MIflyer12 wrote:bnatraveler wrote:I flew down on DL61/28DEC ATL-GIG and booked back on AA. It looks like it was a good idea in the end (despite the markedly lower level of inflight service from AA in J), as it seems like N154DL is also plowing the skies on the return last night - but diverted to POS and now SJU. Anyone know what is going on with that ship?
https://FlightAware.com/live/flight/N154DL
You recognize that for four of the last five months reported by the DOT's 'Air Travel Consumer Report' that DL mainline has had a lower rate of diversions than AA mainline, right?
https://www.transportation.gov/airconsu ... ports-2019
Weatherwatcher1 wrote:The double diversion is actually quite impressive. They had a diversion to Trinidad. They likely didn’t have the crew duty time to get to ATL. Instead of spending 24 hours in a Trinidad, they were able to dispatch short to SJU to use the remaining crew duty time. In SJU they could meet up with a new crew deadheaded in from ATL on the first flight of the day. Not all airlines and crews are able to do that since it is logistically quite complicated.
evanb wrote:bnatraveler wrote:I flew down on DL61/28DEC ATL-GIG and booked back on AA. It looks like it was a good idea in the end (despite the markedly lower level of inflight service from AA in J), as it seems like N154DL is also plowing the skies on the return last night - but diverted to POS and now SJU. Anyone know what is going on with that ship?
First diversion likely medical. Crew running short of time due to time on the ground at POS. Delta likely positioned new crew to SJU to take over flight. Alternative was cancelling and putting everyone in hotels at POS until crew achieved sufficient rest.
raylee67 wrote:Weatherwatcher1 wrote:The double diversion is actually quite impressive. They had a diversion to Trinidad. They likely didn’t have the crew duty time to get to ATL. Instead of spending 24 hours in a Trinidad, they were able to dispatch short to SJU to use the remaining crew duty time. In SJU they could meet up with a new crew deadheaded in from ATL on the first flight of the day. Not all airlines and crews are able to do that since it is logistically quite complicated.
Impressive operational arrangement indeed. Similar to how they flew the last flight out of SJU before the hurricane hit last time.
catiii wrote:raylee67 wrote:Weatherwatcher1 wrote:The double diversion is actually quite impressive. They had a diversion to Trinidad. They likely didn’t have the crew duty time to get to ATL. Instead of spending 24 hours in a Trinidad, they were able to dispatch short to SJU to use the remaining crew duty time. In SJU they could meet up with a new crew deadheaded in from ATL on the first flight of the day. Not all airlines and crews are able to do that since it is logistically quite complicated.
A more impressive operation is, you know, not having to divert...
Cubsrule wrote:catiii wrote:raylee67 wrote:Impressive operational arrangement indeed. Similar to how they flew the last flight out of SJU before the hurricane hit last time.
OK, but who has that? Stuff breaks sometimes. That’s true even for carriers like DL with solid m/x. Heck, I’ve diverted on WN BNA-MDW because the airport was closed due to a disabled aircraft on the runway. That’s not apples-to-apples here, of course, but the idea that diversions mean that the operation has problems isn’t true.
Listen I’m with you. Mechanicals happen. But let’s not pretend like a double divert to recover is such an impressive “operational arrangement.” Nor is it remotely similar to them cutting it close going into SJU ahead of a storm.
KFTG wrote:Surprised to learn that one of the ex-Gulf Air ships is still in use at Delta. Thought they'd retired that subfleet?
CriticalPoint wrote:Weatherwatcher1 wrote:The double diversion is actually quite impressive. They had a diversion to Trinidad. They likely didn’t have the crew duty time to get to ATL. Instead of spending 24 hours in a Trinidad, they were able to dispatch short to SJU to use the remaining crew duty time. In SJU they could meet up with a new crew deadheaded in from ATL on the first flight of the day. Not all airlines and crews are able to do that since it is logistically quite complicated.
Except this is not what happened. Plane left SJU after several hours on the ground to arrive in ATL 12hrs late.
So not really any logistics needed
Weatherwatcher1 wrote:CriticalPoint wrote:Weatherwatcher1 wrote:The double diversion is actually quite impressive. They had a diversion to Trinidad. They likely didn’t have the crew duty time to get to ATL. Instead of spending 24 hours in a Trinidad, they were able to dispatch short to SJU to use the remaining crew duty time. In SJU they could meet up with a new crew deadheaded in from ATL on the first flight of the day. Not all airlines and crews are able to do that since it is logistically quite complicated.
It left two hours after the new crew arrived in SJU. They scheduled the plane to leave 1 hour after the first flight of the day from ATL arrived, but took a delay.
catiii wrote:evanb wrote:bnatraveler wrote:I flew down on DL61/28DEC ATL-GIG and booked back on AA. It looks like it was a good idea in the end (despite the markedly lower level of inflight service from AA in J), as it seems like N154DL is also plowing the skies on the return last night - but diverted to POS and now SJU. Anyone know what is going on with that ship?
It was a mechanical. Have a colleague onboard. As of an hour ago they did not have a plan to recover but were working on one.
Weatherwatcher1 wrote:It left two hours after the new crew arrived in SJU. They scheduled the plane to leave 1 hour after the first flight of the day from ATL arrived, but took a delay.
777Mech wrote:Yeah no, this was a medical diversion. I'm looking right at the flight remarks.
MSPNWA wrote:
Almost five hours on the ground would be an unusually long time for a medical situation.
MSPNWA wrote:Weatherwatcher1 wrote:The result is that the recovery for this flight was nothing special. It wasn't going the extra mile, as no new flights were created nor was the new crew expedited to SJU. This was the cheapest/slowest option that didn't leave the PAX stranded. Any airline worth their salt would have matched or even beaten this effort.
ethernal wrote:MSPNWA wrote:Weatherwatcher1 wrote:The result is that the recovery for this flight was nothing special. It wasn't going the extra mile, as no new flights were created nor was the new crew expedited to SJU. This was the cheapest/slowest option that didn't leave the PAX stranded. Any airline worth their salt would have matched or even beaten this effort.
I don't think taking a 12 hour delay is worth patting Delta on the back about, but let's not pretend that most other airlines wouldn't have taken a longer one. I am confident that most airlines would have overnighted at POS and taken a 24+ delay.
Could have been both. Divert for medical and then something breaks on the ground. Or it could even be as simple as having to re stock the O2 and EMK and dealing with finding 3rd party mtc to sign the logbook who are qualified and approved by DL/FAA.
mrpippy wrote:Avherald reports that the captain told passengers it was a generator failure
https://avherald.com/h?article=4d17d775&opt=0
