globalflyer
MIA Concourse G
Fri Dec 20, 2019 12:09 pm
So I am sitting in G this morning thinking this is the last of the original piers at KMIA. Does anyone know its history? Was the PA or NA? I cannot imagine the incredible history that these walls have seen. Now home to F9, UA and UP.
jeffh747
Re: MIA Concourse G
Fri Dec 20, 2019 3:18 pm
Hi there,
There is a forum post from about 16 years ago that has a little bit of info: viewtopic.php?t=225521 with some good pictures. It definitely feels like it's straight from the 80s. While it lacks a ton of modern amenities, I myself am using it tomorrow am and looking forward to it because it feels like you're back in time.
ATR-72-600, A318 A319 A320 A320neo A321 A321neo A332 A333 B717 B727 B734 B73G B738 B739 B752 B762 B763 B772 B788 CRJ2 DHC6 DHC8-300 E145 E190 MD82 MD83 MD90 SF340B
OB1504
Re: MIA Concourse G
Sat Dec 21, 2019 12:43 am
The thread that jeffh747 linked to is a great resource.
The extension built in the 1960s is roughly from current gates G6/G7 upward. From inside, it’s clearly noticeable that the building gets wider and the floor in the far end of the concourse is higher up, as evidenced by the ramp near G8.
When the 21st Street Terminal originally opened in 1959 with the numbered concourses, it was roughly Eastern on concourses 5 and 6 (later D and C), Braniff on concourse 5, Pan Am and foreign carriers on concourse 4 (E), National and Northeast on concourse 3 (F), and the rest of the domestic carriers on concourse 2 (G). Delta moved to concourse 1 (now H) when it opened in 1961 and has been there ever since. No other airline at MIA has operated from the same concourse for anywhere near as long as Delta’s 58 years at H.
When American first started flying to MIA in 1979, they used gates at G. As their operation grew in the mid 1980s, they started using some gates on H. Once they bought Eastern’s Latin American network, AA moved out of concourse G and H to concourses D and E, eventually expanding to concourse C, then B, then A, until everything was merged together into the present linear terminal.
Since G’s most recent extension was built in the 1960s and the most recent remodel was in the 1970s, it has a lot of unusual attributes. It’s the only two story concourse, the only concourse that cannot handle international arrivals, and the only concourse without an underground hydrant fueling system. A lot of the gates have staircases to the ground level since they were constructed when propliners were still popular. Bahamasair uses gate G6 as a ground load gate and has passengers walk across the tarmac to the airplane when they send their ATR. Also, virtually every gate from G8 up thru G19 is a widebody gate that can accommodate aircraft like the DC-10 and L-1011 that were popular in the 1970s. Many of the gates still have stop bars for classic airliners like the 707 and DC-8. Gates G16 and G19 can even accommodate 747s.
Through the 1980s and 1990s, G continued to serve a menagerie of domestic carriers, including Continental, Northwest, TWA, Tower Air, United, and ValuJet (later AirTran). Air Canada also used gates on G.
Continental was with Eastern at D In the 1980s but moved to G by the 1990s. United moved to F in the early 1990s when they bought Pan Am’s Latin American routes and made a half hearted attempt at a hub.
Tower Air shut down in 2000 and TWA merged with AA in 2001. Air Canada moved to concourse J when it opened in 2005. Continental moved to newly vacated gates in H around the same time. In the 1990s, Bahamasair used to use gates at the far end of H that were permanently closed to accommodate a dual taxiway when J opened, so they must’ve moved to G in the early 2000s. Northwest merged with Delta in 2008 and moved to Delta’s gates in H.
By the end of the 2000s, G was largely a ghost town, with the only carriers being Alaska, AirTran, Bahamasair, Gulfstream, Sun Country, and charter flights to Cuba operated by an ever changing assortment of airlines, including Allegiant Air, Sky King, and Vision. Alaska, AirTran, and Gulfstream all pulled out in favor of FLL.
Nowadays the current tenants are Bahamasair, Frontier, Sun Country, Sunwing, and United.
When Continental and United announced their merger in 2010, there wasn’t room at H and J to consolidate their combined operations, so they moved to the current split concourse arrangement where some flights are out of G and some are out of H. United tries to put as many flights are they can on H with its more modern facilities, but during peak times they have up to four aircraft overnighting at G. United currently uses gates G9, G11, G15 (former Northwest gates) and occasionally G16 or G19.
Frontier has been in G since they started flying to MIA in 2014. MIA is now their newest base and their typical gates are G8, G10, G12, G14, and sometimes G16. I call it the morning zoo because of all the animal tails lined up at 6 AM.
Bahamasair typically uses G6 or G8, and sometimes G4. These are the same gates Sun Country tends to use for their seasonal service during the winter.
Sunwing is a relatively new airline at MIA with seasonal winter service. Their flights to/from Canadian airports with US CBP preclearance tend to use G8, G10, or G12. The flights without preclearance use F.
In the summer there are also charter flights to the Caribbean (typically the Dominican Republic) operated by carriers like Eastern 3.0 (formerly Dynamic), Swift Air, and World Atlantic.
Gate G1 is now closed but featured a lower level waiting area and 4 or 5 parking positions for small propeller aircraft like the Beechcraft 1900, but it hasn’t been used since Gulfstream (now Silver) pulled out of MIA. They used to have a sizable operation with service to various cities in Florida and the Bahamas. The 1900s used to park in pairs parallel to the terminal where gates G3 and G5 were. Nowadays G3 is just a parking lot and the G1 holdroom is abandoned and blocked off.
Gates G5 and G7 have no jet bridges and are used as “remote” parking only, though Swift Air will occasionally have a ferry flight without passengers leave from one of those spots. On the Google Maps satellite image, you can still see the lead in lines for the props on G5, and the ones on G6 which are still used. G7 featured the airport’s last remaining “mini me” jet bridge, which fell into disrepair by the start of the 2010s and was removed.
Gate G2 was permanently closed not too long ago for some sort of terminal expansion between G and H. I have no idea what it’s for but it seems to be office space.
Gates G14, G16, and G19 can accommodate larger widebodies and were regularly used as additional “remote” parking (typically LATAM 767s spending the day at MIA before heading back to South America at night) until Frontier built up their operation in November. Gate G14 also has the longest jet bridge at MIA.
Taxiway P runs abeam gates G14, G16, and G19. When an A380 uses this taxiway to get between runway 9 and concourse J, the service road which runs behind these gates is blocked off by the aviation department because the wingspan is wider than the taxiway and the outboard edges of the wings pass over the service road, posing a threat to traffic.
Gate G17 existed but was evidently eliminated at some point during the 1980s. If you compare the first two photos you can see that the jet bridges on the west side have moved and the bridges no longer correspond to the stairwells.
Here are some overviews of G:
The most current plan for concourse G is to demolish it and use the area for remote parking. Eventually E and F are to be demolished as well and the area occupied by E, F, and G will be home to two new super concourses. The recent Frontier expansion might put a damper on the demolition plans for G since there’s nowhere else they can fit unless they don’t mind being spread across two or three concourses like Air Florida was back in the day, or like how United is now.
N62NA
Re: MIA Concourse G
Sat Dec 21, 2019 2:39 am
Thank you OB1504 for taking the time to provide all that interesting information.
jfk777
Re: MIA Concourse G
Sat Dec 21, 2019 2:06 pm
Concourses F & G need to be torn down and a "super" concourse like "J" needs to get built, G hasn't really been renovated except for putting in widebody gates. F was expanded in the late 1980's in the last years of PA and did getting some investment when United tried their Latin hub. Taking E down at the same time would kill too many gates, especially for OneWorld Airlines like BA.
jfk777
Re: MIA Concourse G
globalflyer
Re: MIA Concourse G
Sat Dec 21, 2019 3:30 pm
Thank you so very much Jeff and OB that was an amazing overview! Very much appreciated!
phatfarmlines
Re: MIA Concourse G
Sat Dec 21, 2019 5:53 pm
Thank you for the great overview OB1504. Here's a trip report that I wrote back in 2002 when I transited through MIA Concourse G. Reading it again makes me realize how much Concourse G changed.
Qantas59
Re: MIA Concourse G
Sat Dec 21, 2019 8:10 pm
Thanks OB1504 for all of that background data!
I seem to recall the TWA gate at the far end of G that showcased very large white TWA letters against a red backdrop. One could see that wall from the moment you entered the concourse.
[photoid][photoid][/photoid][/photoid]/Users/jaytanguay/Desktop/Screen Shot 2016-10-27 at 9.30.09 AM.png
OB1504
Re: MIA Concourse G
Sat Dec 21, 2019 9:45 pm
This is exactly what the aviation department plans to do. Concourses E, F, and G will eventually be demolished and replaced with two superconcourses that can handle plenty of international widebodies.
xxcr
Re: MIA Concourse G
Sun Dec 22, 2019 12:15 am
I fly to MIA 6-8x a year on UA and im so happy they moved from terminal G to H. Terminal G is so old lacks a lot of the amenities the other terminals offer. Hopefully once they renovate G, they'll add a lounge and make it more modern.
Seating was fine at G, but it lacked Charging stations, the bathrooms were small and a bit rundown, straight out of the 80s lol.
OB1504
Re: MIA Concourse G
Sun Dec 22, 2019 5:38 pm
United is still using G for some flights since they only have access to 2-3 gates on H. They’re the only domestic carrier with split operations.
G won’t be renovated and will look the same as it does now when it’s ultimately demolished.
