to a stretch of a 50 year old design. An updated 757 would have been a better idea.
Revelation
Sat Nov 23, 2019 5:25 pm
You are showing no respect for karma. There could be a significant competitive edge flying a plane that does not have the excess range and weight and being purchased when the vendor is motivated to sell cheap to get a marquee customer, pretty much the same reason BA just did a LOI for 200 MAXes. You may very well find yourself in the last row of a DL 787-10 some day rueing this day.
Revelation
Sat Nov 23, 2019 5:28 pm
don0245 wrote:
You got it!!
Pretty much the same thing I thought when I saw the original 737-900-not-ER.
I did a long double take while my brain tried to sort out what it was seeing.
DL747400
Sat Nov 23, 2019 7:54 pm
OK, but let's also look at the flip side: There could be a significant competitive advantage (and possibly even a revenue premium?) to operating roomier aircraft which customers prefer. Wider cabin, wider aisles and greater cabin height all contribute to the perception (both a real and perceived) of a more spacious cabin.
Yes please! I love the 787 and would bounce off the wall with glee if DL were to acquire them. While I prefer Airbus narrowbodies, my preference flips to Boeing for widebodies.
ikramerica
Sat Nov 23, 2019 7:59 pm
DenverTed wrote:
720:
737-9:
737-10:
The 738 was designed specifically to match the retiring 722A specs.
While the 757 was the “727 replacement” in Boeing’s portfolio, the 757/767 was actually meant to replace the 707 and DC8 in airline fleets. Airlines took on the 757 alongside the 722 for added capacity and the economics were superior, but it wasn’t cost effective to retire young 727s.
Stitch
Sat Nov 23, 2019 10:05 pm
I believe the ducting runs a bit farther back - where there is the blank then a window and then another blank.
The larger block of continuous blanks should be the left-hand lavatory located just aft of First Class - if you look at a UA 737-900ER, for example, that has the same lavatory configuration, there is the same blanking of windows at that location on the left side.
Ruscoe
Sat Nov 23, 2019 11:04 pm
Changes to 737-10 are more than MLG and length.
Some of the others are:
Mid exit door 4" wider
MTOW ``92,000kg
Changes to flaps
Changes to Centre of Gravity to prevent "tail tip"
Autoland Changes
Changes to body configuration to reduce risk of tail strike
Refer www.737.org.uk
Ruscoe
ODwyerPW
Sat Nov 23, 2019 11:25 pm
You answered your own question here:
flyingphil wrote:
new extendable main landing gear.
it's new. maybe it will find it's way to special MAX8 ShortField and MAX9ER versions..
learning never stops.
rbavfan
Sat Nov 23, 2019 11:31 pm
If it was effective enough WN would have purchased it for MDW among a couple others.
rbavfan
Sat Nov 23, 2019 11:35 pm
Because boing list them by manufacture number. They don't start each model at an 01 number.
rbavfan
Sat Nov 23, 2019 11:40 pm
No it does not. At MDW, DAL if a plane takes longer to load no matter the distance it will cut the number of flights/gate/day.
rbavfan
Sun Nov 24, 2019 12:05 am
ikramerica wrote:
DenverTed wrote:
720:
737-9:
737-10:
Look back at adds and all the Boeing docs the 757 was designed to replace the 727-200ADV while allowing for extra seats. Dig into any Aviation week magazine in 1797 to 1983 for Boeing advo nearly every issue. The 767 was not marked directly as a 707/DC8 replacement as it was more for replacement of 1011/DC10's domestically on routes they were to large for as the markets changed after deregulation. It was not till TWA started ETOPS to the EU that the 767 became a 707/DC8 replacement. Both 757/767 were also designed to operate out of LGA & DCA airports.
rbavfan
Sun Nov 24, 2019 12:08 am
On those models with mid lavatory they just use metal windows plugs. Not the same as no window frames cut into the fuselage. The plugs have to be checked the same as if windows were installed. Increasing maintenance cost.
rbavfan
Sun Nov 24, 2019 12:11 am
Because Boeing list them by manufacture number. They don't start each model at an 01 number.
rbavfan
Sun Nov 24, 2019 12:13 am
MTOW ``92,000kg
Changes to flaps
Autoland Changes
Refer http://www.737.org.uk
Ruscoe
your link cannot be found.
TheWorm123
Sun Nov 24, 2019 12:17 am
MTOW ``92,000kg
Changes to flaps
Autoland Changes
Ruscoe
I’m not the poster you quoted but try http://www.b737.org.uk/
B752 B753 A332 A321 B738
Pudelhund
Sun Nov 24, 2019 12:21 am
You are in luck because the -10 doesn’t have MCAS.
flyboy80
Does anyone know how the -10 wing size ratio compares with the 757-300? I would think the 757 still has "more wing" relative to its size, but I may be wrong.
EWRamp
Sun Nov 24, 2019 12:25 am
230 pax in a single aisle a/c sounds like a enplaning and deplaning nightmare. Just as awful as being seated in the last row of a 753. It is a beauty tho.
airlineworker
Sun Nov 24, 2019 12:43 am
We are talking about a six inch wider cabin, not noticeable to most passengers.
With all the time Boeing is spending on the MAX, it should be the safest plane in the sky. Some might say they would never fly the Max, but when the dust settles, passengers will not give it a second thought. Over the years and the many flights I have taken, never have I heard a passenger ask what type of airliner they were boarding.
9Patch
Sun Nov 24, 2019 1:01 am
In 1985 I was on a SAS DC-10 flight from CPH to ANC. We were all sitting in our seats waiting to take off when it was announced there would be a delay to fix a mechanical issue. We deplaned for a couple of hours and reboarded.
While waiting to take off a flight attendant was talking to the passengers seated near an exit. Someone brought up the previous DC-10 crashes. The FA said not to worry, it all had been fixed and the plane was safe. I don't recall being the least bit worried and none of the other passengers who overheard the conversation seemed to be either. We just wanted to get going.
Antaras
Sun Nov 24, 2019 1:10 am
So didn't you try the densest A321neo on the world?
I was on Vietjet's A321NX which was config-ed as Y240 on a ~6hrs route from SGN to ICN and it seems fine for me :D.
If you disagree with my statement, assume that it was just a joke :duck:
skipness1E
Sun Nov 24, 2019 1:13 am
1985 was six years after the last major DC10 crash. The Max may not be so lucky.
The DeathCruiser Mk10 is perhaps not a good analogy
77H
Sun Nov 24, 2019 2:07 am
Been in the back of ‘lac (753) plenty of times. It’s not thaaaaat bad. Patience is a virtue.
77H
foxtrotbravo21
Sun Nov 24, 2019 2:20 am
There were very likely be come changes for airlines who have ordered the 737-8 Max, and 737-9 Max with MCAS to switched to this newest 737-10.
ojjunior
Sun Nov 24, 2019 3:10 am
See kids, this is what happens when you don't study enough to get rich and to have your own biz jet.
You will get stuck in a single aisle modern crampliner with 200+ other poor souls for the rest of your life sharing 3 or 4 toilets.
KFLLCFII
Sun Nov 24, 2019 3:38 am
737-100 versus 737-10
(Source: Boeing ACAPs)
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
gunsontheroof
Sun Nov 24, 2019 4:19 am
Looks good, but I'm kind of surprised that Boeing is sticking with the MAX branding. It didn't seem too far-fetched that they might quietly phase that out with the introduction of a new version, but here we are.
Picked a hell of a week to quit sniffing glue.
Aviation737
Sun Nov 24, 2019 5:22 am
Wow some people are really salty about the 737 and Boeing
RickNRoll
Sun Nov 24, 2019 5:23 am
Landing gear is the same height. Engines are fitted exactly the same.
Users browsing this forum: abrelosojos, AECM, Anansaudiajet, B6WNQX, Baidu [Spider], Boeing74741R, bpatus297, Chasensfo, Clipper136, D328, darloscott, ERJ170, Fiend, Google Adsense [Bot], Ishrion, jameijeirasc, jcwr56, jetset, jfk777, KLMatSJC, RJMAZ, Tkt96, VS4ever, withak and 219 guests
