calpsafltskeds
Re: United Fleet, Network, & Livery Thread - 2020
Tue May 19, 2020 6:42 pm
About half of the 772A fleet is flown every few days with the other half being parked/stored over 4 days. N777UA was last flown 5/3 - I have noticed some units scheduled to go back into service after a couple weeks get cancelled or rescheduled, so we'll see what happens with this unit. As mentioned previously, if loads look like a tight fit, UA has been scheduling larger aircraft a couple days out.
tphuang
Tue May 19, 2020 6:45 pm
I just saw that UA is starting to remove seats from some of its RJ to be compliant with scope agreement. Does that mean we will see more CRJ550? Or is this a different type of conversion?
Blockplus
Tue May 19, 2020 6:59 pm
2big possibilities I see. 1. They are preparing to furlough more pilots than Jan 2016 hire date ( that mandates removal of seats) or . The republic e170s are gonna disappear. As they are smaller and burn about as much as the 175 advanced even configured to 70 seats.
codc10
Tue May 19, 2020 7:34 pm
I think that number (post-Jan 2016 hires) is around 2200 or so. Unfortunately, I think it indicates the former, barring some sort of miraculous recovery.
MIflyer12
Tue May 19, 2020 7:36 pm
fun2fly wrote:
Two comments: "new" is the term they stated, not used or perhaps all used will be delivered in 2020/2021. Either way, capex will be down a lot.
The use of 'new' in that context is interesting. Given the commitments for used aircraft there could be more clarity. From Reuters, emphasis mine:
United, which is due to present at the Wolfe conference later on Tuesday, said its total adjusted capital expenditure for 2021 would be close to $2 billion versus around $4.5 billion this year, falling to below $500 million in 2022 when it does not expect to take delivery of any new aircraft. It is taking fully financed jet deliveries this year and next.
How about unfinanced aircraft for 2020-2021? Are they saying those are deferred, or that everything committed is financed?
https://www.reuters.com/article/us-heal ... SKBN22V1Y9
adamblang
Tue May 19, 2020 7:37 pm
N3340W wrote:
So it appears that N777UA is being dusted off for a flight tomorrow (5/20) SFO-EWR as UA711. Was this expected, or a surprise to those who follow the fleet status?
Good to have the original 777 in the air on the 25th anniversary of the type's first revenue flight (June 7, 1995).
tphuang
Tue May 19, 2020 7:53 pm
pretty sure they are deferred. They said earlier that they are only taking fully financed MAX jet until demand comes back. I assume that taking widebodies are lower on their priority list right now.
Boeing12345
Tue May 19, 2020 11:49 pm
jayunited wrote:
ordbosewr wrote:
The SEC filing does not specifically call out any of the types of capital expenditures. The reference to the 787's expected is not called out, but likely.
It may be that the $2B includes both widebody and narrowbody, I do not know.
I would be shocked if UA restarted the Polaris/PE program before Q4 2021 at the earliest. Looking at the fleet except for the 3 PW 77Es that were scheduled to join the domestic fleet the only 77E frame without Polaris/PE is N77014. Of the 763 fleet only 7 frames still have the old diamond seats those frames can either be held in long term storage or retired (they are some of the oldest frames in the fleet). The 77Ws and 78Xs are being delivered with Polaris/PE installed this just leaves both the 788s and 789s. Of the 12 788s in the fleet only 4 have been reconfigured and of the 789s delivered prior to Q4 2019 only 2 have been reconfigured. Basically once the recovery starts UA could just leave the 764s, the 7 763 frames that have diamond seats and the one 77E in storage. By doing this UA could then assure passengers on any international flight operated by a 77W, 77E, 78X, and 763 that their flight would be on a Polaris equip aircraft. That leaves only the 788s/789s, UA could either isolate the Polaris/PE equip 788/9s to certain routes or let them all float around the system.
Looking at the narrow body fleet UA has done a great job with the A319 fleet with the exception of 14 frames the entire A319 fleet has been reconfigured with 12 brand new first class seats. The 14 frames still in the old configuration of 8 first class seats are all in storage. The entire 753 fleet has been reconfigured with 234 total seats. Only 11 RR powered 752 have been reconfigured with slimline seats, (not sure if those 11 frames are part of the 16 frames stored at airport locations or if they are part of the larger fleet stored at long term facilities like ROW, I simply don't feel like cross referencing the tail numbers).
Also I think construction on new United Clubs and Polaris lounges will cease until 2022 at the earliest, even at an airport like EWR where a UC is so desperately needed I think everything is on hold until our financial situation improves.
910 de-preservation has started and inducting June 2nd in XMN for Polaris and C4.
912 de-preservation started and also induct on June 2nd for Polaris mod.
ericm2031
Wed May 20, 2020 1:35 pm
Care to elaborate? All the CRJ700s were planned to be converted to G7 CRJ550 except for some OO birds to that are needed for ASE and MMH. But there are some strong signs on both the OO and YV earnings calls that G7 is struggling financially and this is currently on hiatus.
CALTECH
Wed May 20, 2020 1:50 pm
strfyr51 wrote:
Okcflyer wrote:
The problem with the 764 is that it has too many unique attributes. Special gear based on 777 design. Special flight deck with 777 components and not used on another high volume 767. In UA’s case, the only CF6 on property. All of these increase execution risk and therefore cost. While the frame itself is efficient, it doesn’t fit within synergies of a large organization.
Stick a fork in most 777HDs (mid 90’s). Those only make sense on Hawaii service from IAH/ORD/DEN/SFO (maxed with cargo).
The 753 is a similar story. Good economics when flying. Stranger. Not worth the time and effort without a large 752 fleet as well.
I think most interesting will be what happens on the narrow bodies. Retirements will happen, especially as MAX’s are delivered. *What* retires first will be most interesting. Early IAE powered Airbuses? Early CFM 737’s? Will the A319/737 size stick around in numbers (Meaning A320’s / 738’s retired) or will the smallest get the whack.
In the booming economy, the small incremental cost of the 738/A320 was considered trivial and easily covered by revenue management practices.
With a contracted market, those 5-6% cost savings can add up, and I’ve always wonder if the engine maintenance factor was properly accounted for. Due to their lower trust, they don’t deteriorate as quickly (fuel savings) and can last longer before overhaul. I suppose in large fleets those smaller birds for the longest time engines off the heavier-worked frames.
you could be right however? I suspect that you're wrong. the 737-700's and maybe non ETOPS 737's might be leaving if any are. the A319;s all have the range to fly conus to HNL and all over the Americas. North to south. they can be the backbone of the returning passenger traffic domestically until we need larger airplanes on a daily basis.
All 737s are ETOPS.
No A-319/320 are ETOPS.
airmec7 wrote:
All 737’s are ETOPS and no 319 is over water certified. Only a small handful of 320 are over water certified.
Do not see any Airbus aircraft ETOPS certified.
All 737s are ETOPS as you stated.
You are here.
codc10
Wed May 20, 2020 2:06 pm
All 737s are ETOPS.
Some 320s have rafts for EOW operations in the Caribbean but no ETOPS.
tphuang
Wed May 20, 2020 2:14 pm
It was my ignorance. Looks like this is related to pilot contract and furlough.
CALTECH
Wed May 20, 2020 2:21 pm
codc10 wrote:
CALTECH wrote:
All 737s are ETOPS.
Yes, the 41XXs and 47XXs, they are Over Water equipped but are not ETOPS.....
4101
4102
4106
4107
4108
4171
4172
4173
4703
4704
4705
4709
4710
4711
4712
4713
4703
You are here.
calpsafltskeds
Wed May 20, 2020 2:22 pm
752:
N14115 exited GYR maint 2699/18May, now in IAH
N13138 sked to exit GYR maint 2759/20May, heading to IAH
789:
N29978 sked first revenue flight 2816/21May IAD-DUB
ericm2031
Wed May 20, 2020 6:22 pm
I found the article, and it too was confusing. Sounds like they need to get some 76-seaters under scope or they will have too many.
Nicknuzzii
Wed May 20, 2020 6:31 pm
Little sign of life today at EWR. UA running about 42 flights a day now instead of the typical 15.
Pi7472000
Wed May 20, 2020 6:47 pm
Will EWR be considered a hub over the next year or a focus city? I know they seem to be leaving LAX, except for hubs, which is sad as they were always the airline I flew all over the world out of LAX in the 1990s and 2000s. Hope they can come back to LAX and make it the hub it once was!!
CriticalPoint
Wed May 20, 2020 6:51 pm
It’s a hub.....do you not see what’s going on in the world?
airplanedriver6
Wed May 20, 2020 7:01 pm
Apples and oranges.
UAL has said they will be converting the 76 seat E175s to a 70 seat config to comply with the scope section of the pilot contract in the event of significant furloughs. Note that United Express already flies some 175s in a 70 seat config so this is not a radical change.
atcsundevil
Wed May 20, 2020 8:45 pm
Downgrading EWR would effectively mean abandoning the New York market. There is a 0% chance that happens. LAX is a totally different situation. United controls EWR, and that will have to be pried from their cold, dead hands.
cosyr
Thu May 21, 2020 1:41 am
I feel like the definition of hub and focus city will change for all airlines for the next two years. I don't see UA ceding any market share to AA and DL. If demand picks up faster than their current plans, UA will expand LAX at a similar pace.
atcsundevil
Thu May 21, 2020 3:42 am
Certainly. EWR hardly looks like a UA hub operating 42 flights per day, when three months ago they were averaging that many flights per day. It'll be a very long time before most hub airports begin to look like hubs again. I fully expect to see some fairly significant impacts across the networks of every airline, but I have zero expectation of UA ceding any ground on their position in New York. They will lose whatever amount of money it takes to maintain their position, because their long term future is dependent on it. Their absence at JFK already puts them at a relative disadvantage to their competitors (albeit more a efficient arrangement), so they'll need to maintain their presence at all costs.
intotheair
Thu May 21, 2020 4:32 am
Listening to Scott Kirby on CNBC this morning, it certainly sounds like they’re planning on bouncing back aggressively in competing with the other airlines. Scott said he doesn’t want to furlough anybody and wants to work with unions on reducing hours instead, and it’s been clear in here that they are trying not to permanently retire any aircraft. He must really think demand is going to snap back pretty quickly and that United will be in a good position to compete against DL and AA.
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 CRK Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
Max Q
Thu May 21, 2020 4:42 am
Did UA take delivery of all 77W aircraft from Boeing ?
GGg
FlyHossD
Thu May 21, 2020 4:55 am
Yes. I believe the last delivery was about 2 or 3 months ago (N2352U).
Max Q
Thu May 21, 2020 5:20 am
Thanks for that, is that 22 airframes altogether?
GGg
FlyHossD
Thu May 21, 2020 6:36 am
Yes, 22 777-322s for UAL. Seems like they're getting good use these days flying cargo in the bellies (primarily in the bellies anyway). I rode on one of them SFO to AUK about a year ago which was a good flight and the beginning of a great trip to New Zealand (great people, great country).
This spreadsheet might be useful to you; check on the different types across the bottom: https://sites.google.com/site/unitedfle ... t-tracking
VirginFlyer
Thu May 21, 2020 7:11 am
I hope they flew you to AKL and not AUK! Looking forward to seeing more North American 777s and 787s in Auckland before too long.
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens. —Bahá'u'lláh
fun2fly
Thu May 21, 2020 10:30 am
One think I was thinking of is how creative are airlines going to have to get to fill the LHR slots when the exemptions expire? Will we see UA LHR routes from cities that didn't have one in the past because, for example, UA may not need 6x daily from EWR? Will they move those around the hubs or perhaps a one off route?
Max Q
Thu May 21, 2020 11:58 am
Thanks for the information
GGg
United1
Thu May 21, 2020 1:00 pm
I would imagine if travel is still depressed when the exceptions expire there will be an extension.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
tphuang
Thu May 21, 2020 1:01 pm
I would look at it this way. UA has been the most conservative airline amongst big 4 in terms of flying. That is not a surprise given it's dependence on international widebody flying and it's large debt load prior to start of this crisis. Due to its high TPAC exposure, it also got hit the earliest. Kirby has been very aggressive at lowering cash burn by basically cutting all expenses and not flying. It seems to me based on the recent 76 to 70 seater conversion, they are planning for a massive furlough of pilots after Sep 30. Probably bigger than DL and AA. We also know about the 30% reduction in M&A staff. And they were never as overstaffed as AA to begin with. So they must be doing this with the expectation that they will be a lot smaller coming out of this.
DL just told their pilots yesterday that they expect to be running a little less than 75% of their pre-COVID schedule by end of 2021 and that yields will be garbage until 2022 and will be below 2019 levels until probably 2023/2024. Given the slow recovery of TPAC/TATL market vs domestic and Kirby's larger layoffs, I would expect UA to be bringing back flying even slower than that. my guess is that they will be running at most at 70% pre-COVID schedule by end of 2021 and probably 60 to 65% schedule by Q3 of 2021. They probably won't get back to pre-COVID size until 2025. I don't think any of this is unreasonable assumptions.
So just thinking of running a 65% schedule for fall of 2021, which stations come back sooner. I would think that the mid-continental domestic hubs (DEN/ORD) get brought back sooner, whereas the coastal ones that relies a lot on international flying will come back slower and require consolidation. That's probably why Kirby said he doesn't expect international flying out of LAX this year. My guess is they will consolidate on the west coastal international stuff to go through SFO for a while. Otherwise, what's going to happen to SFO? You can either run like a 60% schedule at SFO and LAX or a 70% schedule at SFO and 45% schedule at LAX. It seems like SFO is a far larger priority for them, so LAX will be under 100 flights a day for a long time imo. And on the east coastal, EWR is their main TATL, TPAC and Latin America hub on the east coast. Again, IAD will be smaller since nobody else is going to make a move there, but it's hard for me to imagine EWR not be a lot smaller given the reduction in 6+ hours international flying demand. With less international flying and reduction in really small RJs, I think it will lead to much fewer feed flights in short term. I don't remember how many flights EWR had pre-COVID but I think it's around 500 or more? I would be surprised if UA is runing more than 350 flights a day out of EWR by end of 2021. And it's going to be hard to get back to pre-COVID level of flights until international demand comes back close to pre-COVID level.
Nicknuzzii
Thu May 21, 2020 1:17 pm
I think UA will be around 85-90% of it’s pre Covid schedule by the end of 2021. By that point the economy should be doing much better. The virus should be behind us but if not won’t it become a familiarity with everyone? Furthermore, for the very small group of people claiming they won’t fly until there is a vaccine, how long could they hold out?
UA has kept EWR pretty much steady in the number of flights per day at EWR at around 415 ish. Almost all of EWR’s growth comes from larger aircraft rather than regional jets. I myself also agree that UA won’t be running more than 350 flights a day from EWR. Maybe not even 300. But would other carriers be willing to come fill the void?
Pi7472000
Thu May 21, 2020 1:22 pm
It seems so hard to even be predicting schedule levels for the fall and winter. If a second wave returns and the economy totally shuts down again except for essential services it seems we could have a repeat of April and May. I would hope they are taking those models into account. Even though a vaccine is not a cure, a safe effective vaccine seems to be what it may take to help UA to have better models to predict long term traffic patterns.
codc10
Thu May 21, 2020 1:24 pm
Kirby has been 100% growth since he walked in the door, outpacing the rest of the industry, and most resources went into the domestic market, while continuing an international expansion program. So I don't think there's precedent to suggest United under Scott Kirby as CEO will suddenly turn into a conservative, "capacity discipline" manager in the post-COVID environment. He's already on the record saying he wants to position the company to "leapfrog" competitors during the recovery, and by that I assume he would be targeting AA, in the main... especially if AA finds itself in another reorganization.
As for the 76 to 70 seaters, here is the provision from the UPA:
1-C-1-h Effect of Furlough
If a Pilot on the Seniority List with an employment date prior to the date of signing of this
Agreement is placed on furlough, the Company shall convert all 76-Seat Aircraft for
operation as 70-Seat Aircraft. The number of such aircraft shall continue to be limited as
though they were being operated as 76-Seat Aircraft. The Company may again commence
operating such Aircraft as 76-Seat Aircraft effective on the date that the most junior Pilot
protected by the first sentence of this Section 1-C-1-h is recalled from furlough.
tphuang
Thu May 21, 2020 1:38 pm
That is true, but Kirby has been doing what he thinks is the right move for UA. Back when he first started, he realized the problem with UA was lack of domestic network on connections, so he started the strategy of building up DEN/ORD/IAH. All of that worked out really well. This time, he has identified cash preservation and survival as the most important move for UA. His moves so far have imo shown that's the strategy for a while. And he has been the most conservative at adding back capacity. Saying many times that UA will only add back capacity when demand comes back. Which is why given the 76 to 70 seaters ( read the seniority list is about 2300 pilot up to the last contract date of Jan 23 2016), I'm thinking it's a good indication that UA is looking to have pilot staff of about 35% smaller. It's going to take a long time to recall/retrain all the pilots afterward.
If EWR was at 415 flights prior to COVID, then I'd be surprised if they are at 300 flights a day by end of 2021.
LAXdude1023
Thu May 21, 2020 1:47 pm
tphuang wrote:
atcsundevil wrote:
I think thats a pretty accurate synopsis. You didnt mention IAH and since its my home airport Ill comment on what I think is realistic.
-Non-Latin Long Haul flying limited to LHR, AMS, FRA, and NRT.
-All Latin destinations remain with the possible exception of some smaller Mexican routes
-Domestic flying will bounce back sooner but at lower levels than previous years. Domestic flying at DEN and ORD will probably come back a bit quicker.
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
MIflyer12
Thu May 21, 2020 1:51 pm
Rephrase your question: What market is better than NYC (for prospective passenger counts and avg fares) for flights to London? They have the power of the EWR hub. They're going to need to maintain EWR-LHR frequency to compete with AA/BA and DL/VS(?).
codc10
Thu May 21, 2020 1:55 pm
Has that actually proven to be the case (that UA is more conservative in adding back capacity than others)? It seems that, as of now, AA and DL are around 12-15% of original (pre-covid) capacity. July will be at a 25% schedule; that's already been guided. I can't see DL or AA being any more aggressive in this respect. Even Southwest is acknowledging the need for dramatic changes by the end of the year *if* demand does not return.
On the Wolfe call a few days ago, in response to a question about recovery, Nocella said they forecast the local markets in United hubs will be the earliest to return, suggesting United would like to quickly ramp service back up. I don't think aggressiveness of cutting in response to the pandemic necessarily signals a conservative approach to recovery. As it turns out, the 'worst-case-scenario' originally forecast (to great shock) by Kirby turned out to be even more optimistic than what ultimately played out. I also question the apparent conventional wisdom that United will return slower, and come out of the crisis comparatively smaller, than its direct competitors. Everything coming from United leadership suggests otherwise.
qf789
Thu May 21, 2020 2:00 pm
United 737MAX9 N27526 positioned MWH-RNT, its first flight since 18 September last year when the aircraft positioned to MWH for storage
https://twitter.com/AirportWebcams/stat ... 36609?s=20
Forum Moderator
STT757
Thu May 21, 2020 2:02 pm
The thing about EWR that people are missing is that they assume UA's domestic operation exists to feed the International. It's the other way around. EWR is a mostly O&D domestic hub for UA and before them CO and before them PE. UA handles more domestic passengers from EWR than B6 and AA combined at EWR, Kennedy and LGA combined. They are slightly behind DL who has 32 million domestic passengers from EWR, Kennedy and LGA vs. UA's 30.5 million domestic passengers from just EWR. EWR has a higher percentage of O&D traffic vs. Kennedy (75.3% EWR, 70.1% Kennedy).
The EWR hub has for most of it's life been a domestic hub which served the large O&D market. Just look back at some of the old schedules:
http://www.departedflights.com/CO103094p33.html
http://www.departedflights.com/CO020187p17.html
http://www.departedflights.com/PE062685p37.html
tphuang
Thu May 21, 2020 2:04 pm
On the Wolfe call a few days ago, in response to a question about recovery, Nocella said they forecast the local markets in United hubs will be the earliest to return, suggesting United would like to quickly ramp service back up. I don't think aggressiveness in cutting in response to the pandemic necessarily signals a conservative approach to recovery. I also question the apparent conventional wisdom that United will return slower, and come out of the crisis comparatively smaller, than its direct competitors. Everything coming from United leadership suggests otherwise.
All the charts have shown that UA has cut the most and AA the least amongst the major carriers. AA is currently flying over 20% of their schedule and probably closer to 25% in June. DL is close to 20% for June and 25% for July. So by July, DL and UA will be flying close to the same portion of pre-COVID schedule. My guess is WN will be over 50% of their schedule by July/August. Again, I'm making estimations on their capacity next year based on their network breakdown and also their work force reduction. It's hard for me to see UA bringing capacity back sooner than DL based on their current moves.
Btw, I'm not criticizing UA for their cuts. what Kirby has done will save them from having to file BK. Coming into this, UA faced possibly the most adversity from this due to its high debt load, large widebody fleet and high exposure to international flying.
codc10
Thu May 21, 2020 2:25 pm
It will be interesting to see how things play out, and, as I've discussed in other threads, I don't think it's reasonable to extrapolate long-term strategies from crisis-mode April/May 2020 schedules. But if we are going to take representations of airline management at face value, it would appear (and this is demonstrated by track record) that this management team is far more growth-oriented than previous groups, evidenced by speaking publicly about attempting to regain market share during the COVID-19 recovery. I would expect United, under Scott Kirby, to be anything but conservative. That's really not in his DNA.
AVENSAB727
Thu May 21, 2020 5:57 pm
Pretty spot on, but SYD resumes on 23 Oct, MUC on July 6.
Always look on the bright side of Life!
LGeneReese
Thu May 21, 2020 9:19 pm
..... subject to change of course..... probably several changes.....
LAXintl
Thu May 21, 2020 9:27 pm
Some color from VP of Flt Ops about demand and schedule outlook.
Many of you have written about a competitor who is adding 100 flights and you are asking about what we are doing. One metric I like to track is the TSA passenger throughput. You can see for yourself that traffic, unfortunately, is still incredibly low. On May 19 for example, only 190,477 passengers passed through TSA checkpoints compared to 2,312,727 on the same day last year. We are seeing very minor improvements, but the improvements are painfully slow. There were days in March and April where we saw fewer than 10,000 passengers fly on United aircraft. Yesterday we carried a total of 32,417 passengers with 28,043 revenue passengers, 1,008 positive space travelers and 3,366 NRSA travelers. Last year at this time we would have carried well over 500,000 passengers daily. The good news is that in July our schedule is planned to be down about 75% down vs. the 90% reduced schedule we will fly in May and June. We will seek to add flying back in a responsible way that allows us to add capacity where it makes sense, but also allows us to be laser focused on cost to reduce our daily cash burn.
.... basically don't look for UA to add blanket capacity. Focus on filing existing flying and minimizing cash burn is the priority.
jayunited
Thu May 21, 2020 9:36 pm
I agree I think Kirby did what was necessary to save United Airlines from bankruptcy. There is no question heading into this crisis of the US3 and WN UA the most exposure with the largest international network and the smallest domestic network. Since a majority of our international network has been grounded UA had to be aggressive and cut domestic capacity down to 10% because the international traffic that we shuffled around the domestic network simply wasn't there. As a matter of fact for about 3 weeks DEN became UA largest hub.
Kirby is an aggressive guy, I don't expect him to back down from this challenge but the challenge he faces here at UA at this moment is how gain domestic marketshare utilizing the fleet we have. Even with both AA and DL announcing the retirement of small portion of their narrow-body fleet their remaining narrow-body fleet is still larger than UA's narrow-body fleet. I know Kirby wants to use this crisis to grow UA domestic footprint but how to get there using our current fleet is the problem he and his team have to figure out.
As far as our hubs go of our interior hubs (ORD, IAH, DEN) UA will look at growing the fastest is DEN. United does not want to loose ground to WN at DEN. Kirby has fought hard to grow DEN, when he joined UA DEN was around 320 departures that was during the summer. Last summer UA reached 500 daily departures during the summer. Kirby nows UA has to be ready for a fight. I think out of all our hubs UA biggest fight will be at DEN. Domestic growth is what fueled UA's growth at DEN, while other hubs depended on a mixture of international and domestic growth, UA growth at DEN was totally fuel by domestic traffic. Both LHR and FRA came about after UA was well on it way to 500 daily summer time flights. Domestic traffic will come back before international traffic getting DEN back in the game will be key.
calpsafltskeds
Fri May 22, 2020 12:06 am
Looking at domestic services, I was thinking it would be great if UA could start a new hub if some airlines falter as UA has plenty of equipment and personnel. Many say UA has a hole in the SE, but I really don't see a golden hub opportunity anywhere. The closest choices would be FLL or MCO, but that would take an airline like Sprirt, Frontier or Jet Blue to get into real trouble. Possibly WN will reassess some of its focus cities. I would hope UA is keeping up on the possibilities of opportunities due to airline failures and/or reductions. Also, some of the LLCs are pretty quick to reassign aircraft and could be trying to pick off some markets.
Many thought there would be possible consolidation in the industry during this crisis, but it seems like its gone silent recently. Does anyone know if HA, JB, AS are more trouble than the Big 3/WN? Could the LLCs consolidate into one airline and become a major player? They all have Airbus equipment (Spirit/Frontier/Allegiant).
UA444
Fri May 22, 2020 1:44 am
Only airlines I see going down the tubes are NK, G4 (good riddance), and AA going through a restructuring. AS is pretty strong financially last I checked, and B6 wasn’t doing terribly
tphuang
Fri May 22, 2020 12:26 pm
I think UA's biggest challenge coming out of this is defending its hubs. Especially DEN, it will be in an uphill fight with WN who has all the money in the world to sustain a loss leading operation to gain market share. I would not be surprised if they buy out F9 to just get their gates at DEN. Remember, UA will also face WN pressure in the bay area, chicago and houston. UA's biggest challenge all across the country is a WN with a war chest of cash and very little debt.
When it comes to SE, I think FLL/MIA is not a great idea, but it will certainly be more open. AA I think will be a lot smaller at MIA given their weak financial position and slow return of deep south America flying. FLL will be quite open since both B6 and WN are likely to focus on bringing back other cities first. I don't think it makes sense for a legacy to build up at a primarily LCC airport. There will be plenty of space at MIA if they wanted to attempt it. I doubt they will. I don't see NK and F9 both remaining independent after this. Either they merge with each other or get taken over by WN or B6.
Does it really make sense for UA to buy an airline for narrowbody aircraft when used aircraft will be widely available at low cost from all the downsized airlines around the world?
