81819
787-10 Performs 14 Hour Commercial Flight
Fri Nov 29, 2019 10:54 am
Hello All,
As posted on the Australian Aviation thread yesterday (by oskarclare), Etihad flew a 787-10 between AUD and BNE, a 7462 mile or 14 hour trip.
https://www.flickr.com/photos/[email protected] ... ateposted/
As speculated, we assume the aircraft flew light with a reduced passenger and freight load. Still, quite an impressive flight considering the published range of the aircraft.
It would be good to hear from A.net members who have more information on this flight. Some of our more technical minded /experienced posters could enlighten us on how this flight was possible.
Travel
rida79
Re: 787-10 Performs 14 Hour Commercial Flight
Fri Nov 29, 2019 11:15 am
you mean from AUH? AUD is also in Australia
MIflyer12
Fri Nov 29, 2019 11:31 am
Unil those restrictions are known - with specificity and confidence - there really isn't much to say. I would be skeptical of assertions that Boeing has severely underrated range on standard conditions.
RyanairGuru
Fri Nov 29, 2019 11:38 am
Given that this flight is scheduled with a 789 and this was a last minute substitution it is pretty reasonable to assume the flight wasn't full unless there happened to be 50 standby pax. Additionally while we are moving towards the Australian summer, late November is still a relatively quiet travel period here (no Thanksgiving bump!) so - without looking up the loads - I would be very surprised if even a 789 was full.
As to Boeing underestimating the aircraft's range, time will tell for sure, but anecdotally it appears that they have. They have form with this, Boeing circa 2003 had little idea how capable the 77W would prove to be.
Worked Hard, Flew Right
Fri Nov 29, 2019 11:56 am
So an aircraft with a design range of 6430 nm with 330 passengers and baggage completed a trip of 6485 nm half empty and that is supposed to be impressive?
You do know the difference between a mile and a nautical mile ?
Avgeek21
Fri Nov 29, 2019 12:08 pm
Don’t forget it’s a UAE holiday period around these days and almost all flights ex UAE are full. So it could well be a swap due to available volume. I’ve seen several ex UAE A380’s with a 100% load and 50+ staff on stby.
afterburner
Fri Nov 29, 2019 12:44 pm
Aren't the most of the passengers of EK/EY/QR flights transit passengers? So in this case the most passengers on this flight wasn't originated from AUH.
RyanairGuru
Fri Nov 29, 2019 1:12 pm
Generally yes, but if it is a local holiday then it stands to reason that there will be a higher proportion of UAE O&D pax.
However if the holiday was affecting loads then it would be in the direction AUH-BNE, with the winds behind them.
PANAMsterdam
Fri Nov 29, 2019 1:16 pm
RyanairGuru wrote:
It is a bit off topic but could you please tell me more about this unexpectedly better than expected range of the 77W or have a link about it? Couldn’t find it
Every country has an airline. The world has Pan Am.
Eyad89
Fri Nov 29, 2019 1:22 pm
What holiday are Emiratis having now?
rnav2dlrey
Fri Nov 29, 2019 1:23 pm
for more detail, search for the thread documenting UA using the 78J on IAD-NRT for a few turns. i believe there are exact fuel/weight numbers in that thread from a UA employee.
Ziyulu
Fri Nov 29, 2019 1:36 pm
So what? United flies a 787 from SFO to SIN, which is 16 hours.
Delta28L
Fri Nov 29, 2019 1:46 pm
787-9 version not a 787-10
flipdewaf
Fri Nov 29, 2019 2:14 pm
there are the IAD-PEK flight numbers (from Jayunited if I remember correctly) the numbers posted show the 787-10 falling exactly on the Boeing payload range chart for the 787-10.
Fred
JustSomeDood
Fri Nov 29, 2019 2:44 pm
Fred
As Boeing's payload range chart quotes [email protected] 330pax, the fact that UA's data supports the chart on a westbound TPAC route means that a 787-10 can fly 6000+nm routes with a full pax load in the real world, which should shut up some vocal advocates that claim the contrary. Even higher density configured -10s (VN with 367 seats) should have no issues flying 10-11 hr routes with no payload penalty.
tommy1808
Fri Nov 29, 2019 3:21 pm
Wasn't there a one-off for more premium seats or so flying some 160 pax a while back?
Best regards
Thomas
flipdewaf
Fri Nov 29, 2019 3:24 pm
JustSomeDood wrote:
Fred
I agree, there are people on here that like to use half truths to peddle their views. Once you have (or can calculate) the vital pieces of information on an aircraft it should be all settled but people like to assume one of the vital pieces then arguments ensue.
1. Takeoff weight
2. Landing weight
3. Still air range
The still air range is often difficult to determine and its often good to use flight distance and flight time as a good proxy.
Fred
ikolkyo
Fri Nov 29, 2019 4:58 pm
You know it was half empty how? Can I see some sources? The flight is typically operated by the 300 seat 787-9 configuration so I doubt it was half empty.
SFOtoORD
Fri Nov 29, 2019 5:28 pm
He didn’t postulate that it was severely underrated and for your point on knowing the restrictions, the next paragraph from the OP said:
81819
Fri Nov 29, 2019 7:23 pm
Hello All,
I have been informed the aircraft had a load factor of 86.3%.
9Patch
Fri Nov 29, 2019 7:44 pm
travelhound wrote:
Hello All,
SeatGuru says Etihad's 787-10 has 289 seats (22 business and 267 standard) so an 86.3% load factor is 249 passengers.
https://www.seatguru.com/airlines/Etiha ... 787-10.php
chiki
Fri Nov 29, 2019 8:19 pm
9Patch wrote:
travelhound wrote:
Hello All,
It's actually 299 seat, but 32 business
Sent from my SM-J415F using Tapatalk
waly777
Fri Nov 29, 2019 8:20 pm
9Patch wrote:
travelhound wrote:
Hello All,
Seatguru is incorrect. EY 787 config:
787-9 has 299 seats (28J, 271Y)
787-10 has 336 seats. (32J, 304Y)
The test of first-rate intelligence is the ability to hold 2 opposed ideas in the mind concurrently, and still function
MSPNWA
Fri Nov 29, 2019 8:39 pm
That's impressive if the load factor is accurate. The 78X has a bit of an A330 potential in it. With performance improvements down the line, the frame becomes more and more lucrative.
CriticalPoint
Fri Nov 29, 2019 9:27 pm
Simple truth is that the 787-10 has the same fuel capacity as the 787-9/8 so the -10 can fly nearly the same distance but in order to carry all the fuel you have to sacrifice load.
United got ETOPS 240 for -10 so that it could fill in for a -9 if needed. There will come a day when a -9 goes tech in LAX and a -10 will fly to MEL, and everyone on here will go nuts........
ElroyJetson
Fri Nov 29, 2019 11:08 pm
This has been discussed endlessly. The consensus is the 787-10 is a 5000nm plane with a 35 ton payload, even against westerly winds. It can comfortably fly 6000nm with full pax and bags. The flight profile mentioned in the OP should be zero surprise to anyone.
As for NZ. They can fly the 787-10 to LAX or SFO with meaningful cargo. Whether or not they choose to do so is a different matter. Whenever anyone mentions a flight like EWR to TLV on a 787-10 many seemed surprised. They shouldn't be.
707 717 727 72S 737 733 737-700 747 757 753 767-300 764 A319 A320 DC-9-10 DC-9-30 DC-9-50, MD-82 MD-88 MD-90 DC-10-10 DC-10-40 F-100
xwb777
Fri Nov 29, 2019 11:17 pm
Commemoration Day and National day. 28th until 4th Dec.
Antaras
Sat Nov 30, 2019 2:38 am
The longest route HVN will operate by B78X is SGN-ICN, 2209 miles - less than 5 hrs flights. HVN will not use its 78X for any other longer routes, that's the reason why VN config the 78Xs so dense.
Edit signature
This is a block of text that can be added to posts you make. There is a 255 character limit.
zkncj
Sat Nov 30, 2019 2:59 am
UA starts SFO-AKL this week with the 787-10 will be an interesting one to following over this busy southern summer travel period, and if there are any tropical fuel stops when required.
When QF used to use the 743 on LAX-AKL it made it most of the time, although if there was head winds or weather in route it would need to stop on HNL or NAN for fuel.
I would compare the 744/743 and the 789/78J to be simlair, eg both could fly the route in conditions, just one of them has more limitations in certain conditions.
qf789
Sat Nov 30, 2019 3:24 am
waly777 wrote:
9Patch wrote:
travelhound wrote:
Hello All,
That is correct, based on 336 seats and a LF of 86.3% there were 290 passengers on board
Forum Moderator
leftcoast8
Sat Nov 30, 2019 3:31 am
I was doing some research about this a while ago. 77W development is a deep rabbit hole to go down, but I found a source that sums it up succinctly: https://leehamnews.com/2011/06/23/leahy ... mment-6844
Upgrades to the GE90-115B in 2005 improved fuel burn by a further 1.5%. Boeing continued iterating on engine and aerodynamics improvements starting in the late 2000s, as the global financial meltdown of 2008-09 increased the urgency with which airlines needed more efficient aircraft, especially with the continued delays in 787 and A350 production. It was around this time, as more and more 744s were being retired, that the 77W became a true juggernaut.
Further reading:
https://medium.com/@O530CarrisPT/boeing ... 41b1e55a39
https://www.flightglobal.com/news/artic ... le-225112/
JustSomeDood
Sat Nov 30, 2019 4:08 am
I guess we'll see what they do with the -10s once more arrive and get integrated, certainly wouldn't bet on the longest routes staying <5 hrs. Their -9s and A350s fly a lot of Oceania /Europe routes which could be subbed in with these to free up those frames for NA flights, if that's what VN wants.
UALMMFlyer
Sat Nov 30, 2019 5:12 am
I was on the IAD-PEK 787-10 flight in August. Loads seemed to be good. I was in Polaris cabin minding my own business as I was busily preparing for my meeting upon landing.
I am not an aviation techie like many on this board, but I was under the impression 787-10 could not flown that far with a full load. I was impressed with the extra range and it was a very good flight. The flight was supposed to me 6,920 mile, but the IFE showed the actual flight path was just under 7,100 miles.
Treat others like you'd like to be treated!
Scarebus34
Sat Nov 30, 2019 5:22 am
I can assure you UA ran all the numbers. If a fuel stop was even remotely possible, they wouldn’t put the bird on the route.
LAX772LR
Sat Nov 30, 2019 5:48 am
....huh? :lol:
Sat Nov 30, 2019 6:29 am
Oh really, the same way UA kept on operating 757s winter after winter on EWR-TATL despite a regular occurrence of fuel stops?
fessor
Sat Nov 30, 2019 7:04 am
waly777 wrote:
9Patch wrote:
travelhound wrote:
Hello All,
787-10 has 32j and 295Y as shown in Ethiad homepage.
ElroyJetson
Sat Nov 30, 2019 7:48 am
SFO-AKL is 5700nm. The 787-10 should make this easily with full pax and bags.
rbavfan
Sat Nov 30, 2019 7:58 am
flipdewaf wrote:
JustSomeDood wrote:
Fred
1. Takeoff weight
2. Landing weight
3. Still air range
Fred
It the frame can fly 6430nm still air it should easily be able to do 6485nm with heavy tail wind pushing it. After all the extra fuel burn would be BNE-AUH not AUH-BNE. Still air is the range the plane can fly with no headwinds or tailwinds.
waly777
Sat Nov 30, 2019 8:01 am
Could you please refer me to where on the etihad homepage this config is shown?
If you refer to "our fleet" on etihad.com, it'll show you (up to 336 seats) for the 787 and you can then click on each seat map for the 787-9 2/3class, and 787-10.
787-9 3 cabin is 226 (formerly 235). 8F, 28J, 190Y
ikramerica
Sat Nov 30, 2019 8:05 am
Further reading:
The original proposal for the 77W was to be a replacement for 742/3. But throughout the development and testing phases, thd range kept increasing, until it was more capable than the 744. Within a year after EIS it approached 8000nm pax only range.
Not knly did it help kill the 744 and A340, it also made the 77L less desirable. Thst aircraft gained range, but range nobody needed. But the 77W ended up being capable of most of the routes you would buy the 77L for.
fessor
Sat Nov 30, 2019 11:38 am
And then count the Seats on the seatmap then I come to that number.
Also if i call i get same information
ShadowLaw
Sat Nov 30, 2019 1:28 pm
This is the whole point of the 787-10 in a nutshell. This is the purpose for which it was built.
waly777
Sat Nov 30, 2019 4:09 pm
Ah yes yes, my apologies. That's a planned config as a result of the economy space retrofit, the 787's will get them similar to the 777 and 380 fleets. The 787-10 is still 304Y total at this point.
Sat Nov 30, 2019 4:21 pm
I cannot agree with you, there would be no business case for Boeing to develop and certify the 787-10 if the “whole point” was to develop an aircraft that would fly 14 hours with passengers and baggage with little or no cargo.
The worldwide demand for that capability is like 10-20 aircraft. No airline is buying the 787-10 just to serve that sort of role.
Look at the routes this particular airframe normally does, it will become apparent to you that thus was more of an anomaly than a regular occurrence.
flyingfool
Sat Nov 30, 2019 5:50 pm
travelhound wrote:
Hello All,
That was on the BNE-AUH sector, AUH-BNE was 40,5%.
Zinu
Wed Dec 04, 2019 11:35 pm
8 out of 11 787-9 currently being operated by VN have Premium Economy offering and currently being used for LHR, FRA and SYD ops from both SGN and HAN. Same for the A350-900(s) that are currently being used for MEL.
Unless the upcoming 787-10(s) will be configured with Premium Economy, I think the densest 787-10 will continue to be used for high demand routes to ICN, PUS and domestic operations between SGN and HAN (or DAD) to compete effectively against the LCC. The landing slots at SGN and HAN are very restricted and congested at the moment so the 787-10 will be very useful for domestic ops.
Japan, China and Russia (from HAN) may also be potential future destinations for the 787-10 operations as well.
