Schmave wrote:Does anyone have any news or updates on engine testing or the first flight? All of the news articles on Google news about the 777x seem to be about 2 weeks old. Presumably they should be getting close to engine readiness if they aren't experiencing any further engine issues.
Opus99 wrote:WH001 moved into the paint hangar yesterday. Any idea why that would happen?
VV wrote:Opus99 wrote:WH001 moved into the paint hangar yesterday. Any idea why that would happen?
Perhaps to get some paint job?
MileHFL400 wrote:I’m seeing some really ambiguous statements along the lines that the plane will have its fist flight “this year.” Does this mean that we should see it later on this year as opposed to early Jan?
Opus99 wrote:VV wrote:Opus99 wrote:WH001 moved into the paint hangar yesterday. Any idea why that would happen?
Maybe, but why? I don’t know maybe it’s getting the red Livery that never came on. That would be nice
catdaddy63 wrote:Doesn't Boeing weigh aircraft in the paint bay? Would be a simple reason, double-check weight and balance before first flight?
keesje wrote:I think the ultimate load test drew attention & probably a deeper look takes place on the certification strategy of the involved structure.
Spetsnaz55 wrote:January 17th is the new rumor date for flight test
MileHFL400 wrote:Spetsnaz55 wrote:January 17th is the new rumor date for flight test
That would mean we would be seeing taxi tests by now.
Stitch wrote:[/quote]from some of the reports about the Ultimate Load test, it sounds like Boeing was pushing the fuselage structure even harder than they had to which might have contributed to the failure (in other words, the frame might have reached 150% if not for the additional stresses being imposed on it above and beyond what was required).
Strato2 wrote:
IF that is true then there are no more words left to explain Boeings stupidity. They wanted to show off and failed because of that. Then again we have MAX.
B764er wrote:It would be impressive to see WH001 come out with the LH livery painted on it. Then to take off in about 10 days will be a 1-2 punch for us all.
keesje wrote:The old fashioned stick to the rules bureaucracy might gain terrain versus the powerfull PR / political machine.
marcelh wrote:B764er wrote:It would be impressive to see WH001 come out with the LH livery painted on it. Then to take off in about 10 days will be a 1-2 punch for us all.
There was also a 747-8i test bed in LH livery as well, but lacked the titles and logo for IIRC legal reasons. An almost all white 779 with a dark blue tail isn't too sexy.... I love the new LH livery, but it's too understated for a first flight.
keesje wrote:According to Boeings testing campaign plan, ultimate load might cause certain structure to fail at a certain value. So if they are measuring, monitoring that structure during ultimate load testing and somewhere else the fuselage explodes & a door flies around, that might cause authorities and Boeing to have a root cause analyses of that event.
Spetsnaz55 wrote:(WH001 is) out of the paint hanger
Spetsnaz55 wrote:It's out of the paint hanger
Stitch wrote:Spetsnaz55 wrote:(WH001 is) out of the paint hanger
I assume it is still in Boeing House Colors?
Spetsnaz55 wrote:Stitch wrote:Spetsnaz55 wrote:(WH001 is) out of the paint hanger
Yes, it wasnt in there for paint
What was it for then?
A paint job doesn't necessarily mean livery change. Could it be just (re)paint of some patches?
Is there no space left in the area to do things such they have been obliged to use a paint hangar?
This is a very significant information.
Stitch wrote:Stitch wrote:Of course there will be an investigation into the root cause, but because the failure was so close to Ultimate Load, there won't be a need to re-do the test.keesje wrote:I think it is much to early to conclude that. We need objective analyses. The silence since the failure (the fuselage rupture leaked months later) isn't a positive. If there were positive preliminairy conclusions we would have seen them asap.
There are a minimum of three regulatory agencies reviewing it, plus Boeing. Is it your assertion that there is a four-way conspiracy between Boeing, the FAA, EASA and the GCAA to suppress information?
How long did it take for the official report of the A380 Ultimate Load failure to be published? For how long was the narrative just "the wings broke too early"?keesje wrote:737 MAX MCAS opened a can of worms. Grandfathered worms.
MCAS was a new system so it was could not have been, and therefore was not, covered under grandfathering.keesje wrote:I hope 777x is certified using different methodologies, strategy.
It will be certified under the methodologies outlined in the regulations. To do so any other way could result in those nasty "unknown unknowns" cropping up later.MileHFL400 wrote:Seeing as it’s based off an existing platform there will be grandfathering.
Indeed there will be, but anything new - like the wings - will be certified under current methodologies, which is why Boeing had to perform an Ultimate Load test.
Sooner787 wrote:Still wondering if Boeing will publicly announce a first flight target date
or keep with their "employees only" notices like the Max 10 rollout ?
iamlucky13 wrote:Sooner787 wrote:Still wondering if Boeing will publicly announce a first flight target date
Hopefully public. First flight is perhaps the biggest milestone in any new aircraft program, and it's relatively disconnected from the MAX troubles. It also is not immediately following a major disaster like the originally scheduled rollout was.
Any announcement will probably only happen very shortly before the flight, however. If I remember right, the 747-8 first flight was only confirmed once the high speed taxi test took place the day before.
jfk777 wrote:hen is the 777X first flight schedule for ?
PepeTheFrog wrote:One has to wonder if the message at https://twitter.com/davidshepardson/sta ... 5130701826 will have impact for the certification timeline:
Opus99 wrote:PepeTheFrog wrote:One has to wonder if the message at https://twitter.com/davidshepardson/sta ... 5130701826 will have impact for the certification timeline:
I would like to hope they've changed this supplier, really and honestly because this is bad if the email is true at least. Apparently this email was sent years ago
I don't see any stupidity in trying to do it right. Do you have evidence of what you say? I wish Boeing to come back faster and stronger from now and for ever
*** 2020 ***
WayexTDI wrote:When you decide to go above and beyond the actual requirement (and original test plans) just to try and show of, and when that test spectacularly fails, then it is stupidity.
