dbo861 wrote:SXDFC wrote:The following planes have been, or are en route to VCV as of 03/22/2020
Are those all 73Gs or are there some 738s mixed in there?
All WN 738s would start with N83xxX, N85xxX or N86xxX (3M8s are numbered N87xxX).
ctrabs0114 wrote:dbo861 wrote:SXDFC wrote:The following planes have been, or are en route to VCV as of 03/22/2020
knope2001 wrote:I spent a bunch more time with the new Southwest schedule reductions -- domestic only.
tphuang wrote:It still seems to me that Southwest is flying too much if they are cutting let's say 45 % of flights and still lose money on every flight. They probably need to cancel up to 60 or 70% soon.
knope2001 wrote:I spent a bunch more time with the new Southwest schedule reductions -- domestic only. The reductions that were loaded seem to be mid April to mid May, which unfortunately makes for a messy dataset in enilria's fantastic weekly stats. So I started comparing the first week of May 2020 versus May 2019 for a few markets, then a few more, and eventually I just decided to do them all. This was a manually tally for 2020 from Southwest.com using Monday 5/11. There may be a little noise based on rounding but these should be on the money or very close.
knope2001 wrote:
….. 30 …….. 8 …... -73% …... 12 …….. 7 …….. 5 …... SLC
….. 21 …….. 6 …... -71% …….. 9 …….. 2 …….. 7 …... ELP
….. 24 …….. 8 …... -67% …... 10 …….. 2 …….. 8 …... MSP
….. 21 …….. 7 …... -66% …….. 8 …….. 6 …….. 2 …... BDL
….. 24 …..... 9 …... -63% …….. 8 …….. 5 …….. 3 …... RNO
….. 35 …... 14 …... -60% …... 16 …….. 7 …….. 9 …... IND
….. 37 ….. 10 …….. 3 …... -69% …... 5 …….. 1 …….. 4 …... CLT
……. 6 …….. 2 …... -68% …... 2 …….. 1 …….. 1 …... OGG
….. 12 …….. 4 …... -67% …... 7 …….. 3 …….. 4 …... MEM
……. 6 …….. 2 …... -64% …... 2 …….. 1 …….. 1 …... HRL
……. 9 …….. 4 …... -54% …... 5 …….. 4 …….. 1 …... CHS
….. 10 …….. 5 …... -52% …... 5 …….. 2 …….. 3 …... ISP
……. 6 …….. 3 …... -52% …... 3 …….. 1 …….. 2 …... PBI
……. 4 …….. 2 …... -47% …... 1 …….. 1 …….. 0 …... CRP
……. 7 …….. 4 …... -44% …... 3 …….. 1 …….. 2 …... ORF
……. 5 …….. 3 …... -40% …... 3 …….. 1 ...... 2 ...... ROC
……. 5 …….. 3 …... -38% …... 3 …….. 1 …….. 2 …... GRR
……. 5 …….. 3 …... -38% …... 2 …….. 1 …….. 1 …... AMA
……. 3 …….. 2 …... -35% …... 1 …….. 1 …….. 0 …... PWM
……. 4 …….. 3 …... -25% …... 3 …….. 1 …….. 2 …... ICT
……. 6 …….. 5 …... -12% …... 2 …….. 2 …….. 0 …... IAD
……. 8 …….. 8 ……... 0% …... 5 …….. 4 …….. 1 …... ECP
……. 4 …….. 4 ……... 0% …... 3 …….. 3 …….. 0 …... PNS
……. 3 …….. 3 ……... 0% …... 2 …….. 1 …….. 1 …... DSM
……. 3 …….. 3 ……... 0% …... 1 …….. 1 …….. 0 …... RIC
……. 3 …….. 3 ……... 0% …... 1 …….. 1 …….. 0 …... GSP
Great post! Given the roughly 50% reduction, seeing the 71% reduction at ELP made me swallow hard. Big cuts at airports well served by other airlines like SLC and MSP makes sense. But ELP is pretty heavy on WN.
Some strange things at the other end of the post stands in stark contrast. ECP keeps at 8 frequencies? ELP keeps only 6. Is WN collecting a revenue guarantee? I was under the impression that they opted not to. GSP stays at 3, but PWM drops to 2? DSM loses a destination but gains a frequency to the remaining destination? Can’t claim that WN has high first class demand to cut losses in the markets keeping a high percentage of their flights.
While interesting, this may be short lived since I agree that more flying needs to be reduced. I’m sure WN has a game plan that factors in the Fed support program.
MIflyer12 wrote:Planespotters.net is showing WN has parked a far bigger fraction of 737-700s than -800s. Even after accounting for the MAX grounding they're parking the smaller planes at a higher rate.
https://www.planespotters.net/airline/S ... t-Airlines
Jshank83 wrote:I did find it interesting they added extra flights from some spokes to STL (ICT/DSM) for part of it. 3 instead of 2 a day in May. I guess they must be focusing some routes on certain places to connect. Maybe makes it easier to cancel flights later? If you only have 1 a day and passengers routed thru it then you don't have a backup flight. If you have 3 then you can just move them.
MIflyer12 wrote:That's a good insight. Generally - but not uniformly - it's the older -700s they've parked.
WN732 wrote:I'm sort of surprised that N700GS is still out there doing flights.
Sooner787 wrote:MIflyer12 wrote:That's a good insight. Generally - but not uniformly - it's the older -700s they've parked.
How many Max's does WN have stored at VCV ?/ was it 34?
I agree with other posters once RTS is granted, those Max's WN already owns will return to service
and replace those older, recently stored 73G's on a one for one basis.
LotsaRunway wrote:Any talk about WN consolidating service in multi-airport metro areas? Places like ISP, IAD, PVD, MHT, PBI, and BUR could be at risk.
wnflyguy wrote:LotsaRunway wrote:Any talk about WN consolidating service in multi-airport metro areas? Places like ISP, IAD, PVD, MHT, PBI, and BUR could be at risk.
No. WN will most likely going to try and keep each station open.
But sounds like because of more falling demand They will be cutting another 500 daily flights from April 15-June 1. This should bring them down to about 1549 flights is the latest estimate. With the additional cuts it's been estimated another 200 aircraft could be temporary parked at IND.
Prayers and hugs for everyone during this pandemic.
Flyguy
Jshank83 wrote:Thought this was an interesting article on how Southwest is handling their network in May.
Southwest Moves Toward a Hub Model With May Schedule
https://crankyflier.com/2020/04/14/sout ... -schedule/
BigPlaneGuy13 wrote:Hey all - just wanted to ask about a quick observation I've made via Flightradar24: a lot of WN's planes still flying throughout the system have split-scimitar winglets. Did WN prioritize flying its 737-700s with these winglets in the system, or is it merely coincidence? Does aircraft age play a factor? Thanks.
737max8 wrote:BigPlaneGuy13 wrote:Hey all - just wanted to ask about a quick observation I've made via Flightradar24: a lot of WN's planes still flying throughout the system have split-scimitar winglets. Did WN prioritize flying its 737-700s with these winglets in the system, or is it merely coincidence? Does aircraft age play a factor? Thanks.
You install scimitars on younger A/C to maximize return on the investment, so it would make sense most of those are the A/C flying and not in storage.
737max8 wrote:Apparently WN is currently the world's largest carrier by ASMs during this pandemic. I'm sure more cuts are coming, but still interesting.
MIflyer12 wrote:737max8 wrote:Apparently WN is currently the world's largest carrier by ASMs during this pandemic. I'm sure more cuts are coming, but still interesting.
Another poster cited a source saying largest carrier by seats. Got a reference for ASMs?
smithbs wrote:MIflyer12 wrote:737max8 wrote:Apparently WN is currently the world's largest carrier by ASMs during this pandemic. I'm sure more cuts are coming, but still interesting.
There was a thread for that, but it has disappeared. Why, I don't know.
pilotfox wrote:N272WN and N8612K are wrapped up and stored at MKE
Midwestindy wrote:Good signs coming from WN today:
Gary Kelly: "I think we've seen the bottom here in- in April. Each week after the first week of April has gotten successively better. I think May will be better than April was, and I don't think June will be a good month, but hopefully it will be a bit better than May. And then we're looking forward to July and August, and we'll just have to see. There are bookings in place. But those could easily be canceled. So it's really one day at a time."
https://www.cbsnews.com/news/transcript ... ay-3-2020/
UWPAviation wrote:Midwestindy wrote:Good signs coming from WN today:
Very good interview. I have always liked Kelly. It's good news to hear that week by week things are getting better, again still no-where near good, but getting better. He is being honest with furloughs and layoffs. The reality is WN is not going to bring all the planes back that are parked, which means some employees wont be making it out. However I do believe WN is in a great position during these times and to make it out very strong.
Flflyer83 wrote:WN is restarting service to CUN, SJD, MBJ, HAV, and NAS on June 7. PVR is tentatively scheduled for Oct. 8 and the rest Oct. 30.
Jshank83 wrote:Flflyer83 wrote:WN is restarting service to CUN, SJD, MBJ, HAV, and NAS on June 7. PVR is tentatively scheduled for Oct. 8 and the rest Oct. 30.
As in they actually plan to or just haven’t pulled it out of the schedule yet?
