ewt340
Re: Cessna SkyCourier Development and Testing Thread
Tue May 19, 2020 8:46 am
It's really smart for them to accommodate LD3 in freighter configurations. LD3-45 should have been considered too.
Okcflyer
Tue May 19, 2020 11:40 am
Given the LD3-45 footprint is slightly smaller than LD3, they’ll definitely fit. The securement system may need tweaked or certified for them but that should be easy to do if some customer wanted that later on. Highly doubt it’s a popular option and may never actually be requested, but it should be straightforward to do should it ever be needed
DiamondFlyer
Tue May 19, 2020 12:56 pm
The LD3 capability is probably why FedEx was on board with this. Right now, for places that get feed via a 208 (well, anything that isn't an ATR for that matter), the freight gets flown to the outstation on FedEx. Then, they have to unload the containerized freight, sort it out of the can, and then move it back out to an aircraft, to bulk load. If you use the LD3's in a 408, you can sort each of the destinations the 408 is going to in MEM/IND, pull them straight off the jet and slide them right into the 408.
Back when I flew package freight, it wasn't uncommon (at least on the UPS side) for it to take at least an hour from the UPS jet landing to loading the small bulk loaded feed planes. For a company like FedEx (or UPS for that matter), time is money.
From my cold, dead hands
Spacepope
Might be as simple as their main customer does not have and does not plan on having any narrowbody freighters in service with containers in the belly. No need to over complicate the design at the very beginning.
FlyingViking
Tue May 19, 2020 2:06 pm
All true, don't forget the time savings at the feeder destination as well. Instead of manually off loading the feeder piece by piece, they can now just roll off the LD-3's to a van and bring them to the station where they'll be downloaded straight on to the belt where the courier vans are backed up to. Saves a ton of time and avoids the human handling and the weather at the airport, the same is true of course in reverse, when the days freight is shipped from the feeder station to the out station or hub.
ua900
Re: First SkyCourier Wings Mated
Tue May 19, 2020 3:07 pm
CX747 wrote:
Glad to see the new Cessna is up in the air. It already has the potential of replacing the majority of FEDEX'S caravans. Small cargo operators, island hopping and para-military usage are all fields where this could shine. Possible USAF interest for SOCOM requirements, foreign nation training etc.
Yup, it's one of the most versatile and smartest new commercial products in around two decades. Congrats to Cessna for making it happen.
DiamondFlyer wrote:
Assuming FedEx uses the LD3 capacity, it will help them immensely in sort times, in moving from the jet to the small feed planes. Very well could allow them to move back last shipment times for air in the outlying small towns in some places.
Agreed, the LD3 capability is a game-changer compared to some others. Small towns can get connected to the world in a jiffy and fairly economical.
wjcandee wrote:
But of course it's 100mph slower than the B1900D. That could make a difference in total operating cost. Also, unpressurized is a limitation in pax service.
As a UA 1K who has also flown on smaller carriers on equipment as small as a Caravan, I have to say that something like the Caravan was phenomenal in terms of ability to see the terrain in greater detail and become familiar with an area in which we'd ultimately touch down and move into for the next couple fo days. Some of the things I saw when flying in became destinations once I was on the ground because flying over a given area allowed for that sneak preview.
:checkmark: :checkmark: :checkmark:
2020: DEN | DFW | EWR | FRA | IAH | LAX | MCO | MUC | ORD | PTY | SFO | TXL
ewt340
Tue May 19, 2020 9:01 pm
Yeah, cause I was thinking, there are probably as much as LD3-45 in the world as LD3 container. By the look of it, the LD3 container would be rotated by 90 degrees to the side rather than being placed on a similar position it's usually in on larger plane.
So, they could only fit 2 LD3-45 in there instead.
Okcflyer
Tue May 19, 2020 11:30 pm
As others mentioned, FedEx doesn’t even use the LD3-45. For that matter, I can’t think of any freight company that uses LD3-45s. At the same time, I cannot think of an air fright company that doesn’t use LD3s.
LD3-45 lose more than 15% of volume due to reduced height, making them extremely inefficient in anything but an A320. I highly doubt this compatibly was even considered by Cessna.
They’re used for pax bags and that’s it. Don’t why any organization would build a model around using AKH’s for integrated freight. Widebodies would always be used for trunk haul. And therefore there would be LD3 positions available. The LD3 can fit main deck if needed on a narrow body assuming sort rush is so high it doesn’t make sense to transload.
Spacepope
Tue May 19, 2020 11:50 pm
Tghe problem with this argument for now is that there are precisely zero Airbus narrowbody freighters in service. I'm sure there will be a mod in the future for them, but right now it's not pressing.
ELBOB
Wed May 20, 2020 6:07 am
lightsaber wrote:
This is great news. I'm very excited for the SkyCourier. In many ways, a modern DC-3.
Huh? It's a 19-pax / 2.5 tonne, unpressurised, high-wing turboprop; a configuration that's been tried about 30 times since the DC-3. What's so exciting? The fact that it says 'Cessna' on it?
It's a modern Skyvan except that type had a bigger cabin and a rear ramp.
Or you can go out right now and buy a C.212 that will take three LD3s through the rear ramp - no handling gear needed to lift up to an elevated cargo door. I really don't understand the hype.
426Shadow
Wed May 20, 2020 7:33 am
Anyone else notice that the left-hand outboard exhaust pipe is pointing upwards but the right-hand outboard one is in the typical configuration? Think that is on purpose?
We are all just fanboys, our opinions don't make or break businesses.
keesje
Wed May 20, 2020 8:56 am
Good catch! Never seen that.
I do see a lot of speed tape/sensors installed around the engine cowlings, struts, wings..
Each PT6 has 2 exhausts, one angles up, one level.
Probably they are measuring comparing left & righty hands airflows, temperatures during taxiing, take-off and flights.
Stationairy & taxiing they probably have done for some time already. Probably innitiating this akward first flight configuration.
https://www.pilootenvliegtuig.nl/2020/0 ... t-gestaag/
I wouldn't be surpized if we see this changed on next flights.
mxaxai
Wed May 20, 2020 9:02 am
It's the same on both engines, so yeah, it's probably on purpose. They didn't bother with mirrored engines left and right, much easier to maintain two identical engines.
mxaxai
Wed May 20, 2020 9:16 am
alberchico wrote:
Kind of amazing that Cessna has not released a single image of what the cockpit of this aircraft looks like. Have never seen that in any other program.
I would expect it to look similar to this one from the Cessna Denali:
https://www.hangarx.com.ar/noticias/avi ... mer-vuelo/
Maybe without fancy cup-holders, though it's probably cheaper to add these for $20 each than to pay for repairs after spilling cofffee over the center pedestal.
HPRamper
Wed May 20, 2020 9:29 am
Elevated cargo door? How exactly would you presume to move these loaded LD3s from one plane to another....on a forklift?? Or dragging by hand? What makes this plane so great is the instant integration into the FX network via easy transload capability, and FX uses things like tugs and dollies to move containers from plane to plane.
timeless159
Wed May 20, 2020 12:23 pm
It's exciting because it is so simple. It doesn't need a ramp. It doesn't need pressurization. It doesn't need retractable gear. It doesn't need STOL capabilities. It won't require two pilots. It doesn't need to go 280kts. All other part 135 twin engine aircraft hauling feeder freight have unnecessary capabilities and added operating expense. It's very satisfying to finally see a twin engine airplane designed for feeder freight routes.
aumaverick
Wed May 20, 2020 1:09 pm
CX47 mentioned potential interest from SOCOM. Just spitballing and wondering, but has anyone ever airdropped an LD3?
I'm just here so I won't get fined. - Marshawn Lynch
GalaxyFlyer
Wed May 20, 2020 2:14 pm
It’d probably be a wreck on impact, not designed for it. SOCOM would just let out an RFP for specialized airdrop equipment, spend a fortune. Doubt you could airdrop much out the side door, anyway, hand bundles. They’d probably use it for small team infiltration/exfiltration.
ewt340
Wed May 20, 2020 2:17 pm
Ok, that make sense now.
Revelation
Wed May 20, 2020 2:49 pm
They do look similar, but that rear ramp adds complexity and weight, presumably stuff that FX was trying to avoid.
Ref: https://en.wikipedia.org/wiki/CASA_C-21 ... Series_400)
Ref: https://en.wikipedia.org/wiki/Cessna_40 ... ifications
JayinKitsap
Wed May 20, 2020 5:46 pm
Some comparisons using the two planes wiki pages Cost of C.212 in 2006 is $ 5.2 to 8 M, cost of $ 5.5M for SkyCourier
C.212 Payload 2,700 kg 408 2,722 kg
Inside cabin dimensions - C.212 doesn't say but can it fit LD-3's? 408 is 70"x70" section with 87" cargo door.
Length & wingspan - C.212 53'X66.5' 440 sf wing 408 55'X72'
Engines C.212 2 × Garrett AiResearch TPE331-10R-513C turboprop engines, 671 kW (900 hp) 408 2 × Pratt & Whitney Canada PT6A-65SC turboprop, 1,100 hp (820 kW) so the 408 has 400 extra HP, that is a big difference, also Pratts.
Speed C.212 354 km/h (220 mph, 191 kn) (max cruise) at 3,050 m (10,007 ft) 408 230 mph (370 km/h, 200 kn) maximum
So FedEX can get from Cessna a plane with probably a lot of common parts with the 208 which they have a shedfull of, a current price of $ 5.5M, the latest simple glass cockpit, Pratt engines which are also on the 208 with 400 extra Horsepower, no rear ramp which apparently they don't need. US manufacture vs Spain.
It is possible that FedEX considered the C.212 but decided that the 408 is a better deal. Yes the 408 is just a utility plane, but it appears that it is designed for both initial and operational economy. As FedEX has ordered 30 ATR42's they are familiar with other planes also.
VirginFlyer
Wed May 20, 2020 7:44 pm
keesje wrote:
Frank Crébas/ Bluelifeaviation
Did you know, if you use the forum’s photoid function, you can not only display the photo, but also link to it:
[photoid]1737923[/photoid]
That way users can actually visit the photo page, see the information, and credit the photographer with the views.
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens. —Bahá'u'lláh
Okcflyer
Wed May 20, 2020 11:34 pm
The pedestal will be quite different. It should have two power control levers and two condition levers at minimum. Probably also MOR. The SkyCourier uses PT6-65SC which are *not* FADEC.
The Denali uses GE’s Catalyst with FADEC and automatic prop/condition control, hence the single lever that acts like a thrust lever. There’s actually been quite a bit of marketing around it’s unique design enabled, largely, by being full digital control.
The SkyCourier is also a bit wider, but I digress. Overall it should be similar in principle.
m1m2
Thu May 21, 2020 2:06 am
I would guess that's to prevent the hot exhaust gasses from being directed onto the wing leading edge. Also would help prevent soot from accumulating on the wing upper and lower surfaces. Turboprops might burn fairly clean, but they do leave soot stains.
eeightning
Thu May 21, 2020 5:45 am
The exhaust pipes are aligned with the local airflow. Once the plane flies through rain and leaves some streamlines, you will see what I mean.
FlyHossD
Thu May 21, 2020 6:40 am
Yes and that local airflow is affected by the rotation of the props - that's why it's similar on the left side of both engines.
dopplerd
Thu May 21, 2020 10:14 am
The left hand inboard pipe is in the exact same config as the right hand inboard.
CDGIAD
Thu May 21, 2020 9:05 pm
When is FedEx supposed to receive its first SkyCourier ?
It will look even better painted.
Really like that Beechcraft's pointy nose.
filipinoavgeek
Fri May 22, 2020 1:49 am
Are there any confirmed non-Fedex orders or interests yet?
alberchico
Sat May 23, 2020 1:36 am
https://www.aopa.org/news-and-media/all ... introduced
Despite being much larger this aircraft has a list price of 5.5 million while the Viking Twin Otter has a price of 6.5 million. I wonder if this will hurt the Twin Otter in the long run. Granted its STOL performance is legendary and the Cessna can't match it, but many carriers simply do not need that kind of performance. If you're not doing any bush flying into short primitive airstrips there simply is no reason to buy a Twin Otter now that you have a better choice.
short summary of every jewish holiday: they tried to kill us ,we won , lets eat !
DL717
Sat May 23, 2020 1:55 am
It’s unfortunate they didn’t go with electro-thermal ice protection. It would have cost more, but it would have been a good selling point for a turboprop weary public in a world that now needs smaller props for small markets. Maybe a boon for ATR in the offing, but man, the market needs a small prop.
Welcome to Nothingburgers. May I take your order?
JayinKitsap
Sat May 23, 2020 3:23 am
I hope it works great for FedEX and they order another batch or two. Somehow I feel that 50+ will be delivered in the freight version before the pax version is picked up. This pandemic has frozen nearly all new orders for possibly a year, then only slowly will it rise.
If it turns out to be a good workhorse, there could end up being as many SkyCouriers as Caravans at FedEX
VirginFlyer
Sat May 23, 2020 3:49 am
Photographs don't bear that out. The left-hand inboard exhaust is in the same configuration as the right-hand outboard (more or less horizontal), while the left-hand outboard exhaust and the right hand inboard one angle up. In other words the same configuration on each engine, rather than a mirrored configuration. The following post shows it well:
V/F
keesje
Sat May 23, 2020 7:27 am
alberchico wrote:
https://www.aopa.org/news-and-media/all-news/2017/november/29/cessna-skycourier-twin-turboprop-introduced
This aircraft has a lot of wing, powerfull engines and looking at the tail, it has a lot of clearance for high AOA. Lightly loaded it probably has good STOL performance.
alberchico
Sat May 23, 2020 12:41 pm
Because it was designed with the needs of FedEx in mind, which tends to operate from well equipped airfields, Cessna did not give it STOL performance. A Twin Otter needs only 1,200 ft of runway for takeoff, while this aircraft requires a whopping 3,300ft. So we'll never see it flying out of a demanding airfield like Lukla in Nepal.
https://www.aerospace-technology.com/pr ... -aircraft/
lightsaber
Sat May 23, 2020 12:53 pm
I thought the long term plan was to replace the Caravans with this larger airframe? Note long term, it is a long time until the Caravans are done.
Lightsaber
HPRamper
Sat May 23, 2020 1:19 pm
Lightsaber
I don't believe that will be the case. FX wants this one for the containerization ability, but only a smallish portion of feeder-only markets will have the capability to handle containers. To do so you must have a dedicated loader and an actual building with a caster or roller deck. A bulk-loaded Caravan, on the other hand, needs no additional equipment other than the hands of the handlers and freight can be moved directly into a truck or van. for delivery. For illustration picture the difference between Bellingham, WA and Wolf Point, MT. Both feeder markets, but quite different in size.
dopplerd
Sat May 23, 2020 2:37 pm
V/F
Thank you, you are correct. I intended to write "right hand outboard" but apparently did not. :banghead:
DiamondFlyer
Sat May 23, 2020 3:29 pm
Lightsaber
Bulk loaded feeders for FedEx/UPS are rarely unloaded straight onto the delivery vehicle. They generally unload into trucks to take it to the local FedEx/UPS facility, where they are then sorted for delivery. FedEx could easily build a small loader for the 408, that's portable and not very large, because of how low the plane sits to the ground.
keesje
Sat May 23, 2020 4:10 pm
At the time Fedex launched the Skycourier, they also launched the ATR72-600F. For that aircraft the Cargo door is front of the wing. For the Skycourier, a kind of tail stand will probably be required.
jetblueguy22
Sat May 23, 2020 5:46 pm
Lightsaber
Does FX really pull all the containers off at the destination sort facility? Boys in brown unload containers off the regular unload doors or a special set up where you bring the trailer in parallel and go to town. Very rarely do cans leave the trailer outside of the airport.
Look at sweatpants guy. This is a 90 million dollar aircraft, not a Tallahassee strip club
Spacepope
Sat May 23, 2020 5:49 pm
Though the door is forward on the ATR, the load goes in to the rear first, so why wouldn't the ATR also need a tailstand? And is that really a big issue?
par13del
Sat May 23, 2020 5:55 pm
So this new plane cannot be bulk loaded on routes where it replaces the Sky Caravan?
Just because it takes containers does not mean it only takes containers.
FLALEFTY
Sat May 23, 2020 6:32 pm
Cessna has adapted the Garmin 1000 avionics suite used in the latest model Grand Caravan to the new 408. This should allow for easy pilot transitions for pilots certified in the Garmin 1000-equipped Caravans.
This is a link to the description and photo of the Caravan's latest cockpit for an idea.
https://txtav.com/en/newsroom/2018/12/t ... k-features
JayinKitsap
Sat May 23, 2020 7:33 pm
DiamondFlyer wrote:
HPRamper wrote:
Lightsaber
For efficiency, a truck that can carry 3 LD3's could pull up to the loader that was longer than the tail to keep the truck a bit distant from the plane, adjusts to the height of the plane and truck. If it had power rollers it would be loading straight onto the truck, it pulls off, 2nd truck delivers the 3 LD3's going out which are loaded. Pull the loader back and the plane is gone in well under a half hour. All on the tarmac out in the rain.
Lightsaber- I have not seen any info on the planned number of SkyCouriers and Caravan's. The caravan has a useful payload of about 2,500 lb with a half tank of fuel, so a bit less than half the payload. So stations that need 1 Caravan delivery a day would probably stay Caravan, stations that need 2 or more Caravan's, in particular those that need more than 2. Edit - this would be for the morning delivery and later the evening pickup. Do some stations only get a single daily, so a very early cut off on next day air?
DiamondFlyer
Sat May 23, 2020 8:36 pm
Most of the small feeder cities, get the plane that comes in during the morning, and it sits until the evening, when it's timed to fly back to the larger city to meet the jet to the hub, with enough time to shift the freight to the jet. When I flew UPS feed freight, it depended on the city you were in, but some places in Northern Arizona had drop off times of noon or so, in order to make Next Day Air.
KD5MDK
Sat May 23, 2020 11:11 pm
V/F
Here I was wondering if it was to direct exhaust away from people working at the loading door.
DiamondFlyer
Sun May 24, 2020 3:39 am
V/F
Very unlikely to be hot loading a 408.
keesje
Sun May 24, 2020 1:49 pm
V/F
Interestingly all Skycourier drawings / art work from recent years has the exhaust pipes level. Probably some testing / validation going on.
Fedex ordered their with 4 horizontal exhaust pipes :wink2: . https://www.aircargonews.net/airlines/f ... turboprop/
I would not be surprized if the test flight configuration was a result of previous ground tests / plating getting warmed if e.g. the wind blows from the wong angle.
source : https://cessna.txtav.com/en/turboprop/skycourier
