Nicknuzzii wrote:Why haven’t they gone daily from EWR yet? Or even tried BUD? No one flies it currently but AA is having a field day with it down the road in PHL.
RainerBoeing777 wrote:For this 2020 LOT will place an order of Boeing 787-10 for its dense routes to YYZ, JFK, EWR, ORD, NRT and ICN
Blerg wrote:Why on earth would they be adding 777s? Seems like they are becoming desperate or clueless, I don't like this new direction they are going in.
SRQLOT wrote:Blerg wrote:Why on earth would they be adding 777s? Seems like they are becoming desperate or clueless, I don't like this new direction they are going in.
It seems they want to lower the costs of wet leasing 3 A340 as they are expensive to operate and fuel thirsty and with possible issues of RR continuing they need more aircraft to grow. Unfortunately they are desperate and everything that LOT wanted to be is not happening.
tomgle wrote:SRQLOT wrote:Blerg wrote:Why on earth would they be adding 777s? Seems like they are becoming desperate or clueless, I don't like this new direction they are going in.
Surely the 777 is too big for that though? And shouldn’t the A340 leases be at least partially covered by compensation from RR?
Blerg wrote:Ok but what's their long term plan then? How long would the leases be for these 777s? Short term or long term? If they are long term then does it make sense for them to operate both the 777 and the 789? On top of already having 788. Add to that a bit of everything on the short-haul side and you get quite a mix which can't be cheap to service and maintain.
artflyer wrote:Blerg wrote:Ok but what's their long term plan then? How long would the leases be for these 777s? Short term or long term? If they are long term then does it make sense for them to operate both the 777 and the 789? On top of already having 788. Add to that a bit of everything on the short-haul side and you get quite a mix which can't be cheap to service and maintain.
The aviation portal that is "source" of this information has zero credibility. Most of its commentators/journalists are former LOT employees from times when the company was run into the ground and now fortunately they have no more ties with LOT, thus no direct info/own credible leaks.
This particular info came from an aviation forum, where from time to time also some LOT employees are active, sharing various gossips, mostly but not always true.
LOT officially denied that it currently trains its crew to any other long-haul type than 787 and I don't think they intended to be so tricky as to use the fact that 777 and 787 are the same type. So this does not seem to be a true gossip.
As you rightly mentioned, also the logical reasoning speaks very much against it.
Blerg wrote:artflyer wrote:Blerg wrote:Ok but what's their long term plan then? How long would the leases be for these 777s? Short term or long term? If they are long term then does it make sense for them to operate both the 777 and the 789? On top of already having 788. Add to that a bit of everything on the short-haul side and you get quite a mix which can't be cheap to service and maintain.
I really hope it's not true as LO has come a long way in recent times.
SRQLOT wrote:Blerg wrote:Ok but what's their long term plan then? How long would the leases be for these 777s? Short term or long term? If they are long term then does it make sense for them to operate both the 777 and the 789? On top of already having 788. Add to that a bit of everything on the short-haul side and you get quite a mix which can't be cheap to service and maintain.
In the initial post I wrote 5 years for the lease, but who knows. As for having a big mix of aircraft, the CEO of LOT stated recently that it is a benefit due to issues with the 737Max. Take it for what it is, I guess he is not concerned about having such a diverse fleet, even if at one point it was a goal to go to cut down on the diversity.
SRQLOT wrote:An update to the 777 story. https://www.rynek-lotniczy.pl/mobile/lo ... -7587.html
Blerg wrote:Wow so they are really getting them!? I think they will look pretty impressive in LO's livery though. Can anyone guess the cabin layout? Will they maybe move some 788s to BUD?
SRQLOT wrote:Blerg wrote:Wow so they are really getting them!? I think they will look pretty impressive in LO's livery though. Can anyone guess the cabin layout? Will they maybe move some 788s to BUD?
Well it kinda looks that way, I’m wrong often but it kinda makes sense no? Being is worried that they might lose a future order for maybe another 20 or so 787s and more future 737Maxs so they give LOT a lifeline to keep them happy. If they will stay with LOT for 3 years and the inside hasn’t been updated I would imagine LOT would do some updates and bring in a Premium Eco to match the 787 fleet.
Yes aren’t 2 788s supposed to be based at BUD? I know short haul flights from BUD now are delayed to May or so.
cityshuttle wrote:Interesting development with the 777 and the 3-year lease. Can we assume that maybe a 787-10 order will follow soon with delivery close to the end of this 3-year lease ?
pdp wrote:If you trim out the damp/wet/moist/ACMI leased frames (and exclude the ERJs as they're stored), you actually end up with:
Q400
E170/175/190/195
737-3/4/5/800/MAX-8
787-8/9
Really not a very diverse fleet as it stands!
Blerg wrote:Can they fit another three widebodies in WAW during their waves?
gloom wrote:Blerg wrote:Can they fit another three widebodies in WAW during their waves?
Taking into account you use waves to fill WB (so they depart a bit later than waves of NB doing shorter turnaround) and then fly them to one-two locations daily, it's probably easier than fitting another NB. Remember LOT is also having a higher share of RJ to standard NB, than most of the fleets.
Adam
SRQLOT wrote:SRQLOT wrote:Blerg wrote:Wow so they are really getting them!? I think they will look pretty impressive in LO's livery though. Can anyone guess the cabin layout? Will they maybe move some 788s to BUD?
parrotta wrote:from 1 May there will be 2 788s based in BUD again as JFK increasing to 7 weekly and ICN to 4 weekly. There would be some days for one more return US flight.
Q400
E170/175/190/195
737-3/4/5/800/MAX-8
787-8/9
Q400
E170/175/190/195
737-3/4/5/800/MAX-8
787-8/9
LOT doesn't have any -300 or -500s. The -300 is opb. Getjet LY-GGC, One -400 is also operated by Getjet LY-MGC.
Blue Air is operating for LOT 2 737-800 and 1 737-700.
LOTs Boeing fleet is 737-400/800 only (excluding MAX).
If you want to count these planes, then add A340s as well.
Q400
E170/175/190/195
737-3/4/5/800/MAX-8
787-8/9
That's not accurate. At the moment LOT uses only A320s from Getjet (LY-ELK flying now). Additionally they leased one 737-700 (SP-LUA, ex Blue Air, still in its colors), but Blue Air is no longer flying for LOT.
tomgle wrote:Warsaw airport served 18,86 million passengers in 2019, an increase of over 1 million compared to 2018. The top 5 scheduled destinations were London, Paris, Kiev, Frankfurt, Amsterdam. https://lotnisko-chopina.pl/pl/aktualno ... egoly.html (source in Polish)
pdp wrote:tomgle wrote:Warsaw airport served 18,86 million passengers in 2019, an increase of over 1 million compared to 2018. The top 5 scheduled destinations were London, Paris, Kiev, Frankfurt, Amsterdam. https://lotnisko-chopina.pl/pl/aktualno ... egoly.html (source in Polish)
London probably has the highest seat availability of any city too:
3/4x W6 A321 daily to LTN
3x LOT various daily to LHR
2x LOT E190 to LCY
2x BA A32X to LHR
Blerg wrote:What would LO gain from buying Condor?
Starting from June 2020, LO will be increasing WAW-BEG from 11 to 12 weekly.
A321Lufthansa wrote:Does anyone know which seats in their 738s are missing the windows? Is the row 7 one of them?
tomgle wrote:I think LOT have retired the 734's, neither of them have flown in at least the last 7 days, according to FR24.
SRQLOT wrote:tomgle wrote:I think LOT have retired the 734's, neither of them have flown in at least the last 7 days, according to FR24.
Looks like they are gone.
Sad there was no announcements for last flight, but LOT is not sentimental to retirements like other airlines.
The 400 was in LOTs fleet for 27 years and as classics 28 years.
https://www.rynek-lotniczy.pl/mobile/lo ... -7690.html
IWMBH wrote:SRQLOT wrote:tomgle wrote:I think LOT have retired the 734's, neither of them have flown in at least the last 7 days, according to FR24.
According to Dutch news outlets the 3 -400's will be converted to freighters.
SP-LLE, SP-LLF and SP-LLG
https://www.luchtvaartnieuws.nl/nieuws/ ... tvliegtuig
