LFW wrote:Thanks for the insight into SQs 787-10s not having crew rests. Do the A359 Regional have crew rests? The different seating maps surprise me also, 787-10 C36Y301 verses A359R C40Y263. Both planes, on the above mentioned route, have the same fares.
ElroyJetson wrote:LFW wrote:Thanks for the insight into SQs 787-10s not having crew rests. Do the A359 Regional have crew rests? The different seating maps surprise me also, 787-10 C36Y301 verses A359R C40Y263. Both planes, on the above mentioned route, have the same fares.
I think you answered your own question. The 787-10 has a bit more floor space than the A359, so it should be able to hold more pax. In the SQ configuration you mentioned the 787-10 seats 337 pax versus 303 pax for the A359. That is an 11% CASM advantage all things being equal.
ElroyJetson wrote:Fuel burn numbers that have been discussed say both planes are virtually equal. My guess is on shorter sectors the 787-10 does better while on longer sectors the A359 does better.
RawSushi wrote:ElroyJetson wrote:Fuel burn numbers that have been discussed say both planes are virtually equal. My guess is on shorter sectors the 787-10 does better while on longer sectors the A359 does better.
The A350-900 isn't as light as it can be because Airbus chose to take advantage of lighter materials to build a much bigger wing (it has a bigger wing than the 777-300ER which is a significantly larger plane). Is this the reason why it does well on longer sectors?
ElroyJetson wrote:A compromise is not an advantage. All plane configuration is a matter of balancing the compromises that have to be made.LFW wrote:Thanks for the insight into SQs 787-10s not having crew rests. Do the A359 Regional have crew rests? The different seating maps surprise me also, 787-10 C36Y301 verses A359R C40Y263. Both planes, on the above mentioned route, have the same fares.
If the SQ A359's all have crew rest areas that adds four or five tons of additional weight. Again, advantage 787-10.
The A359 is an excellent long haul plane, but the 787-10 is optimized more for regional routes.
Yahnih wrote:Just had the pleasure of riding both this past weekend on the ICN-SIN RT route.
Although the A359 was quieter, the 78X felt far more roomier, which is contributed by floor space and the windows being larger. Window seats still are covered by the design of the new business seat, but with the 78X windows I found it easier to look out.
78X is perfect for regional routes for SQ. I think SQ long-haul is better with the 777. Their a359 regionals should convert to the international configuration IMHO.
Francoflier wrote:It's always surprised me that SQ ordered both the -10 and the 359 regional. They seem to be doing the same job with only minor differences...
Did they just want the flexibility of having the option to convert them back to standard 359s down the line?
caljn wrote:Yahnih wrote:Just had the pleasure of riding both this past weekend on the ICN-SIN RT route.
Oh geez. This "quieter" nonsense has got to stop. Were you in the same position in both planes while measuring decibels? I have flown the 787-10 several times these last few months and it is certainly quiet, comfortable and pleasant. "Quietness" is utterly subjective at this level of technology.
changyou wrote:A359R: no crew bunk. And designed for two meal service flights. But also overlapping B78X routes due to it being also regional configured.
Eg: flts below 8hrs
zeke wrote:changyou wrote:A359R: no crew bunk. And designed for two meal service flights. But also overlapping B78X routes due to it being also regional configured.
Eg: flts below 8hrs
Are you sure it’s got no crew bunk or something your guessing ? I see nothing in the master configuration list.
changyou wrote:Absolutely.
Crew bunks: 359ULH and 359LH
Nil crew bunk: 359Medium or regional
zeke wrote:changyou wrote:Absolutely.
What is the source for this ? It does not show up in @Airnav.
changyou wrote:From the SIA A350 crew manuals of course.
ElroyJetson wrote:If the SQ A359's all have crew rest areas that adds four or five tons of additional weight.
MartijnNL wrote:ElroyJetson wrote:If the SQ A359's all have crew rest areas that adds four or five tons of additional weight.
A couple of beds weigh 5,000 kg?
MartijnNL wrote:A couple of beds weigh 5,000 kg?
GW54 wrote:Do SQ actually have a A350R? Here in Wellington we see tge A350 which has replaced the old 772R aircraft. Christchurch also get the A350 that replaced the SQ 772ER. We both see the sane A350's which offer the Long Haul product of Business, Premium Economy and Economy. To date we seen virtually every A350 in the 9V-SM* fleet. These aircraft operate long haul out of SIN. As an example 9V-SMJ operated SQ247 SIN-MEL-WLG- MEL-SIN rotation recently. It arrived into SIN from FRA and on return to SIN it operated to MAN. If there are A350-9 dedicated regional configs what are the A/C rego's
