jayunited wrote:United this past weekend and also today UA operated several humanitarian flights out of Peru and Ecuador trying to help stranded Americans get home. So far I don't see any more humanitarian flights loaded in the system but that does not mean The State Department isn't working on securing more flights in the future if needed.
More cargo flights have been loaded into the system for later this week. For now it looks as though UA is resticting these flights to ORD. EWR and IAH, also for now all of these international cargo flights are operating to Europe. I'm not sure if UA will operate any cargo flights to/from Asia once our passenger operations to/from Asia is reduced to SFO-NRT early next week. But for now UA is still operating HNL/SFO/EWR/DEN/IAD/GUM - NRT and SFO-SIN. With the exception of GUM, and HNL every other flight to NRT today had a ton of cargo on it, so it will be interesting to see what happens with the cargo once the remainder of our flights except for SFO are suspended.
ericm2031 wrote:Do we know if they are only loading cargo into the cargo pits or are they loading cargo into seats as we've seen some other carriers doing? Same question for the AA flights, is this something allowed by the FAA or only in some foreign countries? Is DL doing any cargo-only flights?
jayunited wrote:ericm2031 wrote:Do we know if they are only loading cargo into the cargo pits or are they loading cargo into seats as we've seen some other carriers doing? Same question for the AA flights, is this something allowed by the FAA or only in some foreign countries? Is DL doing any cargo-only flights?
I don't see UA going as far as removing seats from aircraft to carry cargo. An empty passenger compartment on a 77W flying to Europe from ORD, IAH, or EWR means an airline could potentially carry around 100,000 pounds perhaps even 110,000 pounds of cargo in the belly depending on the fuel requirements. Also keep in mind UA because we are only using a small portion of our fleet as cargo charters we need to turn these aircraft in Europe fairly quickly. Loading individual boxes in the passengers cabin and having employees walk these pieces up and down stairs slows down the turn around time and there is the potential for employees to get injured since they wouldn't be able to hold on to the handrails while entering and exiting the cabin of a 77W or 789.
calpsafltskeds wrote:739:
38417 exited VCV 2753/22Mar in EvoBlu livery
Storage: I have a color-coded spreadsheet that's hopefully somewhat up to date her:
https://sites.google.com/site/unitedfle ... ris-update (tabs at bottom for different fleets - Express fleet not checked yet.
Assume the following in storage: (in addition to the below, several line stations have numerous aircraft parksed of which some may be longer term and some will rotate in and out of service)
ROW
319: N838UA, 320: N227UA, 738: N25201/N73291, 739: N72405, 752: N512UA/N595UA/N18119, 753: N77867, 772: N219UA/N220UA/N221UA/N222UA/N768UA/N799UA
IND:
763: N665UA/N675UA/N677UA
MCO: (some could be maint or will rotate in/out of service)
752: N21108/N18122/N13113/N17122/N48127, 753: N75851/N75861, 763: N664UA/N667UA/N670UA/N671UA
TPA: (some could be in maint or will rotate in/out of service)
738: N27213/N37255/N35260/N78285/N37290, 739: N75432/N78438N66903/N61881
GYR: (could be maint, possible fleet exit storage)
320: N432UA, 752: N14115/N13138
ROW
IND:
calpsafltskeds wrote:Are you talking only mainline or Express as well and is the 43 UA only? I assume that includes aircraft on gates.
Looking at DEN, there are 4 788s on the ground and all the rest are narrowbodies that aren't departing today.
Interesting that about 10 of the 16 or 17 narrowbodies have upcoming flights scheduled after about 2 days on the ground. I only see 6 319/320s that do not have a flight scheduled. FR24 only allows me to go back a week without upgrading from Silver.
Maybe more cancellations are on the way or UA wants to keep aircraft moving every couple of days at this point.
KVH68 wrote:jetmatt777 wrote:Anything that isn't headed to the desert (for right now) will be rotated around the schedule to spread around hours to keep maintenance items low. (Cycles and hours). I'm sure as the schedule continues to deteriorate this will change but that is what we have heard right now.
That sounds like a good plan. When you fly the planes on a rotation, you don't have to use resources to put them into short-term storage. Besides, planes like to fly. When they sit on the ground too long, the seals relax and they develop hydraulic and fuel leaks.
N649DL wrote:KVH68 wrote:jetmatt777 wrote:Anything that isn't headed to the desert (for right now) will be rotated around the schedule to spread around hours to keep maintenance items low. (Cycles and hours). I'm sure as the schedule continues to deteriorate this will change but that is what we have heard right now.
Very true but if UA can do what AA did and switch out to have all cargo flights (maybe using those HD domestic 777s) that could be a win. The 763s are older and the ex-3 class variants always had lower cycles so those should be temporarily stored for future use as many have brand new interior configurations.
calpsafltskeds wrote:752:
Hopefully the transcons have good cargo loads as the seat maps are awful... I don't understand why UA doesn't cancel the narrowbodies in these markets unless they are bulked out as well - hopefully they are.
calpsafltskeds wrote:Jay, I've been looking at a combination or United.com and the UA app for the schedule, type flown and seat map before and after departure. Of course I can't see what's in the bins, but it looks like the flight schedule should be 3 or 4 a day evenly timed out and probably all wide bodies, assuming the bins are full with freight.
For example, last night EWR-LAX had a 752 and a 772A run 30 mins apart in the dinner hour with 13 & 26 seats taken. On the return UA ran 3 redeyes LAX-EWR 1 wide and 2 narrows with 50, 30 and 15 passengers.
Pretty close to the same on EWR-SFO-EWR, with 2 redeyes east and 2 light trips westbound at 6pm and 8pm.
I can't see why one narrowbody RT wasn't cxld in each market.
calpsafltskeds wrote:I wonder if WN could short-term lease at least some of their 73Gs sold to UA.
jetblastdubai wrote:calpsafltskeds wrote:I wonder if WN could short-term lease at least some of their 73Gs sold to UA.
With projected demand down for the coming months, UA could probably use more of their smallest mainline fleet type in the air instead of the larger ones.
Additionally, throwing WN a short-term lifeline isn't something I would think UA would ever want to do after the cut-throat way WN went after UA in years past when UA was having issues.
CALTECH wrote:
There is no demand for MORE aircraft. Many will get parked, maybe for good.
calpsafltskeds wrote:JetBlast, my thought was instead of parking either 73G or larger narrowbodies, just lease them to WN. The expense to operate a 738 or 739 isn't much more than a 73G. It would park fewer aircraft and bring in revenue.
You'd rather have UA park more aircraft than bring in revenue from any source? Doesn't make sense.
calpsafltskeds wrote:Anyone shocked by the njumber of the flights currently in the air by operator? 3/26/20 at 2131 EDT
UA roughly 1/6th of WN and a 13rd of both AA and DL. It could be UA's aircraft are at hub airports?,
307 SWA Southwest "Southwest" (Dallas, TX)
169 DAL Delta "Delta"
161 AAL American Airlines "American"
131 SKW SkyWest "SkyWest" (St. George, UT)
126 CSN China Southern Airlines "China Southern" (China)
107 ASA Alaska Airlines "Alaska"
89 CCA Air China "Air China" (China)
79 CES China Eastern "China Eastern" (China)
70 JAL Japan Airlines "Japanair" (Japan)
67 NKS Spirit "Spirit Wings" (Miramar, FL)
61 JBU JetBlue "JetBlue"
56 UAL United "United"
codc10 wrote:calpsafltskeds wrote:Anyone shocked by the njumber of the flights currently in the air by operator? 3/26/20 at 2131 EDT
United had fewer daily flights than AA/DL/WN to begin with, and more international. UA also was very aggressive in cutting its March schedule. Not terribly surprising.
I understand that but since UA already bought these 73Gs, wouldn't it be better to utilize them instead of the larger narrowbodies in the fleet? If they're going to park A/C anyway, it might as well be A/C that they'd have a harder time filling as well having slightly higher operating costs.
There was talk of using bigger jets to grab cargo business.
It is no longer talk for the next few weeks UA will be operating up to 40 cargo flights per week. Most cargo flight are being operated on either 77Ws, 78Xs, and 789s, from time to time we are using 77Es, however UA will not be using any 767s for cargo flights.
Also just happened to check and today March 27, 2020 at 22:31 zulu time UA only has 75 flights in the air at different phases of their flight. It is hard to imagine that on a Friday evening generally one of the busiest travel days UA only has 75 mainline flights in the air.
jayunited wrote:...however UA will not be using any 767s for cargo flights.
airplanedriver6 wrote:jayunited wrote:...however UA will not be using any 767s for cargo flights.
Interesting. Everything must be in containers or on smaller pallets, no?
Doesn't the 767 have the largest cargo door in UA's passenger fleet?
jayunited wrote:calpsafltskeds wrote:Jay, I've been looking at a combination or United.com and the UA app for the schedule, type flown and seat map before and after departure. Of course I can't see what's in the bins, but it looks like the flight schedule should be 3 or 4 a day evenly timed out and probably all wide bodies, assuming the bins are full with freight.
I get what you are saying canceling a narrowbody roundtrip and put those people on a widebody. United could do that but one thing we are hearing from flight attendants and customer service agents is social distance adherence guidelines on aircraft. While there are no official guidelines UA is saying if a customer request to be moved into a different seat the customer service agents comply. We do have gate agents asking if they have a narrowbody with only 25 people on board can they just move people themselves in SHARES into different seats to keep that social distance. So far UA's position has been for the agents to use their best judgement and if a customer asks to be place back into their original seat just move them back. We also a few days ago on UA2 SIN-SFO had a situation arise where there were only 28 seats booked in business class and over 120 people booked in coach. Originally there were no upgrades so SIN C.S. spaced out the passengers in business class and did the best they could to space customers out in coach. However that all changed once the flight opened to check-in at the airport 15 passengers wanted to either use their miles or pay cash for the upgrade into business class. The question was can we sell those seats? United position was do not give the seats away for free people know the risk if they want to pay to sit in close proximity to someone for 15 hours then sell the seat.
In conversations with my bosses yesterday they fully expect the industry to change as a result of COVID-19, just like the industry changed as a result of 9/11. Right now the government is saying social distance but are airline to enforce that policy, so far I'm being told we can't get an answer to that question from the FAA, DOT, or Trump Administration. My bosses are telling me that UA already has teams putting together scenarios that will cover any policy changes that come about as a result of COVID-19. From best case scenarios to worse case scenarios. Some experts on Trumps coronavirus task force are now saying COVID-19 might become a seasonal thing where we see cases drop but then rise again in November and December. United has teams looking at how this will impact the airline, will we need to remove rows of seats from aircraft? Will we need to block middle seats and only have passengers seated in window and aisle seats? Airlines know the cabin filtration system can remove COVID-19 from the air as the air is recycled. But how does an airline protect a passengers from the passenger seated next to them. For example a passenger seated in row 7A and 7C, that air hasn't had a chance to be recycled, how do protect passengers onboard? Will airlines be required to protect passengers onboard, will we in the very near future be required to take every passengers temperature before they board a flight? It was such an incredible conversation I had with with my boss yesterday just to get an insight into what UA is thinking the future of this industry will be and the changes COVID-19 will have going forward.
DL stated they will be a much smaller airline coming out of this I think a lot people took that to mean less flights, but what if in addition to less flights it also means less people on each airplane? UA like I said has teams of people (working remotely) working on this because we know (or at the very least we expect) there will be changes once the pandemic portion of this virus is over. COVID-19 is here and even with a vaccine my bosses are saying they are being told COVID-19 is probably here to stay even once a vaccine is widely available. So how do you protect customers and employees on an aircraft in the future?
If part of the solution to protect passengers is to remove seats or block seats on aircraft what impact will that have the ticket prices?
calpsafltskeds wrote:Jay, that makes perfect sense. The 767 floor issues and lack of taking normal pallets or LD3s width-wise is the problem. However, if using narrower LD2 containers (25% less space than an LD3), the 767 can pair those units for decent cubic footage, but isn't standard for many shippers.
For what it takes, here's the volume of total LD2 and LD3 spaces on below aircraft. Does not include bulk bins or floor weight issues:
763 30 LD2s 3,720 CF
788 28 LD3s 4,452 CF
764 38 LD2s 4,712 CF
772 32 LD3s 5,088 CF
789 36 LD3s 5,724 CF
78X 40 LD3s 5,360 CF
77W 44 LD3s 6,996 CF
calpsafltskeds wrote:More stored aircraft.
All 764s appear are parked or stored. 9 in ROW.
Many 763s in IAH, plus 4 in ROW storage
10 772s in ROW storage
9 of 10 752PWs in ROW storage. N596UA been in SFO since 3/21
Parking locations: SFO, ORD, DEN, IAH, IAD, EWR, MCO, GUM, HNL, MSY, MIA, TPA, SAT, CLE, AUS, BOX, FLL, LAS, LGA, PDX
Storage/maint: ROW, GYR, INT, DLH, LCQ, ILN, HKG, XMN, VCV
77H wrote:calpsafltskeds wrote:Jay, that makes perfect sense. The 767 floor issues and lack of taking normal pallets or LD3s width-wise is the problem. However, if using narrower LD2 containers (25% less space than an LD3), the 767 can pair those units for decent cubic footage, but isn't standard for many shippers.
At the risk of sounding pedantic, about ~18 or so of the PW 77E’s only have 28 positions. The 77U subfleet according to your UA Fleet page.
Excellent work on that by the way.
77H
