enilria
OAG Changes 11/24/2019:;NK Exits KIN-MCO;AS Exits DUT?;TP Adds BOS-PDL;UA Adds DEN-SLN
Sun Nov 24, 2019 12:47 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
8V AET-FAI DEC 0.7>0.5[0.6] JAN 0.7>0.5[0.7]
8V AET-SVS DEC 0>0.2[0] JAN 0>0.2[0]
8V FAI-SVS DEC 0>0.2[0] JAN 0>0.2[0]
AA ABQ-ORD MAR 2>3[2] APR 2>3[2] MAY 2>3[2.0]
AA AUS-PHL APR 2>3[2] MAY 2>3[2.0]
AA AVL-DFW MAR 1.0>1.9[0] APR 1.0>2[0] MAY 1.0>2[0.9] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>1.6[1.0]
AA CLT-CRW JUN 4>5[5] JUL 4>5[5]
AA CLT-PUJ MAY 2>1.2[3]
AA CUU-DFW JUN 3>2[3] JUL 3>2[3] AUG 3>2[3]
AA DCA-RSW MAY 1.0>1.3[1.0]
AA DFW-OGG MAY 2>1.2[1.5]
**AA DSM-MIA JUN 0>0.3[0] JUL 0>0.3[0]
AA FLL-ORD APR 3>2[2] MAY 2>1.2[0.9]
AA HPN-ORD MAR 2>3[2] APR 2>3[2] MAY 2>3[3] JUN 2>3[3] JUL 2>3[3] AUG 2>3[3]
AA HSV-ORD MAR 1.1>2.0[1.0] APR 1.0>2[1.0]
**AA JAN-MIA JUN 0>0.3[0] JUL 0>0.3[0]
AA KIN-MIA JUN 3>4[3] JUL 3>4[3]
AA LAX-ORD APR 9>10[9] MAY 9>10[10]
AA LSE-ORD APR 3>4[3] MAY 3>4[4] JUN 3>4[4] JUL 3>4[4] AUG 3>4[4]
AA MEM-ORD MAY 5>4[5] JUN 5>4[5] JUL 5>4[5] AUG 5>4[5]
AA MIA-SDQ JUN 5>4[4] JUL 5>4[5]
AA MSN-ORD JUN 7>6[6] JUL 7>6[6] AUG 7>6[6]
AA MSN-PHX MAY 0.2>1.0[0.1]
AA MSY-ORD MAR 2>3[2] APR 1.9>3[1.9] MAY 1.9>3[1.8] JUN 1.8>3[1.7] JUL 1.9>3[1.6] AUG 1.9>3[1.6]
AA ORD-RSW MAY 4>3[2] JUN 4>3[1.1] JUL 4>3[1.0] AUG 4>3[1.0]
AA PHL-PUJ MAY 1.0>0.3[1.9] AUG 1.5>1.1[1.7]
Big cut
*AA PHL-SEA APR 3>1.0[1.5] MAY 4>1.0[3]
AA PHL-YUL APR 5>2[3] MAY 5>2[5]
*AN CLD-TSM JAN 0>0.3[0] FEB 0>0.4[0] MAR 0>0.4[0]
*AN HHR-TSM JAN 0>0.3[0] FEB 0>0.4[0] MAR 0>0.4[0]
I assume this is an error? On their website it says "Invalid" if I type DUT.
**AS ANC-DUT DEC 3>0[2] JAN 4>0[3] FEB 2>0[2] MAR 2>0[2] APR 2>0[2] MAY 2>0[2]
AS ANC-SCC APR 1.4>2[1.4]
AS GST-JNU MAY 0.3>0[0]
AS MCO-PDX MAY 1.0>1.3[1.0]
AS PDX-SEA MAY 20>18[16]
AS PDX-SFO MAY 8>7[8]
AS SEA-SIT MAY 0.8>0.5[0.6]
AV JFK-SAL DEC 2>1.1[2] JAN 2>1.0[2] FEB 2>1.0[2] MAR 2>1.1[2.0]
AV LAX-SAL DEC 4>3[3] JAN 4>3[2] FEB 4>3[3] MAR 4>3[3]
B6 BDL-PBI MAR 1.2>2[1.0] APR 1.0>1.9[1.0]
B6 BDL-RSW MAR 1.2>2[1.0] APR 0.9>1.9[1.0]
B6 BOS-EWR MAY 6>7[4]
B6 BOS-RSW APR 6>7[8]
B6 BOS-TPA APR 5>6[5]
B6 EWR-MCO MAY 5>6[5]
B6 FLL-LAS MAR 1.2>2[1.0] APR 1.1>2[1.0]
B6 FLL-PUJ MAY 1.0>0.4[1.4]
BR ORD-TPE JUN 0.7>1.0[0.7] JUL 0.7>1.0[0.7] AUG 0.7>1.0[0.7]
DL ATL-GSO MAY 8>9[8] JUN 8>9[8] JUL 8>10[8] AUG 8>9[8]
DL BNA-SLC JAN 1.0>1.5[1.0]
DL COS-SLC JUN 2>3[3] JUL 2>3[3] AUG 2>3[3]
DL DTW-LEX MAY 4>5[4] JUN 4>5[4] JUL 4>5[3] AUG 4>5[4]
DL FLL-MSP APR 2>1.5[1.0]
*DL IAD-SEA JUN 1.0>1.7[1.0] JUL 1.0>1.9[0.9] AUG 1.0>1.8[1.0]
DL LAX-SFO APR 8>7[8] MAY 8>7[8]
DL PHL-SLC MAY 1.0>1.6[0.9]
DL PSP-SLC JUN 3>2[2] JUL 3>2[2] AUG 3>2[2]
DL SEA-SFO MAY 7>8[7]
DL SEA-SJD APR 1.0>0.8[0.1]
F9 DEN-FLL JAN 1.0>0.2[0]
F9 DEN-LAX JAN 3>2[1.4]
F9 DEN-PHX JAN 4>3[2]
F9 DEN-SMF JAN 1.4>0.6[0.3]
F9 LAS-OMA JAN 0.6>0.8[0.3] FEB 0.6>0.9[0.4]
F9 MCO-ONT JAN 0.7>0.4[1.0] FEB 0.6>1.0[1.0]
F9 MCO-SAN JAN 1.0>0.2[0.2]
*JL HND-HNL MAR 0>0.3[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0]
*JL HND-LAX APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
*JL HNL-NRT APR 4>2[4] MAY 4>2[4] JUN 4>2[4] JUL 4>2[4] AUG 4>2[4]
LF BNA-TUP FEB 1.5>3[4] MAR 0>3[4] MAY 0>1.3[3]
LF CEC-OAK FEB 0.6>1.0[1.0] MAY 0>1.0[1.3] JUN 0>1.0[1.6] JUL 0>1.0[1.5] AUG 0>1.0[1.6]
LF LAS-PGA FEB 0.3>0.6[0.4] MAR 0>0.6[0.7] APR 0>0.6[0.9] MAY 0>0.6[1.0] JUN 0>0.6[1.0] JUL 0>0.6[1.0] AUG 0>0.6[1.0]
LF LAS-SBA FEB 0.6>1.0[0.7] MAR 0>1.0[0.7] APR 0>1.0[0.9] MAY 0>1.0[1.5] JUN 0>1.0[1.6] JUL 0>1.0[1.5] AUG 0>1.0[1.6]
*LF LAS-SBP FEB 0.3>0.6[0] MAR 0>0.6[0] APR 0>0.6[0] MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.6[0] AUG 0>0.6[0]
LF OAK-SBA FEB 0.6>1.0[1.0] MAY 0>1.0[1.5] JUN 0>1.0[1.8] JUL 0>1.0[1.9] AUG 0>1.0[1.8]
LF PGA-PHX FEB 0.6>1.0[1.3] MAR 0>1.0[1.6] APR 0>1.0[1.4] MAY 0>1.2[1.3] JUL 0>1.3[1.0] AUG 0>1.3[1.0]
*LF PSP-SMF FEB 0.6>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
*LF SBA-SMF FEB 1.0>1.7[0] MAR 0>1.7[0] APR 0>1.7[0.5] MAY 0>1.7[1.0] JUN 0>1.7[1.0] JUL 0>1.7[1.0] AUG 0>1.7[1.0]
LF STL-TBN FEB 1.0>1.7[1.1] MAY 0>0.8[1.7]
*NH HND-IAD APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
*NH HND-IAH APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
*NH HND-LAX APR 1.0>2[1.0] MAY 1.0>2[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>2[1.0]
*NH HND-SEA APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
*NH HND-SJC APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
*NK CRW-MCO FEB 0>0.2[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.4[0]
Didn't last long
**NK KIN-MCO FEB 0.4>0.2[0] MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.5]
**TP BOS-PDL JUN 0>0.6[0] JUL 0>0.7[0] AUG 0>0.7[0]
TP IAD-LIS JUN 0.7>0.9[0.4] JUL 0.7>1.0[0.7] AUG 0.7>1.0[0.7]
TP LIS-MIA APR 1.0>1.4[1.0] MAY 1.0>1.4[1.0] JUN 1.0>1.4[1.0] JUL 1.0>1.4[1.0] AUG 1.0>1.4[1.0]
TP LIS-ORD JUL 0.7>1.0[0.7] AUG 0.7>1.0[0.7]
UA BUF-IAD APR 3>4[3]
UA BZN-IAH JUN 0.4>0.7[0.6] JUL 1.0>1.3[1.3] AUG 0.5>0.7[0.8]
UA BZN-LAX JUN 1.3>1.0[1.4] JUL 2>1.0[2] AUG 1.5>1.0[1.6]
UA BZN-SFO JUL 1.0>1.3[1.3]
UA CLE-LAX JUN 1.9>3[1.8] JUL 1.9>3[1.8] AUG 1.8>3[1.9]
UA COS-LAX JUN 2>3[2] JUL 2>3[2.0] AUG 2>3[2]
UA CVG-IAH APR 3>4[4]
UA DEN-LBL FEB 0.8>1.7[0.9] MAR 0.9>1.7[0.8] APR 0.9>1.9[0.9] MAY 0.8>1.8[0.9] JUN 0.9>1.9[0.8] JUL 0.9>1.9[0.9] AUG 0.8>1.8[0.8]
UA DEN-MSO MAY 3>2[3]
**UA DEN-SLN MAR 0>0.9[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0]
*UA EWR-HKG JAN 0.9>0.6[1.0] FEB 0.9>0.4[1.0] MAR 1.0>0.5[1.0]
UA FAT-LAX JUN 3>4[4] JUL 3>4[4] AUG 3>4[4]
UA FCA-SFO JUN 0.9>0.5[0.5] JUL 2>1.1[1.1] AUG 2>1.5[1.7]
UA FNT-ORD APR 1.0>3[4]
*UA HYS-SLN MAR 1.7>0.2[1.7] APR 1.7>0[1.7] MAY 1.7>0[1.7] JUN 1.7>0[1.7] JUL 1.7>0[1.7] AUG 1.7>0[1.7]
UA IAH-LAX JUN 9>11[10] JUL 9>11[10] AUG 9>11[9]
UA IAH-RIC APR 1.0>2[1.1]
UA LAS-LAX JUN 5>6[5] JUL 5>6[4] AUG 5>6[5]
*UA LAX-MEL APR 1.0>0.6[1.0] MAY 1.0>0.6[1.0] JUN 1.0>0.6[1.0] JUL 1.0>0.6[1.0] AUG 1.0>0.6[1.0]
UA LAX-MRY JUN 4>5[4] JUL 4>5[4] AUG 4>5[4]
UA LAX-PHX JUN 4>5[3] JUL 4>5[3] AUG 4>5[3]
UA LAX-RDM JUN 1.0>1.9[1.0] JUL 1.0>2[1.0] AUG 1.0>2[1.0]
UA LAX-SAN JUL 5>4[5] AUG 5>4[5]
UA LAX-YVR JUN 1.0>1.9[1.8] JUL 1.0>2[2] AUG 1.0>2[2]
*UA LBL-PUB FEB 0.8>0.0[0.9] MAR 1.0>0[0.8] APR 1.0>0[0.9] MAY 1.0>0[0.9] JUN 1.0>0[0.8] JUL 1.0>0[0.9] AUG 1.0>0[0.9]
UA LGA-ORD JAN 15>13[14]
UA ORD-TVC APR 3>4[4]
VH MDE-MIA FEB 0.6>1.0[0.3] MAR 0.6>1.0[0.3] APR 0.6>1.0[0.4] MAY 0.6>1.0[0.3] JUN 0.1>0.7[0.7]
MAH4546
Re: OAG Changes 11/24/2019:;NK Exits KIN-MCO;AS Exits DUT?;TP Adds BOS-PDL;UA Adds DEN-SLN
Sun Nov 24, 2019 12:58 pm
Alaska doesn’t fly to Dutch Harbor. They have Pennair fly the route for them and it’s only sold under AS code. Following the Saab 2000 crash, the Penair flight is replaced by a Ravn flight through May 31st, and Alaska will not add it’s code.
a.
777Mech
Thanks as always for putting this together every week!
Maybe the writing was on the wall for DL to start PDL from BOS and TP is just getting ahead of the curve here.
Dominion301
Sun Nov 24, 2019 1:11 pm
In addition to PHL-SEA, PHL-YUL is also a big cut.
The big winner this week I’d say is CLE with an extra daily to LAX.
Chuska
Sun Nov 24, 2019 1:29 pm
Great to see Taos Air adding Los Angeles (via Hawthorne) and San Diego (via Carlsbad) in addition to their Taos-Dallas/Austin service for the winter. Hope to see the likes of AA* and UA* there soon.
MIflyer12
Sun Nov 24, 2019 1:43 pm
I'm not sure the route is big enough for yet more carriers. This may be a case of TP crowding DL out instead of coaxing them in.
BA744PHX
Sun Nov 24, 2019 1:44 pm
Flights will be operated by Advanced Air
sprxUSA
Sun Nov 24, 2019 1:58 pm
Guess Lliberal and Salina can sustain all nonstops to DEN as the tags (HYS-SLN, PUB-LBL) are eliminated. Too bad Hays loses through flight to ORD (via SLN currently).
Contour's SBA-SMF-PSP and LAS-SBP are already flying and have been since mid October IIRC.
Gem State Airlines..."we have a gem of an airline"
enilria
Sun Nov 24, 2019 2:21 pm
A very large fraction of all the schedule changes in this report involve different operating airlines. That is referenced on the FAQ above. A good explanation, however. :)
Ishrion
Sun Nov 24, 2019 4:08 pm
So United’s reducing LAX-MEL... good time for AA to step in.
AirFiero
Sun Nov 24, 2019 4:29 pm
Wow, so both JL and NH are moving a bunch of routes from NRT to HND? That’s unexpected.
babastud
Sun Nov 24, 2019 7:25 pm
I would not be surprised to see this route cut at some point, with UA having MEL now also out of SFO and so much capacity to Australia added in the last few years, I don't know if its that profitable anymore out of LAX for UA?
KLMatSJC
Sun Nov 24, 2019 7:29 pm
Are these actually bookable yet? I still don't see them up.
A318/19/20/21/21N A332/3 A343/5 A388 B712 B722 B732/3/4/7/8/9/9ER B744/4M B752/3 B762ER/3/3ER/4ER B77E/L/W B788 CRJ2/7/9 Q400 EMB-120 ERJ-135/140/145/145XR/175 DC-10-10 MD-82/83/88/90
Long Live the Tulip, Cactus, and Redwood
tphuang
Sun Nov 24, 2019 8:33 pm
Thanks enilria
Big cut
At this rate AA's operating at FLL will just be CLT/DFW/PHL. Also, that's some serious cuts at PHL. It's weird to me they can't compete on a route like PHL-SEA.
No better time for B6 to jump on this one.
so strange to me on this focus city to focus city route for WN, they are going to have the lowest number of flights and capacity.
I'm going to have to check this. I'm surprised no one else has mentioned this. Pretty big step for DL to go 2x on this I would assume quite competitive business routes, especially with Amazon HQ2 factor.
Is there actual O&D on this route? Weird NK gave up on this so fast.
[/quote]
On the whole, quite a bit of expansion here for UA out of LAX outside of MEL flight.
OzarkD9S
Sun Nov 24, 2019 11:07 pm
I'm assuming AS interlines with Ravn at least? If not it will be a real pain for the DUT folks trying to get anywhere outside of AK.
"True, I talk of dreams,
Which are the children of an idle brain." -Mercutio
Sun Nov 24, 2019 11:08 pm
Pretty impressive to see TP's sustained momentum here. I think BOS-PDL is a brilliant and smartly placed ad to counter DL. I see a world where the route may have DL, and TP with a B6 feed at the BOS end.
Alex
durangomac
Sun Nov 24, 2019 11:41 pm
Yes, 7H has an interline agreement with AS. You'll find a few codeshare flights out there where AS is on 7H flights if I remember correctly. I can't remember which routes though.
ericm2031
Mon Nov 25, 2019 1:01 am
I think it's just a continuation of the current schedule/frequency. The SFO and LAX flights operate on opposite days.
NWADTWE16
Mon Nov 25, 2019 2:19 am
B6 making smart moves lately from Northeast strong cities (for them) to South Florida. I specifically watch RSW of course as my home airport and they are expanding their already large "snow bird" portfolio with extra daily HPN last week, and now extra daily BDL & BOS. Their near 20 or more flights a day peak currently from RSW.
I haven't been everywhere, but it's on my list!
clrd4t8koff
Mon Nov 25, 2019 2:50 am
This really surprises me. I’m literally sitting at ORD having just come in on BR56. I flew J and it was only 50% full. With OZ pulling ORD-ICN, AA dropping all Asian flights, and seeing how bad BR did today I don’t get this adding flights to daily.
RyanairGuru
Mon Nov 25, 2019 3:28 am
They're using the same strategy with MEL-LAX/SFO next year as they are with SYD-IAH/LAX: alternating days in Northern Summer and add capacity for Northern Winter.
In NS they can make more money using the aircraft freed up by making these four routes less than daily on other markets (three daily TATL would be a lot more profitable than more capacity to Australia in low season) whereas in NW it makes a lot of sense to add capacity there as Australia is one of the few markets that peaks at that time of the year.
Worked Hard, Flew Right
acentauri
Mon Nov 25, 2019 3:29 am
enilria wrote:
FAQ
Big cut
This may be a 2 month only reduction, relating to aircraft shortage, since it returns to 4 X Daily from June 4.
PHLspecial
Mon Nov 25, 2019 3:40 am
acentauri wrote:
enilria wrote:
FAQ
Big cut
I mean that is a big market to cut from. Though I wonder if AA is doing Oasis on a bunch of LUS A321 at that time
FSDan
Mon Nov 25, 2019 4:15 am
tphuang wrote:
Thanks enilria
I think this is similar to what AA operated on the route last summer (it might even have been cut entirely for a few months last summer as AA scrambled to deal with the MAX situation...). Quite different from even just a few years ago when they were still flying FLL-PAP 2x daily as well as PHX, DCA, etc.!
WN in general doesn't fly much from their Florida focus cities to their Western focus cities. Rarely more than 1-2 daily. It makes some sense considering WN doesn't have a particularly competitive product for transcons.
We'll see if it comes to fruition this time. I believe DL loaded this for last summer too, but cut it back to 1x daily before summer came around. Hopefully this time it sticks!
I think some of this was offset by some cuts last week or the week before. UA (like pretty much everyone else) is quite heavily gate constrained at LAX.
This is my signature until I think of a better one.
32andBelow
Mon Nov 25, 2019 5:58 am
This whole thing makes no sense. The crash was pilot error. The Saab 2000 is still flying. Dut is a very important market to AS. And they just bail like this. Why isn’t the Saab 2000 flying? Is the airplane not safe????
MAH4546
Mon Nov 25, 2019 7:55 am
Penair has suspended Saab flying.
https://blog.alaskaair.com/alaska-airli ... ight-3296/
a.
32andBelow
Mon Nov 25, 2019 8:09 am
Just to Dutch harbor. The question is why? It still goes tos and point which is just as challenging
usairways85
Mon Nov 25, 2019 1:33 pm
PHLspecial wrote:
acentauri wrote:
enilria wrote:
FAQ
Big cut
Meanwhile AS is at 2x except for Jan - mid March.
tphuang
Mon Nov 25, 2019 1:54 pm
Looking at this objectively, I'm not sure why DL cannot sustain 2x daily in the summer. I think this time will stick.
Here is the data from this Q2
Route Dist Carrier Board AvgFare NSFare ConnFare% NS Per Flt # Flights LF Yield
SEAIAD 2306 AS 35064 300.54 297.98 375.48 96.69% 165.3 230 92.22% 274.8
SEAIAD 2306 DL 21864 286.78 280.12 410.27 94.89% 139.4 173 90.64% 253.89
SEAIAD 2306 UA 92810 315.71 313.33 373.68 96.06% 171.9 583 92.62% 290.2
And compare that to some other transcon and longer midcons out of SEA
SEAORD 1721 DL 65852 207.8 204.2 323.36 96.98% 138.9 514 92.21% 188.29
SEABOS 2496 DL 58627 292.17 284.57 384.66 92.40% 160 396 92.55% 263.36
SEAJFK 2422 DL 122246 331.53 326.67 488.54 97.00% 179.3 736 92.63% 302.58
SEARDU 2354 DL 25907 320.41 305.92 383.49 81.31% 159.7 180 90.14% 275.75
SEAIND 1866 DL 19771 264.2 244.5 341.47 79.69% 132.4 167 89.43% 218.65
It's not doing that much worse than RDU (which is about the same distance). It's quite a bit worse than JFK, but that has more connection at JFK end and half of the flights are D1. It's a little worse than the longer distanced BOS on an abnormally high fare quarter for BOS-SEA. Given the stage length, it's definitely running better margins than ORD.
TUSDawg23
Mon Nov 25, 2019 2:38 pm
enilria wrote:
FAQ
Contour Airlines seems like they are having some success flying these P2P flights which is really nice to see. I just hope they can sustain it flying 30 seat ERJs if/when fuel prices spike again.
sprxUSA
Mon Nov 25, 2019 3:08 pm
Looking st LBL, HYS,and SLN sched in late March, goes to a not to hot sched for first two. Arr frm DEN and return between 12-1pm, then a 5pm hour in/out at Hays, 8pm in/out at LBL. No deps earlier than the 1pm hour. Guess if one doesn't want to get anywhere early it is good. I see Scottsbluff, Kearney, and North Platte,NE have similar type schedules as well. Salina has early to DEN, 12pm in/out from ORD, and ron in late from DEN.
HVNandrew
Mon Nov 25, 2019 3:10 pm
That's a huge cut, and surprising given that YUL's economy is booming right now. I wonder what's motivating this?
enilria
Mon Nov 25, 2019 3:38 pm
They did a similarly dramatic cut in PHL-SEA. I wonder if these are errors or if this has something to do with shifting the MAX cuts out of JFK for the Spring.
usflyer msp
Mon Nov 25, 2019 3:53 pm
You can't judge based on a flight this week. Thanksgiving week in the US has basically no business travellers so you would expect J to be pretty empty.
clrd4t8koff
Mon Nov 25, 2019 6:47 pm
On top of my flight I also mentioned the recent withdrawal of Asiana from ORD, as well as AA’s complete withdrawal for ORD-Asia flights. So I’m not judging based on just my flight this week. Several other factors are being mentioned.
chepos
Mon Nov 25, 2019 7:16 pm
Add to the list ORD-HKG on UA getting the axe. It is no secret ORD-Asia is over served. BR does offer some low fares to SE Asia, so I am sure they can usually fill the plane (whether or not the flight is profitable is a completely different story).
Fly the Flag!!!!
Dominion301
Mon Nov 25, 2019 7:38 pm
I don't think this has anything to do with MAX cuts as it's all Eagle flying. It seems like AA have pulled almost all the expanded transborder flying they added in 2018. For example YOW-PHL was cut back to 2x earlier this year with departures at 0600 & 1305. YUL-PHL at 2x only has afternoon departures at 1257 and 1805. I really don't think AA has much of a 'strategy' when it comes to Canada anymore. YYZ-LGA is a shadow of its former self at only 4x ERD.
enilria
Tue Nov 26, 2019 3:36 pm
PHL-SEA isn't Eagle flying, but it isn't really relevant whether it is Eagle flying or not anyway. They can just do a cancel down where bigger aircraft swaps for a smaller aircraft until an Eagle route falls out the bottom. That's actually the profit optimal thing to do when you have a larger aircraft not flying. It makes much less sense to cancel its route than to downsize out some lower yield bookings and get rid of a route or flights on a smaller aircraft at the end of the swaps.
