jplatts wrote:The lack of RIC-MDW nonstop service is one of the biggest network holes that needs to be addressed by WN once WN has more planes in its fleet.
Here are the Q2 2019 PDEW's of RIC-CHI compared to some markets already served nonstop from both MDW and ORD:
RIC-CHI - 226
SDF-CHI - 220
ABQ-CHI - 192
OKC-CHI - 191
TUS-CHI - 173
BHM-CHI - 170
ALB-CHI - 159
wnflyguy wrote:Domestic I see either COS or FAT.
MIflyer12 wrote:Do you want to keep pretending that there's no non-stop competition on those routes, that nobody is willing to connect? PDEWs without citing competition to same or competing airports lacks vital context. Every city pair you list there has non-stops on it by UA and/or AA - some have many.
flyfresno wrote:wnflyguy wrote:Domestic I see either COS or FAT.
Both are probably highly dependent on the MAX issues getting resolved. Also, working against FAT, WN would probably have to share a gate or gates with another airline, which I know is a big negative for them. The next expansion isn't supposed to open for two years, and is only 2 new gates. COS seems much better positioned, especially from a "spare gates" standpoint. I could easily see a combination of MDW/DAL/PHX/LAS from there.
jplatts wrote:There are also some other markets larger than COS that aren't currently served by WN such as TYS, CHA, CAE, BFL, HSV, LEX, and SYR.
Veigar wrote:Once MAX is back, should we expect to see a LAS-HNL route ?
jplatts wrote:
I agree that WN adding LAS-HNL nonstop service is a possibility once the MAX is back since WN would be able to more easily connect passengers to some destinations further east such as ABQ, ATL, AUS, BWI, MDW, CMH, DAL, FLL, HOU, IND, MCI, SDF, MKE, BNA, OKC, OMA, PIT, STL, and SAT from HNL if WN adds HNL-LAS nonstop service.
WN also would have some O&D traffic on LAS-HNL if WN adds LAS-HNL nonstop service due to (a) WN being able to do an morning departure that gets into Vegas earlier than the HA HNL-LAS afternoon nonstop flight and (b) WN FF's in the LAS market who prefer to fly on WN over other carriers.
OzarkD9S wrote:Without redeye flying, many of these connections would be impossible in both directions, without some ghastly overnight layovers.
A HNL-LAS nonstop flight that departs from HNL at 8:00 AM Hawaii time would allow passengers to connect onto LAS-ABQ, LAS-AUS, LAS-BWI, LAS-MDW, LAS-CMH, LAS-DAL, LAS-FLL, LAS-HOU, LAS-IND, LAS-MCI, LAS-SDF, LAS-MKE, LAS-BNA, LAS-OKC, LAS-OMA, LAS-PIT, LAS-STL, and LAS-SAT nonstop flights that depart after 5:45 PM Pacific Time and arrive at the final destination before 2:00 AM local time.
An 8:00 AM departure to LAS from HNL arrives at LAS around 4:45 PM Pacific Time (when daylight savings time is in effect), giving passengers connecting to Texas, the Midwest, the Southeast, or the Mid-Atlantic from HNL a layover between 1 and 3 1/2 hours at LAS if the HNL-LAS nonstop flight is on time.
As mentioned above, connections to some destinations in Texas, the Midwest, the Southeast, and the Mid-Atlantic from HNL (and vice versa) would be possible without redeye flights if WN operates a morning departure to LAS that departs from HNL before 8:15 AM Hawaii Time. Connections to Texas, the Midwest, the Southeast, and the Mid-Atlantic are even easier to do without redeye flights when DST isn't in effect as Hawaii doesn't observe DST and Hawaii is only 2 hours behind LAS when DST isn't in effect as opposed to 3 hours behind LAS when DST is in effect.
WN operating redeye flights that depart from Hawaii after 11:00 PM Hawaii Time might also be a possibility as WN has some flights departing from destinations in the Eastern U.S. between 11:00 PM and 12:00 AM Hawaii Time when DST is in effect (which would be between 5:00 AM EDT and 6:00 AM EDT).
DakotaFlyer wrote:I'm sure the answer is no, but once Southwest has more capacity would FAR ever be considered? I would not only attract the Fargo MSA, but also Grand Forks, Winnipeg, maybe Bismarck and large portion of western MN/Northern SD. Perhaps a flight to 2x to Chicago, Denver, and 1x Houston
jplatts wrote:SK is planning on replacing its 737-700 and 737-800 planes with A320neo planes during the next three years, and WN might be able to possibly acquire some used 737-700's and 737-800's from SK in order to address the plane shortage that WN is currently facing as a result of the 737 MAX grounding.
KL also has plans to retire its 16 737-700's by 2022, and WN might possibly be able to pick up some extra used 737-700's from KL.
X3 and TB also had plans to retire their 737-700's last year, but Wikipedia is still showing TB still having 5 737-700's in its fleet and XB still having 1 737-700 in its fleet.
bob75013 wrote:If MAX's are flying by EOY 2020, who cares about used NGs that become available in 2022 and 2023?
SANFan wrote:I see lots of discussion about Hawaii service and mainland connections -- especially thru LAS (when that actually happens) and OAK of course.
Just thought I'd remind folks here that the new SAN service which starts this April, has a very connection-friendly schedule. I know that SAN is no LAS or PHX as far as # of WN flight offerings but SAN does have nonstop service to ~36 WN destinations with ~125-130 weekday departures. Here's the start-up sked for SAN-HNL on 4/20:
SAN: 3:40pm #2081 B-738
HNL: 6:45pm
HNL: 9:35am #2085 B-738
SAN: 6:15pm
This timing of flights should satisfy local O&D traffic pretty well and will certainly create many network connecting options. There also seems to be good connectivity to the Outer Islands from/to HNL at these times.
I posted a list last year of the many evening departures from SAN to many WN destinations that would connect from HNL. It appears that WN is definitely going to have network connections in mind as they build HI service at SAN.
bb
Jshank83 wrote:WN seems to be holding back some Hawaii-SAN-XXX connections for some reason. Earlier I saw some flights that had plenty of time to connect if you look them up separately but were not offered on a connecting itinerary.
wnflyguy wrote:Predictions for 2020.
If the MAX grounding is lifted.
Nothing major for the current summer time schedule out for sale.
AUG I can see the ETOPS process start for the MAX8 and MAX7.
Fall and Winter schedule new cities.
International we will finally see the delayed since the hurricane damages SXM. With a daily FLL-SXM and Saturday only BWI-SXM.
Domestic I see either COS or FAT .
Nov/Dec schedule I think you will see the NG Etops stay strictly out west.
This will allow them to add a daily flight to 1 HNL-ONT and 1 HNL-OGG.
OAK-HNL will Jump to 5 a day on weekdays 4 day on weekends.
SAT/SUN only could possibly see 1 HNL-LGB and 1 OGG-LGB.
HNL-OGG jumps up to 10 a day.
1 daily ITO-OAK.
DEN will see more connecting of the dots with a daily flight to ISP,MHT,PWM,RIC,DSM and ROC.
NOW if the MAX grounding keeps going. WN will make a play for Either JetBlue or Spirit to diversify it's fleet quicker than going organic.
Flyguy
Jshank83 wrote:I don’t want this question to go down a huge rabbit hole of should they/will they, etc.
If WN were to order A220/E195/A32X what is the soonest they could get any of them delivered? Years from now? What’s the backlog?
Again I don’t want to go down a huge rabbit hole with this. Just literally want how quick it could get any of these new?
jplatts wrote:Jshank83 wrote:I don’t want this question to go down a huge rabbit hole of should they/will they, etc.
WN will be able to pick up additional used 737-700 and 737-800 planes in the next 4 years with (a) SK replacing its 23 737-700's and 28 737-800's with A320neo planes during the next 4 years and (b) KL planning on retiring its 16 737-700's by 2022.
WN might also be able to acquire 10 737-700's from DL if DL takes delivery of enough A220-300's to replace its 737-700's.
WN can probably get used 737-700's faster than A220, E195-E2, A319neo, or A320neo planes with more used 737-700's becoming available in the next 4 years.
jplatts wrote:There were two articles in the Dallas Business Journal this week regarding further expansion of WN's network and WN possibly operating redeye flights in the future:
- Will Southwest ever fly red eyes? Exec talks that and more in this Q&A - https://www.bizjournals.com/dallas/news/2020/01/13/southwest-airlines-red-eyes-adam-decaire.html
- Southwest CEO teases South America expansion out of this Texas airport - https://www.bizjournals.com/dallas/news/2020/01/13/southwest-south-america-houston.html
AirFiero wrote:jplatts wrote:There were two articles in the Dallas Business Journal this week regarding further expansion of WN's network and WN possibly operating redeye flights in the future:
The articles are behind a paywall. Can you summarize?
tphuang wrote:So interesting they are admitting that Houston is their main Latin America hub now. I think FLL will fade back in it's importance to wn.
BNAMealer wrote:Gary Kelly said in the video above there will be about 3 key key cities WN will focus on growing this decade. HOU is one of them, what are the other two?
Vctony wrote:BNAMealer wrote:Gary Kelly said in the video above there will be about 3 key key cities WN will focus on growing this decade. HOU is one of them, what are the other two?
BWI and DEN.
jplatts wrote:flyfresno wrote:wnflyguy wrote:Domestic I see either COS or FAT.
The Greensboro/Winston Salem/High Point CSA is larger by population than Colorado Springs or Fresno and currently lacks service on WN. The population of the Greensboro/Winston Salem/High Point CSA is 1,677,551 compared to the Fresno CSA population of 1,303,438 or the Colorado Springs MSA population of 723,878.
GSO might be far enough from both RDU and CLT to support WN service with GSO being 79 miles from RDU and 102 miles from CLT (by driving distance). While AUS and SAT are closer to each other (by driving distance) than GSO and RDU are, WN serves both AUS and SAT due to (a) both AUS and SAT being in larger metro areas (by population) than GSO, (b) WN serving SAT since beginning operations in 1971, (c) AUS being one of the first destinations outside of DAL/HOU/SAT that was served by WN, and (d) both AUS and SAT having significantly more demand for domestic air travel than GSO does.
There was even a post back from March 2014 in the Airliners.net forums (which can be found at https://www.airliners.net/forum/viewtopic.php?t=569967#p8442255) which said that GSO is an important business market and population center that WN will probably serve at some point.
(XNA) in Highfill announced Tuesday (Jan. 14) enplanements rose 17% to a record of 922,533 in 2019, from 788,261 in 2018.
BNAMealer wrote:Vctony wrote:BNAMealer wrote:Gary Kelly said in the video above there will be about 3 key key cities WN will focus on growing this decade. HOU is one of them, what are the other two?
BWI and DEN.
I wonder what more they can/will do at BWI. DEN is going to be their largest station and HOU is slowly becoming their Latin America gateway, but what unique feature will BWI have?
BNAMealer wrote:tphuang wrote:So interesting they are admitting that Houston is their main Latin America hub now. I think FLL will fade back in it's importance to wn.
FLL isn’t even a base for WN. I never really understood why they made the investment there.
Midwestindy wrote:MAX cuts have been extended
jplatts wrote:Midwestindy wrote:MAX cuts have been extended
I have previously mentioned that WN might be able to pick up some used 737-700's from SK and KL as WN is not likely to be back to normal anytime soon, even if the 737 MAX is back in service by the end of this year.
WN acquiring used 737-700's from DL might also be a possibility if DL plans on getting rid of its 737-700's once it takes delivery of some A220-300 planes.
WN has also now delayed the schedule extension that was originally scheduled for February 11, 2020 to March 12, 2020.
SWADawg wrote:jplatts wrote:Midwestindy wrote:MAX cuts have been extended
WN has already taken every (viable) -700 available. Any -700’s that would be available anytime soon would be very high cycle, and at the end of their usable service life. Right now, it’s get the MAX back in the air, or acquire a competitor. The second option is honestly closer to becoming a reality the longer this grounding drags out.
A220-300 and future A220- 500. Fuel savings on long east/west flights, Assembled in Mobile, AL.
They are getting burned the hardest on this MAX deal.
SWADawg wrote:WN has already taken every (viable) -700 available. Any -700’s that would be available anytime soon would be very high cycle, and at the end of their usable service life. Right now, it’s get the MAX back in the air, or acquire a competitor. The second option is honestly closer to becoming a reality the longer this grounding drags out.
jplatts wrote:SWADawg wrote:WN has already taken every (viable) -700 available. Any -700’s that would be available anytime soon would be very high cycle, and at the end of their usable service life. Right now, it’s get the MAX back in the air, or acquire a competitor. The second option is honestly closer to becoming a reality the longer this grounding drags out.
All 16 of the 737-700's remaining in KLM's fleet are less than 12 years old, and KLM already has plans to get rid of these planes in the next 3 years. The KLM 737-700's also likely have several years of usable service life remaining with KLM's 737-700's being less than 12 years old.
WN acquiring some used 737-700's from KLM might certainly be a viable option with KLM's 737-700's being newer than most the 737-700's in WN's fleet, even though WN does have some 737-700's that are 8 to 12 years old.
Most of SK's 737-700's are more than 15 years old, but there are a few 737-700 planes remaining in SK's fleet that are 10 to 15 years old. A few of SK's 737-700's do have some usable service life remaining as there are many 737-700's more than 13 years old that are still in service with WN, SK, or other airlines. WN might be able to acquire a few used 737-700's from SK with SK having a few 737-700's that are new enough to have a few years of usable service life remaining.
tphuang wrote:Here is the LGB numbers from Q3 in light of the recent news. I'm posting all the routes here
CityPair Dist Carrier Board AvgFare NSFare ConnFare % NS PerFlight # Flights LF Yield PRASM Vs B6
LGBDEN 854 WN 21543 136.14 135.64 153.41 97.16% 143.3 184 81.68% 110.78 0.1297 N/A
I also posted the other carriers here including WN at DEN. That's a route without any competition for WN and the yields are horrendous.
