Jshank83
Re: St. Louis Aviation Thread - 2020
Sat Jun 06, 2020 1:25 am
RFP to extend metro link to BLV is out.
https://scctd.org/metro-transit-release ... l-project/
atrude777
Sat Jun 06, 2020 1:47 am
UA Updated Schedule for July...
If I have it correct...
ORD
3 Daily
SFO
None
IAH
None
EWR
1 Daily
DEN
1 Daily
Overall, 5 daily from STL now, instead of 2 daily.
Alex
Jshank83
Sat Jun 06, 2020 4:48 am
ORD
3 Daily
SFO
None
IAH
None
EWR
1 Daily
DEN
1 Daily
Alex
I have
3 ORD
2 DEN
2 EWR
2 IAH
1 IAD
0 SFO
10 total (they are running 3 now. 2 ORD, 1 EWR. Ewr started a week or so ago)
atrude777
Sat Jun 06, 2020 2:24 pm
Jshank83 wrote:
I have
3 ORD
2 DEN
2 EWR
2 IAH
1 IAD
0 SFO
I used 6th of July in United's Shares System, and still showing the same thing on my end. I did forget IAD!
Which date did you use? I admit, I realized I used a Holiday Weekend.
Using 10th of July, I am seeing the schedule you posted.
Alex
BHMNONREV
Sat Jun 06, 2020 3:28 pm
atrude777 wrote:
Jshank83 wrote:
I have
3 ORD
2 DEN
2 EWR
2 IAH
1 IAD
0 SFO
Alex
And interestingly enough, all flights except ORD are showing EMB-170/175..
Jshank83
Sat Jun 06, 2020 4:44 pm
atrude777 wrote:
Jshank83 wrote:
I have
3 ORD
2 DEN
2 EWR
2 IAH
1 IAD
0 SFO
Alex
I think it kicks in the 8th
Jshank83
Sun Jun 07, 2020 12:25 am
Alaska’s STL-IND will end next week and be replaced by STL-DFW.
https://twitter.com/unaccompflyer/statu ... 36930?s=21
Jshank83
Sun Jun 07, 2020 1:57 pm
AA update for July
CLT 4
DFW 6
ORD 4
PHL 3
LGA 2
DCA 1
PHX 1
MIA 1
LAX 0
Jshank83
Tue Jun 09, 2020 11:27 pm
The airport tweeted out they had more passengers this past weekend than any weekend since March 13-15. That means they had more passengers than a weekend that overall across the network averaged about 531K per day and last weekend was 404k average per day.
TWA302
Wed Jun 10, 2020 2:25 pm
Did they share a number? I'm lazy today and don't want to look :lol:
Jshank83
Wed Jun 10, 2020 4:08 pm
Southwest is adding more flights on shorts notice. Some start as early as today.
Looking at next week
17 extra flights
Dallas extra Fri-Sun
Panama City extra Fri-Sun
Tampa extra daily (next week they already had 2 on Sunday scheduled)
Fort Myers extra Mon, Tues, Fri-Sun
58% of its schedule pre-COVID
Jshank83
Wed Jun 10, 2020 4:09 pm
They did not..
dcaproducer
Wed Jun 10, 2020 5:00 pm
Jshank83 wrote:
They did not..
Looking at TSA’s throughput numbers we’re at about 16-17% of 2019’s daily totals, but I’ve said all along airports like STL will bounce back up faster than some of the big hub cities like NYC, DC, LA, etc. WN helps, but it’s nice to see AA and UA adding back service.
Speaking of which, how’s BLV doing with Allegiant?
Jshank83
Wed Jun 10, 2020 5:32 pm
dcaproducer wrote:
Jshank83 wrote:
They did not..
Basing off next week. They are running 30 flights a week. 2019 was 32 flights a week. Eight tomorrow. Every flight seems to be running. I haven't seen any passenger numbers though. March will come out tomorrow for them. I did see a tweet that last weekend 8% of US airline passengers were on Allegiant. Which I assume is pretty good for them.
dcaproducer
Thu Jun 11, 2020 12:53 am
Jshank83 wrote:
dcaproducer wrote:
Jshank83 wrote:
They did not..
Allegiant, probably more than NK and F9, really has an interesting market and doesn’t really appeal to business travelers. They will probably have a decent summer.
Jshank83
Thu Jun 11, 2020 1:52 am
I think it helps that they are so heavy on Florida routes.
Jshank83
Thu Jun 11, 2020 3:08 pm
LF at STL for March 45.5%
Passengers BLV for March (not terrible all things considered)
Down 30.8% for the month
Down 6.37% on the year
Jshank83
Thu Jun 11, 2020 3:50 pm
2019 Year end LF for International flights
WN MBJ 93.3%
WN PUJ 83.8% - March only
F9 CUN 83.7%
WN CUN 82.6%
Volaris/Apple SJD 76%
F9 PUJ 74.4%
Volaris/Apple PVR 74.1%
Volaris/Apple HUX 72.85%
AC 71.75% (no December numbers)
pmanni1
Sat Jun 13, 2020 2:11 pm
Interesting that WN has added a 2nd daily flight to SJC most days but has yet to add back SFO. Neither has UA. Seems like SFO would be a priority.
Jshank83
Sat Jun 13, 2020 4:56 pm
The only thing I can think of is there are more connection options thru SJC/OAK (and they are adding a 2nd SMF starting next weekend), so right now they are focusing on that more than O&D to SFO with business travel still lacking.
jplatts
Sat Jun 13, 2020 5:57 pm
I had noticed that WN will be reducing GRR-MDW nonstop service from 3 daily nonstops to down to only 1 daily nonstop starting on November 1st, but GRR will be gaining an extra daily nonstop to DEN on WN starting on November 2nd.
WN re-adding STL-GRR nonstop service might be a possibility with the cuts that WN is making on the MDW-GRR nonstop route. WN would also have more connecting feed on STL-GRR than it did back in Spring 2016 when WN last operated STL-GRR nonstop service as WN now has nonstop service out of STL to DSM, OAK, PDX, SMF, SJC, and ICT.
Load factors and # of passengers on WN STL-GRR in 2015 and 2016:
2015 - 73208 passengers, 72.82% load factor
2016 - 18017 passengers, 72.15% load factor
If WN does re-add STL-GRR nonstop service, WN would likely be able to get better load factors on STL-GRR than it did 4 years ago once demand for domestic air travel returns to normal levels as WN would be able offer more connections from GRR through STL than it did back in 2016.
STL is also far enough from GRR to support the return of WN STL-GRR nonstop service with STL-GRR being 382 miles long whereas MDW-GRR is the shortest WN nonstop route within the contiguous U.S. at only 137 miles long.
WN also had a higher percentage of connecting passengers on MDW-GRR in Q3 2019 than it did on STL-GRR in Q1 2016, with 97.7% of passengers connecting to other destinations on WN MDW-GRR flights in Q3 2019 vs. 83.6% of passengers connecting to other destinations on WN STL-GRR flights in Q1 2016.
In addition to a higher percentage of O&D traffic, the PDEW of STL-GRR on WN in Q1 2016 was 14 passengers per day, which is approximately double the PDEW of MDW-GRR on WN in Q3 2019, which was only 7 passengers per day.
WN had a load factor of 74.20% on the MDW-GRR route in 2019 and WN carried 206,851 passengers on MDW-GRR flights in 2019.
Jshank83
Sat Jun 13, 2020 8:46 pm
Upcoming restarts with the schedule updates today.
Southwest
June 14 - CLE/PIT/OKC
June 21 - CMH
June 28 - PHL/RDU
July 5 - MSP
American
July 8 - LGA (LGA-STL starts day before)
Delta
July 2 - LGA
July 4 - MSP (MSP-STL starts the day before)
United
July 6 - IAD/DEN
July 7 - IAH (IAH-STL starts day before)
Sun Country
June 26 - MSP
Previously scheduled domestic routes by airline not schedule to start by end of July
UA-SFO
AA-LAX
DL-CVG
WN- BDL/CHS/DTW/MSY/PNS/SAT/SFO
SY-PDX
pmanni1
Sun Jun 14, 2020 12:42 pm
If WN is trying to put the squeeze on it's competitors then CVG would be a good add that would probably knock DL out for good. They should take advantage of UA on SFO and AA on LAX as well.
gravytrain
Sun Jun 14, 2020 3:40 pm
Anyone able to explain this?
https://twitter.com/tpc_stl/status/1271795062712696833
Its the LA Chargers owners private jet at Downtown Airport. Seems to have been sitting there overnight judging by the photos also. A long way for some maintenance work on a small private aircraft surely?
jplatts
Sun Jun 14, 2020 7:48 pm
I agree that WN adding STL-CVG nonstop service is a possibility if DL drops STL-CVG nonstop service with CVG being one of the top destinations that WN doesn't currently serve nonstop from STL. The PDEW of STL-CVG was also higher than that of STL-DSM, STL-LIT, or STL-ICT in Q3 2019, and over 31% of the passengers traveling between STL and CVG were connecting on airlines other than DL in Q3 2019.
WN would also be able to offer connections to other destinations west of the Mississippi from CVG through STL if WN adds STL-CVG nonstop service, and WN also already has a FF base in STL and other markets west of the Mississippi River to support STL-CVG nonstop service.
There have also been some cuts made by AA, UA, and F9 out of CVG within the last year, including
(a) AA having already discontinued CVG-PHX nonstop service,
(b) AA not resuming CVG-PHX nonstop service in December 2020,
(c) AA downgauging CVG-DFW mainline flights to A319's from MD-80's subsequent to AA retiring its last MD-80's in September 2019,
(d) UA having already discontinuing CVG-SFO nonstop service in January 2020, and
(e) F9 dropping CVG-AUS, CVG-DFW, CVG-LAX, CVG-MSP, CVG-PHX, CVG-SAN, and CVG-SFO nonstop service.
There will also probably be more passengers connecting to destinations west of the Mississippi River from CVG once demand for domestic air travel returns to normal levels with the cuts that AA, UA, and F9 have made at CVG.
WN could add an evening nonstop flight to STL from OAK, which would allow passengers to connect to STL from Hawaii on WN. An evening nonstop to STL from OAK along with a morning nonstop to OAK from STL would also allow St. Louis-based business travelers to take day trips to the San Francisco Bay Area from STL on WN without having to connect.
According to AA's current flight schedules, AA is currently planning on resuming STL-LAX nonstop service on August 5th. WN is also currently planning on being back up to 3 daily nonstops on STL-LAX starting on August 11th.
While I am unsure if DL adding STL-LAX nonstop service will happen anytime soon due to DL's plans to become a smaller airline post-COVID-19, I had previously mentioned DL adding STL-LAX nonstop service as a possibility with DL already having nonstop service to LAX from CVG, CMH, DTW, IND, MCI, MSP, and OMA in the Midwest.
There are also some other adds apart from the addition of STL-CVG nonstop service or increased STL-SFO/OAK/LAX nonstop service that could be made by WN such as the return of STL-ABQ/BHM/GRR/SDF/SNA nonstop service and the addition of STL-CLT/JAX/ORF nonstop service.
stlgph
Mon Jun 15, 2020 12:54 am
CVG/STL on Southwest would be a nice little add to see and provide better opportunities to a number of cities in the midwest/east of Denver.
if assumptions could fly, airliners.net would be the world's busiest airport
TWA302
Mon Jun 15, 2020 3:14 pm
I would gamble on this being a legal visit for the upcoming lawsuit against the NFL and the LA Rams. I am sure Spanos will be deposed and this might be why.
Jshank83
Tue Jun 16, 2020 2:39 am
WN at STL is 2nd. Just under 80%Great to see.
Midwestindy wrote:
WN at nearly 90% capacity for DEN in July...wow
dcaproducer
Tue Jun 16, 2020 3:27 pm
This definitely shows the strength of WN and their financial position. It also shows the strength of STL's location.
It also shows DL's conservative approach to adding capacity.
TWA302
Tue Jun 16, 2020 5:04 pm
This should be interesting who played their cards properly. I applaud WN for getting things back moving sooner than the rest and thrilled to see STL capacity that high!
Jshank83
Tue Jun 16, 2020 6:10 pm
Also, to go along with the chart, I see WN was using E36/38/40 today. I know the E34-40 wing had been closed after demand plummeted. So hopefully that means it is back fully open.
Jshank83
Tue Jun 16, 2020 7:46 pm
Went thru the July schedule for 19-21
Fri 90
Sat 86
Sun 88
So that puts Friday at 76.3% of last July.
SLC is 2x daily. These COVID schedules have been so wonky. Cut SLC then it goes 2x daily. Still no SAT/MSY/DTW/SFO/BDL.
Midwestindy
Thu Jun 18, 2020 1:17 pm
WN updated their August schedule this morning, IND-STL will now start in August, September & October haven't been updated yet so I expect IND-STL to be added for those months as well.
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
TVNWZ
Thu Jun 18, 2020 1:31 pm
My guess is someone else charted the plane. Can’t see the city paying someone to fly in private to answer questions.
TWA302
Thu Jun 18, 2020 1:59 pm
I don't think someone else is going to charter Spanos' G-V. He is in town for one reason or another (overnight) so who knows. We can guess. It makes it more mysterious! BRING OUR CHARGERS HOME! :stirthepot:
pmanni1
Thu Jun 18, 2020 2:18 pm
Sounds like a perfect time for WN to add CVG. Interesting to see such disparity between STL and MCI in flight losses. https://www.ksdk.com/article/news/local ... P063_ehb0k
Jshank83
Thu Jun 18, 2020 8:22 pm
Allegiant extended their schedule. AZA comes back in December.
Jshank83
Thu Jun 18, 2020 8:38 pm
DTW back July 5th (that one filled way back in)
BDL/MSY/SFO back Aug 11
Jshank83
Thu Jun 18, 2020 10:26 pm
^ SAT also back August 11
Updated WN August schedule (from precovid):
Fri 115(-8)
Sat 112 (+26)
Sun 112 (-24)
Total week 799 (-38 or -4.5%)
Jshank83
Fri Jun 19, 2020 5:07 am
One more thing. Listening to a KMOX interview with the airport director. The guy doing the interview says he got ahold of an internal WN memo that says “cities coming back strong this year ATL/AUS/STL/BNA. Each will see restoration to previous departure levels and some growth this year. STL is continuing its roll as a strong WN customer bass and convenient flow point for the midwest.
So that’s good to hear.
pmanni1
Fri Jun 19, 2020 10:47 am
Fri 115(-8)
Sat 112 (+26)
Sun 112 (-24)
So everything is added back except CHS and PNS? Am I missing anything?
gravytrain
Fri Jun 19, 2020 1:12 pm
According to twitter and local radio, it wasn't there for depositions nor for maintenance. It flew in from Van Nuys Airport in LA Friday morning and flew back there on Sunday morning.
Seems very fishy.
Jshank83
Fri Jun 19, 2020 1:40 pm
Fri 115(-8)
Sat 112 (+26)
Sun 112 (-24)
CUN but I assume you were leaving that out. ECP surprising goes away on August 11th. Last year I think they ran it into October or November and they are running a bunch of it at the moment. But yes everything but PNS and CHS.
TVNWZ
Fri Jun 19, 2020 2:17 pm
gravytrain wrote:
TWA302 wrote:
I don't think someone else is going to charter Spanos' G-V. He is in town for one reason or another (overnight) so who knows. We can guess. It makes it more mysterious! BRING OUR CHhuARGERS HOME! :stirthepot:
Seems very fishy.
Recruiting cheerleaders at Diamond Cabaret or the Hustler Club?
TWA302
Mon Jun 22, 2020 6:31 pm
Jshank83
Mon Jun 22, 2020 8:01 pm
TWA302 wrote:
Yes, just cities. I have heard the unions are getting involved. I still think it has about a .00001% chance of passing. It needs 60% of the vote and I think even getting 50% is going to be tough.
BNAMealer
Mon Jun 22, 2020 8:24 pm
Jshank83 wrote:
What exactly is the point of privatizing STL anyway? Just look 300 miles to the north in Chicago to see how privatizing public infrastructure goes.
stl07
Mon Jun 22, 2020 9:08 pm
BNAMealer wrote:
The point is that it lines Rex's pocket with lots of money and the NAACP and Mayor with lots of donations
Instead of typing in "mods", consider using the report function.
Love how every "travel blogger" says they will never fly AA/Ethihad again and then says it again and again on subsequent flights.
TWA302
Tue Jun 23, 2020 2:50 pm
48 years ago, the DB Cooper 2.0 attempt at STL. Almost movie-like especially with McNally's girlfriend hijacking Allen Barklage and his helicopter. Not a well known story but for some reason I find it fascinating, and that McNally is out of prison.
AP - Photo
McNally on the left, circa 2016 from a podcast.
https://twitter.com/aarongnirk/status/733766088605868032?s=20
https://www.stltoday.com/news/local/history/june-23-1972-youre-not-going-to-believe-this-a-bizarre-hijacking-at-lambert/article_1aac5de6-6eb4-5245-a126-7adf324d5eb2.html
T18
Tue Jun 23, 2020 4:36 pm
By the way anyone who can't read the above post dispatch article and gets squiggles for letters, just copy and paste that into a word processor and like magic it become legible.
“Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting.” ― Steve McQueen (Le Mans) 1971
