kiowa
Cancelled fights at MDW Christmas Eve
Tue Dec 24, 2019 2:16 pm
https://www.marketwatch.com/story/fog-f ... =bigcharts
Why would so many flights get cancelled at MDW and not at ORD because of fog this morning?
ATCJesus
Re: Cancelled fights at MDW Christmas Eve
Tue Dec 24, 2019 2:30 pm
One is a lot closer to the lake than the other.
IAHFLYR
Tue Dec 24, 2019 2:37 pm
MDW landing mins are much higher than ORD due to the lack of CAT II or CAT III approach capability at MDW.
Weatherwatcher1
Tue Dec 24, 2019 2:56 pm
I believe the RNAV approaches are the best possible at MDW. With 100 foot ceilings, nothing has arrived since 2am. ORD has CATIII ILS.
As a side note, due to flow control and many regional jets not being able to make CAT III approaches, ORD is almost exclusively mainline this morning. The regionals can’t get in with 100 foot ceilings.
flight152
Tue Dec 24, 2019 3:01 pm
Visibility is the controlling factor with approaches, not ceiling height. Several regionals can do Cat 2 approaches.
jakeroberts212
Tue Dec 24, 2019 4:26 pm
Fun times for the WN staff at MDW today. Imagine emotions are running high at being told your flight is cancelled on Christmas Eve and WN (I believe) has no interline partners to rebook passengers on other airlines.
I get weather issues are out of WN's hands, but at least AA and UA have options if their regional jets can't land to either book them on mainline flights or other airlines if there's space.
IAHFLYR
Tue Dec 24, 2019 4:30 pm
Exactly correct, visibility controls straight-in landing min.....ceiling applies for circling approaches though ceiling can certainly have an impact on straight-in approaches just not determining the mins.
Weatherwatcher1
Tue Dec 24, 2019 4:40 pm
I didn’t see what the visibility was. I only saw 100 ft ceiling, so I assume visibility was also very low
bigb
Tue Dec 24, 2019 4:47 pm
Visibility was definitely below CAT II mins for some time this morning which affected regional dispatching of flights I am sure.
zuckie13
Tue Dec 24, 2019 4:48 pm
Visibility controls, but good luck having that visibility for landing if the ceiling is below the decision height.
ScottB
Tue Dec 24, 2019 4:59 pm
The availability of interline options doesn't help much when everyone's running 90+% load factors and you're at a hub. OK, maybe a Global Services passenger might get one of the three available seats on Delta but pretty much everyone else is just as screwed as they would be on WN. The interline option is much more of a help when you're trying to avoid going through a hub that is melting down due to weather or power outages or whatever.
swacle
Tue Dec 24, 2019 5:08 pm
The lowest I saw was 1/8 mile and 100 foot ceilings, well below minimums.
Aircraft Flown: SF3 DH8 DH4 328 ERJ CRJ CR7 CR9 E70 E75 D9S M80 712 72S 732 733 734 735 73G 738 739 739ER 752 318 319 32
mikezc128
Tue Dec 24, 2019 5:14 pm
Looks like a United 777 diverted to MKE this morning.
http://flightaware.com/live/flight/UAL9 ... /KSFO/KMKE
Threshold Aviation Photography
Wags69
Tue Dec 24, 2019 5:17 pm
Was rough driving this morning. Was driving by KDPA along the east perimeter, and could barely see the threshold lights to 33.
Cubsrule
Indeed. I bet the other airlines serving MDW had barely a 738 worth of empty seats between them, if that. Also keep in mind that because of the way that WN's network works -- where the vast majority of connecting passengers have options over at least four or five "hubs" in different parts of the country -- WN can reprotect in house in a similar way to how interlining works for a carrier that might have flights to just a hub or two from a given outstation.
jakeroberts212
Tue Dec 24, 2019 7:38 pm
I don’t know if I was on another planet, but the couple of times I’ve flown on Christmas Eve, including last year, the flights have been empty. What’s all this concern about no space on other airlines today?
Cubsrule
Tue Dec 24, 2019 8:00 pm
Load factor really is irrelevant given WN's share at MDW. If DL had a load factor of zero, it still wouldn't be able to accommodate even 5 percent of the WN passengers.
Scarebus34
Tue Dec 24, 2019 10:33 pm
The fog lasted much longer at ORD than MDW.... however, WN is terrible in IRROP situations and since their planes typically don't do out and back flying, its easier for them to cancel their way out of a mess. MDW also does not have a Cat II/III approach, ORD does.
Scarebus34
Tue Dec 24, 2019 10:34 pm
Not necessarily - depends. You can have 1/8SM visibility but RVR greater than 6000. This would not be below minimums.
jakeroberts212
Tue Dec 24, 2019 10:45 pm
I hear you, but if WN interlined they could have at least sent passengers to ORD where CAT II/III is available.
Dieuwer
Tue Dec 24, 2019 10:53 pm
Don't fly WN in winter. Same goes for JetBlue and Spirit.
Cubsrule
Tue Dec 24, 2019 11:02 pm
I guess, but given that the airport was operating normally by 0900, for which passengers would that have been worth it? It’s a couple of hours gate to gate at best.
ericm2031
Wed Dec 25, 2019 1:56 am
Most airlines avoid rebooking on other airlines for weather. So unless you have some status with the airline or some reason to give the airline that warrants an exception to be made, you would probably be out of luck regardless
IAHFLYR
Wed Dec 25, 2019 1:59 pm
My bad as in my mind I lumped RVR in as the visibility requirement. Seen thousands of times where prevailing is as you mentioned and RVR is well above CAT 1 mins. Thanks for the post.
Varsity1
Wed Dec 25, 2019 2:22 pm
RVR is controlling, some regionals can do CATII down to 100ft/1200RVR
Horizon can do CATIII
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
MIflyer12
Wed Dec 25, 2019 2:36 pm
Is there something structural at MDW that has prohibited installation of CAT II or CAT III capabilities?
kiowa
Wed Dec 25, 2019 3:32 pm
Why would MDW not have the same quality of FAA approaches that ORD has? I would understand that with a less busy airport but you would think that MDW is busy enough to warrant a more precise landing system.
Weatherwatcher1
Wed Dec 25, 2019 4:07 pm
Displaced thresholds because of the airport perimeter being completely closed in by busy streets and development does not lend itself to ILS equipment
jayunited
Wed Dec 25, 2019 5:07 pm
That diversion was do to the fact the captain was a CAT II captain on the 777 and with visibility below CAT II minimum this flight had no choice but to divert to MKE.
I do know fog was in the forecast although I'm not sure what the forecast called for before this flight left SFO, but by the time the flight made it to ORD visibility across the entire region was dropping fast, CAT I and CAT II pilots couldn't land at ORD.
Scarebus34
Wed Dec 25, 2019 7:11 pm
United doesn’t have any Cat 1 pilots. The captain is either high mins (which was the case in the 777) and can fly Cat II approaches down to 1200 RVR or they’re Cat III. Since 1/4SM is Cat II they would have been legal regardless of what the forecast said.
jayunited
Wed Dec 25, 2019 7:42 pm
Its very frustrating when people twist another persons words to try and make their point. I clearly stated the captain was a CAT II captain on the 777 and visibility was below CAT II. Never once stated UA hads CAT I captains.
The second part of my post is not specifc to United Airlines only I stated CAT I and CAT II pilots couldn't land at ORD. Last time I checked UA wasn't the only airline flying into ORD.
wjcandee
Wed Dec 25, 2019 8:13 pm
ATA developed and certified an RNAV approach at MDW that could be flown with its HUD-equipped 737-800s. It worked very well for them. Don't know if WN followed suit, but I know that at the time ATA had a lot more bells and whistles on its 738s (or at least ACTIVATED on its 738s) than WN did.
CriticalPoint
Wed Dec 25, 2019 9:30 pm
Up until 10ish years ago SW pilots were not allowed to use the auto throttles, so they couldn’t do a CAT III if they wanted too.
They can now of course......
wjcandee
Wed Dec 25, 2019 11:46 pm
Exactly. Or autobrakes.
Aliqiout
Wed Dec 25, 2019 11:51 pm
That's not true at all. AS,AA,DL, and UA are all perfectly happy rebooking for weather. They won't for a couple of hours, but they will for a significant delay.
kiowa
Thu Dec 26, 2019 8:03 pm
I thought I remembered reading on the accident report of the SW crash at MDW several years ago that the pilots were using the autobrakes even though they were not authorized to use them at the time. Are you saying that they are now allowed or trained to use autobrakes and autothrottles?
barney captain
Thu Dec 26, 2019 8:13 pm
All of our CATIII approaches are hand flown with the A/P and AT's disengaged - so the authorization to use AT's is irrelevant. We have been doing CATIII approaches for over 25 years.
Southeast Of Disorder
barney captain
Thu Dec 26, 2019 8:18 pm
We are using the AT's and AB's without restriction (except as mentioned above) and have been for many years.
Elementalism
Thu Dec 26, 2019 8:27 pm
Last Friday MSP had some pretty good fog. I couldn't see lights from the ground through the haze until we were over the river going into 30L Was wondering if we would make minimums.
I cant imagine MDW with fog.
mcdu
Thu Dec 26, 2019 8:35 pm
That’s great that WN had lots of empty seats to protect their customers on. Those “four or five” hubs must be a blessing to their customers. Just out of curiosity, how do they get them reconnected at one of those hubs if none of their flights are operating?
Cubsrule
Thu Dec 26, 2019 9:08 pm
Passengers at MDW already were in trouble because of WN’s share. I was speaking of passengers stuck at outstations.
By the way, how many outsourced pilots does your beloved UA have flying airplanes with the globe on them?
CriticalPoint
Thu Dec 26, 2019 9:37 pm
I buy that with the use of a HUD. But only your NGs have HUDs so have have you been doing it for 25 years.
Also we fly CATIII/LAND 3 to the lowest charted mins which can be as low as 300RVR.
So what are SW mins?
barney captain
Fri Dec 27, 2019 3:16 am
All of our NG's and MAX's have the HGS installed - as did the Classics (since about 1995). We have CATIIIa landing mins of 6/6/3 and takeoff RVR as low as 3/3/3.
CriticalPoint
Fri Dec 27, 2019 3:32 am
Impressive! United has HUDs on the 787 only and the only approach we can hand-fly is an SA CATII to 1200 RVR.
I would assume you use a DH instead of an AH? Is that correct?
We can also do 300 RVR departures
barney captain
Fri Dec 27, 2019 3:57 am
We use an RA derived DA of 50' - but for all intents and purposes, if we have the RVR to start the approach, and assuming it doesn't drop, we can likely land. I would love to see us add autoland and with the classics now gone, maybe that will happen (our classics weren't capable). We have to disconnect the AT's and AP no later than GS intercept for any HGS approach (CATIII, CATII Special CATI etc...).
barney captain
Fri Dec 27, 2019 4:12 am
I just looked and it seems like our lowest minimums in MDW is the ILS Z 31C using the HGS. It will get us down to 204' DA with a minimum required vis of 3000RVR.
pdp
Fri Dec 27, 2019 7:49 am
Is this an SWA specific thing? The only ILS for 31C that the FAA publishes is this: https://aeronav.faa.gov/d-tpp/1913/00081ILD31C.PDF
From what I understand (because that chart is an absolute abortion in design) the RA is 250’.
barney captain
Fri Dec 27, 2019 10:38 am
Yes, it's a Southwest custom tailored approach chart supplied through Jeppesen -
mcdu
Fri Dec 27, 2019 11:03 am
If you would like to start the topic about United we could chat there. For some reason I thought this topic was about MDW. My comments were in regards to you saying WN didn’t have any issues with the fog and getting passengers to their destinations.
So in keeping with the topic....That is good WN had all those empty seats at the outstations. I am sure if it had affected the customers they would have been unhappy but apparently it didn’t according to you so glad this has all been cleared up.
Cubsrule
Fri Dec 27, 2019 3:26 pm
Of course it affected passengers. But in a time of record load factors, interlining is hardly a panacea.
Users browsing this forum: 777luver, 9YCAL, ADL77W, Baidu [Spider], bananaboy, Bavd, FormerBHMRamper, Google Adsense [Bot], jodie, kennyomg, MEA-707, minister, Noshow, NZ516, Okcflyer, OldAeroGuy, pascal7z, qfvhoqa, SCFlyer, SInGAPORE_AIR, tphuang, User001, vhtje, worldranger and 236 guests
