xwb777
Air India announces BOM - STN
Mon Dec 30, 2019 11:56 am
Starting from 20FEB20, Air India will be serving London Stansted three times per week onboard the B787-8.
The news comes after Air India expressed its intentions to expand in London. The addition of STN comes after seeing that it is difficult to expand at LHR.
AI133 BOM0955 – 1400STN 788 146
AI132 STN1530 – 0550+1BOM 788 146
Link: https://www.routesonline.com/news/38/ai ... -feb-2020/
Blerg
Re: Air India announces BOM - STN
Mon Dec 30, 2019 11:57 am
Do they offer connections in BOM or is this primarily introduced for point to point traffic?
xwb777
Mon Dec 30, 2019 12:39 pm
I think its primarily P2P.
VTORD
Mon Dec 30, 2019 1:32 pm
With a 9:55 AM departure, I very much doubt there will be much scope for connecting flights. Maybe a 4 - 5 at most.
voxkel
Mon Dec 30, 2019 1:53 pm
Doesn't AI already fly BOM-ATQ-STN?
PHXWRLD
Mon Dec 30, 2019 1:57 pm
I wonder if AI will follow this up with STN-DEL?
hohd
Mon Dec 30, 2019 2:30 pm
If the flight departed 3 hrs later, then many connections would be possible, but with this timing only connections could be from large cities which already have multiple connections or direct flights to London..
africawings
Mon Dec 30, 2019 2:32 pm
Wouldn't Gatwick be a better option to Stanstead?
Galwayman
Mon Dec 30, 2019 3:22 pm
STN is perfect for Air India , handy for London , Birmingham and the Midlands ...
Galwayman
Mon Dec 30, 2019 3:25 pm
STN is infinitely better to capture P2P and the Indian diaspora within the U.K.
Slash787
Mon Dec 30, 2019 3:32 pm
Which route are they cutting/reducing in order to start this route?
B747fanReal
Mon Dec 30, 2019 3:34 pm
They’ll be using one of the aircrafts(the last stored wide body which is expected to be back in service) for this route according to Times Of India
Sent from my iPhone XS MAX using Tapatalk
flybhx764
Mon Dec 30, 2019 3:40 pm
I thought they would time this so this aircraft would rotate on the stn to atq sector.
VT-ANB and VT-ANJ are the current 2 x 787s not in service.
hohd
Mon Dec 30, 2019 4:04 pm
No it is DEL-ATQ-STN.
Delta28L
Mon Dec 30, 2019 4:09 pm
Is this route suppose to be an alternative to EKs STN-DXB?
avier
Mon Dec 30, 2019 5:23 pm
The aircraft rotation is BOM-ATQ-STN v.v.
https://www.flightradar24.com/data/flights/ai165
Spiderguy252
Mon Dec 30, 2019 6:15 pm
AI followed through on BOM-NBO as well.
But I believe they were also set to launch DEL-MAA-Bali but that hasn't happened. Any word on that, or is that plan shelved?
Vahroone
vadodara
Mon Dec 30, 2019 11:30 pm
Any ideas on the size of this market?
SQ317
Tue Dec 31, 2019 12:00 am
In a word, huge
caliboy93
Tue Dec 31, 2019 4:46 am
Why did they choose STN over Gatwick given that the latter is the 2nd major airport?
voxkel
Tue Dec 31, 2019 4:56 am
I think the Indian diaspora is closer to STN.
On another note is this just making STN-ATQ-BOM a non-stop, or will this be in addition to the 1-stop via ATQ?
tso310
Tue Dec 31, 2019 5:15 am
As Voxkel states STN is relatively easy to get to from the East Midlands plus having started the Amritsar flights a few months ago they must be satisfied with with STN.
smallvoyageur
Tue Dec 31, 2019 10:57 am
Well you have the hourly CrossCountry trains which travels from Birmingham to Stansted, via Leicester and Peterborough. The only snag is this service is notorious for delays.
gilesdavies
Tue Dec 31, 2019 11:01 am
Going by Air India's lack of punctuality, most flights will probably be delayed by 3+ hours anyway and will be perfect timing for the connections you suggest! :rotfl:
VTORD
Tue Dec 31, 2019 12:22 pm
This is an additional flight. AI165 has a 03:10 AM departure out of ATQ. The a/c rotation on AI165/166 is BOM-ATQ-STN-ATQ-BOM whereas on this one is BOM-STN-BOM
https://twitter.com/KaranAtALounge/stat ... 5799977984
avier
Tue Dec 31, 2019 2:16 pm
AI was keen to fill up the void left by the now defunct 9W on the BOM-LHR route, which had upto x3 daily on a 77W. However, due to lack of slots at LHR, they chose STN. They could have instead shifted the x7 weekly of (which is split between) BLR/AMD-LHR , to STN.
And used those freed up slots for second daily BOM-LHR, rather than this split airport operations for BOM-London flights. Also BOM has considerable premium traffic over BLR/AMD, to make that justifiable.
hohd
Tue Dec 31, 2019 2:42 pm
AI already flies to Birmingham from ATQ and DEL, so this flight is in addition to that. Perhaps to capture BOM market for Birmingham and Stansted area. Regarding premium traffic, BLR also has fair amount of premium traffic, AMD not much.
The only void in the UK network is now Manchester, which Jet was flying, perhaps AI should try either from BOM or DEL or both.
