CFRPwingALbody
Re: BeNeLux Aviation Thread - 2020
Sat May 16, 2020 9:42 am
The Trouw article states that the 500k limit stays until 2024. So no increase until 2024. Beyond 2024 growth of 1-1,5% is allowed, if earned by operating more efficiently and less noisy.
Blerg
Sat May 16, 2020 10:12 am
I saw some information online that SN will be removing 10 planes while some others refer to 13 aircraft. Which is it in the end? Do we know what planes will leave for sure?
777klm
Sat May 16, 2020 10:56 am
From 54 down to 38 aircraft, so 16 in total.
https://press.brusselsairlines.com/brus ... te-creeren
Home airport: AMS
Next flight: CNX - BKK
Jetty
Sat May 16, 2020 11:01 am
CFRPwingALbody wrote:
I thought I explained it clearly. The 500k is for commercial flights only. But the number of commercial flights (500k) is based on a sound contour and all flights to an airport.
If planes become less noisy the amount of commercial flights can grow. Or the permitted noise emissions are increased.
I think, before Covid-19; the increase from 500k to 540k commercial flight was created by allowing more noise. I think that the growth now has to come from operating less noisy.
I know there are more factors determining the permitted amount of commercial flights. But AFAIK noise is one of the more important. ATM planning and emissions are others.
Your explanation is clear but wrong. The number of flights -commercial indeed- allowed since 2008 is a fixed arbitrary number not dependent on noise levels or other factors. The increase in 2008 was based on forecasted noise and emissions levels but that is something else than that it’s adjusted based on those levels. There has been no increase since 2008 or before Covid. 540K was discussed and is now officially planned (but not formal yet).
Dutchy
Sat May 16, 2020 12:08 pm
AFAIK you are both right and totally wrong. ;)
Blerg
Sat May 16, 2020 1:17 pm
Thank you, so we still don't know which planes will be leaving their fleet?
Dutchy
Sat May 16, 2020 1:38 pm
27 destinations will be cut, among them:
Europe: Lanzarote, Madeira, Kos, Sint-Petersburg, Krakau, Warschau, Sevilla, Valencia, Bristol, Hannover, Moskou, Billund, Santorini and Vilnius
Africa: Marrakesh, Ouagadougou and Conakry
3 destination will be added: Frankfurt, München and Zürich
Source
So based on that, we will see cuts in the A320 fleet and might be 1 A330.
Blerg
Sat May 16, 2020 1:58 pm
Source
I have to say that I am shocked that they haven't been flying to FRA, MUC and ZRH! I wonder if some LX and LH flights might get transferred to SN.
SeanM1997
Fri May 22, 2020 8:57 pm
Luxair to launch Luxembourg - Manchester from 29 June 2020
LUX 1340-1430 MAN (Mon, Wed & Fri)
MAN 1510-1800 LUX (Mon, Wed & Fri)
davidjohnson6
Fri May 22, 2020 9:12 pm
Was Manchester-Luxembourg profitable for Flybe when they were around ?
User001
Fri May 22, 2020 9:29 pm
It was a route that was served until the very end, as well as expanded from 4 weekly to daily in its last year, so, can only use that anecdotal evidence to suggest it was. The fact Luxair are picking up the route, in the midst of this crisis, seem to confirm as such.
oldJoe
Sat May 23, 2020 2:12 am
Luxair is more or less a state owned company. Do they really need a route to Manchester that often ?
Blerg
Sat May 23, 2020 4:35 am
What plane will they use on this route? Q400? Also are they going for locals or do they also offer transfer options via LUX?
User001
Sat May 23, 2020 7:35 am
Given they are starting the route, clearly they do.
eurotrader85
Sat May 23, 2020 10:58 am
Yes Q400 which makes sense given the capacity Flybe had on the route.
Plenty of expat traffic going back and forth but not sure if offering transfer traffic. Is a shame if not as LUX would be a gem to transfer through.
eurotrader85
Sat May 23, 2020 11:02 am
Source
Its a fair point, obviously all LH group now anyway but given ZRH-BRU was possibly the most ridiculously expensive flight on the planet you would have thought SN would have been in there on their metal before.
PlaneGeek22
Sat May 23, 2020 11:32 am
Source
Personally I am not surprised. Doesn't make sense to compete like that. However, because of coronavirus, there is more focus on shorter routes because there, demand will come back quicker. So now, more capacity on key business routes are important.
blueflyer
Sat May 23, 2020 7:39 pm
It is a bit disingenuous for Brussels Airlines to trump the opening of these three new destinations because they are not real gains. All Lufthansa group airlines have been told to cooperate in order to minimize overnight stops to the extent possible across their entire European network. Brussels Airlines is opening FRA, ZRH and MUC so Lufthansa and Swiss crew no longer overnight in BRU to operate the first flight out to their respective hubs. At the same time, look for Lufthansa to take over the first flight out to BRU out of German markets where they have a crew base. Swiss should take over the first flight out from GVA to BRU which was previously operated by Brussels Airlines. So no real gain.
Brussels Airlines is also working on rescheduling their flights to Africa (I think delaying departures by about two hours) to give themselves enough time to cut night stops at most European outstations, start their planes and crew from BRU every day and complete a rotation back to BRU in time to connect with their African flights.
As an aside, efforts to minimize night stops are making labor negotiations more difficult as crew will probably see a significant cut in the portion of their income from overnight stops, however it is hard to estimate how much until a schedule is published.... and anything resembling a full schedule isn't going to be published anytime soon.
Of the 16 aircraft to be removed (see press release link in a previous post), 5 are CitiJet CRJs (wet lease cancellation), 9 A320s, and 2 A330s.
Between the two of them, I believe that OUA and CKY added up to three weekly frequencies, so if 2 A330s are to be retired, other long-haul destinations will see significant frequency cuts.
Blerg
Sun May 24, 2020 5:19 am
Very interesting, thank you for that. So basically it's all about reshuffling and cost cutting in the end.
