calpsafltskeds
Re: United Fleet, Network, & Livery Thread - 2020
Thu Jul 16, 2020 2:50 pm
I'm sure the 77Ws aren't going anywhere. Beast of an aircraft with range and lift. Newest non 787s in WB fleet.
If you are talking potential retirements, something to review:
Oldest aircraft are
763s and 320s built prior to 1995
Lots of units from 1995 to 1999 - WB 55, NB 144
Most discussed about leaving fleet
7 Non-Polaris 763s and entire fleet of Non-Polaris 764s
772A
752 PW fleet of 11
739A fleet of 12
Older Airbus and 737 aircraft
WB (Ranked by oldest first) - 787s and 77Ws should all be staying
763: 21 of 38 are 1995 or earlier build, only 8 newer than 2000, most have 2 versions of Polaris
772A: 13 of 21 are 1995/96 build, other 6 are 2000 build (could some be retired and replaced by 772ER units?)
772ER: PW: 19 are 1997/1999 build, rest are 2000-2002 build, Polaris complete except 1 domestic and 3 slated for domestic
772ER: GE: 14 of 22 are 1998/99, rest are 2 each 2000, 2002, 2007, 2010
764ER: might retire, different engines, none have Polaris, all 18 to 20 years old
NB (Ranked by oldest first) - 739ER/737MAX should all be staying
320: 21 of 97 are pre-1995 build, rest evenly spread from 1995 to 2002
752: PW engines is small fleet of 11, premium heavy/high ASM cost, 5 pre-1995 build, 6 1995-1999 build
752: RR in fleet of 40, 11 are 1994, all but last 3 are 1995-1999 build, international config
73G: all 40 are 1998/99 build - some might be needed for short field performance flights
738: 43 of 141 are 1998/99 build
319: 27 of 74 1997/99 build, newer units brought into fleet as used
739A: 12 non-ERs all 2001 build have been mentioned as possible fleet exits - performance limited, IAH sked not a real issue
753: all 21 units 2001 to 2004 build, some of last off the line (don't expect an exit unless 752RR fleet leaves, A321 to replace?)
calpsafltskeds
Thu Jul 16, 2020 8:37 pm
787-8 Polaris/PE:
N26910 sked to exit XMN 2698/18Jul with Polaris/PP
6th unit in 28J/21PE/36E+/158Y configuration
Do not see another 788 heading to XMN at this time.
jayunited
Thu Jul 16, 2020 11:31 pm
calpsafltskeds wrote:
787-8 Polaris/PE:
Yeah the reason those frames went through modification was because they were due for heavy maintenance and UA already had the ship sets in XMN, so it just made sense to do the modification at the same time.
Don't give up hope on UA finding the money to complete the modification on the remaining 788s. Just this week we learned construction will resume on UA's backup site in Arlington Heights, IL. All we know is UA found some money from somewhere and construction will resume later this month, UA expects to have the backup facility up and running by late Q1 or early Q2 2021 which will spell the end for our current backup facility in Elk Grove Village.
NoNonsense
Fri Jul 17, 2020 2:12 am
f further retirements are officially announced, it would stand to reason the 777-As, the 767-400ERs, and half the 767-300ERs will be the first to be retired, along with the oldest 737-800s, and maybe some of the A320 and A319s. The 777-As are primarily used for West Coast-Hawaii, transcontinental, and a few hub to hub routes (all pre-COVID of course). The 767-400ERs (all 16) have not been refurbished to the new Polaris cabin. These birds were built and delivered to CO from 1999 to 2002. The non-refurbed 763s and likely a few of the Polaris'd ones could also go and some of the oldest 777-200s as well, perhaps those that have not been updated to the new cabin standard, which would result in some leaving from the legacy UA and CO fleets. UA has indicated the future of its long haul fleet will be focused around the 787. I could also see them put some of the 77W's in long term storage but not phase those out. The A319/A320 fleet largely dates back to a 1992 order, though some A319's were built and delivered in 2002-3 and a few more recently acquired from a Chinese airline. I'd also think half the 737-700 fleet, if not all of it, could also go.
that's a lot of unnecessary guessing and speculation !
LAXintl
Fri Jul 17, 2020 4:25 am
ALPA today passed the two LOAs which offer early outs for those approaching retirement age(62 and above) and a voluntary furlough/COLA for the rest to help reduce the number of pilots that would be forced into an involuntary furlough come Oct.1st.
Lets see how many take the offers to help mitigate the impact on rest of pilot group.
calpsafltskeds
Fri Jul 17, 2020 1:13 pm
319:
N874UA, Ex China Southern B-6021 exited XMN Induction 2703/16Jul, enroute SFO via NRT & ANC
MIflyer12
Fri Jul 17, 2020 1:48 pm
Retiring a few of many types doesn't really get you much in structural cost savings. The big $ is in retiring sub-types, or full types: it simplifies frame scheduling, it eliminates parts inventory, it eliminates a pilot work group (think of inefficiencies from small groups across multiple bases). The 757, 753, 767 and 764 all have a common type rating.
Now, if you forecast that demand is going to be depressed for years and you've got a dozen 27-year-old A320s it's pragmatic to recognize they have little value to the carrier. Send them to retirement early.
jayunited
Fri Jul 17, 2020 8:41 pm
I know it has been a while but a fleet update came out this week and not much has changed, the last update showed the PW 752s retired, the remainder of the fleet still shows active or stored no further decisions have been made on retirements.
The one change that caught my attention was the MAX 9 update. United already took delivery of 14 MAX 9 frames before the grounding, and according to the update Boeing has another 13 MAX 9 frames ready for delivery for a total of 27 MAX 9s. With United previously stating they will only take delivery of 40 MAXs in 2021, what wasn't clear in the latest fleet update is if the remaining 13 MAX frames will be the MAX 10 variant.
With the grounding and now COVID the fleet updates don't come as often as they use to (which is to be expected), but hopefully soon there will be some clarity as it pertains to the fleet.
calpsafltskeds
Fri Jul 17, 2020 9:10 pm
Jay, surely no shock and fullly expected, but has the PW 752 fleet officially retired? Is the document internal or available publicly?
jayunited
Fri Jul 17, 2020 10:28 pm
Internal only for now, I'm not sure why UA still has not publicly announced the retirement of the PW 752 fleet. This is the second fleet update that has come out showing this sub-fleet as retired.
Ishrion
Fri Jul 17, 2020 10:40 pm
United will release its second quarter 2020 results next Tuesday, so I’m guessing we’ll hear about retirements around then.
UAinAUS
Sat Jul 18, 2020 7:20 am
UAX Update:
CR5:
N503GJ parked at STL
CR2:
N909SW parked at TUS
N408AW returned to flying
N418AW returned to flying
N467AW returned to flying
jayunited
Sun Jul 19, 2020 12:21 am
N222UA is being pulled out of long term storage at ROW tonight (at least that is the plan), it is schedule to fly UA2719-18 ROW-IAD. I'm not exactly sure why UA is pulling this frame out of ROW, but keep in mind it was the first 77E to be reconfigured from the international IPTE layout, to domestic HD layout, with 32J and 330Y.
audidudi
Sun Jul 19, 2020 2:18 am
It just took off at 20:14:
https://www.flightradar24.com/UAL2719/24fa0237
audidudi
Sun Jul 19, 2020 7:22 pm
audidudi
Mon Jul 20, 2020 6:46 pm
Latest ex-EZY A319 for UA, G-EZIW, ferried from LGW>SOF...will become N3303U:
https://flightaware.com/live/flight/GEZIW
LGeneReese
Tue Jul 21, 2020 3:13 am
Any info on if UA intends to proceed on this deal? Especially since these aircraft have CFM engines...
drerx7
Wed Jul 22, 2020 3:26 am
I noticed a few different domestic/regional widebody flights outside of hub-hub runs like LAS etc. for September...how reliable is that schedule at this point? What are some regional widebody routes penciled in so far?
HOUSTON, TEXAS
audidudi
Wed Jul 22, 2020 9:19 pm
Latest ex-EZY A319 for UA, G-EZAL, ferried from LGW>QLA today...will become N9312U.
https://flightaware.com/live/flight/GEZAL
ericm2031
Wed Jul 22, 2020 10:00 pm
The vast majority of the domestic schedule is only reliable through Labor Day right now, although widebodies might be scheduled farther out than the general schedule, not entirely sure.
jetblastdubai
Wed Jul 22, 2020 11:23 pm
jayunited wrote:
The response was UA is studying the proposed AA/B6 codeshare closely. If approved UA does expect regulators to require both airlines to give up valuable slots and gates at JFK. At which point UA fully intends to submit its application to snap up as many slots and gate as we can to get us back into JFK in a meaningful way.
Not to veer too far off the topic at hand but but I'm sure someone on here knows the answer.
It's been mentioned on a-net that "someone" returned 70 slots at JFK. Assuming this statement is true, whether it's 70 slots by one carrier or 70 slots from multiple carriers, but if these slots were returned to the Port Authority, wouldn't they be able to be picked up by anyone at any time....possibly for free? Gates are a whole other issue but I would think that if the Port Authority wanted to monetize these returned/unused slots, they would bend over backwards to make gates available somewhere on the airfield so that the carrier that acquires them can actually use them and pay the associated fees to the Port.
I snagged this snippet from another thread and thought this question might be better addressed in this thread.
United1
Wed Jul 22, 2020 11:24 pm
UA hasn't updated it's schedule past September 7th. Anything, domestic at least, past that point is the pre-Covid schedule.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
tphuang
Wed Jul 22, 2020 11:35 pm
There is going to be so many slots available at jfk next year. I am not sure why they need to wait for regulators? Who is going to be flying full schedule at JFK?
jayunited
Wed Jul 22, 2020 11:50 pm
There were slots available pre-COVID but they were all either early morning or late evening slots, from mid-morning through early evening there were no slots available.
Which brings up the question is JFK strict on the use it or loose it rule? I 100% agree no one will be flying a full schedule at JFK in 2021 but doesn't necessarily mean airlines will be forced to return those unused slots to JFK. Also if JFK does strictly enforce the use it or loose it rule there is nothing preventing an airline like B6 for example from requesting an exemption citing the coronavirus as the reason.
tphuang
Thu Jul 23, 2020 12:58 am
I would think it has the same rules as lga, at least 80% usage. And they both have slot waiver at the moment. Who knows how long that will last. All the lcc are eager for the lga waiver to end.
I am still under the belief that aa has already released a bunch of slots at jfk or done a smaller slot lease or sale with JetBlue already. I recall a few months ago spirit filed complaint about airlines at jfk not fully utilizing their slots. Which forced JetBlue to ramp up its pre covid summer schedule. United could certainly do the same here.
I think if United wants to go back into jfk, slots would not be the biggest concern. Being stuck in terminal 1, facing strong competition, low corporate demand and dl possibly retaliating on ewr lax would be bigger concerns.
Nicknuzzii
Thu Jul 23, 2020 2:24 am
One thing to clear up with the NK lawsuit is that JFK is not involved. NK is actually suing the DOT regarding WN’s departure from EWR and where the slots went. United of course sided with the DOT to prevent delays and for other obvious reasons.
tphuang
Thu Jul 23, 2020 10:54 am
No, there was apparently a separate complaint filed at Port Authority about carriers not using their all their slots (completely unrelated to EWR). As long as other airlines don't complain, I suspect PA will not force airlines to release slots. Although in this case, I think a bunch of slots have already been returned. Whether or not they work for UA is a different question altogether.
audidudi
Thu Jul 23, 2020 7:57 pm
319:
And has now arrived at GYR after spending the last 6 days at SFO:
https://flightaware.com/live/flight/N874UA
LGeneReese
Fri Jul 24, 2020 6:25 am
319:
The UA interior is completely installed. All it will need is a paint job and it’s ready to go.... But for now it’s just going to sit at GYR for who knows how long....
CALTECH
Fri Jul 24, 2020 4:55 pm
This is unprecedented. Worse than 9/11.
CRJ5000 wrote:
With nearly every industry decimated with no end in sight, I don't see how the government can throw more money at the airlines.
Yes, it's an election year, however the 99% of people who aren't in aviation are generally VERY put off by corporate bailouts, and for the most part have a very negative view of airlines in the first place. Go read comments on news articles, social media, etc regarding the airline portion of the CARES act and payroll protection grants. Nearly all of them are opposed. Would you really want to bailout the industry again a month before the election to appease 1% and alienate the other 99%?
It's not 1%, it is over 7.5 %, and those are high paying jobs with a lot of mortgages, car payments........
Agree that bailouts are not the way to go, the government is printing money it doesn't have.......
" 2016, the total U.S. economy generated $18.6 trillion
in value-added economic activity and supported 144.3
million jobs
. At the same time, civil aviation directly or
indirectly supported:
• $1.8 trillion in total economic activity,
• 10.9 million jobs, and
• contributed 5.2 percent of U.S. gross domestic product (GDP). "
You are here.
UAinAUS
Sun Jul 26, 2020 2:53 am
UAX Update:
CR5 Correction:
N541GJ parked at STL
N542GJ is flying
N503GJ returned to flying
CR2:
N470ZW returned to flying
N863AS returned to flying
airlineaddict
Sun Jul 26, 2020 3:05 am
Any updates on the SFO - HKG - SIN restart? Maybe the better question is whether or not there have been any updates on HKG’s COVID testing requirements for crew members that would allow for the flights to restart?
UA857
Sun Jul 26, 2020 8:23 am
I think UA should return to JFK once the 737 MAX 10 are delivered. Since UA has 100 737 MAX 10s on order with 50 of them being in Polaris-configuration that will replace both the 752 on the transcon UA could fly them out from SFO/LAX-JFK/EWR/BOS leaving the A321XLR to do the international 752´s job. As for Terminal space UA could use T7 after BA moves to T8.
United1
Sun Jul 26, 2020 3:59 pm
Supposedly T7 is being ripped down so T5 can be expanded. I don't know whether or not UA will re-enter JFK although there may be some opportunities too in the near future. The rest of what you wrote with the 737-10s taking over on transcontinental routes and the A321XLRs replacing 752s on international flights was UAs plan pre-Covid19 at least.
drerx7
Sun Jul 26, 2020 4:12 pm
Thanks for the responses to my scheduling question... do yall know when the next schedule update will occur?
HOUSTON, TEXAS
rjbesikof
Mon Jul 27, 2020 12:51 am
Could there also be a possiblity that the stop before going to SIN could be changed from HKG? What I mean is could SFO-HKG-SIN be changed to something like SFO-ICN-SIN? Also, is there also a possibility for United to resume the nonstop(s) to SIN?
windy95
Mon Jul 27, 2020 4:08 pm
Since they are closing JFK totally as a MX base I would assume that there are no plans in the future to add flights into JFK
codc10
Mon Jul 27, 2020 4:59 pm
Any other TechOps closures?
airmec7
Mon Jul 27, 2020 7:15 pm
We was told in TechOps, that JFK is the only line base that will be closed. As it only takes care of 3rd party MX issues. We were also told that back shops in SFO could be closing, with the exception the landing gear & engine shops will remain open.
On the same call they said UA was looking at ways to get back into JFK. If we get slots back in JFK and reopen the line base. The MX that are displaced would be the 1st to get recalled before it’s opened up system wide for open positions.
jayunited
Mon Jul 27, 2020 9:12 pm
At JFK UA MX is a 3rd party vendor we have (had) contracts to perform maintenance for other airlines. Right now because of COVID there isn't a whole lot of work but the closing of the base has no bearing on UA's desire to get back into JFK with our own metal. United made it clear on the call and in the town hall that they want back in at JFK. Kirby and his team believes we can get back in, in a meaningful way (whatever that means in terms of routes) but for now United is waiting to see what becomes of this purposed AA/B6 codeshare and what the requisite fallout will be.
United is also talking about scaling back at SFO again another based where in addition to caring for UA aircraft they also provide maintenance to other airlines. I think if there is a scale down at SFO it would only be temporary for sure nothing permanent, but still no one likes to see things like this happening. But we have to keep in mind United Technical Operations has contracts with over 43 customers from around the world to perform maintenance here in the U.S. at places like JKF and SFO, and again the fallout from COVID has resulted less business with some airlines suspending operations to the U.S. completely. As much as I hate seeing this happen it isn't unexpected because the workload isn't there especially from those foreign carriers.
FlyingElvii
Tue Jul 28, 2020 3:06 am
Is Oakland still open?
United1
Tue Jul 28, 2020 3:27 am
OAK MTC was closed during UAs bankruptcy case.
UA444
Tue Jul 28, 2020 5:17 am
I just find it so, so satisfying seeing them actively and bluntly say they want back at JFK, when everyone here said it was the smartest, best thing they could’ve ever done and those that disagreed with it were harassed into oblivion. They don’t need JFK! They have EWR all to themselves and if you do this or go this way, you can get to lower Manhattan 3/10ths of a second faster from EWR! EWR is in New York! Then Scott Kirby enters the picture and on day 1 basically said they were brain dead for that decision.
Have they taken down their smug “JFK, you seem so distant” ads around NYC? Might want to take care of that before you go begging at the front door.
codc10
Tue Jul 28, 2020 1:05 pm
Schadenfreude?
UA isn’t trying to get back into JFK for the NYC-originating market... it’s been documented that the California point of sale (particularly LAX) suffered most from the EWR-exclusive move. Most in Manhattan are driven by airline loyalty for the EWR vs. JFK question, while those coming *to* New York exhibit a stronger preference for JFK (where LGA is not a viable option).
Of course, with COVID-19 and what will be a multi-year collapse in business travel, who knows whether there will be enough premium customers, paying premium fares, to justify another p.s.-style operation at JFK. I’d certainly welcome it, but there’s no doubt the virus has changed the Manhattan business landscape, in ways we probably haven’t fully realized yet.
jayunited
Tue Jul 28, 2020 1:14 pm
Personally I still believe it was the right decision for UA at the time. You have to look at where UA was when the decision was made to leave JFK. We had a serious shortage of narrow bodies, the sCO 752 were still being heavily utilized on many TATL routes out of EWR with only a handful of spares sitting around. We still had the domestic 763s also known as the ghetto birds, premium customers flying into and out of EWR to both SFO and LAX were demanding the same level of service that customers were getting flying into and out of JFK instead of the hodgepodge of service which included just about every single narrowbody in UA fleet. And finally it was no secret that UA was loosing money at JFK and needed to stop the bleeding. The results of that decision speak for themselves, pre-COVID UA's EWR-SFO-EWR route was one of the top 5 most profitable routes in America and in the top 10 most profitable routes in the World, while LAX-EWR-LAX was one of the top 10 most profitable routes in America. UA went from a money loosing operation at both EWR and JFK and quickly turned EWR-SFO and EWR-LAX into some of our most profitable routes pre-COVID.
Kirby comes in and says it was a mistake and that is fine everyone is entitled to their opinion. But remember when Kirby joined UA we had more narrow bodies in the form of 739NGs, the ghetto birds had been reconfigured and refreshed nose to tail with included diamond lie flats seats and deployed on many TATL routes freeing up many of those valuable sCO 752s. The domestic 77HD fleet had grown from 5 frames to 19 frames freeing up even more narrow bodies. And finally premium service had expanded to UA's SFO-BOS-SFO route. A lot of things happened between the time UA left JFK and Kirbys arrival at UA.
The is no question the merger was screwed up from the beginning and mistakes were made. UA squandered opportunities, and wasted billions of dollars and perhaps Kirby would have handled things differently from the start of the merger if he were here. But by the time UA made the decision to leave JFK the train had already left the station and UA was loosing premium customers in New York City. This is especially true at JFK where UA was loosing corporate clients and business travelers in general to Kirby over at American Airlines. We can't forget about a surging and very dangerous Delta Airlines who went for UA's juggler on both the JFK-SFO and JFK-LAX routes. Standing and fighting AA and DL at JFK simply wasn't an option and UA didn't have the liquidity to stomach the losses. I can't tell you the number of corporate clients UA lost when Delta decided to offer for a limited time a status match through their Sky Miles program. That was probably one of the biggest f*** you's Delta gave United, and there was nothing UA could do about it because we didn't have the money or the aircraft to stand and fight, retreat to the relative safety of EWR was UA's only option.
calpsafltskeds
Thu Jul 30, 2020 1:37 pm
The below story shows that UA and NZ have traded LHR slots with
UA dropping 11pm arvl, adding 1050am arrival
UA dropping 11:05pm dept, adding 320pm departure.
These would seem to be superior times, but does it mean the AM eastbound from IAD or EWR would be cancelled?
https://www.stuff.co.nz/business/indust ... p=12364828
jayunited
Thu Jul 30, 2020 2:05 pm
Pre-COVID I thought UA latest departure left LHR around 8:30PM heading to EWR? I also thought our AM departures from the US arrived at LHR around 9PM? I could be wrong but I don't remember an 11:05pm departure out of LHR or an 11pm arrival on UA.
codc10
Thu Jul 30, 2020 2:15 pm
Those slot times don't match any existing UA service... I believe UA has some legacy slots from the Pan Am deal that have been leased/traded to other carriers over the years. I wonder if this could be one of those slot pairs? The times are illogical for (resumed) NZ-metal service without a 24:05 RON, though... very interesting. A 3:20pm departure slot fills a midday gap in the LHR-EWR schedule, or could potentially result in a retimed UA SFO-LHR-SFO service to better connect with UA/NZ SFO-AKL-SFO.
UAL777UK
Thu Jul 30, 2020 4:14 pm
In all my years in flying UA in and out of LHR (since 1995) I have never seen a 11.05pm departure, that has to be an error.
adamblang
I know we hashed this out a year or so ago but I can't find it –
Does the NZ/UA JV cover only NZ<->US service or does it extend to transportation continuing on to Europe?
